richardthestag
Range Rover resto - Project Southpaw p24
1 minute ago, richardthestag said:
thanks mon brave
Re yootoob money and I demonetised due to lack of followers and profanity. Couldn't care less about that anyway as the adverts just get in the way ;)
Yes I am pulling together a HGF video and currently uploading episode 5 of Project Southpaw which what you have read above is the spoiler.
haha yeah im not surprised :)
ah cool I look forward to seeing it, I asked because I know a HGF on your daily can be one of those jobs that you may want to just get done and over with rather then faff around also trying to film it!
but I appreciate that you are filming it for us!
Share this post
Link to post
lets bring Southpaw up to date
Episode 6 is right here with all the Demonitised content
You chaps happy with videos or would you prefer photos and text also? It does duplicate the video but .....
Personally, I really appreciate watching your videos and imagine they already take a lot of extra work (and frustration) without having a write-up as well.
Sent from my SM-G955F using Tapatalk
Share this post
Link to post
I love these videos, Richard. Feels more immersive than pics/text would be, partly as you tend to explain what you're actually doing while doing it. Helps my little brain grasp it.
Sweary man in a shed in Devon, surrounded by BL chod. Big thumbs up from me.
Looking forward to the HGF update!
Share this post
Link to post
Photos and text please.
(Windy Miller popping his head out at 3.47 can be avoided that way!)
Share this post
Link to post
aye I enjoy both the writing and the videos :)
its also not a bad way to have 2 records of the build, should you need to refer back to something etc, or should something happen to the youtube videos or vice versa etc
Share this post
Link to post
it was the Robin !! 🤪
I do try to edit them out but I can be quite flatulent
write ups will continue :D
Share this post
Link to post
The Robins in our garden seem to have decided their territories to include one of the "awaiting restoration" vehicles in each territory.
Share this post
Link to post
write up on Southpaw :D
spent an age cleaning gloop off the drivers side inner wing, sticky oil, sand and mud. Used a screw driver and wire brush to loosen stuff and an air blow gun to shift it.
Then I used some eastwood spray paint prep that the owner of the car had already bought. very effective but some nasty chemicals!
The paint which is 121 chassis paint from rust.co.uk and applied with a 2mm paint gun running at 75-80psi ish. very tough but quite orange peely. exactly what the customer wanted! And I think it looks good too
Autosparks couldn't help with changing the lhd loom to rhd, shame. Gave up wasting any more time and bought a complete loom* from a 1993 200tdi Range Rover. Alas it arrived without engine/gearbox and door looms. Those were extras..... double alas they had sold the engine and gearbox looms but I managed to snaffle the door looms for an additional £50.
Repair panels for the inner wing were sourced from YRMIT.Co.uk, dirt cheap but accurate cut. Wish I had gone this way with the drivers side. Just cut the lot out and weld new in, no chasing holes
Tag welded it in as it is on the original spot weld lines and is also not structural...
prep and paint finished it off nicely
installed the bulkhead loom into place, the old body (front - back) looms are hanging off the rear view mirror
dropping the headlining one side at the time gave me the space to route the body loom through to the back end of the car
indicator units were spliced into the new loom using crimped bullets and quality sleevies
for the rear light units, I cut the prep 1991 connectors  off the original body loom and then spliced them onto the new loom. This allowed me to locate the splice inside the car rather than with the elements
2nd hand but working boge unit finally arrived. had to remove top and bottom ball joints, fit the refurbed top joint and then get it in the car
and that's it ! rear suspension complete. Just need to finish the brakes and get the propshaft on and I can drop the back end back onto the ground
Today, no pics sorry.
Fitted up the rear brake lines and pads
bled the brakes throughout.
Fitted the rear prop
then removed the old engine and gearbox loom and scratched me head for a while
Oh and found that the fuel line and return are protected where they cross 2cm above the exhaust by tin foil!
Share this post
Link to post
On 10/26/2019 at 4:45 PM, richardthestag said:
thanks mon brave
It's criminal that you're not benefiting in a fiduciary sense from these videos.  As well as learning a lot from them, I still laugh every time you say seal then make the 'ow-ow' noise.  See also 'fnarr fnarr' after anything vaguely rude-sounding.
Share this post
Link to post
  • Similar Content
    • By Shirley Knott
      Greetings all.
      After lurking here for a short while, frankly liking what I see and enjoying the various shite, the site has well and truly struck a chord with me. I'm a serial buyer of ropey sub £1k vehicles, don't have to but genuinely enjoy it.
      I feel like I might (Just might) have found my 'spiritual' home here
      I've been posting across the web on owner specific forums (Usually using either my JoeyEunos or RandomPrecion handles) for a while now, but from here-on-in I will pull my threads together and merge them here into one ghastly topic.
      My current steeds...
      Lupo 1.7 SDI
      SAM_5560 by
      and the work/story so far...http://forums.clublupo.co.uk/index.php?/topic/102863-joeyeunoss-sdi-beater/
      Golf Mk4 SDI
      SAM_5531 by
      and the thread.... http://uk-mkivs.net/topic/597074-project-slow/
      Early (1989) Mk1 Eunos (This one was recently sold)
      SAM_4656 by
      the thread...http://www.mx5nutz.com/forum/index.php?showtopic=213274
      Other shite I've owned and moved on in the last year include this ropey Passat...
      SAM_6011 by
      and this legendary £300 Fiesta Finesse...
      Festa by
      Cars I'd like to own/actively looking for in the forthcoming weeks/months/years...
      Rover 75 (Dizzler)
      Peugeot 405 (XUD)
      Mk1 Octavia (Estate/dizzler, pre pd or SDI)
      Honda CRV (Gen1)
      Volvo 240/850
    • By Broadsword
      I think the Broadsword fleet has become sufficiently complicated to merit a combined thread so that gradually all new additions will appear in one place.
      As of Sunday 17th March the situation is interesting.
      Two Citoren Xantias (remember the white Xantia of Excellence is for sale people!)
      http://autoshite.com/topic/34699-w-reg-citroen-xantia-20-hdi-xantia-of-excellence-%C2%A3999/
      http://autoshite.com/topic/34596-citroen-xantia-double-madness-rust/page-2
      A turquoise XJR6 pending overdue-collection (need that gone now!)
      http://autoshite.com/topic/34003-jaguar-xjr6-double-madness-double-sold
      An XJS 3.6 manual project which will get in high gear soonish. Wont be a keeper but will be fun getting it back to something presentable. Drivers fantastic!
      http://autoshite.com/topic/34664-jaguar-xjs-36-manual
      A Range Rover P38, which is turning out to be really rather good.
      And to mix things up even more I'm off on a collection caper today. Had first refusal on it and was expecting it to come around in a year, but things soon changed and no way was I going to pass up on it. It may well render the second Xantia redundant as I've got a really good feeling about this motor.
      In the meantime here are some snaps of the Range Rover. As usual it was a car I said I would probably never buy due to their reliability*. I have said the same of Jag XJR, XJS, XK8 and I have had all of those now. Basically the moment I declare buying a particular car is impractical or improbable, I end up buying one.
      Things to note on the P38. It's a nice colour with tidy body. The EAS has been removed. It runs and drives lovely and it doesn't have enough electrical problems to hinder progress. The main one is the driver's side window not working, but that should be fixable. I've tried changing the outstation, that didn't fix it. Might be wiring under the seat. Other than that I bought it and took it for an MOT the very next day, and it passed. Since then it had what seemed like a battery drain, but since unplugging the RF thingy for the remote locking and putting on a proper lead-acid battery, which the car can actually charge, unlike the modern lead-calcium batteries, it has been perfect. I will treat it to a full service soon.
      Stay tuned for the latest collection later today!
    • By beko1987
      I've noticed that some people on here have imagination, and get through a wide variety of different brands of cars
      Then there's me, who after hitting the armagedden button when the 406 threw me a load of urgent work that I didn't have the time or money to perform by it's MOT obtained yet another french car!
      My car history really has been a bit samey
      Landrover Series 3 (PMA124Y)
      Peugeot 206 (W636OAU)
      Ford Puma (Y874RCB)
      Citroen ZX (R385VRD)
      Citoren XM (R267PGF)
      Citroen ZX (L592NWK)
      Citroen Xantia (R499AMV)
      Renault Laguna (YT55ENP)
      Renault Laguna (FV51FYP)
      Peugeot 406 (HY02FUA)
      2 out of 10 of the above are still alive...
      And as of tonight
      Citroen ZX (R579SLX)
      So over 11 cars, a definite pattern! But I like boring, I like samey, I like reliable*
      Current status? Well our very own Bramz7 is somewhere in the north of england (maybe even nearly scotland) delivering a car. At almost possibly maybe 4.30/5pm he will arrive in Derby and collect Bub's ZX. Following a very silent drive to my house in Oxfordshire as the ZX has no radio we shall convey ourselves to his house, and I shall drive home...
      Moar later!
