bramz7
Bramz ever changing fleet
Over-light steering is a standard R800 trait, along with GR9 seats.
They have an interesting quirk too - if one of the terminals comes off the battery, you won't notice anything different driving-wise, but the electric windows will start randomly going up and down all by themselves.
Share this post
Link to post
It did that to me a few weeks ago! I thought i'd lent on the switch pack by accident. Started beeping like crazy and the Went down again and then a few minutes later the engine cut out.
Negative terminal had popped off (forgot to tighten it)
Share this post
Link to post
The seats in the 800 are superb. Really Rover did what they do best in that era and made a great sofa surrounded by a not so great, if adequate motor car.
Window switches are a bit rubbery feeling too, but they work.
I've got a lead on a reasonable looking 525tds now. Bah.
Share this post
Link to post
Just had a gander under the BMW bonnet (not for the first time) and noticed how these have a very windy serpentine belt layout....I think the garage can sort that one out. Belt looks fine, there is a squeaky pulley somewhere though.
Took the Rover out this morning just to town and back and I really do like it. I don't think it would suit a manual box at all, they really do feel as if they were made for ploddy old ZF automatics.
Share this post
Link to post
I finally have a car that passed its MOT at the first attempt. At long last.
It's not bad right? It drives nice enough, the engine is a bit revvy and non BMW like, and the gearbox is far better when warm, but it'll do. Fine wood* trim and cream leather will do me.
In other news, I just managed to get the final new comer to my fleet insured for £26 earlier today, which was mighty pleasing.
Share this post
Link to post
A roffle prize I was genuinely sad to miss. It is my favourite E46 colour scheme and sounds like a cracker! Many congrats on flying through the MOT!
Share this post
Link to post
Oh yeah that's a fair point, I did actually wonder if that was the case before I wrote that.
Discovered another small niggle...the passenger side window is very lazy if lowered more than a couple of inches, and needs help to come back up. I think that's it as far as faults go.
Share this post
Link to post
I had that whole switch pack apart just after I bought the car as it was stiff. Loads of dust and crap inside. Cleaned it all out with electrical contact cleaner and cotton buds.
I’ve found vodka an adequate substitute for contact cleaner on occasion.
Or was that the other way round? I forget now.
Share this post
Link to post
This BMW still absolutely hums of oil, especially when up to temperature, and more so when stationary. It hasn't dropped any on the ground, but it's flashing up the amber oil warning periodically too.....
Is this any concern? Surely, after 200 miles of driving, any excess oil from the PCV episode would have been burned clean off?
Rover continues to be fine, it's a bit crumbly on the front arches but it's fine otherwise.
On the lookout for some pride yank shite now. Sadly all Japanese stuff is incompatible with insurance.
Share this post
Link to post
i've had a couple of e46 that show the oil warning light when you pull the key out when the level was fine it quite common on them. Is there any oil in the under tray?
I'd keep an eye on the levels my Z4 uses a litre of oil every few hundred miles, which I think is the PCV setup.
Edit - I'd change the oil it can't do any harm.
Share this post
Link to post
Knowing your luck and that were you thinking of a Blazer, have you considered an early-ish Jeep Cherokee?
I've never had one but they keep popping up on the radar for comfy yank cruisers that are easy to source parts for and shouldn't be difficult to fix. The earlier ones might be classic friendly as well.
Share this post
Link to post
A good call regarding the Cherokee. I kind of want something with a hideous interior with button velour or something, but I've got an open mind.
Budget will be around £2k, but that's when I've saved up a dash more.
Share this post
Link to post
Hmmm, BMW oil level right at max still, so I presume if there is a leak it's a small one.
However...why does my oil cap have what looks like real milky coffee on it?
Edited to add coolant also at max, thanks to stupidly easy to use measurement system. God knows how people neglect these cars when they have possibly the most user friendly level checkers I've ever had
Share this post
Link to post
Yeah a quick Google suggests it was just condensation.
I've been doing short runs but let it get up to temperature usually. Helps the box out a bit too as it hangs in gear a bit when stone cold.
Regarding XM....I'll pass this time but thanks! Set on a yank now.
Share this post
Link to post
I'm not surprised Sam! Trouble is I want to keep them all! Think the trailer tent is doomed as I could convert the estate easily into a comfy overnight bedroom. I know James slept in it a few times with his dogs. If you get a yank I'm coming down for a passenger ride!
Share this post
Link to post
I'm pretty sure they did Grand Cherokees with some suitably tasteless interiors.
Erm, yeah they did, I bought one off you and it was ace, thankfully no VM in that one.
Caramac leather ftw.
Like this?
I do remember this being one of the comfiest places to sit evah!
Share this post
Link to post
My brother has an 325 and one of his colleagues has a 318, both E46 model. Each do 7-8 miles twice a day and both suffer with mayonnaise every winter. It clears when the weather warms up and is (usually) nowt to worry about.
Share this post
Link to post
I've also considered a STS. 4.6 V8 and FWD...and only £250 to insure.
They do like to grenade though don't they?
Cracked blocks and heads aplenty on these.
Almost bought a 99 sts before I got the xj8. Was only £750 but had quite a few previous mot advisories for blue smoke at idle.
Neadless to say I walked away.
Share this post
Link to post
