robinmasters
Robinmasters' French Fancies - W[C] PGW?
Yes, one of those. You've seen the car before, and I've already used up my best jokes (so I'll repeat them).
An epic journey, including:
- THREE COUNTIES
- THAT LONDON
- TRAINS
- SHANKS' PONY
- And possibly a pastry-encased but disappointing meal
Share this post
Link to post
The...great.....suprendo?
Plz pm address for celeb stalking purposes.
Guildford. Founded by the Fordworkers guild 1765 just ahead of the release of the sidevalve engine.
Main export: white sports socks.
Famous residents: Geoffrey Durham and Anton Rogers.
Temp: 18 degrees.
Share this post
Link to post
The drive home was fun. Lots of fun. I think it was bramz that described it as 'peppy'. Certainly is. No trouble keeping up on the motorway, and feels pretty solid too, not at all like I remember smol cars in the nineties.
The lacquer peel is significant, to say the least, but that's really the biggest problem. My daughter looked at the bonnet and said 'Is it ok, it looks like it's got a disease'.
To do list so far:
- Tyres-whilst they're not a common size, decent brands are still cheap. Any doubt over the ones currently fitted-they'll be replaced.
- Sort lacquer peel; I've always quite fancied a French car with a tricolore roof, but I don't think this colour would suit it. Mark's been gradually jet-washing the lacquer off, but I've discovered that it can be taken off without (visibly) damaging the paint; unfortunately someone has been at it before, but less carefully. I don't think even the worst scratches need paint though.
- Stickers; I really don't like extraneous or deteriorated stickers, so some will have to go. The original dealer sticker stays, despite being faded; it's not curling or cracking. A 'K&N' sticker on the rear window has already gone, and the 'radio code' stickers on the front windows aren't far behind-they've been a brown sticky mess on every Citroen I've owned.
- Fit stereo with USB; I'll keep the original. DIN adapter already on the way.
- Fix inoperative boot lock
- Cigar lighter not working; not important enough to check all fuses, it can wait until the BoL arrives.
- Left side of dash (ie entire speedometer) not illuminated. Possibly heater panel too, will have a look when the radio is out.
- Reverse light not working. Haven't checked the bulb yet (because the boot doesn't open).
- Faded plastics-door mirrors, and window winders. And the glove box buttons.
- Clean. Low priority.
- Think about removing battering rams. They're an open box section where they join the car, so should be easy enough (I've had an angle grinder for years, never used it). The gaping holes left in the bumper could simply be covered with plastic vents.
There's not really anything wrong with it. Dunno when it was last serviced, or when the cam belt was done (or if, it's only done 60k), so will do both in due course.
I might actually keep this thread updated beyond the first week of ownership!
Share this post
Link to post
  • Similar Content
    • By Peter C
      Woke up this morning, had a little time before I had to leave the house for work, had a quick look at what’s new for sale on Retro Rides and saw an ad for a W124 200E manual, located 15 miles from home. I had no intention of buying a car today but I had to have it! I called the seller and arranged a viewing.
      Faults:
      2 x rusty front wings (TADTS)
      1 x rusty rear arch
      Needs a polish
      Tracking is out because new track rod end was fitted for MoT
      Engine has oil leak/s
      Good points:
      It’s a W124 200E!
      5 speed manual transmission
      New clutch
      Brand new MoT
      Superb MoT history
      4 x as new Continental tyres
      Last owner for 15 years, her husband before that for 4 years
      Very tidy MB-Tex interior
      Drives well
      All electrics work
      The dealer kindly delivered the car to my house but I managed a pez station shot on route:
      Plans:
      Remove front wings, cut away rust and apply plenty of wob.
      In-situ similar repair for rear arch
      Clean and polish
      Service engine
      Adjust tracking
      Leave patina and enjoy the car as it is
      I will update this thread once progress is made.
      Hopefully these two will become good friends.
    • By PhilA
      Well, here we go again. I bit the bullet and bought me this.
      It's still up at the lot right now, there will be a miniature Collection Thread embedded in this thread when I go fetch it. Hopefully if the weather's good, that'll be this weekend.
      So, what is it?
      As the title suggests, it's a 1951 Pontiac Chieftain.
      It's got a flat-head straight eight hiding in the engine bay, 4.4 litres of it. It's bolted to a 4-speed Hydra-Matic Drive gearbox. No torque converter on this one, just a fluid coupling. 116 horses at a screaming 3700 RPM, 240lb/ft at 2000. It idles at 375 RPM. Redline just shy of 4k.
      Did I mention it's quite big? Sixteen foot eight from end to end and it seats six people in comfort. Every door has a quarter-light, too. Comfort is provided by properly sized tyres and (quite surprisingly for the age of it) double independent wishbone front suspension. Steering is via worm/wheel steering box so is moderately direct and the brakes are hydraulic drums all round. Modern and scientific!
      It's an honest example; looks to have had a "restoration" about 15-20 years back and the rust is coming through the seams and filler. The bottoms of the door skins have gone, the bottom of the A-pillars have gone (the front doors, on a single hinge a piece still open and close with one finger!) And it's got a couple holes and blebs in all the places you would expect.
      Not much electrical works. It needs to be completely rewired because someone has "converted" it to 12V. Thankfully it was originally negative ground so that's a good start. Gauges and such can be driven from a 6V bucking converter.
      Engine has had some work done on it- starts and runs nicely with very little greb coming out of the exhaust. It's got a few gaskets that need replacing and the tappets need some major adjustment, the gearbox engages gears correctly, the steering is okay but has a lot of slack in the center and the brakes work well, dont sink or feel spongy but need adjustment.
      More to come. I'll post up more pictures when I get it home.
      --Phil
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By strangeangel
      I thought I'd start a thread for this as I'll probably end up asking all sorts of questions, given that this is my first 'proper' Citroën.
      So... the ground clearance lever won't go all the way to the highest setting (all others work), which is bad 'cos the book says I need it to do that in order to check the LHM level. It feels like something's seized, so I don't want to force it. Any ideas for a plan of attack would be much appreciated.
      Next up are the wheels. I now have a set of 205 pepperpots that have just gone off for powder coating & I need to get some tyres for them. The handbook says the car should have 165/70R14s on, the wheels came with 185/65R14 on. Any thoughts about what size I should get please? Cheers.
