Saabnut Posted July 1, 2019 Share Posted July 1, 2019 There is no rush on the cam tool, I am not planning on using it any time soon, so no need for the guilts! ? dozeydustman 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted August 17, 2019 Author Share Posted August 17, 2019 Today's tinkering has been caught short as the wife needs the Saab and madam is going out with who/whatever she is currently dating meaning some of my jobs scheduled for today are no longer on the cards and I'll be left to my own devices with sod all to do instead. At least I got the EGR changed on the Saab Spot the difference. Despite cleaning the old one before I did the MOT it sooted up very quickly again and the solenoid has failed. £29 part from eBay WCPGW? Borrowed a code reader from workmate, I'll have to see if I can get one of these for myself as it's one of very few that seem to work on the car. Cleared. £10 splash & dash and a real good rag up to Rowlands Castle and back has restored performance, a re-gen occurred (first since mid-June) which only lasted about 15 mins instead of the 30-45 before I sorted the manifold, and minimal smoke on acceleration means we're good for a little while yet. Tomorrow's plans have been cancelled, so weather dependent I'm hoping I can do the cam belt etc. Though I bet I end up needing to order more parts Jim Bell and The Moog 2 Link to comment Share on other sites More sharing options...
dozeydustman Posted August 17, 2019 Author Share Posted August 17, 2019 Forgot to add, getting the air-con working resulted in it draining the battery. This requires some thinking. Jim Bell 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted September 1, 2019 Author Share Posted September 1, 2019 Some investigation this weekend during an unexpected trip to see my very ill nan in Kent and resultant impromptu overnight stay with my parents, dad and I did some investigations of the air con not working this morning and the intermittent lack of power that has plagued me since a week or so after the MoT. The new EGR had worked itself loose despite being torqued up to what the HBOL says is correct. Redone the bolts up to just nipped tight with a dab of thread lock should prevent this again. Injector No.4 wiring had worked itself loose; I think it was still connected but dad lockwired this in place while I was nipping up the EGR bolts. Did a code read, P0400 is still showing, and comes back immediately after clearing as does the EML; I do get that EGR 'Whoosh' every now and then so I would say the valve is at least partially working. Doing some googling it could be anything in the exhaust system that's causing this. There's also a lot of turbo lag so thinking waste gate is knackered? I'm going to test the EGR off the car anyway just to make sure the solenoid is working; it's brand new but that doesn't mean anything with car parts now. Air con. The low tension side of the relay isn't switching at all. The LT out from the relay goes to the switch via something; the cabin switch does make the dash display AC OFF so I don't think it's that. The annoying thing is it worked for the first 3 months I owned the car and it means it's a dicky connection behind the dashboard or in the engine bay. TBH, I may just wire a switch into the relay's socket which is mounted in the dash somewhere so I can switch the air con on and off inside the car. The clonking noise from the O/S F still needs investigation. I'm off later this month for my 3rd wedding anniversary so what better way to 2 days of the week of than tinkering with my old shitheap (wife only has 3 days off!) Jim Bell 1 Link to comment Share on other sites More sharing options...
SiC Posted September 1, 2019 Share Posted September 1, 2019 Do you have climate control? If so, unlikely Aircon to be a connection behind the dash as the front electric module is what does the switching over the CAN network. I wouldn't wire up permanently as it needs to cycle the compressor as it reaches max pressure, drops and then reruns the compressor. How are your vacuum lines? If not replaced, they're possibly perished in the engine heat and leaking. Get a length of silicone pipe off eBay and replace them if necessary. Injector connector can be had not too expensive either. A repair kit exists as the injector connector for cyl 3 usually fails on these. Or just carry on tie wrapping it. Link to comment Share on other sites More sharing options...
jonathan_dyane Posted September 1, 2019 Share Posted September 1, 2019 Is it that the relay isn’t being earthed? The earth is ecu switched so if this is the case it means that either there is another fault causing the ecu to disengage a/c or for some reason it needs activation on Tech 2. Link to comment Share on other sites More sharing options...
dozeydustman Posted September 2, 2019 Author Share Posted September 2, 2019 16 hours ago, SiC said: Do you have climate control? If so, unlikely Aircon to be a connection behind the dash as the front electric module is what does the switching over the CAN network. I wouldn't wire up permanently as it needs to cycle the compressor as it reaches max pressure, drops and then reruns the compressor. How are your vacuum lines? If not replaced, they're possibly perished in the engine heat and leaking. Get a length of silicone pipe off eBay and replace them if necessary. Injector connector can be had not too expensive either. A repair kit exists as the injector connector for cyl 3 usually fails on these. Or just carry on tie wrapping it. Yep this car has automatic climate control, I've found online that holding in recirculate and auto is supposed to reboot the system, though it's made no effect. I think I'll have to get it Tech-2 looked at. Vacuum lines were in good condition when I did the manifold swap, now you've mentioned them I'm wondering if I've got them swapped round the wrong way to the reservoir on the back of the manifold. I'll take a look later this week. Could also be that they've come off, but I can't hear any hissing noises from under the bonnet. 15 hours ago, jonathan_dyane said: Is it that the relay isn’t being earthed? The earth is ecu switched so if this is the case it means that either there is another fault causing the ecu to disengage a/c or for some reason it needs activation on Tech 2. Given that every now and then the whole car has an electrical hissy fit it wouldn't surprise me if the ECU has an intermittent fault. Sometimes the driver's door won't lock when the zapper is pressed, then other times the front passenger door won't lock; it'll have a moment where it will default the trip computer to 40.7MPG and 150 miles of range irrespective of tank level, then the next time it'll be back to what it was beforehand. I'll have the local independent Saab specialist have a look and see if it's been deactivated (and probably get bumraped in the wallet for the pleasure). Jim Bell 1 Link to comment Share on other sites More sharing options...
SiC Posted September 2, 2019 Share Posted September 2, 2019 The software in these cars is pretty buggy. Often problems could be resolved by disconnecting the battery for a couple of minutes to reboot it. Mine needed it every so often as it sometimes wouldn't go to sleep on key out. Door lock modules failing TADIS. My front passenger side was getting very intermittent not long before it got written off. Mine would also forget the trips MPG on key out and revert to a previous startup reading next time. Again TADIS. Buggy software. MPG computer is separate from the engine ECU, but works out it's reading from the ECU over the can bus. Also wildly optimistic at times. I could get it reading 60mpg, but actually only did 48mpg when I calculated it from fuel fill. dozeydustman 1 Link to comment Share on other sites More sharing options...
Stanky Posted September 2, 2019 Share Posted September 2, 2019 Yeah mine was a right old carry on with the door lock modules. There are 3 working ones in the box you collected last week, but I was never convinced it wasn't the ECu not sending the right message to the modules rather than the modules themselves, as the issue was intermittent. I got to the point that I knew one didn't seem to like hot days, and one didn't like cold days, and it was incredibly rare for all 4 to work at the same time, but lived with it. Replacement is actually quite easy once you've done it once, the module comes out the door handle hole on the outside, but for christ sake make sure it works before refitting the door card and closing the door. Often my DTE would read zero miles or the MPG would go to zero too. It'd recover but as SiC says, buggy software. Considering how little it actually has to do its a bit shit - A linux PC of equivalent vintage would perform way more varied work way more reliably, but then thats the evil influence of GM I suppose. dozeydustman 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted September 2, 2019 Author Share Posted September 2, 2019 2 hours ago, SiC said: The software in these cars is pretty buggy. Often problems could be resolved by disconnecting the battery for a couple of minutes to reboot it. Mine needed it every so often as it sometimes wouldn't go to sleep on key out. Door lock modules failing TADIS. My front passenger side was getting very intermittent not long before it got written off. Mine would also forget the trips MPG on key out and revert to a previous startup reading next time. Again TADIS. Buggy software. MPG computer is separate from the engine ECU, but works out it's reading from the ECU over the can bus. Also wildly optimistic at times. I could get it reading 60mpg, but actually only did 48mpg when I calculated it from fuel fill. 1 hour ago, Stanky said: Yeah mine was a right old carry on with the door lock modules. There are 3 working ones in the box you collected last week, but I was never convinced it wasn't the ECu not sending the right message to the modules rather than the modules themselves, as the issue was intermittent. I got to the point that I knew one didn't seem to like hot days, and one didn't like cold days, and it was incredibly rare for all 4 to work at the same time, but lived with it. Replacement is actually quite easy once you've done it once, the module comes out the door handle hole on the outside, but for christ sake make sure it works before refitting the door card and closing the door. Often my DTE would read zero miles or the MPG would go to zero too. It'd recover but as SiC says, buggy software. Considering how little it actually has to do its a bit shit - A linux PC of equivalent vintage would perform way more varied work way more reliably, but then thats the evil influence of GM I suppose. Disconnecting the battery only seems to cure the jam sensor in the electric windows when they play up! The MPG calculation isn't far off what I work out doing some basic number crunching - ±1-2 mpg most of the time. Door locks tend to give out when it's very very hot, so I'll have a ferret about in the doors on my few days off later this month, provided swapping the cam belt etc doesn't get over-involved with too much bother. I've had the door cards off before to replace window switches, while I'm at it I'll check the door shut fuse box for blown fuses as a lot of this has appeared since the mirror fold button stopped working for no reason whatsoever. Could be pure co-incidence - electrics on this car are even more French than a French car. Jim Bell 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted September 19, 2019 Author Share Posted September 19, 2019 Spent some time this afternoon looking for the clonking noise that got suddenly worse on the way back from taking the Mrs over to Bognor this afternoon. Jacked car up, nothing that I had replaced has lost its torque save the o/s/f calliper, even then it only needed a tiny nudge to get it up to its full 155Nm. There's a little free play at the strut top so they may need changing for the next MoT. As I lowered the car down I heard a clonk from inside the engine bay. O/S engine mounting had worked itself loose. It's all torqued up no and there's no undue rattles now save a light knock from the strut top mount. Performance has been restored by remaking the EGR connection; I will look at blanking this off at some point, especially as I've got through 3 in 4 years of owning the car. I'm just waiting for the alternator belt to arrive then I can change the cam belt, this may have to wait until next week; I need the car on Saturday all day, and I can't risk something going wrong or needing another part if I start the job tomorrow. Jim Bell 1 Link to comment Share on other sites More sharing options...
Fraz Posted September 20, 2019 Share Posted September 20, 2019 Re the EGR valve constantly breaking. I’ve had a number of these engines all with constant EGR issues requiring them to be stripped and cleaned. I found a guide guide online which shows you how to strip and clean the black electrical solenoid of the EGR which previously I’d never delved into. It required a 4mm drill bit and 4mm punch which you used to hammer out it’s internals, clean them and de-rust it and put it back together. Both times they ran like a dream afterwards. For some time. Might be worth a google and try and try next time the EGR sticks . dozeydustman 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted September 20, 2019 Author Share Posted September 20, 2019 2 hours ago, Fraz said: Re the EGR valve constantly breaking. I’ve had a number of these engines all with constant EGR issues requiring them to be stripped and cleaned. I found a guide guide online which shows you how to strip and clean the black electrical solenoid of the EGR which previously I’d never delved into. It required a 4mm drill bit and 4mm punch which you used to hammer out it’s internals, clean them and de-rust it and put it back together. Both times they ran like a dream afterwards. For some time. Might be worth a google and try and try next time the EGR sticks . That is useful to know, I've got one sitting in the garage that I took off recently and I know it works (or tries to) when I've put 12v across the terminals. Link to comment Share on other sites More sharing options...
Fraz Posted September 20, 2019 Share Posted September 20, 2019 https://www.vectra-c.com/forum/showthread.php?45867-how-to-clean-z19-egr-valve-(proper-method) dozeydustman 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted September 20, 2019 Author Share Posted September 20, 2019 Many thanks @Fraz, I'll put this to good use on the spare EGR I have in the garage. Link to comment Share on other sites More sharing options...
dozeydustman Posted September 28, 2019 Author Share Posted September 28, 2019 As I will have an unexpected new chariot within the next week or so, my ownership of this beastie must come to an end. I will certainly miss her as she's done me well over the last 4 and a half years, and if I come across another cheap Saab which isn't fucked, I'll certainly show interest. I'm thinking it'll make a great WBOD for someone; unsure of price just yet, but with 6 and a half month's MoT, a few spares and a roof rack I purloined off Stanky it will do someone a good turn. For Sell details etc to follow as I need to get the private plate retained and give it a bloody good clean, valet and photographs. Link to comment Share on other sites More sharing options...
Wingz123 Posted September 28, 2019 Share Posted September 28, 2019 Have pmd Link to comment Share on other sites More sharing options...
dozeydustman Posted September 28, 2019 Author Share Posted September 28, 2019 37 minutes ago, Wingz123 said: Have pmd Replied Link to comment Share on other sites More sharing options...
dozeydustman Posted October 1, 2019 Author Share Posted October 1, 2019 Rightyho. With a new smoll green car incoming soon, I need to sell on the Saab. MoT mid-may 2020 I've seen similar ratbags on Bumtree, Faceache marketplace etc for around £300. How does £250 to a shiter sound for a WBOD? May Roffle at £4.50 a ticket/£8 for two if there's enough interest. Will be available once the private plate is back on retention, which should be no later than middle of the month. Will keep taxed until end of October, will be kept in the garage. 207,500 miles on the clock The good: 48-60mpg (indicated) Half-leather interior (Vector trim) IN BEIGE Comfy long distance cruiser Cruise control works 7 months MoT New EGR All previous faults have been dealt with re: charging and EML. Comes with about £100 of new spares, a fitted roof rack and a box of bits and pieces Stanky salvaged from his since departed 9-3 Parrot hands free kit. Fair amount of history and service records. The Bad: Cup holder is broken battered and bruised Air con doesn't work Sometimes the turbo lags, sometimes it's fine. Doesn't bring up a fault code so possibly a vacuum line (I may look into this) Parrot kit is a bit crap. Answers on a postcard please. Photos to follow once it's stopped sodding raining so I can vacuum the interior! Link to comment Share on other sites More sharing options...
Floatylight Posted October 1, 2019 Share Posted October 1, 2019 Could be on for this depending on cost of sorting C4 Picasso Turbo woes from the garage on Thursday.. Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
dozeydustman Posted October 1, 2019 Author Share Posted October 1, 2019 Forgot to add - Location Chichester, West Sussex Link to comment Share on other sites More sharing options...
bangernomics Posted October 1, 2019 Share Posted October 1, 2019 4 randoms including 46 please Link to comment Share on other sites More sharing options...
Floatylight Posted October 1, 2019 Share Posted October 1, 2019 Two randoms please..Sent from my Moto G (5) using Tapatalk Link to comment Share on other sites More sharing options...
dozeydustman Posted October 1, 2019 Author Share Posted October 1, 2019 - - - - bangernomics - - - - Floatylight - - - - - - - bangernomics - - TheDoctor - - - bangernomics - - - - - floatylight - - - - - - - - TheDoctor - - - - - bangernomics - - - - - - - - - - - - - Just to get the ball rolling Link to comment Share on other sites More sharing options...
DoctorRetro Posted October 1, 2019 Share Posted October 1, 2019 Yeah, give me a couple of randoms please. Depending on the MOT result on Friday, it could be more. Link to comment Share on other sites More sharing options...
bangernomics Posted October 1, 2019 Share Posted October 1, 2019 Bumpage for townmate roffle. Link to comment Share on other sites More sharing options...
mitsisigma01 Posted October 2, 2019 Share Posted October 2, 2019 Stanky, get it bought! Link to comment Share on other sites More sharing options...
dozeydustman Posted October 3, 2019 Author Share Posted October 3, 2019 The full 4sell/wroffle page can now be found Here compleat with photographic reproductions. Next update to this thread will be when the car is sold/won with (hopefully) a lucky shiter grabbing the keys off me! Jim Bell 1 Link to comment Share on other sites More sharing options...
Floatylight Posted October 21, 2019 Share Posted October 21, 2019 I am now the custodian of this fine vehicle following a deal being struck with[mention=5176]gadgetgricey[/mention] you can follow it's progress (or not) over on my thread https://r.tapatalk.com/shareLink/topic?url=https://autoshite.com/topic/33908-floatylights-fleet-saab-shanigigans-picasso-plight/&share_tid=33908&share_fid=68430&share_type=t&link_source=app Sent from my Moto G (5) using Tapatalk Jim Bell 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted February 23, 2022 Author Share Posted February 23, 2022 I done a buy mercedade, Sigmund Fraud, somewhatfoolish and 21 others 24 Link to comment Share on other sites More sharing options...
