High Jetter Posted March 25 Share Posted March 25 Sounds like a shite day, Sat tomm Link to comment Share on other sites More sharing options...
dozeydustman Posted March 26 Author Share Posted March 26 5 hours ago, High Jetter said: Sounds like a shite day, Sat tomm I work Saturdays, and not on overtime 😕 Link to comment Share on other sites More sharing options...
mitsisigma01 Posted March 26 Share Posted March 26 I've got 4 of the fkrs to get off a Focus , original key was fkd, new one made of chocolate,also now fkd . Drills, hammer , chisels and sockets now being gathered 🤞 Link to comment Share on other sites More sharing options...
Crackers Posted March 26 Share Posted March 26 I saw this, this morning, from a distance. Looks nice. Link to comment Share on other sites More sharing options...
dozeydustman Posted June 21 Author Share Posted June 21 No gas in it. Was working ok-ish until a couple of weeks ago. I just hope a pipe hasn’t blown Link to comment Share on other sites More sharing options...
dozeydustman Posted June 21 Author Share Posted June 21 I now have aircon. 10g of refrigerant extracted, no leaks and 650g refrigerant pumped in. Lovely and cool now. CaptainBoom, rainagain, AnnoyingPentium and 1 other 4 Link to comment Share on other sites More sharing options...
horriblemercedes Posted June 21 Share Posted June 21 I hope it stays that way! I'm hoping a regas fixes mine, but I'm not doing it until after the MOT on the 4th of July Link to comment Share on other sites More sharing options...
dozeydustman Posted June 21 Author Share Posted June 21 7 minutes ago, horriblemercedes said: I hope it stays that way! I'm hoping a regas fixes mine, but I'm not doing it until after the MOT on the 4th of July It stopped working on way back from taking my stepdaughter home, I also noticed the external air temp sensor had dropped from 27 to -17 degrees C. Wondering if that’s anything to do with it. Link to comment Share on other sites More sharing options...
Jazoli Posted June 21 Share Posted June 21 52 minutes ago, dozeydustman said: It stopped working on way back from taking my stepdaughter home, I also noticed the external air temp sensor had dropped from 27 to -17 degrees C. Wondering if that’s anything to do with it. Yup it will be. Link to comment Share on other sites More sharing options...
dozeydustman Posted June 21 Author Share Posted June 21 New external temp sensor ordered. See if that cures it Jazoli 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted Wednesday at 03:27 PM Author Share Posted Wednesday at 03:27 PM Definitely the temp sensor. Started up after work and it read 27, A/C ice cold. By the time I’d got to Midhurst outdoor temp was apparently -4 and it was trying to warm me up! Link to comment Share on other sites More sharing options...
Talbot Posted Wednesday at 03:40 PM Share Posted Wednesday at 03:40 PM Most modern* AC systems make use of the outside air temp sensor and a sunlight detector on the dashboard to adjust the amount of cooling being generated. Many systems can cope with the loss of one or either of these sensors, but some use them as gospel and turn off the AC if it thinks it's not necessary, even if the interior car sensor is at 30c and you're requesting 20c. Clearly the Saab/Vaux system is one of those. The good news is that the sensor is often an industry standard NTP sensor, meaning you don't need a £30 sensor from a dealer, you can use a 99p sensor from ebay and splice it in. Do check first tho! Link to comment Share on other sites More sharing options...
dozeydustman Posted Wednesday at 04:19 PM Author Share Posted Wednesday at 04:19 PM 38 minutes ago, Talbot said: Most modern* AC systems make use of the outside air temp sensor and a sunlight detector on the dashboard to adjust the amount of cooling being generated. Many systems can cope with the loss of one or either of these sensors, but some use them as gospel and turn off the AC if it thinks it's not necessary, even if the interior car sensor is at 30c and you're requesting 20c. Clearly the Saab/Vaux system is one of those. The good news is that the sensor is often an industry standard NTP sensor, meaning you don't need a £30 sensor from a dealer, you can use a 99p sensor from ebay and splice it in. Do check first tho! I got a good tested used one from Neo Brothers Link to comment Share on other sites More sharing options...
