dozeydustman
Saab 93 - HUZZAH!
Just about an hour ago I went to start my car up, had Mrs Dustman with me, to go and pick Miss Dustman up from work. Turned over fine but took a while to fire up.
Steering felt heavy. Thought maybe as it's currently -5 + wind chill it's just cold & the fluid is thick.
Started reversing out my bay then I was greeted with:
"DING DONG" - ABS fault.
"DING DONG" - ESP fault
"DING DONG" - headlamp auto levelling not working, contact service.
I shut the car down straight away and we went in Mrs D's Corolla.
Alternator is less than 2 months old, it's a recon unit from Alternator Man in Portsmouth. Hoping the cold isn't killing the battery and it's taking the 'nator out with it (battery passed the drop test last time the no-charge warning came up). Looks like a session with the multimeter after work tomorrow.....
MEH.
Share this post
Link to post
Check the battery, a failing alternator killed mine - and the cold will make things a lot worse too.
However worth testing the current as the alternator might be broken still - someone else on here (I can't recall who, but it was a Rover I think) got a recon alternator with a warranty and it turned out to be DOA I think. He got it replaced no questions asked I think - these things happen.
Share this post
Link to post
It is cold.
I have seen an engine freeze up so water pump won't turn, so belt slips and no charge. etc.
Have a look at the coolant?
Driven off the cam belt on the diseasel engine I believe. Coolant and pump less than a month old, was done with cam belt/EGR/DPF change a few weeks back.
Looks like I'll be getting the battery drop tested as well then tomorrow.
The 'nator isn't a particular pain to change on this motor, but it's hassle I could do without at the moment.
Share this post
Link to post
Well, I went to go and test the alternator this afternoon after work, and engine won't even turn. I'm hoping the battery is knackered as opposed to being the alternator. It was tested when the old alternator packed up in late December, and was deemed OK.
Going to whip it off tomorrow and see if I can get it load tested again
Share this post
Link to post
Wouldn't surprise me if it has finally died SiC, it's a very old Bosch battery with a supposed lifetime guarantee, but as it put on by previous owner I'm not sure if the guarantee passes to me - need to do some research and find the receipt. Still waiting for my neighbour to return home as he borrowed my charger a couple of weeks back and foolishly thought I'd not need it for some time!
Decent 096 batteries ain't cheap. I've fitted off-brand batteries to previous cars in the past and some have barely lasted a year before they've packed up - doesn't matter if my wheels are a pile of shite or something decent, I always buy the best I can afford.
The car has had none of the weird symptoms prior to failure it had in December when it was the alternator (trip computer mess-arsing about, speedo dropping to 0 and back to current speed etc.) - just hoping it's not some major electrical fault 'cause if that's the case I'll be buggered.
Share this post
Link to post
I believe these are 096 batteries:
https://www.coxmotorparts.co.uk/honda-shop/genuine-honda-civic-2-2-diesel-battery-2006-2011/
Unfortunately just under the free delivery threshold.
Saabs of this vintage tend to go a bit crazy when the batteries die. They also sometimes a power cycle on the battery when they start being silly - especially if they don't shut themselves into low power mode when the ignition turns off.
Maybe teaching to suck eggs, but make sure you disconnect the battery from the car before connecting the charger.
Share this post
Link to post
An overnight charge appeared to succeed as battery took a charge according to the charger's gauge, soon as it went on the car and turned over for 2 seconds then died, so sounds like a dead cell. New battery it is.
Just hope it hasn't taken the alternator out with it.
Share this post
Link to post
Enormous Varta 78Ah battery ordered from Tayna for the same price the local motor factors wanted for a 65A Banner brand - I don't particularly like fitting cheap batteries to cars, even shitemobiles. I've had cheap batteries last less than 6 months in the past. Let's see how we get on when it arrives, hoping running it for no more than 30 seconds before the electrics went haywire didn't ruin the alternator.
Share this post
Link to post
New battery. Hoorah!
I don't like the look of that voltage. I'm thinking 13.5-14v is correct. A quick 10 minute run didn't make the lights come on, and the battery has remained at 12.7v after switching off, and again half an hour later. I don't think there's a discharge anywhere, so looks like the 2 month old alternator is not healthy.
Bummer.
Share this post
Link to post
Is that 13.08v with the engine running? If so, how long has the engine been running for when you took that reading?
Yep with the engine running. That was after 10-15 minutes driving down the A27 and back. It was fluctuating between 12.8 and 13.0 before I set off. Granted it's not a long run, when I fitted the alternator back in January it read 13.7 at tickover before I took it for a run, and a heady 13.9 after a good half an hour.
Connections to the 'nator and battery are secure, so I can only assume it's failed.
Share this post
Link to post
I'd be giving the place that rebuilt it a ring and explain patiently what has happened - I'm sure they will be happy to exchange it for another one.
I know a weird man in a shed in mid-hampshire who rebuilds them if you are interested. He is properly weird though.
Share this post
Link to post
Thanks for that Stanky, if I get no joy from the place I bought it from (based in Pompey) I'll give you a shout.
Thinking about whipping it off and getting an independent check it over with a verdict.
Share this post
Link to post
£215 for a reconditioned Bosch (excluding deposit/surcharge) from ECP. Same price for a brand new Denso and no surcharge.
Just wondering why the recon one I purchased was only £100ish. Think it's a Denso unit I got back.
Give me a Lucas ACR any day. Much simpler
Share this post
Link to post
And about a third of the output on a good day if the charge light wasn’t glowing faintly
I've never had a Lucas ACR be unreliable. Had them on my Scimitars and a number of tractors I've looked after in the past, only failed due to worn brushes, which are easily replaced.
Share this post
Link to post
But a Lucas ACR has no chance in providing enough capacity to power a modern car - especially one laden with electronics like the Saab 9-3 is.
There isn't really too much in design between a ACR and the alternator on your Saab though tbh. Just tighter packed to get more power out of it.
Share this post
Link to post
What's more annoying is the place I bought it from just hangs up when they answer the phone, or go direct to voicemail, and hasn't returned my message. Two days have passed since leaving a voicemail
Has anyone here used AlternatorMan in Portsmouth?
Share this post
Link to post
Yes I have, just goes through to voicemail on either. When I bought the alternator he at least sent me a text to say he was out for lunch. Conveniently his website has stopped working as well, and his eBay shop has closed down.
My dad called me up earlier to see how things were and he reckons the guy has either shut up shop or is purposefully ignoring me. Might take a trip down there after work on Friday see if the place is Mother Hubbard.
Share this post
Link to post
if you're coming over this far might be worth taking a small detour afterwards to this chap
http://www.jasm.co.uk
He's the funny guy I took my Geep starter motors to. He told me what was wrong and that it would be cheaper for me to fix it myself, and explained how. He was right and it was free to fix.
Are you mobile without the Saab? its not likely to be a drive-in drive-out job.
Share this post
Link to post
Yeah I have Mrs Dustman's corolla as she's not working this week, I'll contact your man at some point tomorrow or Friday and see what he says.
I have been put in touch with a garage nearby who specialise in the Swedish marques, and as I work with the bloke's brother he's going to swap it over for mates rates (£75), if I can supply a new/recon alternator that works.
I'll probably get all this done and then in April find it needs half a million quid to get it through the MoT.....
Share this post
Link to post
If your Alternator is only charging at 13.05 volts, then you have a problem. It should charge at a minimum of 14.00 volts, otherwise there is not enough of a gradient so that the energy can flow into the battery and keep it fully charged. At rest, a fully charged battery will show 12.7 to 12.8volts.Charge state can also be verified by a hydrometer test on a lead acid type battery. Not possible to test a sealed Calcium type with a hydrometer for obvious reasons.
If you want to test that the alternator is not shorting the battery to ground, then I tested mine in the following manner: Using analogue meter set to the 10 amp scale, I disconnected the negative battery terminal. Connect one lead from the meter to the battery post and the other to the battery negative lead. If all is well, you will get a very slight movement on the meter needle. If a small swing, switch now to the 1 amp scale to read the discahrge, it will be around 50 milliamps, depending on your cars equipment. But if the alternator diodes are faulty, then the needle will show a much larger swing. In my case, I got a swing of over 1 amp, which showed that the alternator diodes were faulty and were allowing current to pass back to the battery and draining it to ground. It drained a new battery in under 24 hour.
This was a brand new reconditioned Alternator supposedly reconditioned by a reputable supplier. I sent it back for an exchange and the next alternator worked perfectly. End of charging problem. But I wasted hours of time before reaching the correct conclusion that the supplied alternator was faulty. I really cursed that supplier!.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
  • Similar Content
    • By Peter C
      Woke up this morning, had a little time before I had to leave the house for work, had a quick look at what’s new for sale on Retro Rides and saw an ad for a W124 200E manual, located 15 miles from home. I had no intention of buying a car today but I had to have it! I called the seller and arranged a viewing.
      Faults:
      2 x rusty front wings (TADTS)
      1 x rusty rear arch
      Needs a polish
      Tracking is out because new track rod end was fitted for MoT
      Engine has oil leak/s
      Good points:
      It’s a W124 200E!
      5 speed manual transmission
      New clutch
      Brand new MoT
      Superb MoT history
      4 x as new Continental tyres
      Last owner for 15 years, her husband before that for 4 years
      Very tidy MB-Tex interior
      Drives well
      All electrics work
      The dealer kindly delivered the car to my house but I managed a pez station shot on route:
      Plans:
      Remove front wings, cut away rust and apply plenty of wob.
      In-situ similar repair for rear arch
      Clean and polish
      Service engine
      Adjust tracking
      Leave patina and enjoy the car as it is
      I will update this thread once progress is made.
      Hopefully these two will become good friends.
    • By JoeyEunos
      Greetings all.
      After lurking here for a short while, frankly liking what I see and enjoying the various shite, the site has well and truly struck a chord with me. I'm a serial buyer of ropey sub £1k vehicles, don't have to but genuinely enjoy it.
      I feel like I might (Just might) have found my 'spiritual' home here
      I've been posting across the web on owner specific forums (Usually using either my JoeyEunos or RandomPrecion handles) for a while now, but from here-on-in I will pull my threads together and merge them here into one ghastly topic.
      My current steeds...
      Lupo 1.7 SDI
      SAM_5560 by
      and the work/story so far...http://forums.clublupo.co.uk/index.php?/topic/102863-joeyeunoss-sdi-beater/
      Golf Mk4 SDI
      SAM_5531 by
      and the thread.... http://uk-mkivs.net/topic/597074-project-slow/
      Early (1989) Mk1 Eunos (This one was recently sold)
      SAM_4656 by
      the thread...http://www.mx5nutz.com/forum/index.php?showtopic=213274
      Other shite I've owned and moved on in the last year include this ropey Passat...
      SAM_6011 by
      and this legendary £300 Fiesta Finesse...
      Festa by
      Cars I'd like to own/actively looking for in the forthcoming weeks/months/years...
      Rover 75 (Dizzler)
      Peugeot 405 (XUD)
      Mk1 Octavia (Estate/dizzler, pre pd or SDI)
      Honda CRV (Gen1)
      Volvo 240/850
    • By richardthestag
      Been a busy 6 months on my old Range Rover that I own 50/50 with Fathathastag
      Bit of background first..
      We bought it March 2015 just as genuine early Range Rovers were starting to get noticed. Alas not early enough that we could have got it for a couple of hundred quid.
      The car had been owned for decades by a Land Rover enthusiast and this particular car retained a lot of features unique to pre 1973 Range Rovers. Sadly he died a few years back and the car was left outside the front of his house.
      I spotted it on eBay and arranged with the owners widow to view. There were no bids and my offer was good enough to take the auction off.
      The engine had been part way through a top end strip down when work stopped, I had no idea even if the car would move. But rented a trailer and relocated it from Watford to North Devon where fathathastag has a barn suitable for storage.
      The project is on the right, we towed it into the field and pushed it into the barn
      In May 2015 I got to do an assessment of the car. body wise most outer panels were ok, the inner wings looked ok, it clearly needed some work but was unsure how much at this point. main objective was to see if the engine was a runner.
      Found that the gearbox and axles were original to the car, but the engine was from an earlyish SD1
      while the seat covers are not original some of the plastic kitkat seat coverings are underneath, the rear seat especially
      The head has some nasty corrosion very near the fire ring seal,
      When I refitted the head one of the bolts tore the thread out. bastard but not entirely uncommon with the alloy blocked RV8
