1987 Citroen BX - The Wafflewagon
vulgalour
On 8/9/2021 at 7:59 PM, SmokinWaffle said:
That's.....not meant to be that melty. I figure it's had some crap on it, more resistance over time, more heat, repeat, melt. I'll give it a clean up when I get a second and see how it goes and keep a close eye - might have to replace that connector though. I probably should anyway.
Oh - I also picked up a garden swing seat in it the other day but forgot to take a picture. Boo.
Am I right in thinking that this is a H4 bulb holder? Now it's getting darker I really need to replace this and a H4 looks about right...I could go outside and take a closer look but it's much warmer on the sofa!
On 8/11/2021 at 10:14 PM, adw1977 said:
I will admit to also owning a pair of black crocs.
Check moneybags out over here - these are shoezones finest. :-D
Link to comment
  • 6 months later...
This has been off the road since the MOT expired in November, just had other things going on.
Wife's Corsa then failed the MOT on the airbag light in late Jan which has been a saga, hopefully over soon, leaving us with no car
In the meantime I picked up an Aygo with an engine light for very cheap, gave it an oil and filter change, Italian tune up and the engine light is all good so that's been our reliable runaround for the past few months. Actually quite like it. Sweet little thing. Aircon and cup holders too.
I miss the BX dearly, always starts even after sitting though. Went into it a month or so ago and there was a small lake in either footwell which was nice. Took out the carpets, rolled them out and dried in the garage, and put little moisture collector's in it which have done a great job.
Taking a proper look at it soon to make a list of what I know is needed, and I'll pop it in for an MOT to see what it fails on.
I know one of the backs of the front arches is questionable, sills probably could do with cutting out and freshening ( although not an MOT failure I don't think, just I know what lurks). Also the fuel pipe on the injection pump keeps popping off every now and then no matter what I do.
Aaaand it has a leaky injector seal.
Stay tuned, hopefully movement soon.
At least now the MOT will be near summer so I'm not scrambling around in winter :)
Link to comment
  • 2 months later...
Two months already? Life doesn't slow down does it.
Got a mostly free weekend - off for a week next week on a little much needed getaway then have a free Sunday after that. Figured I'd take a quick look this eve and start it up at the weekend for a bit of a once over, and book the MOT for either next weekend or the weekend after.
Battery dead for the first time - not surprising but impressive. It's sat for nearly 8 months and has only been started to jump start a couple other cars - at least 6-7 times and only now is the battery flat.
Sills are looking....well, see for yourself:
Not great. But I'll take a better look when I can raise it up.
Popped the battery out and busted out the trusty Halfords battery charger that has served me well the past few years:
Will hopefully start it up tomorrow and check the various fluid levels, LHM, rust, that leaky injector and take it for a nice little uninsured poke around the bloke to see what's what.
Sitting in it and smelling it, just being in it brings me such joy and happiness. I miss it so much esepcially with this nicer weather and want to get it back in use! Soon my pretty, soon.
Also there is now a big fuck off spider that lives next to one of the front spheres in the engine bay. Like, it's huge. I'm hoping it's gone by tomorrow.
Link to comment
  • 6 months later...
After many months of no movement (car wise at least - life has been very busy elsewhere), we have acquired a house of our very own with a chuffing great garage w/a workshop area out back. House needs renovation - but the garage doesn't. BX was moved in two days after we got the keys.
LOOK AT THE SPARE SPACE AROUND THE CAR. It even has electric heating if needed, and storage overhead.
First time in over a year it's been out of the elements and it was genuinely a very happy and almost emotional moment getting it in there. Finally in a place where I can give it the care it needs. Since we had more rain and some snow it's acquired a large amount of water on the passenger seat and carpet, which has caused some mould to start to form - so it couldn't come soon enough.
The car itself was also so excited it couldn't contain itself, and had a large diesel piddle on the road outside. New neighbours loaned me their pressure washer and hose to get it all cleaned up / washed in the drains as when it started to spread out with the rain it was a large hazard.
Nothing gives better new neighbour first impressions than causing an environmental hazard immediately.
The line from the injector to the pump has a couple pinholes in it now it seems and was spraying out like nobodies business. Only noticed after I'd been talking to the recovery driver for 5 minutes though after unloading!
Also pictured, cheeky Berlingo £400 driveway find that I got the other week. Sitting for a year, but went straight through an MOT an put it immediately into use. Stripped out the back to use as a van for the house stuff/tip runs, job's a good'un. Already more than earning it's keep.
Probably no updates for 3-6 months at least, as we'll be mega busy with the house - but at least in that time it's not filling with water or rusting away in the elements!
Link to comment
Good luck with the new place, sounds like you got the workshop/house condition the right way around and that garage is proper fancy with it's tiled flooring and whatnot.  I bet the water is getting in through the front passenger door seal again.
Link to comment
On 12/27/2022 at 6:32 AM, somewhatfoolish said:
Going to start a house thread so we can tell you you're doing it RONG? Nice garage, is there room at the far end for a workbench?
There is, but I don't need it because it has a separate part through the door at the back right which is an attached workshop/space. I'm extremely happy with it!
Thank you - appreciate that. And it certainly is by the looks of it. Looked at it again today though after being in the garage for a few days. Much less condensation - I'll get  dehumidifier in there in time / when I'm not doing a constant episode of 60 minute makeover on repeat!
On 12/27/2022 at 5:17 PM, GrumpiusMaximus said:
I’ve seen the estate agent’s pictures of the inside of the house.  Don’t change a thing!  It suits the BX perfectly!
In ripping off wallpaper and such we actually found some writing and it appears to have been redecorated in 1986 last - so it lines up with when the BX rolled off the forecourt nearly! But no. It smelt and looked awful - pictures don't portray the stagnant old cigarette/old room smell!
On 12/27/2022 at 8:03 PM, bigfella2 said:
Are you still in Sheffield?
Rotherham, yes.
Link to comment
  • Similar Content
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Broadsword
      I think the Broadsword fleet has become sufficiently complicated to merit a combined thread so that gradually all new additions will appear in one place.
      As of Sunday 17th March the situation is interesting.
      Two Citoren Xantias (remember the white Xantia of Excellence is for sale people!)
      http://autoshite.com/topic/34699-w-reg-citroen-xantia-20-hdi-xantia-of-excellence-%C2%A3999/
      http://autoshite.com/topic/34596-citroen-xantia-double-madness-rust/page-2
      A turquoise XJR6 pending overdue-collection (need that gone now!)
      http://autoshite.com/topic/34003-jaguar-xjr6-double-madness-double-sold
      An XJS 3.6 manual project which will get in high gear soonish. Wont be a keeper but will be fun getting it back to something presentable. Drivers fantastic!
      http://autoshite.com/topic/34664-jaguar-xjs-36-manual
      A Range Rover P38, which is turning out to be really rather good.
      And to mix things up even more I'm off on a collection caper today. Had first refusal on it and was expecting it to come around in a year, but things soon changed and no way was I going to pass up on it. It may well render the second Xantia redundant as I've got a really good feeling about this motor.
      In the meantime here are some snaps of the Range Rover. As usual it was a car I said I would probably never buy due to their reliability*. I have said the same of Jag XJR, XJS, XK8 and I have had all of those now. Basically the moment I declare buying a particular car is impractical or improbable, I end up buying one.
      Things to note on the P38. It's a nice colour with tidy body. The EAS has been removed. It runs and drives lovely and it doesn't have enough electrical problems to hinder progress. The main one is the driver's side window not working, but that should be fixable. I've tried changing the outstation, that didn't fix it. Might be wiring under the seat. Other than that I bought it and took it for an MOT the very next day, and it passed. Since then it had what seemed like a battery drain, but since unplugging the RF thingy for the remote locking and putting on a proper lead-acid battery, which the car can actually charge, unlike the modern lead-calcium batteries, it has been perfect. I will treat it to a full service soon.
      Stay tuned for the latest collection later today!
    • By captain_70s
      Hullo,
      I'm a masochist from Leeds who is running two rusty, worn out Triumph Dolomites as my only transport in rural Aberdeenshire. You might recognise me from various other forums and Facebook groups. Realistically I need to buy a modern car of some sort, but instead I find myself looking at £300 Citroen BXs and Triumph Acclaims on Gumtree and thinking "yeah, that'd fit right in with the rest of the broken cars I can't afford".
      On to the cars, the main attraction being my 1976 1850HL "50 Shades of Yellow" that I bought for £850 and is currently my daily driver, here is a picture of it before I sanded off some surface rust and sprayed it badly in the wrong shade of yellow with rattle cans:
      Within a month of purchase I managed to plant it in to a steel fence backwards after a botched gear change on a wet roundabout and ruined the N/S rear wing, although judging by the other dent that's packed with filler it looks like somebody had already done the same. I also managed to destroy a halfshaft and one of my Sprint alloys (good for an extra 15hp) in the incident, so now it's sitting on it's original steelies but painted black (good for an extra 5hp).
      It's only broken down on me twice. once with some sort of fuel delivery related problem which may or may not have been an empty fuel tank and once when the thermostat jammed shut and it overheated and blew out some O-rings for the cooling system. It has recently developed a taste for coolant and oil which is rather annoying, although it's done 89,300 miles which is about 80,000 more miles than BL engineering is designed to last, I'm keeping my eye on eBay for replacement engines...
      I tried to keep ahead of the rust a bit by rubbing down the arches and re-painting them, but apparently rattle can paint isn't great when you are spraying it at -5C, it also highlighted how although my car might have been Inca Yellow in 1976 it's now more of a "cat piss" sort of shade. So I ended up with the wrong shade of yellow which has rust coming back through after 5 weeks. Did I mention I'm incompetent?
      The other car is the first "classic" car I bought, so I can't bear to sell it. It's a '77 Dolomite 1300 and it cost £1400 (about £400 too much) and has been nothing but a pain in the arse:
      It looks much prettier (from 100 yards) but that's most due to the darker paintwork hiding the rust. It lives a mollycoddled life in my garage, where it somehow still manages to rust, and is utterly rubbish. 0-60 is measured on a calendar, top speed is 80ish but at that point it uses more oil than petrol, it rarely ventures over 50mph and if you encounter an incline of any sort you can kiss that sort of speed goodbye, along with about £20 of 20W50 as it vanishes out of the exhaust in the form of blue smoke.
      One of the PO's had clearly never heard of the term "oil change" so it developed into brown sludge that coated everything internally with the next owner(s) blissfully pouring fresh oil on top of it. This lasted until about 600 miles into my ownership when there was muffled "pop" from the engine bay and the car became a 3-cylinder. The cause was catastrophic wear to the top end causing a rocker arm to snap:
      As this was my first classic car I'd assumed it was supposed to sound like the engine was full of marbles, it wasn't.
      I put the engine back together with second hand bits declared it utterly fucked and promptly did another 5000 miles with it. After about 3500 of those miles the oil burning started, valve seals have gone so it's been relegated to my parent's garage as a backup car and something to take to local car shows as the 1850 is now embarrassingly ugly. I'm keeping my eye on eBay for replacement engines (deja vu, anybody?) Oh, I also recently reversed it into a parked Ford Fiesta and royally fucked up the rear bumper, rear panel and bootlid. Did I mention I'm incompetent?
      There have been two other cars in my life. My first car, a 2008 Toyota Yaris 1.0 an it's replacement a 2012 Corsa 1.4T. I didn't really want either of them, but it's a long story involving my parents and poor life choices. Ask if you want to hear it!
      So that's a brief summary of my current shite. If you want more pictures or details of anything do say as I've got photos of almost everything I'd done with the cars.
    • By mat_the_cat
      Thought I should probably start a thread, given that a few people have suggested it. For my sins, my first car was a 1985 Hyundai Stellar. Bought back in 1997, when the sun still shone, I had more hair, and the world was generally a better place.
      This may be the earliest photo I have, I think from 1998:
      Anyway, I drove everywhere in it, and clocked up over 100k miles before I was given an Alfa Romeo 75. So I took the Stellar off the road for some much needed TLC. Made some progress on it - Rebuilt all the suspension, fitted a rebuilt Cortina* rear axle, Princess 4 pot front calipers and Capri vented discs etc - before a couple of house moves and renovations put it on the back burner.
      * before anyone says they are identical underneath, there are some differences. I fitted a replacement axle fairly early on in my ownership, only to fit that not only was the propshaft flange the wrong size, the UJ was totally different so I couldn't even fit a new yoke. Finding a company on the day before New Year's Eve who could cut off the end, weld a new UJ on and balance it wasn't too easy, especially one that was accessible by push bike!
      Anyway, late last year I found some renewed motivation, and have been working on it when time and money permit. Here is what it looked like in October:
      OMG barn find?
      Front suspension OK at first glance...
      ...but it has turned out the calipers had seized (so are away being rebuilt) and all the (brand new) ball joint boots had perished:
      Quite a bit of welding is needed too, but I had a setback just before Christmas when we were burgled and my welder stolen
      Crusty roof rail
      I've cleared some of the crap away from it now (it's not stored at mine - I'd love to own somewhere that big!) so might be able to get more photos. Currently working on the rear brakes, and disappointed to find that the shotblasted rear axle is now starting to rust after two coats of POR15 and 7 years storage under cover...
    • By mat_the_cat
      This.
      By popular* demand* here is a thread about the least popular VW van around.
      The photo is as bought, back in 2006. Purchased with a year's MOT, 6 months tax, and a caravan all for £600. To his credit, the seller had received many enquiries from people wanting to buy either the caravan or van, but not both although refused to end the auction early when there were bids already on it. So it failed to go anywhere near what I thought it would sell for.
      The combination suited us well, as we could live in the caravan wile we carried out major house work, and use the van for carrying building materials. This we did, enduring a sometimes cosy but often cold winter in the caravan while I used the LT as my only road legal vehicle. It was already carpeted inside, with a simple electrical system as it had been previously used as a motorbike race van. It saw a little bit of use as a 'tent on wheels', seen here in Scotland in 2007:
      I'd always wanted to build a campervan, although I kept this quiet when seeking domestic funding for buying it in the first place! So when the bulk of the work was done, I suggested using some fittings from the caravan to convert it. This was met with approval (to my surprise), and we planned to take it to a festival one August.
      I waited for a forecast of dry weather, but none came and I was running out of time so ended up booking time off work a week before the festival. The reason for dry weather is that I wanted to tackle some welding...
      As it turned out, I had one dry day to work on it! After much searching I'd bought some genuine VW panels (despite forum experts saying there were none remaining), which fitted very nicely
      Managed to get that far on Monday, then it was time to tackle the floorpan but I'll leave that tale for another day...
