Cavcraft
Cavcraft 2k19: U WOT M8?
Don’t forget the Cat is worth a few bob on those!
That's why the yard is always very keen to take these off me!
Share this post
Link to post
This was the other one. Bottled out of driving it home 20 odd miles, had planned to take some straps to keep the bonnet down and just go for it. The yard said it's a frag job, bit of a shame as it had 12 months MOT.
Share this post
Link to post
Right, things have been moving apace recently.
This came and went...
57155644_2033104963652116_88992256366403
..was stuck in an orchard, not running.
This turned out to be knackered so sadly went...
58068383_2034152853547327_32300669069919
There was some sort of C220 estate thing that was knackered, then there was this, courtesy of Chaseracer and his very kind friend, Ray.
57251150_2033601993602413_16231599503793
Non-runner, dash lights gone for a Burton. Tried three different batteries (before realising they were all flat!) and spent time arsing about cleaning the - lead contacts. Put the battery off the spare Puma on, dash lights worked, car tried to start.
That sounded promising, so spent 20 frustrating minutes trying to find my boost pack (obvs. it was in the same place I looked three times at) and it fired up! Happy days!
The n/s/f tyre (nearly new Michelin :( ) had a gash in the sidewall, so I lobbed the spare on (dreadful)…
57251252_2033601753602437_47705719769913
...then remembered there was a similar sized decent one in my lock-up, somewhere. Ten minutes of routing round later, found two, one punctured, one ok. Two trips to the local tyre shop later...
57568504_2033601626935783_76681384932052
...and we're in business. Now time for a drive...
57578734_2034127760216503_19424562630696
57362593_2034127796883166_14360118228124
57221224_2034127820216497_29517549288816
57544662_2034127853549827_84476477457322
And time for a bath, a bloody good bath, preceded by a bloody good shower...
58374839_2034127880216491_29238556932052
57541772_2034127923549820_42629234898973
57511539_2034127966883149_27280066319115
Thus leading to...
57485866_2034128043549808_25235085158011
57821783_2034128066883139_50976977272994
57503908_2034128140216465_13335726480299
Back seats refitted (Google/YouTube)…
57384325_2034127730216506_34185765692563
Pretty sure these were a joint effort between Ford, VW and Seat. See if you can spot VW's input, cleverly* having drains that block, fill the footwell AND STOP THE FUCKING CENTRAL LOCKING WORKING.
 57578702_2034779193484693_39989472407427
Shit got real...
57451085_2034779306818015_79732916546835
58379620_2034779243484688_34073655965122
57555462_2034779376818008_70550178156186
Tried to unblock drains and checked tyre pressures, whilst also using the wet and vac to draw about 6,000 litres of water out of the footwell.
Did some more cleaning (mostly inside) and it's a hell of a lot better now. Oh, one of the scrappers had a brand spanking new tyre in the boot the same size as the Galaxy one, so that's going to be fitted at some point.
 58032992_2034779400151339_85965195070092
Drives ok, doesn't seem as quick as the 2005 Sharan TDi once owned, but still goes ok and is (have been told) it should be veg friendly. Possibly a slight blow from exhaust, and there's a strange annoying whirring or clicking sound from passenger floor area, I think.
Anyhow, it's hopefully going to replace the beloved Vectra as the family car, due to  room/size/dieseltowbar/veg. Fingers crossed.
Thanks again to ChaseRacer and Ray, owe you one.
Share this post
Link to post
On an R plate I would guess it is probably the older rotary pump diesel which were only available in 90 or 110hp FLAVA.
A 2005 would have been a PD, probably a 130, so a decent chunk more power.
Share this post
Link to post
Retiring or retarded, you decide (like you hadn't already)
Sat afternoon check list:
Walk the dog? Done.
Five minute dash round house before missus gets up? Done.
Agreed to buy a car that you haven't seen in photographs, let alone real life?  Done.
Plan to go and pay for it, then cycle back later and pick it up? Done.
Discover upon arrival it's got salvage yard chalk writing on it and a different coloured door?  Done.
Look at receipt from May 2018 for a £620 service and a few bits and feel smug?  Done.
Ride back later to pick it up, get 2 miles away and watch temp gauge steadily ride until it reaches the red, pray to every God known and lose smug smile instantly? Done.
Ladies and genitalmen, I present...
Image may contain: outdoor
Image may contain: car and outdoor
 I think a quick message to the yard beckons.
Share this post
Link to post
This is turning into something of a surreal day.  In-between scoring the fabulous Vectra and winning the roffle that I didn't know I'd entered, this got delivered. Yeah, it's modern, but it's partially fucked and was incredibly cheap.
Share this post
Link to post
Fuck, it's done 160k at last MOT so it's sixty thousand past the "mileage of certain death" that those engines seem to have. My Focus was almost like it had a timer set, the odo ticked onto six digits and the whole fucking thing fell apart like a clown car. Didn't realise Binis used the same engine.
Share this post
Link to post
Right,
Vectra: last journey booked.
Mini: Engine rattles when revved like a 1978 Ford Pinto 1.6 with a worn cam. Various diagnosis included IT'S FUKED M8/ bottom end gone/top end gone and the recovery driver's firm belief it's injector related. He thought we'd paid £4,000 for the car, incidentally. It'll be for sale (obvs) soon.
Share this post
Link to post
14 minutes ago, dean36014 said:
Check the small bolts holding the injectors in for tightness. They work loose and should be checked every service.
Which would have happened, were the motor in a Volvo... 😉
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
