dozeydustman Posted November 2, 2019 Share Posted November 2, 2019 As far as i am aware the dpf is intact; it was jet washed out 2-3 years ago by the fitters at work. It was Passive and active regenerating as it should under normal driving conditions. Since changing the manifold it would do a big clear out of black smoke every now and then before settling back to normal or doing a full on grey smoke regen. As it doesn’t do a wastegate/dump valve whoosh on gear change that was the next thing I was going to investigate. Last fault codes I had were p0400 (failed EGR) and p0234 (turbo overboost ) Floatylight 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 2, 2019 Author Share Posted November 2, 2019 Ok, convinced the intercooler is shot so have enquired about s new one on eBay.. also ordered a pair of droplinks..Sent from my Moto G (5) using Tapatalk Saabnut 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 3, 2019 Author Share Posted November 3, 2019 Purchases made, pray for decent weather next week!Sent from my Moto G (5) using Tapatalk The Moog 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 4, 2019 Author Share Posted November 4, 2019 Decent weather, let's get it stripped downSent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted November 4, 2019 Author Share Posted November 4, 2019 Well that's certainly not going to be helping!Sent from my Moto G (5) using Tapatalk Saabnut, The Moog, shedenvy and 1 other 2 2 Link to comment Share on other sites More sharing options...
Floatylight Posted November 8, 2019 Author Share Posted November 8, 2019 Update time.Replacement second hand intercooler arrived and was fitted today. Went for a drive and it threw P0234, cleared it, went for another drove and seems much happier, definitely more boost. Will check and the small sensor pipes. Tomorrow hope to fit the £10 droplinks and lubricate the heater fan.May press into work use on Monday for a trip to Bedford and see how I get on.Suspect the thermostat is stuck open as it only get to 50 degrees according to the obd, unfortunately doesn't seem possible to get just a thermostat and comes as a complete assembly at £60!Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Tickman Posted November 8, 2019 Share Posted November 8, 2019 Will the Renault 5 thermostat do the job? Floatylight 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 8, 2019 Author Share Posted November 8, 2019 Will the Renault 5 thermostat do the job?Mmm, I shall investigateSent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted November 9, 2019 Author Share Posted November 9, 2019 First day out and about in the Saab today, running much better but still a bit slow to spool up the turbo at lower revs, sometimes throws an eml if revved to the red line. Need to check some of the smaller pipes for leaks but now the bloody bonnet release won't work... FFS!!!Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted November 11, 2019 Author Share Posted November 11, 2019 Managed to open Bonnet & adjust release mechanism. Decided to do an oil & filter change before putting into work use so bits ordered! Also ordered a rear wiper blade from ECP for under £4! Back using Picasso for work, as log as I take it easy it keeps on plodding on.. Sent from my Moto G (5) using Tapatalk The Moog 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 17, 2019 Author Share Posted November 17, 2019 This weekend's updates:- Saab heater fan replaced with one which was in the boot which after a bit of lubrication was squeek free, replaced a small piece of hose which seemed a bit damaged in the boost circuit and put on a spare battery borrowed from[mention=17429]sutty2006[/mention] while I sort warranty replacement from Tayna. Went for a drive, still not boosting properly and when revved to 4k throws an eml, ungrateful baxtered! Also still letting water in from what seems to be driver's a pillar but not sign of any drains in that area.. In other news Smoll FL's C3 has an intermittent injector fault... Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
sutty2006 Posted November 17, 2019 Share Posted November 17, 2019 Which one did you use? My guess is on the smaller one of the two. Link to comment Share on other sites More sharing options...
Floatylight Posted November 17, 2019 Author Share Posted November 17, 2019 Which one did you use? My guess is on the smaller one of the two. Yeah, the smaller one was perfect, charged up no problem..Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
sutty2006 Posted November 18, 2019 Share Posted November 18, 2019 7 hours ago, Floatylight said: Yeah, the smaller one was perfect, charged up no problem.. Sent from my Moto G (5) using Tapatalk Great success Floatylight 1 Link to comment Share on other sites More sharing options...
Floatylight Posted November 20, 2019 Author Share Posted November 20, 2019 So this week the Saab has been deployed as WBOD / Work hack, first long haul today to Aylesbury & back (240 miles) same tomorrow. (Used the C4GP on Monday for Southampton & back)No major issues to report, seems to be getting better with use, still issues with boost below 3k revs, need to get an oil & filter done and replace thermostat as rarely gets up to temp, still need to replace drop links..But over 55 mpgees and didn't look too shabby. Contemplating running a challenge to see what I can end up with after 12m of reinvesting mileage allowances into upgrading cars.. 20k miles at HMRC rates...Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted November 26, 2019 Author Share Posted November 26, 2019 Decided to discontinue using the Saab for long journeys until I've had time/daylight/no rain to do an oil & filter change, fit the new thermostat and replace the coolant, unfortunately the combination of time/daylight and no rain looks unlikely for the foreseeable. C4GP has now started showing its displeasure at being driven with a blocked DPF so I've ordered a replacement, also due a service so I've ordered the bits to do that as well. Just hope the stars align so I've got a chance of getting one of them in decent running order... feeling a bit dissilusioned TBH!! Sent from my Moto G (5) using Tapatalk stonedagain 1 Link to comment Share on other sites More sharing options...
Floatylight Posted December 29, 2019 Author Share Posted December 29, 2019 Update.Changed the thermostat on the Saab and now runs at correct temp and been using for work, done over 1500 miles in it now.Got a noisy tensioner somewhere so ideally would fit the cambelt kit, water pump & bottom pulley that came with it, courtesy of Dozeydustman but might move it on after doing the droplinks, oil and filter..Sent from my Moto G (5) using Tapatalk LightBulbFun 1 Link to comment Share on other sites More sharing options...
Floatylight Posted December 29, 2019 Author Share Posted December 29, 2019 Further update, tried out new impact gun and replaced front tie rods,definitely less clunky, treated it to a quick wash and some new mats, still need to do the oil and filter but filter is in an awful place on these, really need a lift..Sent from my Moto G (5) using Tapatalk LightBulbFun 1 Link to comment Share on other sites More sharing options...
Fraz Posted December 30, 2019 Share Posted December 30, 2019 Assuming the Saab is the z19dth 1.9 tid version are you aware that if the EGR isnt working quite right it’ll have no boost low down the revs? might be worth while removing it, cleaning it and freeing it up and firing it back together just in case. Mine used to stick for fun sometimes causing no boat below 2500ish rpm Floatylight 1 Link to comment Share on other sites More sharing options...
Floatylight Posted December 30, 2019 Author Share Posted December 30, 2019 Assuming the Saab is the z19dth 1.9 tid version are you aware that if the EGR isnt working quite right it’ll have no boost low down the revs? might be worth while removing it, cleaning it and freeing it up and firing it back together just in case. Mine used to stick for fun sometimes causing no boat below 2500ish rpmIt is the z19dth, it's had a new EGR this year (I think) but the MAP sensor was so cacked up I wonder if the EGR needs cleaning again.I think.maybe not getting up to temp may have been causing other issues..Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Fraz Posted December 30, 2019 Share Posted December 30, 2019 Def worthwhile checking the EGR and it’s pipework. Symptoms sound similar to when the EGR system isn’t working right prior to it throwing a code, also, if you do plump for a new thermostat stay away from circoli stuff from ecp. Terrible, terrible quality thermostats. Floatylight 1 Link to comment Share on other sites More sharing options...
Floatylight Posted January 2, 2020 Author Share Posted January 2, 2020 Unexpected fleet changes on the cards.....Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted January 8, 2020 Author Share Posted January 8, 2020 Quick update, replaced the rocker cover on the c4gp today as it appeared loads of oil was coming out of the breather but also established I have a chuffing injector, so do I do it myself or farm it out, a quick look on you tube and it doesnt look too bad.In other news Delivery of Saab / Collection of replacement organised for Sunday and have an incoming Zafira as well, so Zafira (1.9cdti 120 Design) 6 Speed 1/2 Leather, decent history, new starter motor, looks tidy, couple of rust stains on the sill ends, c108k miles, I'll get some pictures but if any interest at £1200 let me know.. located Stafford but deliver M40/M1/A14 potentially possible..Sent from my SM-T585 using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted January 12, 2020 Author Share Posted January 12, 2020 So, it was fun while it lasted with the Ex Roffle, Dozeydustman Saab 9-3, I've made some improvements, fitted a new intercooler, thermostat, drop links, fixed the keys and generally had a tinker but it's time to move on.. It will be swapped later today at the request of a serial Saab tinkerer, but that will happen this afternoon, first need to get some pictures of the Zafira on the Force Hail Post.. Link to comment Share on other sites More sharing options...
brownnova Posted January 12, 2020 Share Posted January 12, 2020 So is the Zafira the Saab’s replacement or is there another replacement on the way? Link to comment Share on other sites More sharing options...
Floatylight Posted January 12, 2020 Author Share Posted January 12, 2020 So is the Zafira the Saab’s replacement or is there another replacement on the way? Nah, the Zafira is Ex FIL who was offered insult px from Arnold Shark so asked me to sell it, however Saab replacement is equally desirable*Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
brownnova Posted January 12, 2020 Share Posted January 12, 2020 Ahhh well good luck with the swap mission... Im guessing Mondeo with a gaffer taped front and rear bumper set... Link to comment Share on other sites More sharing options...
Floatylight Posted January 12, 2020 Author Share Posted January 12, 2020 incoming, Pez station shot, but no fuel reqd due to 1/2 tank already in..Sent from my Moto G (5) using Tapatalk Shirley Knott, BL Bloke, cpjitservices and 1 other 4 Link to comment Share on other sites More sharing options...
brownnova Posted January 12, 2020 Share Posted January 12, 2020 Oooh that’s is miserable!!! Well scored!! Link to comment Share on other sites More sharing options...
Floatylight Posted January 12, 2020 Author Share Posted January 12, 2020 Oooh that’s is miserable!!! Well scored!! Goes well and suspension seems to be properly attached which is an improvement on the Saab.. pushed straight into work use in the morning, expect it to have done over 600 miles by Tuesday night...Sent from my Moto G (5) using Tapatalk brownnova 1 Link to comment Share on other sites More sharing options...
