sutty2006
The 50 quid Omega. Fault diagnosing.
So I bought this omega in 2015/16 with the intention of doing a banger rally to Benidorm. The engine had a horrible grinding noise and the auto box was lazy. I spent £100 buying it, £50 on oil and filter for the gearbox and sold it for £200. I sold it to a distant mate who put another 2.5 Diesel engine in and put it back on the road. He’s been using it as a daily ever since. He bought a later omega in better condition with the same engine and offered me this one back or scrap it. £50 exchanged palms and the Omega is now back on my driveway. Epic.
So the plan is this. I’m going to let it sit on my drive for a while, as next year I’m going to do another Banger rally. Cool. Then on return, the engine and Auto gearbox will be transplanted into my diesel Carlton. I hate having a manual gearbox so a diesel auto carlton is a great idea. Whether it happens or not is another thing. But I’ll cross that bridge when I get to it.
Share this post
Link to post
I had an early Omega 2.5 td auto. Shite interior build quality but really comfy and so relaxing to drive and sit in. The latter was an Important consideration as I used to spend a lot of time on standby (or more precisely sitby) so a nice warm heated seat was just the thing after hours in freezing pissing wet Welsh countryside. You could also travel several hundred miles and get out of the car with nary a twinge or a touch of stiffness. Mine ran on cooking oil, which could be had in huge catering size tins for about half the cost of diesel back in 07.
Share this post
Link to post
56 minutes ago, RoadworkUK said:
I still think those things have a severely fit front end design.
Any Vauxhall without the chrome V looks decent, but i do prefer the preface lift.
Mine is a post face lift.
Share this post
Link to post
Great story.
I’m right up for contemporising cars in sympathetic ways (engine from correct manufacturer, no “decking” and stock externals).
As Billeh says, a 21st Century Carlton is a great idea.
The Sierra bASe will never be a mule, but I would like to Duratec a Sierra. Eminent style without the clatter of Pinto. Sounds divine.
Good luck man.
Share this post
Link to post
Cheers. Technically it’s a BMW engine (e34 525tds motor) down rates to 130hp. The AR25 gearbox may get binned fro an AR35 so some sneaky mods can be done... but the way I see it, it’s already bolted into a Vauxhall so the engine mounts, sump etc should all fit and the Carlton’s were designed for a 6 cylinder anyway so the space is there.
Ive put the rear seats back in (as some assembly was required) the interior is different to the original one which is better, as the originals were minging.
Share this post
Link to post
I’m getting married tomorrow. So between rain showers and the sun coming out I’ve been measuring up this future project. There is plenty of room for the motor. I roughly measured 28 inches engine length which is plenty. Even the omegas radiator mounts are the right width. The only issue I might have are the engine mounts. The BMW engine mounts sit a lot further forward than the CIH diesel mounts. Won’t be too hard making some adaptations to those.
Share this post
Link to post
If I had a two car driveway I'd have a pre-facelift Omega on it alongside the Lexus. I wouldn't really care what engine, I just want to save one. The pre-facelifts just have a far nicer look to them, and the dashboard/heater set up is far better than the weird system they put into the later models.
I really miss the MV6 which is now, thankfully ,with @Brodders. I have actual pangs of sadness sometimes (i.e. when I'm looking over old cases at work and spot it in the background of my site photographs) and I have even dreamt a couple of times I have it again. On a sombre note, I wonder if it's because it was the car I was using when my mum sadly passed away (she passed away less than two weeks after I bought it). I think there's probably some associative memories going on there, but either way, because my mum had a 3.0 CDX Carlton estate when I was a youngster, and because both my parents had use of a pre-facelift Omega estate (2.5 CD) when I was a teenager, I have a serious soft spot for them.
Anyway, not to end the post on a 'downer', I'm incredibly excited for the six cylinder Carlton diesel. :-D It would certainly do a much better job than the 2.3 diesel Vauxhall deemed worthy for it.
Share this post
Link to post
My only issue, is what happens to an engine less omega ?
Put it away carefully until it has some value?  Stick a Monaro V8 in it ? Have it crushed.
Share this post
Link to post
11 hours ago, busmansholiday said:
Good luck for you and your intended one for tomorrow and in the future years.
10 hours ago, N Dentressangle said:
Absolutely!
Have a great day, and don't talk to her about old Vauxhalls 😉
Thanks folks. Well it’s nearly 4am, I’ve had 2 hours sleep and I’m wide awake with stomach ache. So I’m trying to take my mind off things. She knows I’m a serial Vauxhall botherer but I’ll do my best not to drag that into the “big day”.
im unsure how much of the subframe will fit. I guess I’ll have to get both cars  side by side and see. If the front subframe from the omega offers up to the carlton chassis then we’re clean clear to flag town and cookin on gas. As for the rest of the car, well it’s ropey, sub 200k heavy smoker abused so I doubt there will be any value to it so it’ll be destined for the bridge over scrap river. Bless it’s sole.
Share this post
Link to post
18 minutes ago, sierraman said:
Good luck with the wedding. If you’ve some time to kill drop the engine out of the Carlton. Take your mind off the nerves. I’m sure the new wife will be understanding when you turn up late, covered in oil, fingers bleeding to the wedding. 😂
Yeah, good plan.
You'll be fine*
Share this post
Link to post
Thanks guys. Yesterday went very well. In an autoshite manner I left my speech at home, I’m crap at speaking but ended up winging it anyway. Was a great day. Currently nursing a bad head, not through alcohol, but the bride/groom suite on site has a low slung entrance to the bedroom and I walked straight into it and ended up on the floor............. twice. Have a few pictures, then I promise Normal service will resume!
Share this post
Link to post
  • Similar Content
    • By Broadsword
      I think the Broadsword fleet has become sufficiently complicated to merit a combined thread so that gradually all new additions will appear in one place.
      As of Sunday 17th March the situation is interesting.
      Two Citoren Xantias (remember the white Xantia of Excellence is for sale people!)
      http://autoshite.com/topic/34699-w-reg-citroen-xantia-20-hdi-xantia-of-excellence-%C2%A3999/
      http://autoshite.com/topic/34596-citroen-xantia-double-madness-rust/page-2
      A turquoise XJR6 pending overdue-collection (need that gone now!)
      http://autoshite.com/topic/34003-jaguar-xjr6-double-madness-double-sold
      An XJS 3.6 manual project which will get in high gear soonish. Wont be a keeper but will be fun getting it back to something presentable. Drivers fantastic!
      http://autoshite.com/topic/34664-jaguar-xjs-36-manual
      A Range Rover P38, which is turning out to be really rather good.
      And to mix things up even more I'm off on a collection caper today. Had first refusal on it and was expecting it to come around in a year, but things soon changed and no way was I going to pass up on it. It may well render the second Xantia redundant as I've got a really good feeling about this motor.
      In the meantime here are some snaps of the Range Rover. As usual it was a car I said I would probably never buy due to their reliability*. I have said the same of Jag XJR, XJS, XK8 and I have had all of those now. Basically the moment I declare buying a particular car is impractical or improbable, I end up buying one.
      Things to note on the P38. It's a nice colour with tidy body. The EAS has been removed. It runs and drives lovely and it doesn't have enough electrical problems to hinder progress. The main one is the driver's side window not working, but that should be fixable. I've tried changing the outstation, that didn't fix it. Might be wiring under the seat. Other than that I bought it and took it for an MOT the very next day, and it passed. Since then it had what seemed like a battery drain, but since unplugging the RF thingy for the remote locking and putting on a proper lead-acid battery, which the car can actually charge, unlike the modern lead-calcium batteries, it has been perfect. I will treat it to a full service soon.
      Stay tuned for the latest collection later today!
    • By beko1987
      I've noticed that some people on here have imagination, and get through a wide variety of different brands of cars
      Then there's me, who after hitting the armagedden button when the 406 threw me a load of urgent work that I didn't have the time or money to perform by it's MOT obtained yet another french car!
      My car history really has been a bit samey
      Landrover Series 3 (PMA124Y)
      Peugeot 206 (W636OAU)
      Ford Puma (Y874RCB)
      Citroen ZX (R385VRD)
      Citoren XM (R267PGF)
      Citroen ZX (L592NWK)
      Citroen Xantia (R499AMV)
      Renault Laguna (YT55ENP)
      Renault Laguna (FV51FYP)
      Peugeot 406 (HY02FUA)
      2 out of 10 of the above are still alive...
      And as of tonight
      Citroen ZX (R579SLX)
      So over 11 cars, a definite pattern! But I like boring, I like samey, I like reliable*
      Current status? Well our very own Bramz7 is somewhere in the north of england (maybe even nearly scotland) delivering a car. At almost possibly maybe 4.30/5pm he will arrive in Derby and collect Bub's ZX. Following a very silent drive to my house in Oxfordshire as the ZX has no radio we shall convey ourselves to his house, and I shall drive home...
      Moar later!
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By TripleRich
      Hi all, new to the forum.  Thought you might be interested in what I've got myself into
      I'd been after my first classic car for a while.  If it's big and made in the 70s I'm interested.  Looked at few things like P6s, Zodiacs, Victors, SD1s and various other things.  Problem was I didn't want to spend a boatload of money on something that looked alright but underneath was actually a total heap.  The solution was to buy a complete heap in the first place and spend the money fixing it.
      So in January I went ahead and bought this from a colleague at work who was moving away and needed to get shot of it.
      It's a part finished restoration (I prefer not started) and it needs a whole load of help if it's going to stand any chance of using a road again.
      Pros
      It's right up my street.  Granada Coupes are quite odd and certainly stand out from the norm.
      It still has the original engine, box, interior and most trim.
      It came with loads of panels I need to repair it (mostly original Ford stock).
      It came with so many spares I could probably build a few Granadas and still have stuff left over.
      It was cheap.
      Cons
      Most of the front end has been cut off.
      Most of the body structure is quite rotten.
      It's going to take me ages.
      I work at a restoration company and my boss kindly allows me to keep the car there.  So I've got access to all the gear I need to restore it.  I've been busy on the car for a while now so will post more pics over the coming days.
      Cheers
