paulplom Posted September 26, 2019 Author Share Posted September 26, 2019 I did a couple of hundred miles in this over the weekend. My partner did 100 or so yesterday. I'm starting to gel with it. It's behaving great. The management light has stayed off since they rewired the stat and the smokyiness has almost gone and only visible when you really boot it. Nothing on start up any more and what's there is the normal black gray stuff. It's averaging above 50 mpg and is great to drive. Im' going to get the aircon sorted asap as it's like a greenhouse when the sun's out. Overall 8 out of 10. Vantman and stonedagain 2 Link to comment Share on other sites More sharing options...
stuboy Posted September 26, 2019 Share Posted September 26, 2019 cool, ur coming to love it, im still warming to my my mondao paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 This is due for mot on Tuesday. It's going to fail. That with other problems, it maybe uneconomic to repair. Would anyone be interested in it for near enough scrap value? Link to comment Share on other sites More sharing options...
loserone Posted August 28, 2020 Share Posted August 28, 2020 What's up with it? A headlight bulb? Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 Dmf knocking I think. Knocking suspension. Black clag on full boost. Eml now and then. Xenon levelling sensor problem. Paeking sensors don't. Air con doesn't And more on Tuesday no doubt. Link to comment Share on other sites More sharing options...
SiC Posted August 28, 2020 Share Posted August 28, 2020 EML clear the code before test. Then it's only suspension that may fail it depending what it is? paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 A xenon lamp won't be cheap. Emissions may be a problem. I'm willing to spend a few hundred. But much more than that and I'll be away. Link to comment Share on other sites More sharing options...
SiC Posted August 28, 2020 Share Posted August 28, 2020 Is the Xenon leveling system warning light on? Often is only the sensors attached to the suspension that fails. Can usually fixed with judicial use of cable ties. paulplom 1 Link to comment Share on other sites More sharing options...
djoptix Posted August 28, 2020 Share Posted August 28, 2020 3 minutes ago, SiC said: Is the Xenon leveling system warning light on? Often is only the sensors attached to the suspension that fails. Can usually fixed with judicial use of cable ties. Judicious...? Link to comment Share on other sites More sharing options...
Tayne Posted August 28, 2020 Share Posted August 28, 2020 1 hour ago, paulplom said: Paeking sensors don't. Change them out for Beijing sensors. Jim Bell, Jenson Velcro and Mally 3 Link to comment Share on other sites More sharing options...
Talbot Posted August 28, 2020 Share Posted August 28, 2020 1 hour ago, paulplom said: Xenon levelling sensor problem. Common fault. The linear sensor on the rear suspension wears at normal ride height, so the system can't see the rear suspension height. Shove a bag of sand in the boot, the ride height drops 10mm and you're using a part of the height sensor that works. Warning lamp goes off, headlamp height adjustment works again. Very little else on your list is an MOT phail. paulplom, stripped fred, Dick Longbridge and 1 other 4 Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 23 minutes ago, SiC said: Is the Xenon leveling system warning light on? Often is only the sensors attached to the suspension that fails. Can usually fixed with judicial use of cable ties. Yes the light has been on a while. I only noticed a lamp out this week. Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 I think it knows it's doomed. We've been on another good run today and it's honking out blue smoke in normal driving conditions now. Even on tickover. I think it's sealed it's fate. Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 I think you've dodged a bullet @Robson3022 Robson3022 1 Link to comment Share on other sites More sharing options...
SiC Posted August 28, 2020 Share Posted August 28, 2020 Diesel though ... As long as the smoke levels are low enough ? paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 It's quite embarrassing though. And it stinks like f. Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 It's got me puzzled. When we pulled up at asda there was blue/grey/black smoke coming out when I revved it and it was stinking. It was perfectly fine all the way home. Could I have got to asda mid regen? Link to comment Share on other sites More sharing options...
sloth Posted August 28, 2020 Share Posted August 28, 2020 yes. honestly, send it for a mot, give it a thrashing before hand and see what list you get. paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted August 28, 2020 Author Share Posted August 28, 2020 That's the plan. Worth a punt for £40. Link to comment Share on other sites More sharing options...
Matty Posted August 28, 2020 Share Posted August 28, 2020 Definatly worth a punt for 40 quid. Reckon you'll get more than that for the old bus though if you're patient ? paulplom 1 Link to comment Share on other sites More sharing options...
sloth Posted August 28, 2020 Share Posted August 28, 2020 saab freaks will be falling over. themselves if you part it. lots of nla bits there. Talbot and paulplom 2 Link to comment Share on other sites More sharing options...
paulplom Posted August 29, 2020 Author Share Posted August 29, 2020 This message just popped up. Straw that broke the camels back. ? Agila 1 Link to comment Share on other sites More sharing options...
Rod/b Posted August 29, 2020 Share Posted August 29, 2020 SCRAP IT the old key fob battery paulplom and puddlethumper 2 Link to comment Share on other sites More sharing options...
djoptix Posted August 29, 2020 Share Posted August 29, 2020 IT'S UTTERLY FUCKING FUCKED MATE send the battery STRAIGHT TO THE SCRAPPER paulplom and puddlethumper 2 Link to comment Share on other sites More sharing options...
djoptix Posted August 29, 2020 Share Posted August 29, 2020 Seriously though, bargain at scrap value, I would have it if I were nearer just for the wheels and tyres. Link to comment Share on other sites More sharing options...
paulplom Posted August 29, 2020 Author Share Posted August 29, 2020 The wheels are fucked. The front two don't hold pressure for more than a week or so. Link to comment Share on other sites More sharing options...
paulplom Posted August 29, 2020 Author Share Posted August 29, 2020 I'll be frigged if I'm spending £1.50 on a battery a few days before it's mot. puddlethumper 1 Link to comment Share on other sites More sharing options...
djoptix Posted August 29, 2020 Share Posted August 29, 2020 15 minutes ago, paulplom said: I'll be frigged if I'm spending £1.50 on a battery a few days before it's mot. Very wise. These things can turn into utter money pits if you're not careful. cort1977, stripped fred, puddlethumper and 3 others 6 Link to comment Share on other sites More sharing options...
paulplom Posted September 2, 2020 Author Share Posted September 2, 2020 Looks like I'll have to splash out on a new battery for the fob. The garage has just rang and said it's passed the mot! The xenon bulb was apparently a ballast resistor? He reckoned it was common on these. Damage for mot and a full service was £188. To say I'm very pleased is an understatement. I though for only the second time in thirty years I was going to have to scrap a car. No idea how it passed the emmisions though. LightBulbFun, stripped fred, rainagain and 2 others 4 1 Link to comment Share on other sites More sharing options...
paulplom Posted September 2, 2020 Author Share Posted September 2, 2020 Some savage advisories though. No idea what the emmisions mean or if it's good or not. Locking wheel nut key is on the front seat so I reckon they've carried out a proper service. 10/10 Six thoudand miles in a year is shite. Still up for a swap for a small petrol with cheap tax. What is this worth with a full mot? RoadworkUK, Sunny Jim and LightBulbFun 3 Link to comment Share on other sites More sharing options...
