snagglepuss
Snagglepuss Motors
Those wheels are Enkie's, quite sought after on the basis of being expensive at the time as they're well made, tough and also light. Well worth the effort to refurb them!
They could do with proper sandblasting and then a powder coat. This though should cost me £40 and a few hours which leaves money for shiny things
Share this post
Link to post
We left the wheels primed last night andeft to go off.
Today was time to do the colour
I bought a waterproof table cloth to try and protect the bench a bit more. It was a partial success
Primed wheels
Starting to dust some coats
Doing the underneath
Also did the centre caps with a little of colour funk
Come out alright. Definitely 10 yarders it not bad.
I also picked up a pair of lower front arms to sort out and poly bush to fit.
These are miles less rusty than last lotso not going to do too much.
Took off the balljoint and other bolts
fd616e7851da77ede524214b0973d874.jpg9533909f85807c2a52dabc8baed12cb6.jpg35b64d60a6def4407f95b7c96b34e383.jpg
Quick go over with wire wheel and brake cleaner
Then the glass reinforced chassis paint to protect them
Couple of coats
Looking good - need polybushing and then is ready to swap over.
Also did the ramps I was given by my neighbour. They had rust spots so wire brush back and then coated in paint to give them another 50 years of life.b
Share this post
Link to post
What you really need is a bright green MX5 now to show those wheels off
I thought it was going beige?
Someone is looking for anything to do/paint to avoid a PhD assignment.
Ermm .. that may still be waiting to be started... Tomorrow...
The wheels look good, as do the ramps.
Cheers. Lacquer to do, then tyres on and on the car. Will do the steels that are currently on the car once I have them off
Share this post
Link to post
The downside to buying stuff from eBay is that sometimes you lack instructions etc.
All my polybushes turned up in a box with no leaflet or markings as to where the bushes go. In my ignorance I assumed that there would be a few different sizes that would be obvious.
Of course not, but I only found that out after sticking a few in.
Not only that but the inner tubes were loose and these differ as well. Fucksticks
Perfect fit
Wrong sized bush
Same same but different
You can see the slight variances here.
I think it is time for digital calipers and some slow methodological work
Share this post
Link to post
Pug tickling
Before the 205 can go in for an MOT it needs the bulbs changing for the warning lights
The bulbs came today and were fitted. I took opportunity to use Northern Monkeys advice and solder in the dash lights.
Iron out
I decide to use led bulbs so needed to work out polarity before fitting them
And tidied up
I was still having contact issues on the dash due to the tracks being a bit pants. I thought I would add some solder to see if that would fix it.
Old manky tracks
Solder flowed on them
Put back together
Boom - full set of lights
As I was putting back together I though I would test the switches... The horn had stopped working
This might be part of it
Took them off and taped them up but still no joy. Checking and the horn connection is only seeing 6v ISH.
So gave up at that point
Share this post
Link to post
I’m sure there’s a testers notice somewhere that states a horn is not required if the vehicle is fitted with a cherry bomb
That also means if someone needs warning of my presence I just need to rev the car!
I may have ordered a horn button and going to fit it somewhere on the dash.
The feed to the horn is only getting 6v which isn't enough to either trigger the relay or activate the horn.
So instead will fit a fused horn button - will also fit a fused 12v socket for phone chargers.
Get it, fit it, MOT it.
Share this post
Link to post
Northern monkey motors was visited this morning to do these things
He kindly slapped the tyres on whilst telling me about his current car buying ban .. before giving me 101 ideas of all the cars I can purchase.
Back home I went from this
To this
The tyres on mini steels will become autotesting tyres.
I need to repaint the wheels - I have got silver in the garage but I reckon someone will want me to paint them another colour.
I left it idling as the battery was flat due to flipping alarm.
Just as I was mocking 320touring for his coolant issues I noticed this
No fan action either. Engine off and bonnet open to cool down. 9dbf73eabefc0be503a72fe8b7ae9b3f.jpg
I couldn't see anything obvious so took it for a spin which fixed the fan - love a free fix.
The difference with the new tyres and brake brace is immense. It shows how knackered the dampers are - once o sort out the bushes I can get the suspension swapped over.
Share this post
Link to post
Puglet got a little touching today as the horn button showed up
Found a blank bit of trim to fit it to - drilled a hole
Thought I had better fit a fuse just in case
Looking at the car I decided to use the feed from the back of the indicator switch to power the horn. It was only getting 6v normally so I took a perm live feed from the stereo, to the button then fuse then back of the indicator stalk
All seems good - it means I don't have to run extra wires through bulkhead.
Trim fitted back in
I don't think it looks too bad.
Steering wheel on
So many bits of trim have been cracked from being old plus people fiddling before - the car is never going to be a concourse example.
Go to start the car and bumhats
The coolant warning light and stop light have stopped working again. A secondhand binnacle is only £15 so will go that route.
For every Yang there is a Ying - 5 bhp added
Next up is MOT time. It's a toss up between getting it done this week or waiting until I am back from holiday in a couple of weeks. If it goes in this week and fails then time will be tight to get it retested unless it is something simple.
Share this post
Link to post
Man says no
Front brake and rear brake are registering no real effort - handbrake is a bit sticky and one of brake pipes is crispy.
May leave it to payday then do the whole lot. Pair of calipers is only £70
Share this post
Link to post
You loaned me a potential deathtrap! I'm going to write a letter to my MP about this. Then I'm setting Lynn Faulds Wood, Dom Littlewood, Ally McBeal and Edward Woodward on you.
In all SRSNS, the brakes felt okay to me. The car managed to stop for everything I wanted it to stop for, planned or unplanned, and they didn't feel much worse than the brakes on my AX.
Share this post
Link to post
  • Similar Content
    • By cobblers
      Train tickets booked from a train station 30 miles away to save £9 on the recommendation of the Mrs
      Mrs booked and primed ready to drop me off at said train station.
      Mobile tool kit primed and ready, missing almost every vital component due to EU regulations about leccy tape and screwdrivers on trains (I left them all at my mums house yesterday).
      If I do break down, I should have something to listen to while I work out whether I'm with the AA or RAC or none of the above.
      Not pictured: pile of cash
    • By 320touring
      A long time ago, in a galaxy far away, The Burd and I went to see the Skizzer to start getting a MK1 Golf Convertible that had been off the road for 10years..
      After a couple of sessions in deepest darkest Wales , coupled with some sterling help and fettling by Skizzer himself, it was time for us to head down and bring the thing back up.
      This went well:
      New tyres were procured and fitted
      The in-game tank pump was pulled out and a new filter fitted
      Then I got in touch with my Inuit side, using brand new* magnets to undertake "tank shite" fishing
      A full check over and a couple of test drives showed it fit to play.
      We set off for sunny Oswestry, only to have both front calipers sticking after 120 miles. Some water and time to collect down saw them free off and cause no further problems.
      Upon getting just past Tebay, it started running rough - nicking into Todhills rest area and luzzing in 10L of fuel had it running bang on for the next 70miles before it died.
      This was the final scene on the way home.
      I got to bed at 00:45, and left it to sit until today.
    • By Dick Longbridge
      As with many of the members on here, I tend to read and comment a lot, but haven’t done much in the way of my own shite related posting. The onslaught of miserable teenage goat bummers (©Bollox2019) has encouraged me to share a little more, rather than look at the screen and shake my head. As my fiancée once told me, Dick is for sharing. Or something.
      Updates are likely to be sporadic, and not necessarily ‘car project work’ per se. Sometimes it may just be the odd photo.
      Anyway, now the disclaimer is out the way, and without further ado, I’ll start with this.
      I bought my Lambretta just over ten years ago. I’ve had a few over the years, and even dabbled with the dark side, or as they are sometimes known, Vespa.
      Collection of this scooter involved a fucked Transit, and a day trip to Stoke from sunny Cornwall. Breathing in diesel exhaust fumes which permeated the van through the rusty gaps under the back doors was becoming tiresome by the twelfth hour of driving. We managed it though, and the scooter was well worth the journey. It’s an Italian 1967 SX150, with a 186 Imola kit, plus various other trick bits. It was originally Verde Mela - a rare Innocenti colour - which is basically apple green. Unfortunately the previous owner stripped every last trace of it from the frame, and repainted it in a Peugeot metallic. Not something I could ever bring myself to do, but it looks good all the same.
      I had plenty of fun with the scooter, and even made it to the Isle of Wight rally on it (I’ve done this a few times on previous scooters). However, as with many of us, life and house got in the way, and it’s sat in the garage under a cover for way too long.
      I hadn’t fired it up for well over 12 months, so decided to drag the old dear out into the sunshine, fire her up, and give her a blast around the estate. I did a quick video of getting the scooter started - no sound because time lapse - startup was a bitch as the fuel was really stale, half evaporated and leaving the oil/ratio mix completely oil heavy. You can make out when it eventually fires up in the video - wait for the smoke around the back end!
      I’ll end by adding the startup video. I’ve got a load more photos somewhere on the external HDD, including some of my previous Lambrettas. I'll have to dig them out when I get chance.
      TTFN.
