Pillock
Welcome to the new forum! Here's some tips and tricks
25 minutes ago, tapir said:
Is there anyway to make pictures appear bigger than a postage stamp in threads without having to click each one? Hoping there's an easy setting i've missed?
sadly when the forum software upgraded for some reason the new thumb nail size for existing Photos was set to 100x100 pixels wide and across
and it was never adjusted sadly
I imagine there may be a way to redo the thumb nails to a larger size hopefully! but it will be on the admin side of things
cc the techy mods @Slartibartfast (and @Stanky ?)
if your talking about photos in a post of your own, then if you click on the photo then click on it again so it opens in a new tab if you then copy the URL and paste it back into the edit box then it will embed large :)
Share this post
Link to post
Generally very pleased with the updated site.
No real problems found, though I do always use it on a laptop, not a mobile.
Just a couple of trivial suggestions:
The login option on the default Autoshite theme is white text on pale brown, which makes it very difficult to see. I use the alternative blue and white theme, which I find is much easier to read, but this doesn't happen until after I have logged in (understandably) so I still need to find the login option on the Autoshite-themed screen. Any chance of changing the colour of the login option to something which contrasts a bit more with the brown background?
My first port of call when I log in is nearly always "Content I have posted in", which I then repeatedly refresh affter I have read each post. This involves hovering over the "Activity" tab, then clicking on "My activity streams", then clicking again on "Content I have posted in", which is a bit tedious. I notice that an "Unread content" option appears on both the "Activity" toolbar and the top right corner of the page. Could a "Content I have posted in" link either be added to the "Activity" toolbar or replace the "Unread content" option on it?
Sorry if this seems like nit-picking, and I do appreciate all the effort you guys have put in to this new incarnation, but even small niggles can get tedious if you encounter them often enough.
Thanks for reading.
Share this post
Link to post
I also use the blue on white theme. And likewise I start off with the "content I have posted in".  So to save these preferences ; I logged in, set that theme, opened that "content I have posted in" page, and then bookmarked it.  Now, whenever I open that bookmark I'm prompted to log in ..which is just two clicks,  and I'm taken directly to that page with blue/white theme already in place.
^ The footnote at the bottom of each of my posts starts off with  ...  (three dots) which is underlined in blue because I have used those for a link to the webpage with the "content I have posted in".  It's a very convenient as just one-click takes me back to the top and directly to that page.  And very easy to set up.    However if I don't post a reply then I can of course just go up to my bookmarks drop-down menu and click on Autoshite, as that would take me there also, and as I'm already logged in - it would be almost as quick. No refresh nor hovering is needed
Hope that helps.
Bfg.
Share this post
Link to post
Hope that helps.
Bfg.
May thanks for the tips. I have set up the bookmark as you suggested and it works a treat.
Also like the idea of the 3 dots in the footnote, but not sure how to turn the 3-dot text into a web page link.
Share this post
Link to post
Open the page you want .. in this case your own "contents I have posted in" and copy the website page address < www.autoshite ....etc >  Then go into your profile > footnote, and select the three dots (or whatever text you happen to choose) and then select "Link" (it looks like a chain link in your reply, or edit, menu bar). That will open a sub window where you simply paste in your copied website page address. Save.. and it will automatically work.
Pete.
Share this post
Link to post
Pete.
Thanks again, works a treat.
is footnote the same as signature?
Couldn't find footnote under profile, but selected Account Settings > Signature and put it in there and it works fine.
Share this post
Link to post
On 9/8/2019 at 8:54 PM, Christine said:
Yeah 502.   Back up  ,still    502    little bit of forum ,then 502 again.
I've been seeing these same symptoms the past few days.
Doesn't matter whether I'm on the PC or the phone, or where I'm connecting from (i.e. home wifi or out and about on 4G).
Share this post
Link to post
When I click "Load more activity" the page used to stay at the first newly-loaded item, allowing me to then scroll down, and on my desktop it still does, but on my laptop, which also used to do this, it now scrolls to the last newly-loaded item and I have to scroll up and then can't tell where the last original item ends and the first new one begins.
Have I accidentally changed a setting on the laptop? If so, how do I revert to the original behaviour?
TIA
Share this post
Link to post
502 error is happening very frequently and to many people it seems.
Is there anything being done to investigate the cause?
I haven't seen any response about it from the mods/techies.
Share this post
Link to post
10 minutes ago, chaseracer said:
Tweaked your settings - try it now.
no offense to the new guy but aint the point of new guys not be able to see those sections until a certain amount of posts are reached
is so it can be sure that the new user is genuine etc, and not just bots or such given the potentially more sensitive info that lies in the other sections?
Share this post
Link to post
I'm real/ genuine and could access the other sections previously but had to re- register when my login wouldn't work...
Share this post
Link to post
Especially when one of the mods follows the Toon Army 😉
Re 502 errors: trust me when I say a lot of man hours has gone into investigating this. We have to keep tweaking things until we find the solution (when I say we I certainly don’t mean me... my only solution is to turn it off and on again). They have got less in my experience, but every now and again you get a run of them. Sorry they’re not solved, we’ve put patches over the sills and covered them with stone chip... hopefully that’ll hold for now 🤔
Share this post
Link to post
  • Similar Content
    • By Stanky
      Hi all,
      Apologies for the downtime, there was some routing issues with our hosting provider which meant the server was cut off from the outside world. I'm finding out what went wrong and how we can avoid a repeat.
    • By pauldoubleyou
      A proper shite 90s jet ski just came up by me and I’m sorely tempted. Looks like a decent version of the year, a seadoo spi.
      Seems rotax powered which I remember from my karting days and I’m hoping to go and see it tomorrow. Looks like a two cylinder carb fed job.
      Anyone played with them?
      As usual the engines in bits and it’s missing the jet whatever that is. Presume where the prop fires water down?
      Are there any rules to it’s use or can I just get it running and blast about on it on the local water and lochs?
    • By pauldoubleyou
      So I’ve held off here for a month now but I’m stuck and need advice.
      Some of you might remember I had a Golf Turbo estate for sale in Jan. Well I sold it to Exiled_Tat_Gatherer and he paid for it with the intention of collection.
      But, I haven’t had a message off him in nearly 4 weeks now and I’ve messaged loads. I’ve phoned him and got voicemail. Now I’m not trying to muddy the lads credibility at all, he’s done his bit but I’m worried about not being able to get in touch.
      He’s in Belgium and intended to fly over and collect. I’m aware he bought numerous other cars off here and wanted to collect them all in a oner but he’s now not posted in ages.
      What the hell do I do? I really need the car shifting but he’s paid for it. I can’t store it forever and I’m still paying tax on it so it can be legal for him to collect.
      Really stuck. Any advice appreciated. I’m erring towards selling it on and refunding him if I can get hold of him but don’t want to be the arsehole.
      Sorry if this isn’t the way to do things but I’m really at a loss.
    • By pauldoubleyou
      Seen on Facebook. No pics of the monza / manza
    • By pauldoubleyou
      Is anyone else into their kits? In new money, that’s scale models.
      Is anyone selling any? I have an unhealthy collection that I can’t particularly let the wife see.
      Latest Abrams about ready to be weathered and next oldie but goody..
