Squire_Dawson
Humber Super Snipe: overhaul.
Hang on...............you mean you're from Oop 'Ere and you LEFT?
In my defence it wasn’t my choice.
My dad was in the Navy and had to come south (Portsmouth dockyard) for his job so we ended up down here. There’s no sea or naval dockyards in Doncaster you see!
Then we moved back to Doncaster for a while living in Bessacarr for those of you local. Then, again, we had to go back south to Pompey which is where I’ve been since, well in Waterlooville actually which is about 10 miles or so north of Pompey.
I don’t hate it down here but it’s an overcrowded over priced rich mans playground and I’d go north again without a doubt. My plan is to use my job here to get £shitloads then jack it in and go back up to the nice bit of the country!
So now you know!
We* don't let that sort back.
*speaking as a naturalised norferner
F U Buddy! I’ve got climate improvement work to do and I have suitable tools for the job!
And I know Donny, I’ll track you down!
Much apologies for the thread drift...
Share this post
Link to post
The car has all the hallmarks of a caring owner of the non-car sort with regards to the mechanics. For instance the battery was bone dry as was the steering box. It has taken me the best part of 2 days to service - you would not believe how many grease points there are on this car - and I still haven't finished. To start with I drained the sump and changed the oil filter. A straightforward task on an old car? Not so - I had to remove the battery and the ignition coil to get the filter out and even then it was a struggle. Later cars had the battery moved to the other side of the engine compartment. Just to give you an idea of the size of this engine, the book says the oilways retain 3 pints after draining! So the fresh oil is already a little dark.
Gearbox and back axle were drained and both were straightforward jobs, indeed the gearbox has been the easiest I've ever filled. The real fun started when I got the grease gun out. There are nearly 30 points to attend to on this car. One grease nipple was missing from the front propshaft U/J so I raided my stores... heaven knows when they were last done. The steering box took a lot of oil until it was full, but after all the work I am certain it drives a little better. There were numerous other points to attend to with an oilcan, the ones which get overlooked like gear shift linkage and throttle pedal pivots, but I had the benefit of a lubrication chart.
Next will be checking the valve clearances and sparking plugs. The car has sprung a water leak, but I can't see where from just yet other than it's at the front. The radiator is the original and has a little plate saying 'Rootes Group' on it, so that will be coming out for a re-core, which I do with all my old cars where the radiators are a bit sus.
Share this post
Link to post
On mine it leaked from the water pump housing. It may be a common thing - not sure. Parts were difficult 20 years ago...but that was pre-internet. There may be some motherlode in Australia or something he he. There was a company Grimes in the UK - I think they are long gone.
Share this post
Link to post
If any of the steering box equipped cars I have owned is a guide, it's empty because the oil all pissed out within a week of filling.
Super motor though.
By Jove you are correct. A fresh patch of fluid appeared on the driveway. I dipped and sniffed and yep, it's EP 90. Incontinent 60 year olds!
Would it be something daft* like needing the waterpump re packing with that thick white grease or similar causing sporadic leakage.
PS please can you leave the number plates in a bucket of salt water for a week or so to improve their appearance.
Bizarrely for a car that has a grease nipple for everything else, the water pump is a 'sealed for life' unit. Did the Rootes engineers not predict such a lifespan?
It's a motor that just looks better everytime you post a pic.
Thank-you kind sir.
Share this post
Link to post
I've really not had any spare time to work on the car, as the usual flaws are appearing such as petrol tank leaks, oil (steering box) leak and worst of all, windscreen leak which is collecting a puddle in the rubber mats. I really need to see to that as a matter of urgency. However, as I took the windscreen washer bottle out to clean and fill, imagine my surprise when I found this -
Share this post
Link to post
RJ Grimes were Rootes specialists, based in some old railway arch’s in Coulsdon, S London.
When they retired, their niece, Sarah, took the bulk over and moved it down to her shop, Speedy Spares, in Brighton
She sold a lot off, quickly but still retains some stock, or knows where to get it.
They are happy to post out, too. Check their website out, and/ or give them a ring. Really helpful, very “old school”.
Share this post
Link to post
Can you get new screen rubbers for these, Josh?   I would be concerned about that leak.   The old Captain Tolley and the like is great for keeping water out of the car but it doesn't always completely cure the capillary action which can see water ingress elsewhere along the rubber.   This doesn't always come inside visibly - it can get into bulkhead voids and A post sections and wreak merry hell five years later.   All of this old stuff you see with "slight bubbling around screen" is often completely fucked under the paint.
Its the first thing I do with old stuff now - new, good quality screen rubbers.....Did it on the Cowley, front and back - its a good opportunity to clean and protect the delicate thin steel flanges too.
Share this post
Link to post
Yes. Virtually every Daimler Conquest for sale has ruined woodwork at the corners - the water then rots out the inner wings. My Wolseley 4/44 did it too. Thiz is something I'd hope the Humber club would have remanufactured if unavailable.
Share this post
Link to post
Every autojumble I go to has tons of BMC stuff but Rootes parts seem really hard to find. Fortunately I haven't had to get anything yet. I need a closer look at the windscreen rubber, but I hope you are right Trev and new ones have been made. That was certainly the case with the MO (which doesn't leak).
Share this post
Link to post
Guest Hooli
This is either a euphemism for a lady bottom or a millennial.
I was going to say 'aren't they the same?' but then I remembered the only use for a millennial is to treat them as a slinky & push them down the stairs.
Share this post
Link to post
 A neat trick I learned on the bus company is to mix equal quantities of grease and gear oil into a slurry and brush it onto areas that need oiling, the gear oil creeps in and lubricates where needed and the grease provides thickness to stop it dripping off and stop water getting in.
Danke, will have a closer look. It does seem to be going down the front of the engine, not the radiator. It seems to do it sporadically. Fortunately it has a thermometer so I can check before any overheating takes place.
 If you have not heard of them this place is supposed to be good.
 http://www.ep-services.co.uk/classic_pumps
 Very nice looking car, well done.
Colin
Share this post
Link to post
I used to use C.O.H.Baines, in or around Tunbridge Wells for windscreen rubbers. They have an extensive catalogue of cross sections, marry yours up and state the length - simples. In the post a day later.
I recall one peculiar rubber that they made just for me. They would go to those lengths.
I was ordering so many up at one stage that I got a visit from their rep!
All worked well, as originally intended, at a sensible price.
Share this post
Link to post
Conrad Conelrad observed the panel lighting wasn't the best. I determined to find out why, as it should at least be readable. I looked under the dashboard and found the speedometer and tri-gauge cluster are lit by one miserly bulb. I pulled the speedometer bulb out and found this, side by side with a fresh one:
For lightbulbfun, they are both Osram and the usual 2.2 watt variety.
I don't think I've posted any dashboard pictures, so here is a shot to savour:
Instead of doing a straight swap with the bulbs, I decided to fit a 5 watt instead. As the panel lights are dimmable the only possible snag was fitting the uprated bulb through the hole, as they are considerably bigger. Fortunately it went in without trouble and the result has been a marked increase in brilliance, as you can see here:
To the right, the cluster is lit by a 2.2 watt in good condition. This is with the dimmer switch set to maximum brightness, so I'll swap that one too. Fuel gauge is smaller so may not need it, I'll have a trial run first.
Otherwise today I went round with the oilcan and attended to all the door locks and hinges, and adjusted the passenger door striker plate, so the door can now again be clicked shut with one finger, which I never tire of doing!
Share this post
Link to post
  • Similar Content
    • By BorniteIdentity
      This week, for the first time ever, I felt old. I have sciatica which swaps from one side to the other, arthritis in one hand and what I think is the beginnings of IBS. On top of that it took me 2 weeks to remember a registration number that once would take me 2 seconds, and I forgot my parent's wedding anniversary.
      I'm only 32.
      Shit. No I'm not. I'm 33. I forgot that too. (Genuinely)
      So, it's about time I committed some of my tales to paper. Well, a shonky server... but that's the best you can do in 2016.
      First up, a list of the cars I've owned (as best as I can remember) in chronological order.
      Main Cars
      1985 VW Polo Formel E. C158 TRT. This was given to me even before I passed my test.
      1991 Rover Metro S. J801 TAC. Bought about 3 months after I passed my test as I was convinced the Polo was about to shit its gearbox.
      1987 Volvo 360 GLT. D781 ___ Managed three months in a Metro before the small car and smaller petrol tank became a bore.
      Ford Mondeo and Honda Civic Coupe by Bornite Identity, on Flickr
      1999 Ford Mondeo Zetec. V384 DBJ. Still the most I've ever spent on a car. It was 3 years old and cost, from memory, about £8,000. Just think of the Rover R8s you could buy with that now!
      1987 Volkswagen Golf GTI 8v by Bornite Identity, on Flickr
      1987 Volkswagen Golf GTI D79 CVV. I very nearly bought a MK1 Golf 1.1 but was persuaded, by my father amusingly, to buy this one from a different friend. From memory I gave about £500 for it, and sold it to some racers later that year for about £300. Amusingly, 16 year later I'd sell the Hartge wheels that came with the car for £530.
      1999 Toyota Avensis CDX by Bornite Identity, on Flickr
      1999 Toyota Avensis CDX. V781 GDP. By far the best car I've ever had. Bought in 2002 for £5300, it had previously been a company car at British Telecom. I ran it from 62,000 to 174,000 before it became surplus to requirements. A German chap bought it on ebay for about £500 and drove over to collect it. Hero.
      2001 Ford Mondeo Zetec by Bornite Identity, on Flickr
      2001 Ford Mondeo Zetec. Y821 EEB. I should have loved this car. I gave £500 for it in 2008 which was stupidly cheap by anybody's standards. It needed 4 tyres (which actually was nice to pick good ones for once) and a coil spring. Sadly, it was just bill after bill after bill. I sold it and promised to never own another Ford. I nearly succeeded.
      1998 Nissan Almera by Bornite Identity, on Flickr
      1998 Nissan Almera GX Auto. S58 NLO. My late Grandfather's car and, upon reflection, my first proper attempt at bangernomics. I bought it for £500 in 2008 from the estate and ran it for well over a year and 30,000 miles. It was also my first automatic which, whilst a bit dumb, did lock up into overdrive and give a good 36 mpg no matter how it was driven.
      2004 Ford Fiesta 1.25 LX and 2006 Ford Focus 2.0 Ghia by Bornite Identity, on Flickr
      2004 Ford Fiesta Zetec. AG53 BWL. My wife's car which I ran for a couple of years when I bought her a Focus as a wedding gift.
      2003 Rover 75 by Bornite Identity, on Flickr
      2003 Rover 75 Club SE. AX53 BFA. This is where my career as a serial car buyer really began. Ignoring all of the warning signs I decided to press a K Series into a daily 100 mile commute, which it did with aplomb. This wasn't actually the car I set out to buy, the one I'd agreed to buy OVERHEATED ON THE FORECOURT whilst I was doing the paperwork. Consequently I couldn't leave fast enough and bought a different car later that day.
      2004 Toyota Avensis T30-X by Bornite Identity, on Flickr
      2004 Toyota Avensis T3-X. KT53 DWZ. Sensible head back on, I decided to get back into something I trusted when my 3rd son was born. This was a lovely car, but not without its problems. The VVTi oil burning issues are well documented and do frequently occur. Ironically, this was less reliable than the Rover it replaced! Despite fearing the worst and 3 months off the road, the new owner has just MOTd it.
      1999 Toyota Avensis SR by Bornite Identity, on Flickr
      1999 Toyota Avensis SR. V263 GDP. Back into bangernomics territory again. The last MK1 Avensis I had was the best car I'd ever had, so I hoped to replicate it with another T22 Avensis. This one came up for sale in my favourite (and rare) colour with a numberplate sequential to my previous car - so it was meant to be. I still have this now, and tomorrow it will tick around to 185,000 miles having been bought by me at 100,500.
      Side Bitches
      1974 Morris Mini 1000 by Bornite Identity, on Flickr
      1974 Morris Mini 1000. GEL 517N. Well, I always wanted one - and was young, free, single and well off at the time (2003). A memorable trip to buy it when I called my new girlfriend by my ex girlfriend's name 20 miles into a 200 mile weekend away. She's never forgiven or forgotten but we're still friends. Oh - and married.
      1977 Ford Capri II GL by Bornite Identity, on Flickr
      1977 Ford Capri II 1600 GL. SMY 675R. I can't remember why I bought this, other than I thought it'd be amusing. It was bought from Norwich for £350 and was perfectly well behaved for the 8 months that I had it (other than a flasher unit expiring). I remember being shocked just how much the windscreen would ice up inside, and duly sold it in November to a guy who was going to drive it daily! It's still alive and now, apparently, black! (Update - it's now silver!!!)
      1989 Volvo 340 DL by Bornite Identity, on Flickr
      1989 Volvo 340 DL. G67 AVN. I bought this for £80. Unbelievable. It was utterly bloody perfect. I wanted to do a banger rally which is why the guy gave it to me so cheap. I'm still yet to do that rally, but no longer have the car. I sold it for about £300 to a family who were clearly down on their luck who, I hope, still have the car.
      1996 Toyota Granvia by Bornite Identity, on Flickr
      1996 Toyota Granvia. N775 JEV. My wife and I decided to increase our numbers further and, with our 4th son on the way, larger transport was required. We quickly realised you can either have 4 children and no apparel, or apparel and no children. After trying a very tired Mercedes Viano, the Granvia was found for 1/4 of the price and it's still here 2 years later. I can safely say that we'll never sell it - it really is another member of the family.
      1993 Mercedes 190e by Bornite Identity, on Flickr
      1993 Mercedes 190e. L795 COJ. I've admired these cars since I was a child. In fact, one of the very few toy cars I still have from my childhood is a Mercedes 190e. Regular readers of "Memoirs from the Hard Shoulder" will know what a PITA this car has been since day 1, but I get the feeling it's a keeper. We'll see!
      1983 Ford Sierra Base 1.6 by Bornite Identity, on Flickr
      1983 Ford Sierra Base. GVG 510Y. Not explicitly my car, but it should be documented here for reference. Oh - and the V5 is in my name. The story is online for all to read as to how five of us acquired what is believed to be the only remaining Ford Sierra Base. Make a brew and read it, it's a fantastic story.
      1982 Ford Sierra L by Bornite Identity, on Flickr
      1982 Ford Sierra L. LCR 503Y. I accidentally won this on ebay for £520. Upon reflection, I shouldn't have sold it - but short stop of saying I regret it. I could never get truly comfortable driving it and, in fairness, I could scratch my Sierra itch with the base if I wanted. Sold it at a stupid profit of £1250. It is believed to be the oldest remaining Ford Sierra in the UK.
      1979 Volvo 343 DL by Bornite Identity, on Flickr
      1979 Volvo 343 DL. DBY 466T As you'll see above, I'd had a 360GLT as a younger lad and fancied one of these earlier cars. The variomatic is, frankly, terrible but amusing. This car has just 8000 miles on the clock and inside was absolutely timewarp. Sadly, the huge bill for the Mercedes 190e cylinder head rebuild meant I had to sell this car shortly after acquiring it. Since then I've had a bit of money luck, and now realise I didn't need to sell it after all. Typical.
      I think that's it. My arthritis is playing up even more now. I've left out a few cars that were actually my wife's, but if I find pictures will add them in at a later date. I'll run this as an ongoing thread on cars and what's happening.
      Current SitRep:
      Purple Avensis: Just about to click over 185,000. Minor drama this week when an HT lead split but otherwise utterly fantastic, fantastically boring and boringly reliable.
      Granvia: Just done 1000 miles in a month around Norfolk, 6 up with suitcases. 31mpg achieved on the way up which is good for an old tub with a 3.0 Turbo Diesel on board. ODO displaying 175,000 which is a mix of miles and kilometers. Say 130,000 miles for argument's sake.
      Mercedes: Being a PITA. It's had the top end completely rebuilt after the chain came off. Now needs welding to pass another MOT and the gearbox bearings are on strike. It's about to go into the garage for winter until I can stomach it again. 151,000 miles on the clock.
      Sierra bASe: Still on sabbatical with AngryDicky who only took it bloody camping in cornwall! Legend.
    • By snagglepuss
      Didn't bother to do a collection thread as was a 30min drive so fairly boring.
      Yesterday I won this
      Which is effectively going to replace the civic and the xantia.
      Picked car from a bodywork guy in foreign lands (Yorkshire).
      First thoughts are that I think it has been sitting for a while but started straight up. Apart from service bits and potentially a cambelt everything seems to be good with it. Comes pre dented.
      Current is differently abled tax so that will need to be changed.
      Windscreen has small crack in passenger side.
      Runs really cold, this is after 30 miles of motorway
      Mind you it honks. Properly honks. Not as much as the focus I got from Shadow but not far off.
      List of jobs
      Oil change
      Spark plugs
      Air filter
      Thermostat
      Rear boot struts
      Front discs and pads
      Cam belt plus bits
      Ball joints
      Drop links
      Rear anti roll bar bushes
      Stereo code
      Windscreen crack
      Swimming pool emptied from boot wheel well
      Seal rear light clusters
      And a big does of cleaning
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
