Kiltox
1992 Renault Clio mk1 1.4 auto RT - STILL FUCKED, HELP?
Had this little honey delivered today from the Autoshite legend that is RobT who saved it from the crusher.
74BE59CA-B168-4910-AC51-8920E3511839.thumb.jpeg.8e56cef2e1fb54bfbc38b3c9d8d447c4.jpegA1363379-6141-47AD-875F-E3A677DEB772.thumb.jpeg.a18b512654c8902bc700d4265daea961.jpeg
Has a few issues - biggest of all is rough running / misfire at idle. Top suspect is the inlet manifold gasket which was kindly supplied.
Needs a proper service since the previous giffer owner seems to have been ripped off by his local garage - the air filter is black as fuck and the spark plugs fitted are probably not the correct ones.
OSF sidelight is inop - broken wire. Upon investigating I found some top class wiring repairs to the lighting harness:
Yes, twisted together wires covered in masking tape. Lovely.
All in all it’s very clean and tidy though - 33k on the clock!
Share this post
Link to post
Ordered some parts before it’d even arrived
Air filter
Oil filter
Fuel filter
Spark plugs
Full set of wipers
Just over £22 from CP4L/ECP.  Should be here in a couple of days. Guessing I’ll actually get the head set I need to fix my Rover instead 😂
Share this post
Link to post
Nah the box doesn’t look like that. There’s only a couple of fuses and relays under the bonnet, rest are in the passenger footwell.
Googling for mk1 Clio stuff doesn’t seem too fruitful - lots of people think a ph1 mk2 Clio is a mk1 🙄
Share this post
Link to post
Aren't these autoboxes the ones that Renault claimed were sealed for life, but actually require an ATF change every seven years or they start fucking up big time? Hence lots of tidy low mileage autos stuck in second gear etc.
Share this post
Link to post
3 minutes ago, Wingz123 said:
Doesnt even look to have any lacquer peel either?
Nah the paint looks pretty damn fine. It has a tiny tiny amount of rust along the leading edge of the drivers door where the paint has obviously been damaged at some point and some scratches / chips where one of those door edge protector things has been 🙄
Some chips around the boot lock where I’m guessing some misguided application of the key has happened 😂 - if everything goes well I might see if I can get a smart repair done on that
Needs a good polish and wax but it is in fine shape.
Share this post
Link to post
46 minutes ago, Kiltox said:
I would’ve thought that it was a bit old for those shenanigans, newer Renaults definitely had that affliction though.
Ask @barrett how he feels about the longevity and idiosyncrasies of this particular autobox.
I’d probably do all I could to prevent disaster.
Share this post
Link to post
The gearbox fault on ours turned out to be an ECU problem, and a replacement ECU solved it, but then it turned out the car was dangerously slow and totally joyless to drive even with all three gears. Then something exploded in the fuel/oil/gearbox oil system and I never even opened the bonnet to check what it was, just called the scrap man. Hateful little cars. A shame, because they're pretty, comfortable and seem to be quite good quality. No rust whatsoever on ours, either. I bet a manual version is a very satisfying way of travelling.
Share this post
Link to post
I hammered it home along the M25 with Audis impeding my progress, so I'd say there's enough poke (it runs fine at motorway speeds, but the rough running really becomes an issue around town).  This one is a 1.4 though so perhaps the 1.1 married to an auto is the dismal affair.  The 'box also seemed fine to me, relatively speaking.  I've got used to the 11 with its harsh shift into third, it really does clunk and make you wince.  This is the second 1.4 auto I've tried and that was sprightly too, so I reckon yours was fucked from the off Scott!  Either that or my definition of fast is different...
Share this post
Link to post
The 1.4's were favourites for head gasket failure weren't they? I seem to recall being told that that was common on them...
Mind you if this has such low mileage and if you remember that red faded one Bramz was looking at with over 300k on.....this should go for years!
Share this post
Link to post
On 8/28/2019 at 10:56 AM, RobT said:
....I've got used to the 11 with its harsh shift into third,....
My understanding is that a harsh shift / thump in the back might be a symptom of low fluid levels.
Share this post
Link to post
Putting it into reverse would also prove that, however I don't know if that method applies to all autoboxes.
Share this post
Link to post
PhilA commented once that his is same, so I think it's a case of TADTS.  All the other gears are smooth-ish, and I've done two oil changes since last October with little difference.
Share this post
Link to post
  • Similar Content
    • By dozeydustman
      Just about an hour ago I went to start my car up, had Mrs Dustman with me, to go and pick Miss Dustman up from work. Turned over fine but took a while to fire up.
      Steering felt heavy. Thought maybe as it's currently -5 + wind chill it's just cold & the fluid is thick.
      Started reversing out my bay then I was greeted with:
      "DING DONG" - ABS fault.
      "DING DONG" - ESP fault
      "DING DONG" - headlamp auto levelling not working, contact service.
      I shut the car down straight away and we went in Mrs D's Corolla.
      Alternator is less than 2 months old, it's a recon unit from Alternator Man in Portsmouth. Hoping the cold isn't killing the battery and it's taking the 'nator out with it (battery passed the drop test last time the no-charge warning came up). Looks like a session with the multimeter after work tomorrow.....
      MEH.
    • By dozeydustman
      Mrs Dustman has a dash cam she wants me to fit to her '99 frog face Corolla. It came with a hard wire kit as opposed to the usual fag lighter lead, so I might as well make a decent* job of it and hide the wiring completely. Trouble is I can't remember how I got the radio pod out when I fitted the DAB unit she now has. I've also got a few dash illumination bulbs to change so I might as well do it all in one hit while it's a sunny afternoon.
      A bit of googling comes up with the US spec dash which appears to be different from the European model, or the 2002-on model. I seem to remember spudging out the dash vents to access some bolts/rivets.
      Failing that, is there an easier place to get a switched live from (besides the radio) that doesn't involve destroying the car's interior?
    • By 1970mgb
      So, someone posted on another thread a link to an Ebay listing for an LHD '74 Marina listed on Ebay.
      I called a little while ago and talked to the seller, and the story is that it was a good running and driving car 10 years ago, but has been neglected and won't run. I'm debating with myself about whether or not I want to take it on as a project.
      I know these had a terrible reputation when new, but at the same time they're actually legitimately rare in the US. I have seen one in person, and most of the estimates I've seen put the number of survivors at 10-20(although I don't know how much we can trust that).
      There's some definite appeal in the engine familiarity for me with the MGB. I MIGHT have to convert it to a manual though. In addition, there's the issue of having it shipped a couple hundred miles to me. It's listed now for $700...if I could do $500 it might be a make or break for me.
      Any thoughts here on it?
      EDIT: The car as it sits now is an automatic. If I swapped the transmission, it would be to a manual. Sorry for any confusion from my incorrect statement!
    • By blackboilersuit
      After many a long year of occasional contribution on here I've probably got enough old shite on fleet now to do something I should have done yonks ago and start a project thread.
      The story so far.........
      I had an 02 CRV for 6 years and it performed faultlessly as an car taking everything in it's stride. The only issue with it was the 25mpg it returned but as I worked close to home that wasn't an issue. Cue December last year and a new job saw my commute go up from 4 miles a day to 32 miles a day.
      By March I was drowning in green shield stamps so  bought the mighty diesel disAstra from Davehedgehog of this here parish. Shown here on the only off-road parking and only second car parking space I have. The garage contains a few motorbikes so I've always stubbornly stuck to a single car rule so I don't have to move motors to get bikes in and out. More on this detail in a bit.....
      A combination of broken motorcycles needing worked on, a bike trip around the Baltic and work meant that I soon realised that I had no time to prep the disAstra for its MOT  at the start of this month. It wasn't worth enough to pay to have the work done so I decided that the poor old thing would be scrapped in favour of a replacement motor.........
      The mighty Volvo (V70 D5) was purchased from Ma & Pa forddeliveryboy of this parish and migrated north of the border back to it's natural home.
      Three days after being pressed into commuting service the mighty volvo suffered a (badly) sticking caliper and much burning brake smells that had to be stripped and rebuilt before work the next day. Sticking piston at that so the whole thing was off and the brakes had to be bled afterwards. Two and a half hours in the pissing rain was a bit character building especially as the still MOT'd (by 3 days) and taxed (but not insured) astra was sitting on the drive. Decision made, insurance checked and a soon to be taken out Admiral multi-car policy will see me with two cars on the fleet again. I could have used one of the bikes but motorway commuting in the pissing rain on two wheels is no fun. The volvo needs an MOT in december so having the astra back on the road will take the pressure off getting that done if it needs work and the weather is bad.
      And so as the volvo continues to provide daily service, project astra revival starts. Known MOT work needed is frilly arches,  broken number plate and front discs and pads so nothing major. Thus far the arches have been sorted without resort to duct tape.
      After a bit of prodding.......
      And after the angle grinder was let loose surprisingly it was only the return lip that was rotten so the welder was broken out to lash on some roughly cut fresh metal.
      Linished off filled, sanded and primed. Note the use of a farmfoods brochure pulled out the bin being used as masking paper for extra shite points.
      Followed by a near perfect colour matched (*) top coat....
      Well I had black on the shelf and it's good enough to stop the primer soaking up the water so that'll do for now.
      Hoping to get brakes and MOT sorted in the coming week so more to follow soon (hopefully).
