Squire_Dawson
Humber Super Snipe: overhaul.
I suppose I am like a doctor... albeit a car doctor.
Continuing with the Squire treatment, a tackled a few more issues that came to light. The boot handle which doubles as the number plate surround and lamp was a little loose. Investigation showed 2 nuts missing. A couple of 2BA and suitable washers put that right, being careful not to over-tighten, as the studs are part of the casting and you're finished if they break.
Next, the steering wheel was not straight. Fearing this could be tracking, I monitored it for several hundred miles and examined the tyres. The car drove fine though and the feel of the steering did not suggest anything amiss. The tyres are fine, so off it came.
It was straightforward enough after careful study of the workshop manual. I took this opportunity to thoroughly clean everything from decades accumulation of dust.
You will note the very loose screw on the gear lever pivot. The steering wheel securing nut was also very loose - I could undo it by hand! After adjusting the indicator cancelling ring I put it all back together. It's obvious where the water is getting in past the windscreen seal.
Fortunately it does not go any further behind the dashboard, just drips down onto the floor.
Then took it for a test drive.
Share this post
Link to post
I'll say it again, that Humber is gorgeous.  If you wanted to do a sick old bloke a good turn you could bring it over to the  Lakes and take me for a little ride in it... ;)
EDDYFEST!!
I wonder if there's anywhere in Barrow or nearby where we could park a pile of rammle for the day sometime?
Share this post
Link to post
You are expected to turn up at the next Autoshite gig dressed accordingly:
A.jpg?resize=300%2C254
Detective Inspector Baxter (Eric Lander) with his boss Detective Chief Superintendant  Lockhart played by Raymond Francis.
236 episodes of No Hiding Place on ITV from 1959 to 1967. A seminal part of my upbringing :)
Share this post
Link to post
EDDYFEST!!
Lakeland Motor Museum.  Those who have already visited will vouch for their tolerance of a load of shite cars arriving at once.
Share this post
Link to post
These are one of a tiny handful of British cars that can pull off whitewalls since they're like a mid-50s Chevy that went to finishing school and learned how to write the date correctly.
That's right. These cars took their styling cues from the 1955 Chevrolets.
I suggest 'Japlac' white enamel.
That sounds suitably 1950's.
It would be an honour sir, I'm sure something can be arranged.
Oh, really?
Well, I did find those flip-flops in a bin, so you can't blame me...
What has recently come to light are two more faults, as is to be expected when pressing a previously dormant car back into service. The first is intermittent charging and a flicking ammeter, but the second is the most urgent. I observed this when I viewed the car and had accounted for it anyway, but a previously absent rattling/whirring noise had me opening the bonnet to ascertain the cause. Water being flicked onto my face by the fan soon had me pinpointing it. I believe Lesapandre is onto something with the water pump, unless its a gasket. But the radiator urgently needs removing for a recore.
There were no signs of overheating and even after a high speed run I could put my hand on top of the radiator - usually they are (and should be) roasting hot. The coolant was never this sludged and rusty. I suspect driving the car has dislodged a load of rubbish and the thermostat, which Conrad Conelrad pointed out must be of low temperature anyway, has jammed open. We shall see once I remove it all this week. I think its had a good innings though..
Share this post
Link to post
Guest Hooli
Plus they have a nice stone wall for hanging the banner on.
Share this post
Link to post
I've always taken my rads to a little workshop behind the shops in Camden Road, Tunbridge Wells. I don't think they have changed anything there in fifty years. Maybe the staff have moved on a couple of generations... oh, and what they charge.
Share this post
Link to post
Bryan the radiator man? Absolutely ace. Worth a visit to experience the huge open vats of noxious chemicals in there. The workshop is about the size of my kitchen, I'm amazed he's not dead. Actually, did you hear about the rumours one of his rivals started spreading a couple of years ago that he'd died? Him and his missus were on a cruise, and when they got back there were a load of tributes and wreaths laid outside the workshop
Share this post
Link to post
  • Similar Content
    • By TripleRich
      Hi all, new to the forum.  Thought you might be interested in what I've got myself into
      I'd been after my first classic car for a while.  If it's big and made in the 70s I'm interested.  Looked at few things like P6s, Zodiacs, Victors, SD1s and various other things.  Problem was I didn't want to spend a boatload of money on something that looked alright but underneath was actually a total heap.  The solution was to buy a complete heap in the first place and spend the money fixing it.
      So in January I went ahead and bought this from a colleague at work who was moving away and needed to get shot of it.
      It's a part finished restoration (I prefer not started) and it needs a whole load of help if it's going to stand any chance of using a road again.
      Pros
      It's right up my street.  Granada Coupes are quite odd and certainly stand out from the norm.
      It still has the original engine, box, interior and most trim.
      It came with loads of panels I need to repair it (mostly original Ford stock).
      It came with so many spares I could probably build a few Granadas and still have stuff left over.
      It was cheap.
      Cons
      Most of the front end has been cut off.
      Most of the body structure is quite rotten.
      It's going to take me ages.
      I work at a restoration company and my boss kindly allows me to keep the car there.  So I've got access to all the gear I need to restore it.  I've been busy on the car for a while now so will post more pics over the coming days.
      Cheers
    • By Supernaut
      What does £191 on eBay get you?
      An E36 BMW 316i with two sets of wheels, a DAB radio, an MOT until December, 110k miles on the clocks, a slightly* fucked back box and a bit of grot on the driver's side sill.
      This is co-owned between me and 17-Coffees and our plan is to do a light restoration and just generally piss about with it. It's actually really nice to drive, and is surprisingly brisk for only being a 1.6.
      Yes, the alloys are getting sacked off ASAP as it came with the original steel wheels with all-but-new Toyo Proxes on them!
    • By vulgalour
      So many broken picture links!  I'll fix it one day.
      I feel I can finally unlurk properly now that I have something worthy of Autoshite to post about.
      Day One
      In the cold light of Day Two
      Came with some great features.
      The best thing about vinyl is that you *can* scrub it clean and with this old boat that was needed; everything was sticky and left a black residue on the hands. I've only been able to bring myself to spend an hour on the driver's door, the rest will have to wait for now.
      Doesn't look as big as it feels, weirdly.
      This is going to be my new daily in a few months, just got to get through a lot of cleaning and a bit of fettling. She's actually not that bad overall and only cost me £450 (plus £25 day insurance to collect her).
      The problems?
      >Quite a few rust blebs, but nothing serious or structural
      >Handbrake needs adjusting, I have to chock the wheels when parked on the drive
      >Driver's door window doesn't work
      >Probably decades of hand grease and silicone spray, built up in alternating layers. The engine bay is cleaner than the cabin.
      >Bonnet rams don't hold up the bonnet.
      >Neither do the boot rams.
      >Garage fitted electric fuel pump has no supressor, interferes with the LW/MW radio
      >PYE tape deck needs new belts, music played on it sounds like it's underwater
      >Bad previous respray with water contamination.
      But you know what, none of that matters. She's supremely comfortable and with some TLC over the summer should be in fine fettle. I'm not sure whether or not the people that look with face agog and jaw slack as I drive past are impressed, worried or amazed that a beige Princess with a brown roof still exists and is out on the road with someone a long way from pensionable age driving it.
