Zelandeth Posted November 29, 2019 Author Share Posted November 29, 2019 On 11/27/2019 at 9:57 PM, spartacus said: I don't understand the deeper tech stuff of the Sun tester but it's a really interesting write up. I've used similar machines in the past and it's enlightening to learn more about them. Have you found out how much it would have been new? These kind of things were usually bought on the tick I think, as a result of being very expensive. Sadly that's not something I've yet been able to track down. An original pricelist would be great. Though simply based on the construction of it, "eye wateringly expensive" springs to mind. Speaking of expensive... Xantia is booked in at Formula 1 on Monday to have four new Uniroyal RainExpert 3 tyres fitted. Had to order them in unsurprisingly...205/60 R15 isn't exactly a common size. They were able to do £83 each fitted, not grumbling at that, Black Circles and MyTyres were in the £72-75 range including fitting (an extra £15 per wheel over the price they show you on the front page), and I'm happy enough to pay a few quid extra to keep a convenient business going. While it's in having that done we'll get it on the ramps for a proper look at the exhaust to see what state it's in. I know the back box is stuffed, but it's harder to judge the state of the rest when just peering under the car. I'm hoping we can get it through the MOT at least so that can be dealt with more at my leisure. Likewise a fresh set of spheres will be wanted in the not too distant future...but are going to have to wait until we've recovered from the dent it's about to put in our account! Link to comment Share on other sites More sharing options...
Zelandeth Posted November 30, 2019 Author Share Posted November 30, 2019 This afternoon an envelope containing four 3/8" BSF bolts dropped through my door. The big question of course was whether they would fit the hub of the Invacar. Finally! I can now confirm that the threads in the hub are 3/8" BSF. With a little fermangling the old wheel nuts (which mostly had somewhat mangled threads) were drilled out to act as conical washers for the time being. These were destined only for the bin so I had no worries about messing with them. This meant that for the first time since September I was able to attach the wheel to the car again. ...Which meant the car is actually sitting on its wheels again rather than axle stands. Obviously won't be getting driven on the road like this, especially with the remains of the original stud still being in there. However it will mean that I can at least move the car in and out of the garage until such time as the replacement hub turns up. Given that I need to shift it to get the Crypton machine out of there...that was kind of important. While I was in the garage I figured it was time to have a better look at the booster fan for the heater. Bit of experimentation was needed, but eventually found somewhere to put it where it was out of the way. I hadn't been successful in tracking down the correct reducer to attach the ducting straight to the fan housing...so out with the duct tape. Not pretty but it's air tight. Then put in place. It will be bolted in place to the top of the wheel tub and the wiring connected up shortly. The airflow isn't fantastic, but it's better than it was unless you were going flat out. At least I know where we're going with the wheel studs/nuts etc now. rainagain, mat_the_cat, LightBulbFun and 1 other 4 Link to comment Share on other sites More sharing options...
Zelandeth Posted November 30, 2019 Author Share Posted November 30, 2019 This afternoon an envelope containing four 3/8" BSF bolts dropped through my door. The big question of course was whether they would fit the hub of the Invacar. Finally! I can now confirm that the threads in the hub are 3/8" BSF. With a little fermangling the old wheel nuts (which mostly had somewhat mangled threads) were drilled out to act as conical washers for the time being. These were destined only for the bin so I had no worries about messing with them. This meant that for the first time since September I was able to attach the wheel to the car again. ...Which meant the car is actually sitting on its wheels again rather than axle stands. Obviously won't be getting driven on the road like this, especially with the remains of the original stud still being in there. However it will mean that I can at least move the car in and out of the garage until such time as the replacement hub turns up. Given that I need to shift it to get the Crypton machine out of there...that was kind of important. While I was in the garage I figured it was time to have a better look at the booster fan for the heater. Bit of experimentation was needed, but eventually found somewhere to put it where it was out of the way. I hadn't been successful in tracking down the correct reducer to attach the ducting straight to the fan housing...so out with the duct tape. Not pretty but it's air tight. Then put in place. It will be bolted in place to the top of the wheel tub and the wiring connected up shortly. The airflow isn't fantastic, but it's better than it was unless you were going flat out. At least I know where we're going with the wheel studs/nuts etc now. spartacus, BlankFrank, LightBulbFun and 1 other 4 Link to comment Share on other sites More sharing options...
LightBulbFun Posted November 30, 2019 Share Posted November 30, 2019 Woo! im glad the whole wheel stud thing is finally over or at least finally figured out! I see your electing to still replace the hub, have you got something figured out for the preloaded bearing issue? I very much look forward to seeing TPA on the road once more its been far too long! Link to comment Share on other sites More sharing options...
Zelandeth Posted December 1, 2019 Author Share Posted December 1, 2019 32 minutes ago, LightBulbFun said: Woo! im glad the whole wheel stud thing is finally over or at least finally figured out! I see your electing to still replace the hub, have you got something figured out for the preloaded bearing issue? I very much look forward to seeing TPA on the road once more its been far too long! Basically going to treat it like any other wheel bearing...will see what sort of drag in on the other one with the driveshaft disconnected and just aim to get them matched. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 2, 2019 Author Share Posted December 2, 2019 Xantia is now wearing a nice new set of Uniroyal RainExpert 3 tyres. Tell you what I wasn't expecting...that changing the tyres has reduced road noise by what feels like about 70%. It's not something I was expecting at all, so took me a good few seconds to figure out what had changed. I'm glad to be back on these tyres to be honest. Have been on others for a few years now down to availability and what cars came with...but the RainExpert has been my tyre of choice going back pretty much to the start of me driving back in 2003. Annoyingly she will definitely be wanting rear discs for the MOT as they've only been working on a small portion of the rear of the disc - quite likely due to the usual Xantia issue of the caliper alignment being screwed up by dissimilar metal corrosion between the axle and caliper. Deceptive this problem as the rear brakes don't do much in the Xantia unless you've a lot of weight onboard - the brakes in this one feel quite capable of stopping the rotation of the planet itself as they are. Front discs will do a bit yet, but the pads are definitely getting towards due for a change. Couple of weeks over two years and ~20K miles. The exhaust has also decided to be annoying, having somehow managed to part company with the rearmost hanger. Still not quite sure how it's managed this...though the whole system appears to have managed to get twisted somehow and this is the first day it's not rattled in several months. Will see if I can convince it to behave tomorrow. If I can get this exhaust through the MOT I'll be happy...as I'd really rather not have to add another hundred or two onto the bill (and finding systems that actually fit well for the Xantia is a pain at the best of the time, irrespective of price). I'd like to get a stainless system made...but I could do with a chance to recover from the work about to be done before having to pay for that too! Broadsword and LightBulbFun 2 Link to comment Share on other sites More sharing options...
LightBulbFun Posted December 4, 2019 Share Posted December 4, 2019 @Zelandeth just wondering, do you know where the wheel nuts from TPA came from? because it turns out that the 10 and 12 inch wheels have their own specific wheel nuts to do to the shoulder angles being different between the 2, and that back in the day an approved repairer letter went out warning not to mix the 2 although interestingly, checking the spare parts manual it only lists 1 type of wheel nut, perhaps this was some sort of later universal type? im not 100% sure (although I do know it dates from 1975, so maybe it was introduced to replace the 2 wheel size specific ones? but I don't know enough about wheel nuts to know if that would be possible) "STY475 wheel nut nut, spherical" just something stuart mentioned that figured id mention here just as a heads up, incase it is a problem or such Link to comment Share on other sites More sharing options...
Zelandeth Posted December 4, 2019 Author Share Posted December 4, 2019 As far as I'm aware the wheel nuts here are just standard Mini items. When the switch to 10" wheels was made I imagine they just swapped over to the Mini nuts as well as they'd have been cheaply and readily available. No idea of the origins of the ones the 12" wheels used though. I seem to have two types here, one with a longer body than the other, the conical section has the same profile on them both though. Having said that, they were in a huge box of bits, so could be from anything! Given they are all a bit beaten up I'll just be replacing them all with new Mini ones. They're not expensive so it just makes sense. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Broadsword Posted December 4, 2019 Share Posted December 4, 2019 I have a spare set of untouched front brake pads for a Xantia, pretty sure they are Brembo and might fit yours if we are in luck and interested. I've done rear brakes on my old white Xantia before. They can get very crusty. I was nervous about the prospect of splitting the caliper to change the disc, but discovered that you can simply take the pads out, then reinsert/tighten the slide pin and gingerly unbolt the caliper from the axle in one piece without opening the system. Be careful unbolting the caliper from the axle, I read that the 17 mm bolts can sheer if things are seized up. I had no problems on mine though. LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted December 4, 2019 Share Posted December 4, 2019 21 minutes ago, Zelandeth said: As far as I'm aware the wheel nuts here are just standard Mini items. When the switch to 10" wheels was made I imagine they just swapped over to the Mini nuts as well as they'd have been cheaply and readily available. No idea of the origins of the ones the 12" wheels used though. I seem to have two types here, one with a longer body than the other, the conical section has the same profile on them both though. Having said that, they were in a huge box of bits, so could be from anything! Given they are all a bit beaten up I'll just be replacing them all with new Mini ones. They're not expensive so it just makes sense. ah thats a good point being on 10 inch wheels means you can just use normal Mini items I guess I should pass the info onto @dollywobbler when he gets back to the UK or such as TWC is on 12 inch wheels, although its been fine for the past 2000+ miles so If a wheel was going to fall off or something it would probably would of done it by now! Link to comment Share on other sites More sharing options...
Zelandeth Posted December 5, 2019 Author Share Posted December 5, 2019 3 hours ago, Broadsword said: I have a spare set of untouched front brake pads for a Xantia, pretty sure they are Brembo and might fit yours if we are in luck and interested. I've done rear brakes on my old white Xantia before. They can get very crusty. I was nervous about the prospect of splitting the caliper to change the disc, but discovered that you can simply take the pads out, then reinsert/tighten the slide pin and gingerly unbolt the caliper from the axle in one piece without opening the system. Be careful unbolting the caliper from the axle, I read that the 17 mm bolts can sheer if things are seized up. I had no problems on mine though. Unlikely the pads will fit unless we're really lucky as she's got the V6 spec brakes which are a good bit bigger than the standard Xantia ones. I'm quite well aware of the big caliper retaining bolts being scary to undo because of the possibility of them shearing...which is why I'll be getting a garage to do that. It's a half hour job for them if it goes well and will be a world of pain for me if it goes awry if I try to do it on the driveway. Today I cleared a bunch of debris out of the door pockets etc, reattached the tailpipe to its hanger (still not sure why it had come off) and removed the demountable tow bar because I smacked my left shin on it yet again this morning. Tomorrow morning she's off over to BL Autos in Welwyn Garden City...then I'll spend a day or two feeling like I've got a relation in hospital while I wait to hear what the list of needed work will be like. Knowing the brakes now need work too I'm bracing for a bill in the order of £750. We'll see. There was one issue with the heater in the van. Mainly that this is it "off." The controller stays on so long as there's power. This is hooked directly into the leisure battery so doesn't shut off when the DC stuff in the back. This won't be a huge issue long term as a proper controller will be replacing this piece of tat at some point (the controller is where they skimped most on the production costs), but for now I'd like to be able to turn it off. Half an hour later this was sorted. So it's now possible to turn it properly off without having to remove the fuse every time. Obviously you need to wait for the heat exchanger to cool and the fan to stop before you can power it down though or you'll damage it. Yes it does mean the clock resets to 00:00 every time you turn things back on...but as the clock keeps laughably poor time (loses about five minutes a day!) that's not really an issue. ... I'm trying to resist the very strong urge to reposition the controller so it's level given it will be getting replaced...but it's really bugging me. Broadsword, mat_the_cat and LightBulbFun 3 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 5, 2019 Author Share Posted December 5, 2019 Well that was a waste of a morning. Turns out the last email I sent to BL Autos never got through, vanishing into the aether somewhere...so they weren't expecting me to appear this morning as they'd never had the message from me saying I'd be there today. This meant that they had nowhere to put the car and their courtesy car was unavailable. So I was left with no option other than to drive back home and book it back in for the tenth. This is a problem as I need the car on the weekend of the 14th/15th, and it's quite unlikely to be ready for then now...so much for my well laid plan. egg 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted December 5, 2019 Share Posted December 5, 2019 28 minutes ago, Zelandeth said: Turns out the last email I sent to BL Autos never got through, vanishing into the aether somewhere... bit late now, but ask them to check their spam folder?, 9 times out of 10 thats where missing emails usually end up! as for being a car down, carefully drill out the rest of the wheel stud in TPAs hub put the 4th bolt in and take her instead? Link to comment Share on other sites More sharing options...
Zelandeth Posted December 5, 2019 Author Share Posted December 5, 2019 1 hour ago, LightBulbFun said: bit late now, but ask them to check their spam folder?, 9 times out of 10 thats where missing emails usually end up! as for being a car down, carefully drill out the rest of the wheel stud in TPAs hub put the 4th bolt in and take her instead? Sadly I also need to fit a dog, weekend worth of stuff and a passenger in too. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 5, 2019 Author Share Posted December 5, 2019 Wait... it's actually a non issue as I'll have the courtesy car while mine is in the garage. My brain hadn't processed that beyond being a way to get back home from the garage. Obviously not being our car the dog will need to travel in his crate (which he hates) which isn't ideal, but it will get us there at least. Edit: Also just discovered that the bolts currently holding the wheel on the Invacar are too long and are jamming against the brake shoes, rendering the car immobile. Blast... Guess I'll need to attack them with the grinder then. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 9, 2019 Author Share Posted December 9, 2019 Had a bit of time this afternoon to poke around with the Sun 1215. No photos I'm afraid as I was busy and there wasn't really much visible to share anyway. Bottom line though is that it looks like we've got everything aside from the gas analyser up and running now. Still work to be done, there's a bit of AC getting coupled into the output of the power supply (obvious because of the gentle waving motion visible on the monitor), so I'll probably just do a wholesale replacement of the electrolytic caps in the power supply. It looks like it will be quite a pig to get it out, so I'd rather only do the job once...hence changing the lot. In other news, gave the Lada an hour or so of a run this afternoon to get it warmed through and to get some of the condensation out. Started first touch of course. I've decided to get off my lazy tail and start dealing with the MOT to do list. This mainly means sorting the offside front brake caliper which has been weeping for a little while. I've now ordered a rebuild kit for it which will hopefully sort it out. Failing that I'll order a pair of new calipers. That should hopefully be all the needs for the test, the exhaust is a mess but it's no different to how it was on the last two MOTs so it shouldn't be a fail, I've got a new middle and rear section on order. At least I've had it all apart recently so I won't have the usual fight to get it apart. Also on the subject of the Lada, it looks like we might have movement on it finding a new home. Still very early days, so I'm not saying more than that...but it looks like things might be moving in the right direction. LightBulbFun 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted December 9, 2019 Share Posted December 9, 2019 Regarding the van heater, I was after your opinion? I'm considering one like this: https://www.ebay.co.uk/itm/2019-NEW-Air-Diesel-Heater-2KW-12V-PLANAR-for-Trucks-Motor-homes-Boat-Bus-Van/153682665087?hash=item23c8335e7f:g:jp8AAOSwfW5dyhMw Would you consider it possible to mount away from an external panel? I'm concerned about the exhaust, as in my potential location there would be around 2-300mm exposed within the cab, albeit tucked away under the seat and exiting inside the wheel arch. On one hand it would be utilising the waste heat from the exhaust, but on the other hand it may get too hot to want to have it even partly accessible! Link to comment Share on other sites More sharing options...
Zelandeth Posted December 9, 2019 Author Share Posted December 9, 2019 2 hours ago, mat_the_cat said: Regarding the van heater, I was after your opinion? I'm considering one like this: https://www.ebay.co.uk/itm/2019-NEW-Air-Diesel-Heater-2KW-12V-PLANAR-for-Trucks-Motor-homes-Boat-Bus-Van/153682665087?hash=item23c8335e7f:g:jp8AAOSwfW5dyhMw Would you consider it possible to mount away from an external panel? I'm concerned about the exhaust, as in my potential location there would be around 2-300mm exposed within the cab, albeit tucked away under the seat and exiting inside the wheel arch. On one hand it would be utilising the waste heat from the exhaust, but on the other hand it may get too hot to want to have it even partly accessible! The exhaust does get *very* hot. Wouldn't think it's insurmountable though...I reckon if you wrapped it with the tape for manifolds etc and then had it contained within a larger metal duct it should be fine. I've not taken the thermometer near mine - but even on the outlet side of the silencer at the far end of the exhaust on mine it's got hot enough to have turned the metal that funky blue colour. They are supremely effective little units though. The one here (5kW in my case) can warm the van up from near freezing to comfortably warm in 10-15 minutes, then throttles back to a near silent idle state maintaining the temperature. One of the issues with this controller is that it won't ever actually shut off when up to temperature - something the aftermarket controllers which I'm looking at for the future addresses. LightBulbFun 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted December 9, 2019 Share Posted December 9, 2019 Thanks. It certainly sounds like more work is required, whether that's insulating the exhaust, or possibly modifying the passenger seat frame to allow it to fit underneath (and hence exit though the floor). Might drop hints for a Christmas present! LightBulbFun 1 Link to comment Share on other sites More sharing options...
strangeangel Posted December 9, 2019 Share Posted December 9, 2019 On 11/30/2019 at 11:27 PM, Zelandeth said: For some reason I was reminded of this... Link to comment Share on other sites More sharing options...
Zelandeth Posted December 10, 2019 Author Share Posted December 10, 2019 31 minutes ago, strangeangel said: For some reason I was reminded of this... You're speaking to someone who has copies on hand of every one of the Apollo Mission Reports & Comms transcripts... I've been a bit of a geek around the subject ever since I was old enough to know what the Moon is. LightBulbFun and strangeangel 2 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 10, 2019 Author Share Posted December 10, 2019 54 minutes ago, mat_the_cat said: Thanks. It certainly sounds like more work is required, whether that's insulating the exhaust, or possibly modifying the passenger seat frame to allow it to fit underneath (and hence exit though the floor). Might drop hints for a Christmas present! Probably easiest. You don't need to make a big hole...just two that are roughly 1" (and one smaller for the fuel line). This plate then goes over the top and the heater is bolted to that. mat_the_cat 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 10, 2019 Author Share Posted December 10, 2019 Well that could have gone better. Dropping the Xantia off this morning at BL Autos (having actually got it properly booked in this time without missing emails causing trouble), I knew the following needed attention. [] Lower steering control arm bushes shot - main thing it was going in for. [] Probably an antiroll bar bush or two (in the boot). [] Rear discs & pads (in boot). [] Exhaust mid & rear sections. This is the list which I was then given. Oh balls...that's longer than I was expecting. The estimate given: £1500 worth of work (approximately). Some of it I'm looking at and asking myself if they really just don't want the work. The rear arm bearings are something you usually have ample warning about the failure of...however I've had not a single clonk or groan from the back which would suggest issues. Likewise the rear spheres. They're definitely not in their first flush of youth and could do with changing, but they're not at the stage I'd expect them to be an MOT fail. The HP pump and pressure regulator have been damp with LHM as long as I've had the car, but she's never actually used a drop of it...so that leak can't be that severe. I'm very tempted to get a second opinion from my usual local garage that I trust...see what the list they give me looks like in comparison. They're not Citroen specialists, but do know the marque pretty well and have known this particular car for something like the last 10 years. You know what really grated? When I was handed their courtesy car it was running on fumes. So first thing I did was fuel it up... assuming at that point that they would have my car for a few days at that point, I filled it up. So after about an hour and a half when I handed the keys back, they got the car back with about £70 of diesel in. Despite that, they still charged me the full £36 for the vehicle condition report. While I realise they're running a business, but that just puts my hackles up a bit. I'd be surprised if one of the staff doesn't have that car home tonight! Speaking of the courtesy car... In addition to having no fuel in, I discovered the moment I got to the M1 that it was similarly lacking in screenwash and had utterly knackered wiper blades. Oh...and a comically badly out of balance front wheel too. It also started beeping at me and flashing the service light at me at one point...though helpfully not in conjunction with any other warning light or message anywhere. Locking/unlocking can only be accomplished with the key from the passenger door. Has also possibly the most unpleasant feeling gearchange of any car I've driven...made worse by the central armrest being perpetually in the way of the gear lever and handbrake. Visibility is utterly shocking in all directions as is standard for a modern car. I was glad to hand it back to be honest. Which is a shame as I've always liked the look of the C4. Just to make things even more fun, the rear silencer on the Xantia decided to totally part company with the rest of the system and start dragging on the ground halfway home...so I had to crawl around on the ground in the pouring rain cable-tying it to the spare wheel carrier (as the one remaining hanger wouldn't budge so I couldn't just pull it off and toss it in the boot). What fun. In other news, as it looks like we might be moving towards a deal being done with regards to the Lada (and me suddenly realising that the Xantia is in fact not going to be sorted in the short term and I am going to have to get my hands dirty), I've got it booked in on Friday for an MOT. The brake caliper overhaul kit is on the way... exhaust sadly will just have to stay as it is for now as the correct mid section is no longer available it appears...so I'll either need to get one made or pick up a non-cat one and see if I can adapt it. Hopefully there will be some movement there soon though. My intention at this point is still to get the Xantia repaired...as I've no idea what I'd replace it with...and I'm already £400 into it between tyres and brake discs. It ain't going to happen overnight though...and I'm reserving the right to change my mind there as it's a lot of money! egg 1 Link to comment Share on other sites More sharing options...
Broadsword Posted December 10, 2019 Share Posted December 10, 2019 Ok so the Xantia needs work, but I don't think the garage has quite put things into perspective with that list. I agree with you thinking they just don't want to do the work. I would definitely go for a second opinion and look to get the urgent messy jobs (like the exhaust) done for as reasonable a price as possible. Brakes I always like to do myself because it can be done slowly and methodically and isn't particularly hard work. Good luck with it. It's a special car that is worth saving. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 10, 2019 Author Share Posted December 10, 2019 Aye, I'd probably have had the brake work done elsewhere beforehand if I'd known it was needed in advance. Reason I'll be getting a garage to do it is simply that the rear caliper retaining bolts on Xantias love to snap when you try to remove them...and if that happens you're obviously in a world of pain. I'd rather that happen to someone in a fully stocked workshop than to me on my driveway in the rain. I'll probably hit them with my rattle gun and of they come out, fine...if not, garage can do it. Exhaust was a bit annoying... I was quite up front that I knew it was ropey and that I was hoping to be able to patch it up enough to allow a decent system to be fitted early in the new year. It demonstrated that ain't happening by half falling off on the way hone. They missed the split nearside CV boot too. I can't honestly see it not being sorted...I mean, what the heck would I replace it with? Few things blend practicality, comfort, speed and ease of use together as seamlessly as this car. I was braced for £750-1000 going in...but the £1500 (which may well have actually been less VAT now I think) was a bit of a shock! Broadsword 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted December 10, 2019 Share Posted December 10, 2019 14 minutes ago, Zelandeth said: I mean, what the heck would I replace it with? if push came to shove, another Xantia activa? with the V6 shoved into it somehow? Link to comment Share on other sites More sharing options...
Zelandeth Posted December 10, 2019 Author Share Posted December 10, 2019 11 minutes ago, LightBulbFun said: if push came to shove, another Xantia activa? with the V6 shoved into it somehow? They did exist on the continent, PSA deemed the potential market over here too small to be worth making an RHD version of it though. To be honest, lovely though they are, the sheer number of model specific bits for the normal V6 cars which are made of unobtanium these days (much less with Activa gubbins added to the mix!) would make me very wary of buying one. Plus in all honesty, I'm not likely to find one that's better sorted than this one. Sure she needs a bit of work this year... but that is the price you pay for having a high performance car...at times they are going to be high maintenance. LightBulbFun 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted December 11, 2019 Share Posted December 11, 2019 On 12/10/2019 at 8:21 PM, Zelandeth said: Plus in all honesty, I'm not likely to find one that's better sorted than this one. Knowing the previous owner, I suspect it's been very well looked after before your ownership too! LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted December 11, 2019 Author Share Posted December 11, 2019 16 minutes ago, mat_the_cat said: Knowing the previous owner, I suspect it's been very well looked after before your ownership too! Indeed. She's had a very blessed existence to be honest...and aside from routine servicing and a battery I've barely had to touch anything so far. From memory an aux belt and crankshaft pulley where the damper fell to bits are about the extent of it. Plus I'm not going to deny that she's not driven particularly gently. C'mon...I live in the city of roundabouts and have a car which can pull 0.98G when cornering...it would be rude not to take advantage of those abilities when traffic permits. Just got to that point in life where a few things go at once... it's always the way, and hopefully once this lot is done things will settle down again. I do wonder how many cars with low values that this stage of life sees off. The 306 Sedan I had was very much in this stage when I got it...that car was an absolute swine for the first few weeks of my ownership, but once that was out of the way she was a solid enough motor. LightBulbFun, mat_the_cat and Mrs6C 3 Link to comment Share on other sites More sharing options...
LightBulbFun Posted December 13, 2019 Share Posted December 13, 2019 I see the tax on TPA has been renewed for another year did you have to do it manually, or has it refreshed itself automatically? (I know that with historic tax you still have to go through the motions its just £0.00, but im just checking in case they have changed things recently) Link to comment Share on other sites More sharing options...
