Kiltox
1992 Renault Clio mk1 1.4 auto RT - STILL FUCKED, HELP?
1 hour ago, Fumbler said:
Putting it into reverse would also prove that, however I don't know if that method applies to all autoboxes.
This is also what I was trying to cover. The 3HP22 in the CX does this sometimes when the fluid is warmed up and going from Neutral to Reverse, but not all the time, and almost never when the fluid is cold; it's quite a random type of thing even though the fluid levels are currently within limits.
Share this post
Link to post
On 8/28/2019 at 9:31 AM, barrett said:
The gearbox fault on ours turned out to be an ECU problem, and a replacement ECU solved it, but then it turned out the car was dangerously slow and totally joyless to drive even with all three gears. Then something exploded in the fuel/oil/gearbox oil system and I never even opened the bonnet to check what it was, just called the scrap man. Hateful little cars. A shame, because they're pretty, comfortable and seem to be quite good quality. No rust whatsoever on ours, either. I bet a manual version is a very satisfying way of travelling.
On my recent trip in northern France these were the most numerous of 80's/90's cars I saw. People seem willing to keep these running when a lot of other Renaults with higher numbers have all but disappeared.
Share this post
Link to post
Saw loads of proper old MK1 Clios in Lille, Rome, Madrid...essentially all of Europe really.
Early seats and engine size badges side by side with the side repeaters are those little details I love on these.
I do miss the RT I had, but it was the insanely gruff diesel with no PAS. Loved that thing. Not great on motorways but could be chucked around like nobodies business everywhere else.
Share this post
Link to post
Sidelight are fixed. I discovered the indicator bulb holder was trashed too, though, so new one on order
Service parts arrived today, air filter was £1 and said to be “OE quality” - it’s actually OE old stock and looks like it’s been kicking around a stock room for a while!
Share this post
Link to post
34 minutes ago, Sausage5000 said:
Clios seemed to get more bloated and hideous for every facelift they got. The 5, Clio mk1 and Clio mk2 pre-facelift are nice lookers.
Like a Polo is now the size of a Golf, it’s how it is. I guess the Twingo is the car for someone that wants something like an old Clio.
The mk4 Clio is actually quite an impressive package as far as moderns go, I have one for sale at the moment (see the modern section) and was very impressed with how it drove on the 350 mile collection journey. It is huge though, the size of a Megane II.
Share this post
Link to post
You mentioned changing the plugs - are the leads ok?  It might be one is breaking down somewhere.  I can’t remember if the “energy” engine in these has a distributor cap/rotor arm arrangement so perhaps something minor is past its best.
I think it’s too old for things like Throttle bodies and lambda sensors but could be wrong!
Share this post
Link to post
Changed the cap and rotor tonight and it still shakes itself to bits at idle / feels like it wants to stall. It has definitely improved the running though, the engine seems to respond better to throttle / start faster etc.
Running out of ideas now though.
Theres a rubber seal between the throttle / single point injector unit and the air box that doesn’t look in great health but I can’t find one anywhere
Share this post
Link to post
It starts fine cold or warm but it shakes itself to death on idle regardless. Pulls strongly if you keep the revs up but struggles at idle, stalls if you switch to reverse from drive without keeping the throttle on
Share this post
Link to post
No idle speed adjustment is there?  Just because she has injection doesn't necessarily mean there's not a screw to set the air bleed past the throttle at idle.
Worth making sure the throttle body is spotlessly clean too.
One thing I have found over the years with a few monopoint cars though is that the earlier systems tended to be *really* sensitive to vacuum leaks.  A microscopically small split in the brake servo line made the Lada idle absolutely awfully.  Never found the leak...but changing the hose resolved it!
Worth going over the engine bay with a microscope to make sure you've not got a leak somewhere.  I'd start from the connection to the MAP sensor and work from there.
MAP issues would also cause issues on light throttle...so worth investigating.
Share this post
Link to post
  • Similar Content
    • By Fumbler
      To mark the genesis of my fleet project thread I here present my new car: a 1997 Nissan Micra Shape-
      It really looks that good. There is a reason for this: its previous owner was an old lady who loved the thing so much so she made every effort to keep it in good shape. It originally came from Fleet in the GU postcode which suggests to me it was bought by the present dealer at auction, hence arriving down here in Kent. Before seeing the car I checked its MOT history and its only fails were thanks to broken stoplights, which shows me that it was very well cared for. I suppose an example of this was that on the last MOT, an advisory was a corroded rear silencer. The silencer on the car when I saw it was new. Methinks the lady wanted to keep it as good as possible. It was kept in a garage and so all the bumpers and black trim are very black and the tyres are in very good condition. Spare never used! Also included a free Dettol first aid kit from 1997.
      This car has 15000 genuine miles on the clock. We clocked over 15000 during the test drive! The lady owner really only trundled around her village in it and the MOT shows that it only did some meagre miles between tests. This, of course, came at a price. We saw a cherry red Micra from 2002 at the same dealer. Paint was shoddy and when they washed it the boot had massive sections of bare metal and it wasn't very happy. This car, however, is in fabulous condition and there was no contest between the two cars- it really is that good, inside and out. Immaculate interior, driver's airbag, cassette player... all there and all functioning (apart from cassette thanks to new battery and failed display). This meant that I bought it for £1600, £100 over what was my uppermost limit, but I knew I wouldn't see another like this that was in as good shape for a fair while. It was priced very ambitiously, at £1990, so I'm content in the fact I managed to slash a few hundred off the price. There wasn't that much paperwork though. All the dealership received was the logbook with 3 service stamps from 1998, 1999 and 2000, the radio key pass, a National Trust sticker, and the original paperwork holder. I suspect the old lady died and had her car auctioned, and the massive file of paperwork is now someone's egg carton, along will everything else she owned.
      As always, this car isn't exactly in showroom condition. While the inside is great and the floor is solid, and the underseal is in great shape, the not undersealed parts need a small looking at. Mainly the rear of the driver's side sill. It's really the only bubbling on the car. I suspect a well aimed stonechip managed to fester over the wintery salted roads, making it rust even more. It's around the size of a 5p piece, and will give me the opportunity to spray the insides of the sill with some chain oil to prevent any further corrosion. Behind the fuel tank there are a few rusty joints- places where the spraygun cannot get paint onto- which some Vactan and Dynax should put to rights. Alternator belt looks original because of the cracking and Nissan badges and will need doing soon as well as the front plate. As much as I like the 90's font and original dealer surround, the dishevelled R and general water ingress is a persistant MOT advisory. It could be the MOT station being strict (and most likely is considering there's a Saxo down the road with far worse blackening), however for the sake of peace of mind and all that, I'll get a new one made. The rear has already been replaced indicating this has happened before.
      All in all, I think this is a nice plucky motor. I'll have it by the end of the week; just got to sort out tax, insurance, and it's going to have an MOT. As part of the deal it's getting the MOT and an oil and filter change which will be something ticked off the list. It has some love scratches and chips here and there, but it drives well, is stiff and controllable, and should make out to be a nice summer project!
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By TripleRich
      Hi all, new to the forum.  Thought you might be interested in what I've got myself into
      I'd been after my first classic car for a while.  If it's big and made in the 70s I'm interested.  Looked at few things like P6s, Zodiacs, Victors, SD1s and various other things.  Problem was I didn't want to spend a boatload of money on something that looked alright but underneath was actually a total heap.  The solution was to buy a complete heap in the first place and spend the money fixing it.
      So in January I went ahead and bought this from a colleague at work who was moving away and needed to get shot of it.
      It's a part finished restoration (I prefer not started) and it needs a whole load of help if it's going to stand any chance of using a road again.
      Pros
      It's right up my street.  Granada Coupes are quite odd and certainly stand out from the norm.
      It still has the original engine, box, interior and most trim.
      It came with loads of panels I need to repair it (mostly original Ford stock).
      It came with so many spares I could probably build a few Granadas and still have stuff left over.
      It was cheap.
      Cons
      Most of the front end has been cut off.
      Most of the body structure is quite rotten.
      It's going to take me ages.
      I work at a restoration company and my boss kindly allows me to keep the car there.  So I've got access to all the gear I need to restore it.  I've been busy on the car for a while now so will post more pics over the coming days.
      Cheers
    • By strangeangel
      I thought I'd start a thread for this as I'll probably end up asking all sorts of questions, given that this is my first 'proper' Citroën.
      So... the ground clearance lever won't go all the way to the highest setting (all others work), which is bad 'cos the book says I need it to do that in order to check the LHM level. It feels like something's seized, so I don't want to force it. Any ideas for a plan of attack would be much appreciated.
      Next up are the wheels. I now have a set of 205 pepperpots that have just gone off for powder coating & I need to get some tyres for them. The handbook says the car should have 165/70R14s on, the wheels came with 185/65R14 on. Any thoughts about what size I should get please? Cheers.
