1970mgb Posted May 15, 2019 Share Posted May 15, 2019 I agree that you shouldn't need 20W-60(especially outside the desert), and honestly the pressures were fine even on what was in the sump before. At the same time, as long as the starter can churn through it okay and the higher pressures give peace of mind, I wouldn't worry too much about it. (this is coming from the guy who once had his sump half full of SAE 60 to fight oil consumption in lieu of taking off and rebuilding the oil mist separator). LightBulbFun 1 Link to comment Share on other sites More sharing options...
SiC Posted May 15, 2019 Author Share Posted May 15, 2019 You shouldn’t need 20w/60 on this engine to get decent oil pressure, that grade of oil is too thick and won’t flow properly - I would swap it out for the correct grade (decent brand mineral oil), which in your case is 20w/50 or 15w/ 50 or even 15w/40. It seems quite happy on this oil. It is the recommended oil by Moss and given a lot of people buy from them, there is sure to be many other B-Series buzzing around with this oil. The change of oil wasn't just because of oil pressure. The old oil was a cheap oil (which I only found out later) and was not correct for the engine. It may have said 20w-50 but I suspect it was thinning out far more than it should have been. Possibly from poor quality and possibly too from fuel dilution. It also had no oil specs on the label. Finally there was no mention of ZDDP on the label, so I suspect it had minimal amounts in it. Either way, the boost in pressure, less tapping and generally smoother engine reassures me it was a correct thing to do. LightBulbFun and Tickman 2 Link to comment Share on other sites More sharing options...
somewhatfoolish Posted May 15, 2019 Share Posted May 15, 2019 When cold 20w60 is exactly the same viscosity as 20w50, the difference in viscosity only occurs at running temps due to the magic of multigrade wizardry. SiC 1 Link to comment Share on other sites More sharing options...
SiC Posted May 15, 2019 Author Share Posted May 15, 2019 I've just written a long reply and Tapatalk crashed when I went to post it. Puller not arrived yet. Hopefully tomorrow. Regulator came though, it's what I expected.A 10v regulator in a box with wires soldered on. Proper cottage industry/giffer made item. I wished the regulator was mounted on a PCB but at least the legs are mostly supported by glue.Gauge went to the expected level. Hopefully the last of me having to fiddle with this setup.While I was in a fiddling mood, I decided to look at the indicators not cancelling on a left command. The plastic cancelling mechanism wasn't broken, just didn't work.Here are some GIFs that may or may not work, depending if the forum software supports this...Left action.Right action (what it's supposed to do).With a bit of carefully* and precisely* applied insulation tape, the mechanism started working again. I suspect the issue was that the left slider piece had smoothed off too much from use and didn't have enough friction. Also of note is how remarkably clean this switch is. Both from dirt and dust. Pretty certain this is a genuine Lucas item. Either original or replaced around when they were still made properly.After that, I packed my tools in the boot and went for another pleasant drive. A total of 50 miles this year...!I did notice the running change slightly during the drive and also noticed that rev counter stops counting above around 3.5k rpm. I will check the gap tomorrow in case the crappy points have closed up a bit. There is a electronic amplifier in between the points and the coil, so if it has closed up a bit, it'll be harder to detect the signs. Really, really must get my original dizzy sent off and fixed! Skizzer, Coprolalia, LightBulbFun and 2 others 5 Link to comment Share on other sites More sharing options...
SiC Posted May 15, 2019 Author Share Posted May 15, 2019 I appear to have quite a bit of new found confidence in this car. 2hr15 drive if avoiding the motorways. Mrs SiC did still question if it'd get there... egg, Six-cylinder, LightBulbFun and 4 others 7 Link to comment Share on other sites More sharing options...
somewhatfoolish Posted May 15, 2019 Share Posted May 15, 2019 That voltage reg is impressively shite. SiC 1 Link to comment Share on other sites More sharing options...
busmansholiday Posted May 16, 2019 Share Posted May 16, 2019 Fuel gauge, don't worry. Reset the trip meter when you fill her. Then work on about 260 miles. The gauge on the B reads what it feels like, which is a sightly better than the TF which reads empty with an almost full tank. Oil, decent 20/50 is what you need, and as I keep saying, cover the oil pressure gauge with some tape to stop you looking at it! As for getting to the festival, of course it'll get there. It's the getting back that you need to have your breakdown recovery card for..... BorniteIdentity and LightBulbFun 2 Link to comment Share on other sites More sharing options...
SiC Posted May 16, 2019 Author Share Posted May 16, 2019 I'm not really that bothered about the pressure so much now as it's more in the normal area. I tend to only really report it on here out of habit! LightBulbFun 1 Link to comment Share on other sites More sharing options...
SiC Posted May 17, 2019 Author Share Posted May 17, 2019 This came today, ready to put my treat on that's been in a box for well over a year now. Car has been well behaved enough to justify it being fitted. Couldn't find any of the bolts with a suitable thread. These were the closest. However they were munging up the thread. So I rooted around my spares box and found two old bolts with the right thread. Couldn't get the pointy spacer thing (forget the name) on too, so left it off. Then used this. Which was a mistake. All it did was bugger up the end as the lack of pointy spacer thing meant it pushed against the thread. Luckily minimal damage. However while tightening the thread in the hub let go. Luckily the hold has more than enough thread for the bolt to go in tightly still if the wheel is reused. So next plan was to whack the back with a hammer. Not a lot happened. Then I attacked it with a chissel in the middle while hoping it would split or at least . Of course it didn't. Had a stop to think about it. Thought about getting the grinder out and just cutting a slit into the fecker then drive a wedge down to crack it into half. However I really didn't want to damage the hub and especially didn't want to damage the column. Went into the garage for a root around. Came out and did this. After applying what seemed way too much force on a breaker bar ... everything all fell off. Assessing the situation, I realised it finally broke free. Built my new steering wheel. Realised the hub was pretty shit quality, so filed away on the centre to smoothen some of the splines out. Put wheel on, tightened it up with my breaker bar as tight as I could. Then torqued up to 50lb/ft - still actually tightened up some more. Hopefully it's on the splines enough. Not sure it went down as far as the old wheel though. Anyway its on. Much nicer to hold. It's smaller, but I can get a better grip on it so it's easier to turn. Also my knees don't hit so much on the back of it either. The old one was a bit too big. Nearer 16 inches. While this I think is a 14 inch wheel. Brake parts haven't come still. Not even shipped yet which is very annoying. Might take the wheels off though for a quick inspection and maybe a quick cleanup. I did buy a Clutch master cylinder from Moss though. I've noticed that the fluid in that master is getting very dark. Also first, second and especially reverse can be hard to select at times. So I'm suspecting it could be the seals going. Slave and pipes I did the other year, so they should be alright still. It's not a metal can original so it must have been replaced at some point. But not by me - so likely at least a good 16+ years old and most of that sitting around. Probably fit that this weekend. Hopefully should be a reasonably easy job. The Moog, Joey spud, Six-cylinder and 6 others 9 Link to comment Share on other sites More sharing options...
purplebargeken Posted May 17, 2019 Share Posted May 17, 2019 Really nice wheel. SiC 1 Link to comment Share on other sites More sharing options...
BorniteIdentity Posted May 18, 2019 Share Posted May 18, 2019 That wheel is smashing. The leather one in my mini is the same but smaller. Good to see it getting used too- and looking forward to meeting you at FotU ! SiC and egg 2 Link to comment Share on other sites More sharing options...
SiC Posted May 18, 2019 Author Share Posted May 18, 2019 A better picture of it in daylight. I'm really happy with it. Surprising how a steering wheel can make a car feel so different. I guess it makes sense as its your main touch interface with the car. Off to give the car another run and see how it feels like. Also hope that I put the wheel vaguely in the central position. Not sure I'll be able to get the damn thing back off if its not! Clutch Master cylinder change over is cancelled for today, as I forgot to buy replacement copper washers for the banjo bolt. Will be my luck that if I try reusing them they will leak and I'll have to do the job again. For the sake of £1.20 of washers, I'll just pick them up on Monday and do it another day. Might try getting the choke on the carbs adjusted, as I haven't adjusted it since refitting the carbs and it can be a bit of a bugger to get started when cold. Not helped I think by the holding nut coming loose and the screws rattling to all different positions! Then I'll get the wheels up, inspect the front brakes and adjust the rear drum adjusters. LightBulbFun 1 Link to comment Share on other sites More sharing options...
1970mgb Posted May 18, 2019 Share Posted May 18, 2019 1 hour ago, SiC said: Off to give the car another run and see how it feels like. Also hope that I put the wheel vaguely in the central position. Not sure I'll be able to get the damn thing back off if its not! Hence my advice about only snugging the nut down enough to hold the wheel in place...not putting 50ft-lbs of torque on it... LightBulbFun 1 Link to comment Share on other sites More sharing options...
SiC Posted May 18, 2019 Author Share Posted May 18, 2019 2 hours ago, 1970mgb said: Hence my advice about only snugging the nut down enough to hold the wheel in place...not putting 50ft-lbs of torque on it... You worry too much! Impact wrench wizzed the nut off in a blink and a wiggle of the wheel to get it off again. Link to comment Share on other sites More sharing options...
LightBulbFun Posted May 18, 2019 Share Posted May 18, 2019 3 minutes ago, SiC said: You worry too much! Impact wrench wizzed the nut off in a blink and a wiggle of the wheel to get it off again. I cant tell if your doing it intentionally or not at this point cobblers 1 Link to comment Share on other sites More sharing options...
SiC Posted May 18, 2019 Author Share Posted May 18, 2019 Not sure if today was a success or not really. Apart from being another complete time thief. Also got a cold and feeling a bit crappy, so wasn't going that quick. Couldn't do the clutch master as I didn't have the copper washers, and I didn't want to risk it leaking then having to do it again. Why I think the master needs changing? That fluid was changed when I did the slave cylinder. Probably two years ago or so, but of course hardly any miles. So decided look at the brakes. So I looked at them. Here are some pictures so you can look at them too... Cleaned them up a bit with a brass brush and plenty of brake cleaner. Discs aren't too pretty either. I gave a quick scrub with a wire brush to clean up a little bit. One thing I noticed is the nicks in the rubber seal. I think these are purely dust seals so not too much of a concern or risk of leaking fluids. Haven't lost any fluid either so I guess it's ok. Otherside was worse. Doesn't matter if it doesn't keep the dust out longer term as I have all new parts in the post to go on anyway. I cleaned up the pads with the brush, brake cleaner and sanded the edges. Putting together using brake grease on the back and sides. Also gave the edges of the backing pad a very light covering of grease. Next up was to adjust the rear brakes. I did the usual tighten up and then loose a couple of clicks. All felt good. Then tried the handbrake. This caused the offside to stay pretty stiffly engaged. Pulled off the drum to inspect. Turns out the handbrake lever is rusty and isn't moving freely. For now if I push the lever back by hand it releases. Something else I need to order and replace. I did try backing off the handbrake adjuster under the car but it didn't make much difference. That pretty much took most of the afternoon today. God knows how. Also warns me that brake overhaul/rebuild on front and back will take most of a weekend. Quite tempted to farm it out to a garage and let them take the pain. Went out for another drive and fill up. Pez shot. Only actually the third time I think it's been to a petrol station in my ownership... Then went back to the local church for another picture while no cars were there. Instead they put banners up in the way! On the way back I went for a quick blast on the ring road to get her upto 60mph. Ran alright but did require a bit of work to keep her in a straight line. Also noticed that the idle has dropped back since filling up. Maybe the new fuel or different brand had affected the mixture. I guess it burns easier so probably a bit richer? Front brakes were a good 30c cooler than previously. Rears still had the imbalance. Pretty sure that's mostly down to the drivers side shoe rubbing, from the handbrake not releasing properly. So far the mileage since coming out the garage has rolled over 70 miles. Now my confidence has been restored some what, I now need to start venturing further afield... egg, Coprolalia, Skizzer and 8 others 11 Link to comment Share on other sites More sharing options...
SiC Posted May 18, 2019 Author Share Posted May 18, 2019 Oh I forgot to mention that I'm still getting dripage out of the gearbox/flywheel area. Oil looks dirty though, so maybe it's just oil sitting in the bottom from where its leaked while sat stationary. Also took my elderly neighbour for a spin in it. Totally made his day which is nice - especially as his wife is in hospital and feeling a bit down. He always tells me about how when his son was 19, he went out and bought a Triumph Spitfire. Both him and his son loved that car apparently! Nice to have made someone's day. Especially as my neighbour is such a jolly friendly chap. Took Mrs SiC upto the supermarket in it. She did quip that it'll probably break now she's in it. She has that affect on my cars sometimes! Anyway the car ran fine. Mrs SiC commented on the fact that it's quite tappy. Sounds like a mini steamtrain apparently??! Maybe I'll have to get an alloy cover to hide that noise more. Longer term if I still have it, it'll probably get an engine rebuild in time. No point doing just the top end when the bottom wouldn't go a miss being rebuilt either. Dick Longbridge, alf892, Scruffy Bodger and 4 others 6 1 Link to comment Share on other sites More sharing options...
Mally Posted May 19, 2019 Share Posted May 19, 2019 Handbrake lever, it's a while ago, but I'm sure the levers have a rivet in that rusts up. You have to take the linings off, remove the lever, hit it with a hammer on the rivet, spray with WD40, wiggle it for 10 minutes until its free and reassemble. You can just spray and wiggle it in situe, but knowing you, you won't. PhilA, busmansholiday, alf892 and 1 other 4 Link to comment Share on other sites More sharing options...
dome Posted May 19, 2019 Share Posted May 19, 2019 Good to see you getting some confidence in this thing. Keep racking up the miles! LightBulbFun 1 Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 7 hours ago, Mally said: Handbrake lever, it's a while ago, but I'm sure the levers have a rivet in that rusts up. You have to take the linings off, remove the lever, hit it with a hammer on the rivet, spray with WD40, wiggle it for 10 minutes until its free and reassemble. You can just spray and wiggle it in situe, but knowing you, you won't. Haha! Yes the whole arm is very rusted. I did actually spray on the pivot point with penetration spray and give it a good wiggle in-situ. However I think it's too badly rusted for that to work. It'll be either get it out, pull it apart and spend ages getting the rust off OR just spend a tenner and get a new one. Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 Took it for another quick spin. If I release the handbrake, leave in gear and hit the handbrake lever back with a hammer then it does seem to release properly. Admittedly it wasn't a long drive (2 to 3 miles ish) but the rears were 23c and 27c respectively. I'll see what they are like after a longer drive. Just need to keep a close eye on them until I get them rebuilt. Took the wipers off to replace the rubber sealing washer. I'm hoping this will fix the footwells getting wet when it rains. Y tho?? Put a bit of touch up paint in that area that had lost a bit of paint. Now just need to figure out why the boot keeps getting wet when it rains! Coprolalia and egg 2 Link to comment Share on other sites More sharing options...
PhilA Posted May 19, 2019 Share Posted May 19, 2019 Because it faces upwards and it's made by BL That's a "feature" Joey spud, Dick Longbridge, adw1977 and 1 other 4 Link to comment Share on other sites More sharing options...
captain_70s Posted May 19, 2019 Share Posted May 19, 2019 50 minutes ago, PhilA said: Because it faces upwards and it's made by BL That's a "feature" Every single one of my BL cars fills it's boot with water, even the one which is a Honda. In the Dolomite's case this means water collects under the fuel tank and rots out both the base of the tank and the boot floor. Great fun. Not sure on the 'ol MG but on my Triumphs the main water ingress area seems to be the rear light cluster seals. Quote Ran alright but did require a bit of work to keep her in a straight line Again, the Dollys are a similar story. Especially the 1850 which required a good 1/4 turn of the wheel to keep it in a straight line against a crosswind... By the time you neared triple digit speeds keeping it on the correct side of a standard width A-road was a genuine struggle due to front end lift. Worth checking any U/Js in the steering system for play, Dolomites burn through them quite rapidly for some reason. Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 The boot has always leaked in this. It was ok before I put the new fuel tank in as the water simply got on the top of the tank, then leaked into that through the rust holes. Now there is a shiny new tank, it doesn't really have much place to go! My suspicion is a combination of the fuel filler seal (did I change this with the tank??), number plate light wire grommets and the rear lights. I did think I replaced them but I've done so much over the years I can't remember. Have also got a new tailgate seal to fit but that's quite a lot of hassle, as I think the tailgate needs to come off to do that one. Not sure how the rear lights come out? Looks to have a nut on the back that bites into the body metalwork. So probably a bit of a mission to remove. Bung it out for now so some of it can drain out. The wayward steering could well be down to the rear drum grabbing. I don't expect amazing high-speed running - especially double figures, but it would be nice to have upto 70mph reasonable. Not that I've got it that fast yet... Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 Just come back from a trip out to Newark Park National Trust with Mrs SiC. Lovely drive over and the car performed fine. About 40 miles round trip or so if you are wondering. Longest journey I've done in it, apart from the original drive back from buying it. Hurrah you say!Most were 30 or 40mph roads, so pretty sedate. Actually tended to be a fair bit slower as getting stuck behind bloody slow Sunday drivers. Including up a hill where a nearly brand new Disco was doing 25-35mph, causing a hold up for a TR4a and myself stuck behind it.On the way up there the front discs were at around 75c (passenger side always ~5c hotter but there is the exhaust manifold that side) and the rear drums were 30c and 38c. Back home it was a different matter. Fronts again around 70c, rears this time though are 35c and 78c. Looks like I didn't whack the handbrake lever in well enough before setting off on the way back. Definitely need that side sorting before I go on any longer or faster road journeys. RayMK, egg, alf892 and 11 others 14 Link to comment Share on other sites More sharing options...
Mally Posted May 19, 2019 Share Posted May 19, 2019 Nice photo that, good to see it's being used as it should. My Roadster had 165 tyres and used to follow ruts everywhere. My GT had 185 tyres, which are not standard, always looked flat, but weren't, and drove perfectly. Both were capable of 70mph, at least! Link to comment Share on other sites More sharing options...
mrbenn Posted May 19, 2019 Share Posted May 19, 2019 Good work! Particularly like that second pic. Link to comment Share on other sites More sharing options...
egg Posted May 19, 2019 Share Posted May 19, 2019 6 hours ago, PhilA said: Because it faces upwards and it's made by BL That's a "feature" Yeah, Ford copied it from BL on many models too. Si - great work. So pleased to see this out in the May time weather. Like Bornite said, will be good to meet you at FoTU. Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 1 hour ago, plasticvandan said: Keep using it and it will sort itself out. I'd love for this to be true and not have to do any more work on this so I can just use it. Unfortunately all that will do is roast the bearings and create even more work to be done. Link to comment Share on other sites More sharing options...
SiC Posted May 19, 2019 Author Share Posted May 19, 2019 Yes and the next car I get will be one that's been used regularly! Unfortunately on these old nails it seems to be that immaculately body usually means hardly driven, fully/mostly working mechanicals means heavily driven but that leads to rougher bodywork. busmansholiday 1 Link to comment Share on other sites More sharing options...
