dollywobbler
Dollywobbler's Foxy little number
5 minutes ago, dollywobbler said:
Thanks folks! Had a bit of a break, then did a bit more fettling, then went for another drive.
17th June 2019
D9SkAxyXYAEjW2E.jpg:large
18th June 2018
you do a good job at rescuing and recommissioning fibreglass cars :) (love the hubnut in white on the side of the body LOL)
(did that lorry ever find its contact lense? :mrgreen: )
Share this post
Link to post
1 hour ago, Skut said:
Well done on pass. A30 35 wheels same fitment and size as an Imps are they not.
Imp is 12" A30/35 are bigger 14" if my memory serves me right
Share this post
Link to post
17 hours ago, Noel Tidybeard said:
so proper mini wheels will work
The offset is quite a bit out. Would need about 3/4" spacers on the back or else the tyres would be rubbing the leaf springs.
Share this post
Link to post
Today, I put about 50 miles on the Fox, including a trip to the new unit to replace diff and gearbox oil. So nice to have working space around the car! The Fox is a big hit with the birds too...
The diff seemed to have no oil in it whatsoever, while the gearbox definitely took more than it dropped. Worth doing then!
She's not going too badly, but I still need to try and set the ignition timing properly. I have at least three strobes, and can't currently find any of them...
60mph is just about possible, but it's hard work, and the temp gauge sits right at the top of 'I'm not scared just yet' when pushing on. Some tweaking to do I think. On the plus side, you don't really need to slow down much for bends it seems, even on shit tyres...
Share this post
Link to post
no oil in the diff? good thing ya checked!, could of been a nasty surprise (especially if the diff sized solid or something at 60)
have to say the fox makes a nice engine noise :)
Share this post
Link to post
Yeah, I've had that happen in an LDV Convoy, it was "exciting" to say the least.
We're not actually 100% certain if the gearbox seized first and detonated the diff or vice-versa...a significant portion of both wound up strewn over about 1/4 of a mile of the A90 just north of Dundee however.  The total lack of oil on the road was quite obvious and most likely was a major factor we think.
Share this post
Link to post
All seems happy enough thankfully. Tomorrow, I need to try and get to the bottom of why the engine feels so flat. It's going to be a long old drive if she doesn't perk up a bit. Given the gearing and the theoretical power, I was expecting her to sit noisily but happily at 60.
Share this post
Link to post
17th June 2019
18th June 2018
Outstanding, truly outstanding.  Love it.
Share this post
Link to post
These engines in my experience are nippy,eager little things and it's the overall gearing that limits their speed rather than their modest CC/BHP.
Could it be running a bit weak on the fueling side of things too.
Did the MOT guys give you a paper copy of its test emissions result ?
Share this post
Link to post
It was just within emissions limits, so definitely not weak. However, I have just discovered that I'm only getting about three-quarter throttle with the pedal mashed into the floor. That'd do it! Timing tweaks this morning have improved matters, but I am now trying to work out how to rid myself of free play so the throttle pedal actually does what it should.
Share this post
Link to post
I'll see what I can do. Probably not today, but no rush.
More importantly, I did remember that I entirely forgot to grease the propshaft while I conveniently had the Fox in the air for the transmission fluids yesterday. That has now been addressed. New tyres should arrive tomorrow.
With the throttle now actually opening fully, this is a car transformed! Sounds proper GRRRR and has a decent turn of speed for a little'un. Thank goodness I spotted that before setting off. I guess it was in Eco mode before...
Share this post
Link to post
Today began with tyre swapping - once I managed to locate the tyres. Had them shipped to my local garage, but they just abandoned them at something looking a bit like a garage because it had a petrol pump outside...
These are 155/80 R12s to replace the 145/70 R12. Gets me a few more MPH per RPM, has the speedo under-reading nicely and should benefit ride if not handling. BIG profile!
Then came back home and gave the ol' girl an oil change. It was quite black, presumably because there has been a lot of choke-use and not so many miles.
Yesterday's video action if you care for such things.
So, that's it. I just need to cram everything I can into the Fox, with the long journey to Bromley starting tomorrow (not today as I'd originally planned). Temp gauge still a little high for comfort, so I reckon a new rad is going to be needed at some point. I hope I don't encounter that point over the weekend...
Share this post
Link to post
Looks tremendous fun. As the bonnet is detachable you could always take it off Roadkill style to lower underbonnet temps if desperate enough. As you say not much reason to buy one over a Metro van new other than longevity. Still a body that has no theoretical lifespan versus a body with a 7 year lifespan is better value long term.
Share this post
Link to post
The hoon back home looked fun. Hopefully the new boots make the journey to Bromley a little more relaxing. Distinctive looks + Peppy buzzy engine + musical gearbox = vehicle with character in droves.
Re: wheels - pretty sure the wheels you currently have on Foxanne are AustinRover era Mini 12 inchers with original size tyres for a base/City model. Maybe you could get away with a nice set of wheels from a Mini?
Share this post
Link to post
31 minutes ago, LightBulbFun said:
Awesome stuff :)
I remember in one video you mentioned the fan belt being a bit loose, and as such it was slipping somewhat, did you end up tensioning that up? :)
Yes. Finally did that the other day. Can't remember if I filmed it...
Wheels are apparently Vauxhall Viva HA, though it wouldn't surprise me if they've been replaced by Mini wheels. I did note that the clearance to the front panel is not great with the new rubber...
Share this post
Link to post
Having got the Fox packed, I actually had some free time. So I decided to do something about this.
That's typically where the gauge would sit if I had the temerity to exceed 50mph. Not great.
Found some flushing fluid, which is handy, as I'm fresh out of cola. Icky!
Then went for a test drive up the Shitefest Cymru test hill, fully laden, foot to the floor.
That's better! It did go slightly higher than that, but only slightly. Result!
Share this post
Link to post
  • Similar Content
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By vulgalour
      As tradition dictates, an thread.
      It all kicked off here: http://autoshite.com/topic/34152-citroen-bx-17rd-for-sale-sale-on-hold-as-its-done-a-citroen-the-little-bastard/
      Lorry is booked for collection tomorrow and a 340ish mile round trip awaits.  It will be a long, but rewarding, day.  No live collection updates because I live in the olden times and even if I didn't, I'm not sure I could be entirely arsed.
      I am looking forward to meeting Dean-numbers, his collection of wobbly French cars and, of course, Bleriot the BX.  It will probably be too dark to do anything when we get back on Friday so I suspect Saturday I'll be up bright and early to get stuck in and see just what I've let myself in for.
    • By scdan4
      That bit hiding up behind the air filter and infront of the turret
      made a prolonged, loud, farty vibratey noise (loud enough to be clearly audible in the cabin with the radio on) twice today, both times it did it the nose was pointing down a steep hill and we had just parked and turned off the engine.
      It goes on for best part of a minute, so managed to track it down. Initial impressions are fuck knows what it is but it's clearly been bodged in the past. The yellow hose has clearly been disconnected sometime, by someone, for some reason, somewhere.
      Thats the blighter.
      Does someone want to tell me why it's blowing raspberries at me?
    • By danthecapriman
      Thought I'd start a thread about my old Capri since it's now reached it's turn in the que to receive a bit of attention.
      I've actually had this since 2001, it's an early mk2, on an M reg 1974. Being an early car it's still got mk1 rear axle and single acting type rear brake set up aswell as a few other minor differences from later cars just to use up remaining mk1 parts.
      It started life here in the Portsmouth area and doesn't seem to have ventured far since.
      Originally a stardust silver 1.6 L poverty model, which means virtually sod all regarding luxuries. Basic 2 pod dash with black 'crackle' finish facia, no radio, no sun roof or vinyl roof, not even a centre console!
      When I got to it unfortunately it had suffered severely from serious rust and latterly a vandal attack, having it's door and rear quarter panel booted in.
      Over the next couple of years I got it sorted and a cheap re paint into roman bronze, which was a favourite colour of mine at the time. For the first year or two it seemed fine but since then things have deteriorated.
      The respray wasn't good! It's thin in places and started to micro blister in various places, worst of which is all over the bonnet. The same bodyshop also did a bit of the bodywork I hadn't finished which was also pretty poor in some places.
      It's always been a great driver and never struggles at mot time so I just kept on using it and doing nothing more than collecting parts now and again with a view to sort it one day.
      It's also gained a few non original extras over the years like a higher spec wood effect 2 pod dash facia (which I like more than the original), a short console, brown interior instead of the utterly fucked black original, 'laser' 4 spoke alloys and a few other things.
      Anyway, fast forward to last weekend, when I dusted it off after winter and noticed various areas of new rust coming through or older rust that's gotten worse. So the decision was made to go for a professional resto job now before I end up finding something else to distract me (like big american cars with knackered engines!).
      1974 Ford Capri BBK244M by Dan Clark, on Flickr
      Here it is as it currently stands. Looks ok from a distance but the reality is very rough around the edges and the paint is so bad in places it's becoming embarrassing!
      IMG_0509 by Dan Clark, on Flickr
      And the interior which I'll be re trimming into black leather at some point after the body works done.
      It's been taken to the same place that did my Mercury's engine rebuild, since they did such a good job and they seem a good professional bunch.
      I dropped it off Monday afternoon for a thorough check over to build up a list of work and get a rough quote.
      Today I heard back from them.
      Good news so far, I suppose. It is as solid where it counts as I thought it was. Chassis is fine, original strut tops fine, most of the back end is solid and just needs a few repairs here and there.
      The worst is the bottom of the windscreen surround due to the wrong seal being used and then fitted badly causing leaks. Inner sill to A post bottom corner very scabby, front wings pretty crap, and various paint defects etc.
      The engine is fine, compression all in tolerances. Suspension needs work, and some brake pipes are getting quite rusty. So far so good and no surprises!
      There's still more checking to do over the next few days but it sounds alright so far.
      This work should be made a bit easier by having a lot of panels and parts to fix things already. The big find being a new unused pair of front wings. Very hard to find mk2 items now, though I did have to pay for them!
      The plan here is to make the car solid, reliable and good looking. I'm not making a show car or going too mad as that stuffs not my thing and if it was I'd start with a better more original car.
      Some of the later add ons will be ditched like the mk3 boot spoiler that I hate! And return it to more standard looking mk2 as it should be. No go faster mods or anything like that.
      The main priority is to get the body sorted and painted properly (engine out job and everything) then maybe a bit of mechanical work as needed.
      The original idea was to re paint back into original stardust silver, but having thought about it I'm leaning more towards another favourite Ford colour of the era, Miami blue metallic, which is a lovely colour! Any opinions?
      This will be another expensive project but not one I think I could do at home on the drive and do justice to, so I'd prefer to farm it out and get it right this time. It also means I can carry on working on my Transit and Granada at home without another distraction!
      For anyone whose interested I'll try to update this now and then as things progress. I'll also try to get the old pics of the car from when I got it so you can see how rusty it was! Bear in mind though that I paid £100 for this car in 2001 with MOT and tax! Try doing that now.
      I'm sure this is going to be worth the expense, not that I'm even considering selling it of course but I've had it so long I kind of feel obligated to do right by the car in a weird way!
