davehedgehog31
Hedgehog Motors - Ropey 607 Arrival
21 hours ago, cms206 said:
I have for many years nursed a 607 fetish and Wednesday night didn't fucking help it.
21 hours ago, Supernaut said:
I remember the massive grin on your face when you pulled back into the car park, and your missus shouting "No! Noooo! No! Stop it!"
Has Andy bought it yet?  Take that how you will...
Share this post
Link to post
Further to last nights investigations, some progress was made tonight. First of all, someone left me a message;
So basically I've set up a laptop with the Peugeot Planet 2000 diagnostic software and acquired the usb to OBD interface required to use it. It's a pretty powerful package by the looks of things. I've been using it to read error codes, clear them and look at different vehicle parameters to try and see what the matter is.
To recap, the car would not start at all, without easystart spray. When it did start it would run in a restricted power mode with EML lit. Last night it was showing a persistent error code about the camshaft sensor which returned after clearing, upon cranking the engine again.
I'm keen to not throw money at it willy nilly, but given the Bosch camshaft sensor was £15, I thought I'd pick one up. I fitted it tonight. It looks like this;
Notice the little tooth on the end, on the one I removed this was smoothed off. I don't know if it's there to be sacrificial. As you can also see the hole for the screw is elongated so it's basically align-able, it doesn't fit in a set position. When I fitted the new sensor I was getting a code about "no reading from camshaft sensor". Not that it wasn't present, just that it wasn't receiving a signal from it.
I guessed this was probably because I had positioned it conservatively so as not to damage it. Thought I'd test with the old one and try inserting it a bit further and trying to line it up properly, if it was damaged it wouldn't be too much of a concern. Done this and got in the car, cleared the codes. Cranked it and it started after minimal cranking... sat and idled fine. No EML and no codes.  It couldn't be that easy? Or could it?
It sat there idling for about ten minutes while I watched the various parameters, no issues at all.
Crucially, there's a parameter for "Cam/Crank Sync" and this showed Yes throughout, so seems like the theory of it having slipped a tooth is out.
Took it out a bimble round the extensive* private* grounds of my stately* home, not on the Queen's Highway obvs, as the cunt is neither taxed nor insured. Gave it a wee razz up a hill and it pulled strongly, no signs of limp mode.
Got back, shut it off and started again as below;
So a fair bit more cranking than you'd like, but it started and then ran fine again, repeated once again.
However, at the third attempt progress was dashed somewhat, it wouldn't start and just cranked. Battery was only reading 11.7v. Will try it with a known good battery tomorrow morning and see.
So to sum up, definite progress. It's definitely one problem less than was there last night and it's good to know that the engine is fundamentally capable of starting and running under it's own steam. Worst case, I may just have tidied up a residual issue and now have a platform to get to the root of the actual issue. Best case, I wang a good battery on it and it works. We can but hope...
Share this post
Link to post
  • Similar Content
    • By Joey spud
      I have been looking for a cheap van for a while now,something that i can cart crap about in and also use as a sort of Day van.
      My budget was £1500 max but i really wanted to spend far less if possible and improve it over time but it soon became obvious that VW t4's are massively scene taxed and Transits are all rotten at this price.
      Vito's likewise rusty and mega milages only available for my budget and i have no love for Vivaro or Trafics as i have spent too many hours towing the things or sending them off on the back of a flatbed.
      So i started looking at the humble Hiace.
      These never seem to go wrong in 17 years of roadside breakdown patrolling i can't recall attending one with anything more serious than a flat tyre or battery.
      Early non turbo 2.4 diesel ones are so simple they just run and run but the downside is they are only 87bhp and so sluggish and a bit thirsty compared to a more modern van.
      I spotted one down in Devon on ebay and while i dithered about the distance it sold for £1500 and i thought fuck it i should have had a bid on that,then it was relisted on a buy it now for £1600 (no bites) then auctioned again starting bid £1000 that was then dropped to £800.
      After a few messages with the seller i popped in a max bid of £999 and waited for the auction to end and i found i had indeed won a shonky 1996 Toyota Hiace for £895.
    • By Shirley Knott
      Greetings all.
      After lurking here for a short while, frankly liking what I see and enjoying the various shite, the site has well and truly struck a chord with me. I'm a serial buyer of ropey sub £1k vehicles, don't have to but genuinely enjoy it.
      I feel like I might (Just might) have found my 'spiritual' home here
      I've been posting across the web on owner specific forums (Usually using either my JoeyEunos or RandomPrecion handles) for a while now, but from here-on-in I will pull my threads together and merge them here into one ghastly topic.
      My current steeds...
      Lupo 1.7 SDI
      SAM_5560 by
      and the work/story so far...http://forums.clublupo.co.uk/index.php?/topic/102863-joeyeunoss-sdi-beater/
      Golf Mk4 SDI
      SAM_5531 by
      and the thread.... http://uk-mkivs.net/topic/597074-project-slow/
      Early (1989) Mk1 Eunos (This one was recently sold)
      SAM_4656 by
      the thread...http://www.mx5nutz.com/forum/index.php?showtopic=213274
      Other shite I've owned and moved on in the last year include this ropey Passat...
      SAM_6011 by
      and this legendary £300 Fiesta Finesse...
      Festa by
      Cars I'd like to own/actively looking for in the forthcoming weeks/months/years...
      Rover 75 (Dizzler)
      Peugeot 405 (XUD)
      Mk1 Octavia (Estate/dizzler, pre pd or SDI)
      Honda CRV (Gen1)
      Volvo 240/850
    • By Peter C
      Woke up this morning, had a little time before I had to leave the house for work, had a quick look at what’s new for sale on Retro Rides and saw an ad for a W124 200E manual, located 15 miles from home. I had no intention of buying a car today but I had to have it! I called the seller and arranged a viewing.
      Faults:
      2 x rusty front wings (TADTS)
      1 x rusty rear arch
      Needs a polish
      Tracking is out because new track rod end was fitted for MoT
      Engine has oil leak/s
      Good points:
      It’s a W124 200E!
      5 speed manual transmission
      New clutch
      Brand new MoT
      Superb MoT history
      4 x as new Continental tyres
      Last owner for 15 years, her husband before that for 4 years
      Very tidy MB-Tex interior
      Drives well
      All electrics work
      The dealer kindly delivered the car to my house but I managed a pez station shot on route:
      Plans:
      Remove front wings, cut away rust and apply plenty of wob.
      In-situ similar repair for rear arch
      Clean and polish
      Service engine
      Adjust tracking
      Leave patina and enjoy the car as it is
      I will update this thread once progress is made.
      Hopefully these two will become good friends.
