strangeangel
The Beige BX Progress Thread: 26/5 Progress!
Today's update, then... the sphere tool was deployed early doors; we were expecting to have to use unreasonable force to get them off, but they were little more than hand tight! To our delight, a quick test ride revealed that the bigger, 2nd hand spheres found in the boot have restored the BX's magic carpet ride :)
In removing the airbox to make room, we found that the plastic inlet had been damaged due to the attached hose being horribly over-tightened, allowing the car to suck in unfiltered air...
That got re-shaped by warming it up with a hair-dryer and strengthened by the insertion of part of a Volvo washer bottle filler neck! The filter itself was shagged; the foam crumbled and it didn't bounce back if you poked a finger at it:
While the car runs it's never idled brilliantly, so we decided to take the carburettor off, and I've brought it home to clean. It's certainly filthy, and the waterway through the bottom of it is blocked solid with alloy corrosion, which has made us wonder about the state of the water pump.
Another thing of note is that the rad has been bodged with some sort of black gunge, and leaks when the car is up on ramps. Replacements can be had for £60 or so, so not the end of the world.
FInally, big thanks to MRS_CLELAND, who spoilt us rotten with a delicious lunch of Thai noodles, and home-made cake! What more could a 'shiters work party ask for?
More soon, hopefully!
Share this post
Link to post
The chin strikes again!
Big thanks to MadMarkHairnet and StrangeAngel for making the trip up to Castle Cleland today. We didn't bust a gut, but had no problems, so we made some progress on the thankfully low-hanging fruit.
Some great parts-chasing research there Mark. To avoid confusion, the tank sender thing we need is fr the fuel (not gauge), and it looks like a small disk with two straight pipes on one side, and on top, two shorter ones possibly bent at 90 degrees for the hoses to fit on.
Our stone chip looks nasty, and has some damp in it, but it's not a distraction from the driving seat, so hopefully Mr MOT will not kick up a fuss. But it's good to know screens can be had.
I didn't take many pics, but as Jaz said, the air filter housing was reinforced with a piece of Lolvo 850. I kept the emblem on it as a tribute to Adrian_SVM for the gift of the sphere tool, lovingly modeled by Mark above. ^^
Share this post
Link to post
Great news on the progress.
Please remember that we still have £65 in the kitty for any expenditure necessary.
If any part are needed or have been bought already, let me know so I can send you monies.
Also if there's need for more, we could always have another collection amongst owners and fans...
Share this post
Link to post
The windscreen being 'forgotten about' on the mot would be handy as it could be replaced at leisure, either through someone's insurance as an autoglass job or buy and fit. Rather than have the entire car ready to pass but struggling on the windscreen or being bum raped by someone who has to come out and fit it there and then
Share this post
Link to post
It's beyond repair, even if they did fix it the edges are all cloudy internally for a good inch.
Crowd fund the £75? But would it be easier to have it mot'd and legal first so you could just say it's been going cloudy for a while and wallop, you caught a stone etc? I don't know how much they care tbh, the meriva had a massive chip for 2 years before it split the screen, amy said it all happened at once 3 days before and the guy didn't care apparently
Maybe wash it first too so it doesn't look like it's been sat for ages
Share this post
Link to post
Good work Team Beige!
I was hoping to be able to lend a hand on this working party but other things of a higher* priority got in the way
(*WHAT could be of higher priority than saving an early miserable spec BX? This is a discussion that me and SWMBO are yet to have...)
Keep up the good work and vicariously satisfying updates. With chins and halos.
And shout if there needs to be more fundraising.
Share this post
Link to post
I should add that we did do some rudimentary MOT-style checks:
- vehicle structure looks good (there is evidence that welding has already been doen in the boot)
- no ripped CV boot/ball joint gaiters, haven't checked for worn joints but there's no knocking when driven.
- lights, horn etc all working, although the huge and weird dip/main beam switch needs some TLC
- brake pipes look sound but some surface rust (will be cleaned up and covered in spray wax at the next work day)
- windscreen is a total fail as discussed earlier (but you never know your luck ;) )
Pics of that rank carburettor getting cleaned soon!
Share this post
Link to post
IIRC, the headlamps do not use relays, so the entire headlamp draw goes through it, buggering up the contacts. Had issues with the switch on my Mk1 all those years ago.
I think it's OK in that respect, the problem is that it's really stiff and sometimes sticks when pushed in. Hopefully a good clean and a bit of lube will cheer it up.
Share this post
Link to post
whos good with lectrickery
put them thru relays cos if you get meltu and cant get another????
safer too
Share this post
Link to post
If you can dig out a sender to fit, Tim, that'd be ace. Don't bother modifying... you may have noticed my "tray of snakes" hose collection in the pics, I'm sure we can make it fit.
I easily found a suitable return hose in that lot.
We haven't spent a penny on it so far, just made do with what we had. :D
Parts needed: only what has been mentioned, if the screen will scrape though a test, I think £100 should cover all it needs for now. Plus about £50 for a test at my tame place, if that's what you're all happy to go with.
We were saying yesterday that after some light shopping and another half day of tinker time, with some luck it should be ready to try for its MOT. :D
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
  • Similar Content
    • By davehedgehog31
      I've had various threads on the go for different collections this year, but thought I'd condense my threads into one manageable thread to document my ham-fisted tinkering.
      At the turn of the year I was driving a nice, dependable, modern 2011 Peugeot 407 and no other vehicle. It was nice enough, but boring as feck. I'd bought it after a series of disastrous heaps in the awkward age bracket of being new and valuable enough to worry about but old enough to be fucked. The 407 was just too new, too bloated and dull. I had a hankering for old metal, my Mineral Oil withdrawal pangs were strong.
      From January I started looking, there were eBay bids, missed reserves, wasted trips from Gumtree and other such nonsense. I happened on an automatic Rover 216 GSI with one giffer owner from a year old. The chap was giving up driving at 93 years old and his grandson was moving it on. I bid, and failed. It was in London though, about 420 miles away so I wasn't all that bothered. Of course when he offered it to me for my losing bid after the winning buyer was a no show I said yes. I was on the Megabus down to that London overnight for about £15. I hung about in Liverpool Street station like a mad shivering jakey until my train out to the suburb for my first sight of the new steed. It was battered outside but had been well looked after. A frankly insulting amount of cash changed hands and I was away up the road.
      We had many adventures together, it was dependable and it whet my appetite for interesting old motors again and proved that the very bottom end of the market was navigable if I had the patience to wade through the sea of shit to find the odd pearl.
      The 407 was still on the fleet at this point but I was covering a lot of miles in the Rover, with a long commute though the fuel economy wasn't ideal. When a friend's mother was looking for a new diesel saloon to replace the faithful old Xsara she had a scheme was concocted. I sold the 407 to her and was on the hunt for an interesting replacement.
      When I was growing up my dad had a succession of hopeless shitters, indeed I was brought home from the hospital as a newborn in a brush painted Skoda Super Estelle. The best car he had was a red XUD Peugeot 405 with air conditioning and electric windows. So when I found a 1994 GTXD advertised by someone who could actually compose a car advert in the fashion you would expect of a human being educated to a Primary School level, I pounced.
      Of course I couldn't buy a car just down the road so it was on the train to Birmingham. First class no less. I stayed in an absolute flea pit of a hotel and drove up the road the next day. This was a proper bit of nostalgia and a really practical borderline classic car. It had been fastidiously maintained by the previous owner. Apart from there being a hole where there was once a stereo and the lack of working air con it was a pleasant drive home.
      Given their relative scarcity and how dependable this one has proven so far, it's a keeper, I'd struggle to part with it.
      Two cars just wasn't enough to worry about, so this Citroen C1 was acquired. Pure Aleppo spec. A camel can go for weeks, or months without stopping at a watering hole, the C1 has a similar thirst for Motor Spirit. Man maths were employed and worked out that it would easily* pay for itself.
      There have been further movements, I'll recap them shortly. I should probably do some work.
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By scdan4
      That bit hiding up behind the air filter and infront of the turret
      made a prolonged, loud, farty vibratey noise (loud enough to be clearly audible in the cabin with the radio on) twice today, both times it did it the nose was pointing down a steep hill and we had just parked and turned off the engine.
      It goes on for best part of a minute, so managed to track it down. Initial impressions are fuck knows what it is but it's clearly been bodged in the past. The yellow hose has clearly been disconnected sometime, by someone, for some reason, somewhere.
      Thats the blighter.
      Does someone want to tell me why it's blowing raspberries at me?
    • By TheDoctor
      As you may have read in the 'Can we save this?' thread, the answer was 'Yes we can!'
      Someone on this forum who wishes to remain nameless, fronted the cash to rescue this little Mazda from certain doom at the hands of a banger racer. I've taken custody of the car, but will make sure they get their money back as soon as is physically possible.
      Perhaps once it's running right, I'll look at some sort of roffle to find it a new home and pay back what it owes me and them.
      Although it had been sitting 5 years or so, it went through an MOT, so that's a good start.
      Known faults.
      - Alternator is kaput. Shouldn't be too hard to find a refurbished one. Presume battery knackered too.
      - Wheel bearing grumbling.
      - Running like crap. Will replace fuel and vacuum pipes and add fuel filter. Then perhaps a carb strip down and rebuild. Aisan 980 carb as far as i know, same as the Toyota was,
      - Flat tyre.
      It's currently sitting outside with a flat battery and no fuel, so that's not a good start!
      As I have very little talent, time or money, and suggestions / help greatly appreciated.
      These are the pictures I have so far - looks good but it's a lot more dull in real life...
