snagglepuss
Snagglepuss Motors
Back from autotesting so thought I would try and track down some of the new noises that appeared over the course of the day.
First up I think the current tyres have had their day
d58a079e4791bd1a6e56e09ebeb3c7ef.jpgadf6328578b2cf72e227041ec7584b25.jpg0fad09eb141b382e1e6d2b1b3bbc4f66.jpg7f98a78429cda2bd669bc9437bb8706d.jpg
They were put on AVO by tickman and have done many trackdays plus autotesting since then.
I have stuck on the semi slicks for now
Whilst changing over the tyres I gave things a prod and pull. The shocks are done - not sure if they are actually original 7d50ff4a894a4c7d651e98682cb9d586.jpgeae8f8f1cb866bf501904b88558e2704.jpg4a0963fe204b9b8123401839ca416484.jpgdb871e850f96cfbe1b1bbf36e6e85c66.jpg
Some of the knocks I think are bushes so will add that to the list to do
Couldn't help poke at the electrics.
Earth strap between the block looked horrible so removed it, cleaned and put it back - I think it may be worth replacing
Headlights have been reluctant to pop up and when they do one doesn't work.
Passenger side one out
Bowl is a bit crusty
May have found the issue - the connector has done the melty trick.
Will replace with a ceramic one.
The other light was a pain - the screws are well rusted so took the lid off
c9109463aed96862ec12f2a5f010260f.jpg0e2e6d7d415ef766b806a06953d5297d.jpgc55a7e6a3e6996db6769a1bd6073d4c6.jpg51228ffbc3f61c104bd2472a0c0ad67f.jpg
This connector is fine
Will leave it for now.
All back together and the earth strap clean seems to have sorted the glowing light
Job list
New suspension (most cost effective)
Replacement tyres
Fit roll bar
Order poly bushes
Do timing mod
Repair headlight connector
Remove alarm siren
Replace earth strap
Share this post
Link to post
Most cost effective with suspension refreshes tend to be budget coilover units. They come fully assembled and ready to bolt in and generally are cheaper than a full set of OEM springs and dampers. JOM blueline are good and cheap, used them a few times now
Share this post
Link to post
Household discussion were had on the way to the train station at 6am this morning which has resulted in some decisions made.
1) Rover needs to get an MOT and be gone. It is just sitting there and has outlived it's welcome. Have agreed to hand it over to a professional to get it ticketed up. Unless someone wants a project?
2) Tein adjustable coilovers and a set of tyres have been ordered (Costs set against Rover selling). Mx5 is to be the tinkering car.
3) 205 will need to go when it comes home. I need to stick a ticket on it and then will probably Roffle - it's a luxury I don't need at the moment. It has got indicators and brakes here waiting to be fitted.
4) SMARTs future is in the balance - new owner hasnt taken to it that well. Will give it a month to see how we get on with it
5)reduction in car related expenses and activities - got house bits to do, PhD to study for and that has to take short term precedent. Plus already got non car holidays booked.
So need to get back to Golf, Mx5 plus one other car.
Scarily when I add up insurance tax plus car bits it gets to a big figure quickly.
Share this post
Link to post
2 hours ago, Matty said:
205 how much mister?
Wont know until I get it through the MOT. If it costs me a fortune then I may just end up keeping it, if it flies through then may move it on.
If someone wants it with minutes of MOT left then £350 would probably take it.
Share this post
Link to post
After negotiations mentioned above - bits for mx5 have been ordered. I am very excited
Four of these (on List A of the Msc blue book for autotesting)
One set of these
Also got rollbar to fit. And trying to ignore the call of polybushes.
Share this post
Link to post
Those headlight bowls sure look angry.
How's the MX5 for aftermarket part support and availability? Just thinking about those bushes... I was browsing for Volvo parts and was somewhat shocked to find that a new lower suspension arm complete with bushes and ball joint is in fact cheaper than getting just the bushes and ball joint separately.
I understand that it's an apples to oranges comparison, though...  there's probably lots of specialized parts for the MX5 instead of low-priced bulk.
Share this post
Link to post
Full car polybush set is about £100 - mx5 stuff is buttons really. Need a new rad - £35, tre - £13, front pads can be had for about £15 etc.
The wishbones are a bit more expensive - it is easier to polybush when stuff is off rather than replace the arms.  The Mx5 is going to be a bit more track focused so comfort is slightly less of an issue.  Will need to call insurance once I have added all the new bits to ensure it is covered.
Share this post
Link to post
Someone asked about the wee Smart.
I really like the car - bit bouncy over Accrington potholes but aside from that a nice thing.
A sort of review of its features
Firstly it is basically a big car with the back seats lopped off. Wheels at the corners mean it will do 65/70 happily on motorway
Of course this has the optional high speed stability package fitted.
It knocks off 3 mph from top end but you can effectively drive the car upside down in tunnels
For those missing their range rover in town, this beauty has a split tailgate. Currently the top half has a neat feature of gravity assist to ensure the top part is shut correctly
Fancy somewhere to drink your Pimm's at Ascot - got you covered
Jeeves has forgotten to top up the screenwash - access holes can be seen here
Inside funky seats await
Cupholders are plenty large enough for on your move drinkies
Loads of little features - moveable gauges
Tiny sunvisors
Heater controls are located around the centre including the Aircon and heated seats switches
Door pockets are functional
Safety is paramount and integrated into the styling (or just sellotaped under the dash)
You know what you are driving
Dash at dusk
But the most interesting part of the car is that it is a robot operated manual car.
Gearstick allows manual changes or auto mode
My inner sega rally demon loves the paddles
To drive it is miles better in the paddle mode as you can keep it on boost longer - in auto it changes up far too soon.
6 gears means the motorway is a doodle. Spritely off the line as well as simple to park.
Will do some engine shots when I get a chance.
Share this post
Link to post
let me know when it is time to move it on, this would be ideal for my nephew to learn to drive in (he's currently only twelve but we'll use the cash'n'carry car park or something)
Share this post
Link to post
Love the smart Will. They're strangely addictive things. I had one in the same colour scheme - but an early LHD example in pulse trim. Compared to which yours is positively decadent with your heated seats and air con... Glass roof+no air con was a delightful* experience in the summer!
Share this post
Link to post
Sun is out, feeling less I'll than I have for a bit so time to fit a rollbar.
Start the clock
fc53c40b8555978dee7114ae65c73eb7.jpg7a264deea696b431aacb6e958986384f.jpg8bad9017a4f16e9843616f921b953e38.jpg
Water had been sitting in this sound deadening so that is removed and binned
All done - time for first trial fitting
Lap time
Metal needs to be trimmed and it is pretty simple with cordless grinder
985120eb7b4bce7c91fb6c4b8a5ad93f.jpgb950e293104f53d7d9dc3ed2869e860e.jpgef1e42e1b444ef391692d4afffe583e1.jpg
Drill holes marked and punched
Time check
Funky drill time
Car up in air and arch liners off
248a7959df27f856fce596202044643f.jpgfcd46489add8cead4bdd00605bcaaefa.jpg7c084ba25ac8a9acbf33e1ef11d950d9.jpg1a20609a6480b80a317a3e4dd5d800a0.jpgf9ac7b2964596481d7d8f29821997f8a.jpg448231a9d399c4f5338bdfd423b50863.jpg
Final challenge somewhat slowed me down.
There is a gap where it mounts to the seatbelt towers. You can trim the old seat belt spacer but instead I decided to enlarge the holes on the bar using a dremmel so I could run the space straight through.
cc2ebefef0ffffe544dda32ccec59e60.jpg434ec384970f696662ccb94bd4ac5c49.jpg2b56128ae3453ee4508158c6fc05d58f.jpg28048c0b826920d0149fc78ef7ffd0d3.jpgc80be4c13ecd698455d05765ac4f96f5.jpg
All metal painted with zinc spray.
Carpet and plastics trimmed and then put the interior back in
Share this post
Link to post
nice work, what was the final time check ? have you been for a drive yet ? I would imagine you will feel a big difference in the car when 'pressing on', especially with the track tyres on too
Share this post
Link to post
its interesting to see it only has spreader plates on the rear fixings, my tr-lane roll bar was the same but I presumed they were missing and used offcuts to make my own for the front fixings. I suppose thinking about the forces involved in a roll situation, the front  fixings will most likely be in compression so a spreader plate there wouldn't do anything useful.
seats and harnesses next ?
Share this post
Link to post
That's very impressive...
Fitted a new exterior door handle to the 216 Cab the other day. Took me three hours.
2.5 hours to get the bastard thing off, and then 20 mins to put back together again....
I think this would have taken me all day, then would have somehow fitted it backwards...
Share this post
Link to post
From start to bars in was just under two hours including tea stops.
Extending the holes was about 90mins. Mainly cause using a cordless Dremel rather than a decent air driven die grinder
Does feel much more of a solid car. Pressing on can't happen at the moment as the suspension just knocks it's balls off!
Share this post
Link to post
Not sure why it is like that - I assume they know what they are doing.
The bolts are quite short so I think front plates might have been a bit of a challenge.
Got a bucket seat and harness to collect but think the seat will be too small for me.
Next up is suspension plus poly bushes.
I did notice the rear sills probably could do with sorting next year.
Share this post
Link to post
Excellent work as usual. Swiftly and with style!
Cheers
Jesus, just looked at the pics again.
You were not joking when you said Slicks....
Oh yes :-)
It's easier being track car so breaking clips doesn't matter as mcuh. Plus mx5s are easy to take apart.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
  • Similar Content
    • By strangeangel
      I thought I'd start a thread for this as I'll probably end up asking all sorts of questions, given that this is my first 'proper' Citroën.
      So... the ground clearance lever won't go all the way to the highest setting (all others work), which is bad 'cos the book says I need it to do that in order to check the LHM level. It feels like something's seized, so I don't want to force it. Any ideas for a plan of attack would be much appreciated.
      Next up are the wheels. I now have a set of 205 pepperpots that have just gone off for powder coating & I need to get some tyres for them. The handbook says the car should have 165/70R14s on, the wheels came with 185/65R14 on. Any thoughts about what size I should get please? Cheers.
    • By Peter C
      Woke up this morning, had a little time before I had to leave the house for work, had a quick look at what’s new for sale on Retro Rides and saw an ad for a W124 200E manual, located 15 miles from home. I had no intention of buying a car today but I had to have it! I called the seller and arranged a viewing.
      Faults:
      2 x rusty front wings (TADTS)
      1 x rusty rear arch
      Needs a polish
      Tracking is out because new track rod end was fitted for MoT
      Engine has oil leak/s
      Good points:
      It’s a W124 200E!
      5 speed manual transmission
      New clutch
      Brand new MoT
      Superb MoT history
      4 x as new Continental tyres
      Last owner for 15 years, her husband before that for 4 years
      Very tidy MB-Tex interior
      Drives well
      All electrics work
      The dealer kindly delivered the car to my house but I managed a pez station shot on route:
      Plans:
      Remove front wings, cut away rust and apply plenty of wob.
      In-situ similar repair for rear arch
      Clean and polish
      Service engine
      Adjust tracking
      Leave patina and enjoy the car as it is
      I will update this thread once progress is made.
      Hopefully these two will become good friends.
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
