Supernaut Posted March 12, 2019 Share Posted March 12, 2019 Yeah, if you just chopped it off that's a fail.IIRC the exhaust needs to exit at the edge of the vehicle, not under it. Nice old boat, though. I expected a column shift, not the floor shift.An acquaintance out in Oregon has a properly shonky earlier one of these in white with a beige interior and column shift. The tailgate doesn't fit properly and whistles in the wind. It's slow too, but sounds brilliant. dome 1 Link to comment Share on other sites More sharing options...
spartacus Posted March 12, 2019 Share Posted March 12, 2019 Oh my, that's vile. Surely you must win a prize.About 20 years ago I worked at a place that did a lot of LPG conversions, the supplier of the kits had a list of vehicles that he didn't recommend converting, the Explorer was at the top. I'm not sure why though. Although I'm sure with your perseverance all will be made well. Does it drive on LPG? dome 1 Link to comment Share on other sites More sharing options...
Rod/b Posted March 12, 2019 Share Posted March 12, 2019 I used to have a 2010 Explorer XLT. It was alright, really. GOOD PURCHASING dome 1 Link to comment Share on other sites More sharing options...
dome Posted March 12, 2019 Author Share Posted March 12, 2019 Oh my, that's vile. Surely you must win a prize.About 20 years ago I worked at a place that did a lot of LPG conversions, the supplier of the kits had a list of vehicles that he didn't recommend converting, the Explorer was at the top. I'm not sure why though. Although I'm sure with your perseverance all will be made well. Does it drive on LPG?It was converted in 2004 and the old boy was told by his garage it had been done well. It's still there and seems to work, the filter looks fresh too. yes oui si 1 Link to comment Share on other sites More sharing options...
dome Posted March 14, 2019 Author Share Posted March 14, 2019 Today was the day to get the engine into the MR2 Firstly i pulled the gearbox back off the engine to lube the shaft and the clutch pivot, then torqued it all up along with the starter. Meanwhile Fraz who lurks on here and Duncan who doesn't prepped the MR2-bumper and taillights out and RHS rear strut off and hub tied out of the way to aid sliding the engine in. We then got the engine and gearbox onto a trolley and ready to slide in Now at this point i should probably mention my highly organised* garage I had arranged things and labelled things as I stripped the two cars down. The original MR2 gearbox mounts had to go onto the Corolla gearbox and as I had clearly labelled 2 mounts as "From Corolla" I knew exactly which mounts to fit which I did a few weeks ago. Fast forward to today and we lifted the back of the car using the crane and slid the engine and box in. We then lowered the car back onto the axle stands and hoisted the engine and box back into place. Except we couldn't for the life of us get things to line up. Yes, I'd fitted 2 of the wrong mounts to the gearbox. We quickly noticed this, and absolutely didn't waste about 3 hours trying to make it fit. The mounts looked the same but were a different size and meant the gearbox was fouling the body. Of course, as soon as we (OK Fraz) figured this out and we swapped them (after removing the "From Corolla" label from them...)it bolted right up. And here it is, in and bolted up. So much for getting it plumbed in and running today. Still, at least it's in. I also jacked up the Exploder in preparation for it's new discs, pads, drop link and CV boot. Now, if nobody minds, I'm off to have a big old glass of whisky. Dick Longbridge, Jim Bell, mat_the_cat and 15 others 18 Link to comment Share on other sites More sharing options...
Split_Pin Posted March 14, 2019 Share Posted March 14, 2019 Excellent wirk Brian, Whisky very well earned. LightBulbFun and dome 2 Link to comment Share on other sites More sharing options...
Mally Posted March 14, 2019 Share Posted March 14, 2019 IIRC the exhaust needs to exit at the edge of the vehicle, not under it. I thought that until we got a Mk7 Tranny Van Link to comment Share on other sites More sharing options...
Fraz Posted March 14, 2019 Share Posted March 14, 2019 There was much swearing and head scratching today due to those mounts... Oh how we all laughed and joked about it ???? Link to comment Share on other sites More sharing options...
The Moog Posted March 14, 2019 Share Posted March 14, 2019 Did applied whiskey help? Link to comment Share on other sites More sharing options...
dome Posted March 15, 2019 Author Share Posted March 15, 2019 Did applied whiskey help? I didn't apply enough! Split_Pin, The Moog and Flat4 3 Link to comment Share on other sites More sharing options...
dome Posted March 22, 2019 Author Share Posted March 22, 2019 OK, MR2 update first. Well, there's not much to update as I haven't touched the car since we got the engine in-Saturday was the only day I had free and the weather was shit. I did however have a crack at the manifold. We need to use the Corolla manifold as the old one doesn't fit the new engine. The trouble is as standard it hits off the subframe. There are aftermarket solutions available to fit the standard MR2 exhaust but they sap power, the standard Corolla manifold is very good. The technique I decided to use was to cut slots in the pipes near the manifold flange, then bend the exhaust up and reweld it. Seems like a good idea? Remember I can't weld... I succeeded but it's not pretty. I'll come back to it and grind it down and tidy it up a bit but it fits. Then you might get a picture. I chopped off a section of the Corolla downpipe to check clearance. And yes, it will be getting fired up like this Next up-fit driveshafts and struts then plumb in the engine. But not this weekend sadly as I'm away with work. Tickman, Dick Longbridge, nacho man and 5 others 8 Link to comment Share on other sites More sharing options...
dome Posted March 22, 2019 Author Share Posted March 22, 2019 And onto the Explorer. The MOT fail wasn't too bad and boiled down to the following Free off all brakesNew pads and discs all round-rears were a fail and fronts were pretty worn. At 2 tons nearly I'm not going to grudge it a set of brakesCV bootAnti roll bar linkFix the exhaustFit some bulbs On Saturday while welding the MR2 exhaust I popped a tailpipe onto the Explorer. Not pretty but in keeping with the general theme of this old heap. Sounds good though I'll likely trim it down a bit more. For irony it's actually an old section of exhaust off the Freelander With the rest of the work again time was the issue but I took an hour or so in the evenings and cracked on with the rest of the fails. Anti roll bar link was straightforward and the balljoint for the front suspension came apart surprisingly easy allowing me to get the shaft out to fit a new CV The driveshaft doesn't split so i elected to use a stretchy CV boot for the first time. Behold, my cone... So, I went in prepared. Driveshaft clamped in vice, new CV boot in a bowl of hot water to soften it and plenty of lube applied. I was warned you get one shot at this as if your hands get water or lube on them then you'll not stretch it on. So, off I went. And, success! Oh no wait. I'd managed to put it on THE WRONG FUCKING WAY ROUND No pictures funnily enough as I was too busy swearing and/or crying. Somehow I managed to wrestle the CV boot back off but nicked it so when I tried to put it back on it split. I did what any sane person would do, gave up and drank some beer. Next morning I dropped it off at my local garage along with some more beer. Some things are best left to the professionals. Wednesday night I could put it all back together and only had the rear discs to do These big lights came in handy These proved challenging as the disc had seized onto the hub so no amount of hitting would free it. I tried heat to no effect. Only one thing for it. Death Wheel FTW Gotcha ya fucker. Back together and I dropped it off at the MOT station yesterday and got this result. Now i can get on with making it presentable and usable. Oh and actually drive it! Joey spud, Dave_Q, Mrcento and 12 others 15 Link to comment Share on other sites More sharing options...
The Moog Posted March 22, 2019 Share Posted March 22, 2019 Good work captain! dome 1 Link to comment Share on other sites More sharing options...
jaypee Posted March 22, 2019 Share Posted March 22, 2019 Many successful points!! Sent from my PRA-LX1 using Tapatalk dome 1 Link to comment Share on other sites More sharing options...
dome Posted March 26, 2019 Author Share Posted March 26, 2019 Explorer I've been away with work since it passed it's MOT so haven't had a chance to even drive the thing since I got it legal until today.Whilst away I did manage to find the time to visit a guy who was breaking one. The problem is I've been so busy getting it through it's MOT I haven't even looked to see what else it might need from a cosmetic point of view.I picked up a caliper carrier which I knew it needed and a set of mats including a rubber boot mat to replace the ones I had to chuck out.He also made me an offer I couldn't refuse for a set of 4 wheels with matching tyres. The wheels that were on mine were pretty shocking-2 different styles for starters and they all looked fucked.3 of the tyres were pretty new but it was on different sizes front to back, so much so that fitting the correct size tyres has lifted the back end at least an inch-I had to jack the truck up further after removing the old wheels to get clearance to fit the new ones! No decent pics yet but it's looking a million times better from the office window It drives not too bad but there's an intermittent wheel wobble which wasn't there on the test drive-one possible cause of this according to those in the know is air getting into the system when the steering is turned with the engine off-for example when changing discs and pads and a cv boot. Will try and bleed it to see if that makes a difference. It's still pretty disgusting inside though. I've ordered a fascia kit to fit a single DIN stereo I have in the loft, then I'll have a look at the oil leak and the fact that when it got the gearbox rebuilt the linkage wasn't adjusted correctly-drive is where 2 is on the shifter and reverse where neutral should be. Oh and the heater blend doors are knackered-the heating is stuck on hot. Well documented and I should be able to get it sorted. Oh and the oil leak... MR2 Zip. Nada. Haven't touched it since putting the engine in, apart from modifying the manifold. Will get stuck into it on Saturday though. mrbenn, The Moog, cort16 and 2 others 5 Link to comment Share on other sites More sharing options...
Sir Snipes Posted March 26, 2019 Share Posted March 26, 2019 I hadn't noticed the mismatched wheels until now... Link to comment Share on other sites More sharing options...
dome Posted March 26, 2019 Author Share Posted March 26, 2019 Did the power steering bleed tonight after work, chucked some fuel in and put some wind in the tyres. What a difference! Cruises quite happily at 70 and is quite a pleasant place to be. Removing the woodscrews from the rear pocket that were rattling around made a big difference too... Sent from my Moto G (5) Plus using Tapatalk Tickman, mrbenn, The Moog and 2 others 5 Link to comment Share on other sites More sharing options...
dome Posted March 26, 2019 Author Share Posted March 26, 2019 I hadn't noticed the mismatched wheels until now...Don't worry, it was the morning after I bought it that I noticed... Sent from my Moto G (5) Plus using Tapatalk Ohdearme 1 Link to comment Share on other sites More sharing options...
Fabergé Greggs Posted March 26, 2019 Share Posted March 26, 2019 What’s the bike? Looks like a pretty similar vibe to a Commencal meta hardtail that was nicked from the roof of my BX (sad face) Link to comment Share on other sites More sharing options...
dome Posted March 26, 2019 Author Share Posted March 26, 2019 What’s the bike? Looks like a pretty similar vibe to a Commencal meta hardtail that was nicked from the roof of my BX (sad face)It's one of these http://nukeproof.com/products/scout-290-sport-2019/ Cracking little bike. I may* be biased though, I work for the distributor... Gutted for you on the theft. Hope you got sorted? Link to comment Share on other sites More sharing options...
Split_Pin Posted March 27, 2019 Share Posted March 27, 2019 Absolutely love this big truck, can't wait to see it this evening at Scotoshite. Link to comment Share on other sites More sharing options...
Fabergé Greggs Posted March 27, 2019 Share Posted March 27, 2019 It's one of these http://nukeproof.com/products/scout-290-sport-2019/ Cracking little bike. I may* be biased though, I work for the distributor... Gutted for you on the theft. Hope you got sorted?Ah nice! I rode my mates nuke proof slopestyle bike for a while, loved that thing to bits! The theft was a little while back now, sadly no more mountain biking for me after I did a thorough job of breaking my arm into a million pieces... sigh dome 1 Link to comment Share on other sites More sharing options...
dome Posted March 27, 2019 Author Share Posted March 27, 2019 Absolutely love this big truck, can't wait to see it this evening at Scotoshite.You'll need hazmat gear, I now realize the term barn find refers to what you find inside this truck. 12 minutes of Tesco's finest forecourt hoover this morning and it's still bogging. Link to comment Share on other sites More sharing options...
Split_Pin Posted March 27, 2019 Share Posted March 27, 2019 Cheap wet and dry vac from Amazon may help? Link to comment Share on other sites More sharing options...
Fraz Posted March 27, 2019 Share Posted March 27, 2019 Set a small fire inside to burn the mess out? 320touring 1 Link to comment Share on other sites More sharing options...
dome Posted March 27, 2019 Author Share Posted March 27, 2019 Cheap wet and dry vac from Amazon may help? Our Vax carpet shampooer committed Har Kari the week before I picked this thing up. Clearly it was sentient. Split_Pin and Dave_Q 2 Link to comment Share on other sites More sharing options...
dome Posted March 28, 2019 Author Share Posted March 28, 2019 The Exploder performed well on it's first decent run on my ownership. A 70 odd mile round trip to Scotoshite last night. It does however like to mark it's spot. The sump leaks quite badly onto the ground when it's stationery and onto the exhaust when it's moving, hardly ideal. I had a quick look when I first got it and pulled a bit of something shit and plasticky off the sump which made the leak worse. A new sump is cheap enough but requires either the engine lifted or the front diff dropped to change it. I'm not getting into that right now so tonight I had a go at sealing it. Here's what came off And here's the sump. Lovely* I could see where the leak was coming from so cleaned it up as best I could and put some chemical metal on, we'll see how that does in the morning when I go to work. Tickman, Split_Pin, The Moog and 1 other 4 Link to comment Share on other sites More sharing options...
Shandylegs Posted March 28, 2019 Share Posted March 28, 2019 Mate had one of these from nearly new. Was never a looker but was fairly pokey for a big lump and I enjoyed driving it. LPG made the 14mpg almost bearable! dome 1 Link to comment Share on other sites More sharing options...
Mrcento Posted March 29, 2019 Share Posted March 29, 2019 The Exploder performed well on it's first decent run on my ownership. A 70 odd mile round trip to Scotoshite last night. It does however like to mark it's spot. The sump leaks quite badly onto the ground when it's stationery and onto the exhaust when it's moving, hardly ideal. I had a quick look when I first got it and pulled a bit of something shit and plasticky off the sump which made the leak worse. A new sump is cheap enough but requires either the engine lifted or the front diff dropped to change it. I'm not getting into that right now so tonight I had a go at sealing it. Here's what came off And here's the sump. Lovely* I could see where the leak was coming from so cleaned it up as best I could and put some chemical metal on, we'll see how that does in the morning when I go to work. Meh. chemical metal and half a tin of hammerite and that'll be leakproof for at least 5 years dome and The Moog 2 Link to comment Share on other sites More sharing options...
big_al_granvia Posted March 29, 2019 Share Posted March 29, 2019 find the holes (assuming the sump isnt porous as fords can go) and get some devcon expoxy putty, we use that on big diesel engines at bo'ness to seal cylinder liners when they have corroded to feck at the seals, then skip of chemical metal and hammerite.... sorted dome 1 Link to comment Share on other sites More sharing options...
