dozeydustman Posted February 19, 2019 Author Share Posted February 19, 2019 Have you tried asking for advice on www.uksaabs.co.uk? I know nothing about the diesels but your swirl flap fault is common and loads of people have fixed it and the info is on there somewhere.I have searched UK saabs without actually joining, plus several interwebs searches about the JTD type engine and swirl flaps in general and it could work then again it might not. 200k engine. Only other car I’ve owned with a similar mileage was a Mk3 golf turbo diesel and that didn’t smoke at all Link to comment Share on other sites More sharing options...
dozeydustman Posted March 23, 2019 Author Share Posted March 23, 2019 Brakes started grinding on this last weekend, offside rear was the culprit. Thankfully have a garage now so can work on a nice level* surface for all sorts of jobs. Hmm they look a little thin Yep, they're spagged. Slider pins were very grubby and difficult to remove from the carrier so much faffing ensued. Mrs wanted to do housework instead of help me (I don't blame her), and stepdaughter is at work until 2pm. Took nearly half an hour to get both the slider pins out. Pukka rewind tool employed All reassembled with plenty of copper grease on the backs of the pads and the slider pins. Very slippy now so shouldn't drag or bind as it was doing. Refitting is blah blah Nearside for comparison, though the piston was a lot more difficult to wind back in for some unknown reason. Wouldn't go in without both the nipple open and hose removed, so I'll have to keep an eye on that. Handbrake needs adjustment now (but I'm done for today with cars, I have gardening to do) Thankfully it looks like a 10 minute job. TL:DR I change my rear brake pads. LightBulbFun and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
tooSavvy Posted March 23, 2019 Share Posted March 23, 2019 GR8 m8 Just been waachinn 'South Main Auto' guy dooinn Camaro reline/full bleed. He has a 'henry hoover' sized gizzmo which takes mains air line and then blows the fluid thru... Eazibleed but he rinsed a GALLON through the reservoir! Oh to be a Pro.... Link to comment Share on other sites More sharing options...
dozeydustman Posted March 23, 2019 Author Share Posted March 23, 2019 It doesn't sort out the emission or random ABS fault, but hey hoe I can deal with that when the time comes. Emissions will be sorted with a good run before the MoT. ABS random fault - pass. I think it's a broken wire or bad connection. Link to comment Share on other sites More sharing options...
dozeydustman Posted March 28, 2019 Author Share Posted March 28, 2019 Having just realised this old crate's MoT runs out in just under a month (I thought it was mid-May) I had a word with dad's tame garage, and they reckon it's worth de-flapping the manifold to sort out the emissions. I know when I've manually moved the flaps with some long nosed pliers the amount of shite coming from the exhaust varies from loads to virtually none when hot. So I now need a cambelt, a flap removal kit and a load of gaskets. If I can do it for under £150 then I'll rewire the rear ABS sensors and bung it through a test. Anyone got a set of timing lock pins I can borrow? GrumpiusMaximus and paulplom 2 Link to comment Share on other sites More sharing options...
purplebargeken Posted March 28, 2019 Share Posted March 28, 2019 You've done a shed load of sorting or trying to sort on this thing, hopefully not too far away now. Link to comment Share on other sites More sharing options...
dozeydustman Posted March 28, 2019 Author Share Posted March 28, 2019 You've done a shed load of sorting or trying to sort on this thing, hopefully not too far away now. I'm considering getting a second hand manifold, performing the flap removal on that then swapping them like for like. Cambelts I've done before, it's removing a high pressure injector system that's got the old sphincter twitching! Hopefully then it's just a case of finding the random ABS/ESP fault. Link to comment Share on other sites More sharing options...
Saabnut Posted March 28, 2019 Share Posted March 28, 2019 Anyone got a set of timing lock pins I can borrow? Yes, I have a set specific for the TDi 1.9 - guess that is what you have (cannot be bothered going through the thread ) If it is of use you are welcome to borrow the kit, guessing you are a long way from Aberdeen so will have to post it to you. dozeydustman 1 Link to comment Share on other sites More sharing options...
J-T Posted March 28, 2019 Share Posted March 28, 2019 Not sure if you're doing the cambelt anyway but it doesn't have to come off to change the manifold. The pump will apparently come off by loosening the retaining nut on the pulley but not removing it. I've been reading up on the same as I've an Alfa 147 with the same engine. New POD 1 Link to comment Share on other sites More sharing options...
Guest Posted March 28, 2019 Share Posted March 28, 2019 Neo Bros do a brand new one for £150. I hate working with Diesel manifolds, that Black stinking sticky gunk is Black,stinking and sticky. https://www.neobrothers.co.uk/intake-inlet-manifold--gasket-saab-9-3-05-12--9-5-06-09-19-16v-diesel-5185-p.asp Christine 1 Link to comment Share on other sites More sharing options...
Guest Posted March 28, 2019 Share Posted March 28, 2019 Not sure if you're doing the cambelt anyway but it doesn't have to come off to change the manifold. The pump will apparently come off by loosening the retaining nut on the pulley but not removing it. I've been reading up on the same as I've an Alfa 147 with the same engine.IIRC, when I replaced the engine and fitted a new manifold to a TTiD, the pulley was held in place with 2 8mm bolts and the pump came off without disturbing the timing or belt. Link to comment Share on other sites More sharing options...
J-T Posted March 28, 2019 Share Posted March 28, 2019 Ah yeh, that's it, you can lock the pulley with 2 of the cambelt cover bolts, then loosen the retaining bolt so the cambelt doesn't need disturbing. I'm pretty sure you can get a brand new Pierburg one for about £130 on ebay (think they were the OE). The one on mine is £350! Link to comment Share on other sites More sharing options...
dozeydustman Posted March 28, 2019 Author Share Posted March 28, 2019 I fully intend on doing the timing belt anyway, it was done Jan 2018 but as there’s a small squeal coming from that side of the engine I think the tensioner is going to give up the ghost as well. One snapped cambelt this decade (Toyota) is enough this decade! Yes, I have a set specific for the TDi 1.9 - guess that is what you have (cannot be bothered going through the thread ) If it is of use you are welcome to borrow the kit, guessing you are a long way from Aberdeen so will have to post it to you.Many thanks Saabnut, I’ll PM you tomorrow as I can’t get on with the mobile version tomorrow and my laptop is updating Link to comment Share on other sites More sharing options...
dozeydustman Posted March 28, 2019 Author Share Posted March 28, 2019 Neo Bros do a brand new one for £150. I hate working with Diesel manifolds, that Black stinking sticky gunk is Black,stinking and sticky. https://www.neobrothers.co.uk/intake-inlet-manifold--gasket-saab-9-3-05-12--9-5-06-09-19-16v-diesel-5185-p.aspI’ll use the parts washer at work, normally good for stinky lorry parts that get covered in all sorts pf crap. £150 for a new manifold is pushing my budget. I think thes manifolds cam be cleaned with Mr Muscle oven cleaner Barry Cade 1 Link to comment Share on other sites More sharing options...
Guest Posted March 28, 2019 Share Posted March 28, 2019 Ah yeh, that's it, you can lock the pulley with 2 of the cambelt cover bolts, then loosen the retaining bolt so the cambelt doesn't need disturbing. I'm pretty sure you can get a brand new Pierburg one for about £130 on ebay (think they were the OE). The one on mine is £350!Which one have you got? I rather like working on the Fiat/Vauxhall/Saab/Alfa 1.9. Saved a few that suffered cambelt failure- new rockers,a belt kit and good as new. SiC 1 Link to comment Share on other sites More sharing options...
SiC Posted March 29, 2019 Share Posted March 29, 2019 I'd still have been saving the hassle of removing the manifold and just sticking a actuator rod repair kit on them. Link to comment Share on other sites More sharing options...
J-T Posted March 29, 2019 Share Posted March 29, 2019 Which one have you got? I rather like working on the Fiat/Vauxhall/Saab/Alfa 1.9. Saved a few that suffered cambelt failure- new rockers,a belt kit and good as new.The later plastic manifold where everything’s internal. There’s a thread on the car in the moderns section Link to comment Share on other sites More sharing options...
dozeydustman Posted March 29, 2019 Author Share Posted March 29, 2019 I'd still have been saving the hassle of removing the manifold and just sticking a actuator rod repair kit on them.2 have seized, one is half hanging out and the last is on its way to siezing. There’s a photo somewhere in this thread where the one that’s jumped out of its hole has left soot everywhere in the engine bay, either way to repair it or blank it the manifold has got to come off. Link to comment Share on other sites More sharing options...
dozeydustman Posted April 19, 2019 Author Share Posted April 19, 2019 Started the manifold replacement today. Lots of soot from missing swirl flap. EGR isn't too badly coked up but I'll still clean it with some oven cleaner. Engine mount out and top timing cover off. There's soot in there as well; shouldn't be. Belt looks older than 13 months...... Got the engine at TDC for cylinder 1 and locked. Still waiting for my nephew to bring over some larger Torx bits so I can get the fan belt tensioner off and set the camshaft timing - it appears 1 tooth out if the timing marks I've found are correct. I've been flummoxed at getting the oil separator and vacuum reservoir off the back of the engine. Doesn't help where some twat in the past has broken the pipe clips and secured coolant hoses, breather hoses and the main wiring loom to various points with cable zippers. Probably half of my electrical woes over the last year caused by this. I'm hoping tomorrow I can finish the job off. And get less mucky. GrumpiusMaximus and Sigmund Fraud 2 Link to comment Share on other sites More sharing options...
SiC Posted April 19, 2019 Share Posted April 19, 2019 If you're doing the belt, don't forget the water pump. Usually goes shortly after the cambelt has been changed. Link to comment Share on other sites More sharing options...
dozeydustman Posted April 19, 2019 Author Share Posted April 19, 2019 If you're doing the belt, don't forget the water pump. Usually goes shortly after the cambelt has been changed. I do have a belt, I don't have a pump. Yet. TBH I just want to get it back up & running, so I may save the belt job for after the MoT. More that's bothering me is getting this sodding oil separator off the back of the engine. I gave up after 2 hours as I cannot find what is keeping it in place. Haynes manual just says unbolt and remove..... Link to comment Share on other sites More sharing options...
dozeydustman Posted April 20, 2019 Author Share Posted April 20, 2019 Quick update while I stop for lunch Oil separator and vacuum reservoir were an absolute shitpot to get out. HBOL said 4 bolts hold it to manifold- I found 6 Pump out. Didn’t put up much of a fight which was good. Manky old manifold is now out. One extremely buggered swirl flap. Just soffing on some marmite on toast, hopefully the diesel beast will be running this afternoon or evening. Tamworthbay, clayts450, Saabnut and 2 others 5 Link to comment Share on other sites More sharing options...
dozeydustman Posted April 20, 2019 Author Share Posted April 20, 2019 If you've seen the grumpy thread I'm not a happy boy. replacement fannymould. fannymould flaps open and close as they should, motor isn't siezed or owt. Apparently came off a car with only 48k km from Germany. got everything in place, connected, new hose clips for the fuel lines I'd disconnected. Went back together surprisingly easy. The woodruff key for the pump drive didn't give me too much hassle either. Everything but the alternator belt is back on the car, reconnected battery and went to prime fuel system (3 turns of the key to 'ON' according to the owner's manual). All sounded good, turned over, had her running for about 30 seconds, and she blew one of these hoses on top of the injectors. Fuxakes. I really hope I don't need a whole new injector, and I can just replace that bit on the top. TL:DR my car came back to life then immediately died again. Link to comment Share on other sites More sharing options...
SiC Posted April 20, 2019 Share Posted April 20, 2019 One of these isn't it?https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fp%2F943639239%3Fiid%3D282513521791 I reckon it would be possible to bodge something up with fishtank/washer fluid fittings and glue for now. Did you learn on the top when working on the car? Link to comment Share on other sites More sharing options...
SiC Posted April 20, 2019 Share Posted April 20, 2019 Also this:https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F182462564967 Link to comment Share on other sites More sharing options...
SiC Posted April 20, 2019 Share Posted April 20, 2019 Interesting to see the connector is original at the mileage you're on. They tend to only go on injector 3 bizarrely. Like 20 quid part and a bit of soldering to change. Link to comment Share on other sites More sharing options...
dozeydustman Posted April 20, 2019 Author Share Posted April 20, 2019 (edited) I try not to lean on an engine, especially not one with loads of gubbins running over the top. It doesn't need 23 and a half stone on top of it. I worked from the driver's side most of the time though there was no guarantee I didn't rub it with my ample midriff. It just went while the engine was running, so it may well have gone anyway out on the road without me faffing about. Service history for this car is relatively comprehensive, but nearly everything was original on that engine - EGR & DPF excluded until today. Edited April 20, 2019 by dozeydustman Saabnut 1 Link to comment Share on other sites More sharing options...
J-T Posted April 20, 2019 Share Posted April 20, 2019 How did you find this job overall? I need to do mine but everytime I look at how much needs removing/moving I die a bit and think 'just give it to alfatune and let him do it' Link to comment Share on other sites More sharing options...
dozeydustman Posted April 20, 2019 Author Share Posted April 20, 2019 How did you find this job overall? I need to do mine but everytime I look at how much needs removing/moving I die a bit and think 'just give it to alfatune and let him do it' I've done easier, I've certainly done worse. It doesn't help that I'm a large oaf with huge fat fingers. Having the intake side at the rear of the engine bay is also a hindrance (who decided this was a good idea?). The worst part was definitely the stripdown of all the gubbins attached to the engine. As I abandoned changing the cambelt I could have saved a good 1-2 hours of stripdown yesterday and the same amount of time reassembling today as well. You must (partially) drain the coolant, at least 5 litres as it passes through the manifold, else you risk it draining from the manifold into the intake ports of the engine. Thankfully getting it all back on the car was quicker than stripping it down. Once the stripdown was done I got the pump and old manifold out in 15-20 mins, and the new manifold and pump back in in another half an hour or so, all up to required torque. The oil separator was the biggest arsehole to do as there were 6 nuts holding it in place, not the 4 the HBOL said. If you need to change the glow plugs it's a good opportunity at the same time. You'll need 10, 12, 13, 14, 17 & 22mm spanners and sockets, Torx T40, T45, possibly a T50 and E14, decent torque wrench, allen keys and long sleeves! I allowed myself a couple of days to do this and if it wasn't for the leakdown pipe breaking, I'd have finished the job off and been driving about this evening. Saabnut, J-T and paulplom 3 Link to comment Share on other sites More sharing options...
dozeydustman Posted April 21, 2019 Author Share Posted April 21, 2019 For those who are so inclined: I'm going to clean this up inside and out, I'm not sure if I want to sell as is on ebay or repair it and keep as a spare. I suppose it depends on how bothered I am to do it! GrumpiusMaximus and Sigmund Fraud 2 Link to comment Share on other sites More sharing options...
