lisbon_road Posted February 27, 2016 Share Posted February 27, 2016 Was passed by K155RMG on some massive Audi a couple of days ago - I can remember as my mum is RMG. Reckon you got a barg with that registration number! Like the detail work, impressive. egg 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted February 27, 2016 Share Posted February 27, 2016 You might try some mildly abrasive product like T-Cut but not T-Cut cos it's shite on the less yellow headlight thingy. Link to comment Share on other sites More sharing options...
egg Posted February 28, 2016 Author Share Posted February 28, 2016 Did you use Autoglym bumper care? The green stuff? If so it will last well, i use it on all the plastics on the Reliant and the Kia. Yep. Certainly looks like a quality product from first use Linseed oil! Would probably work! I do use some on my wooden window frames every 6 months or so... You might try some mildly abrasive product like T-Cut but not T-Cut cos it's shite on the less yellow headlight thingy. I have some meguiars 'Plastx' which may do the job. The heater controls and wheel trims should be on their way this week now. oldcars 1 Link to comment Share on other sites More sharing options...
egg Posted February 29, 2016 Author Share Posted February 29, 2016 Old cars can be like an archaeological dig...as I'm doing much good work to the heating system (I hope) I thought I'd have a look at the Pollen filter....(particularly as there are lots of slight size variations in possible ebay replacements) It is dated December 2004 - and this all fits in, as it was last seen at the main stealer (Cuff Miller) in 2005, so clearly servicing has been less thorough since! I've been aware that the car has had a windscreen advisory for 10 years or more - and was surprised giffer owner hadn't got it sorted in that time. Well, perhaps he did at some point and it has got a new chip since. As under the windscreen scuttle (where the pollen filter is) I found a dozen or more chunks of sharp edged glass. Clearly, the diligent* windscreen fitter decided to leave a present behind... andrew e and beko1987 2 Link to comment Share on other sites More sharing options...
Pillock Posted February 29, 2016 Share Posted February 29, 2016 Is that windscreen glass? I thought it never ever broke into pieces unless it was cut, because of the bonded plastic layer. Magnificent Rustbucket 1 Link to comment Share on other sites More sharing options...
egg Posted February 29, 2016 Author Share Posted February 29, 2016 I think it must be - although I take your point - I can't see how much broken glass got under there otherwise.... Link to comment Share on other sites More sharing options...
fatharris Posted February 29, 2016 Share Posted February 29, 2016 Looks more like the single pane glass you get in some old garages? Magnificent Rustbucket and egg 2 Link to comment Share on other sites More sharing options...
stuboy Posted February 29, 2016 Share Posted February 29, 2016 ohh how i miss this.. you passed through my home town ashford.. egg 1 Link to comment Share on other sites More sharing options...
stuboy Posted February 29, 2016 Share Posted February 29, 2016 dunno if ur on fb... as my friends run a page called mondeo mk1 register egg 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted March 2, 2016 Share Posted March 2, 2016 That is one huuuuuge pollen filter. Bloody hell. egg 1 Link to comment Share on other sites More sharing options...
egg Posted March 2, 2016 Author Share Posted March 2, 2016 dunno if ur on fb... as my friends run a page called mondeo mk1 registerThanks, joined! Link to comment Share on other sites More sharing options...
egg Posted March 5, 2016 Author Share Posted March 5, 2016 Got a original Ford pollen filter replacement for under a tenner, so fitted and all cleaned up. Spot the difference? The new heater controls have arrived (entirely reasonable £16 delivered) from a breaker/banger racer. All connectors look about right (I hope). The new unit has two light bulbs (arrowed below). Now, these were missing from the old broken unit. I have a theory about that. I wonder if they had been replaced in the past, and perhaps they were too highly rated - causing overheating and the plastic to crack. I'm going to replace the ones in this new unit as it is a dashboard apart job to change them - they are 90p each here - (http://www.seautoelectrical.co.uk/) Once the bulbs are here, I can get this fitted and back on the road! Wheel trim options - I can get some proper new ones from fordpartsuk.com for around £20 a corner. Or, proper autoshite style - some used one's here at half the price. decisions! (http://www.ebay.co.uk/itm/401075718770?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true) oldcars, trigger, The Moog and 1 other 4 Link to comment Share on other sites More sharing options...
stuboy Posted March 5, 2016 Share Posted March 5, 2016 keep up the good work on this Link to comment Share on other sites More sharing options...
PhilA Posted March 6, 2016 Share Posted March 6, 2016 Auto Glum black plastic stuff "goosegog juice" isn't bad, though you'll need a few applications in a row because the plastic will go streaky if it's been "dry" for a long time. Re: the headlight lenses, PlastX isn't bad but I've had much better results with the equivalent 3M stuff, they just call it Plastic Polish. Here it comes in a black bottle. Phil egg 1 Link to comment Share on other sites More sharing options...
fatharris Posted March 7, 2016 Share Posted March 7, 2016 I can't see the wheel trims (work internet), but if they're going on this Mondeo, they need to be those really intricate ones.https://www.fordpartsuk.com/shop/ford_mondeo_mk1_14_wheel_trim_f_6955906_c_314.htm saucedoctor 1 Link to comment Share on other sites More sharing options...
Pillock Posted March 7, 2016 Share Posted March 7, 2016 Pah, GLX trims? On a car with no rev counter? There will be UPROAR. Link to comment Share on other sites More sharing options...
stuboy Posted March 7, 2016 Share Posted March 7, 2016 Pah, GLX trims? On a car with no rev counter? There will be UPROAR.blasphermy!! Link to comment Share on other sites More sharing options...
egg Posted March 7, 2016 Author Share Posted March 7, 2016 These are what it has now - and what I'd like to keep. Spending £80 on a set of four of these does seem extravagant for purely cosmetic reasons though. Only two are actually broken so could get away with £40. I've seen one used one (see ebay link above) and have asked him if he has at least one more... I can get a set of 4 of these for £41, that would look ok - but not be quite right! Link to comment Share on other sites More sharing options...
AnthonyG Posted March 7, 2016 Share Posted March 7, 2016 Noooo! They are Mk2 GLX trims, stick to the originals 😀! Good news on the heater controls, and that pollen filter change looks like the first it's had this century....... Lord Sterling, oldcars, Magnificent Rustbucket and 1 other 4 Link to comment Share on other sites More sharing options...
Lord Sterling Posted March 7, 2016 Share Posted March 7, 2016 Sweet. That pic of the dash reminded me of the days I used to mess around with the K11 Micra's dash, usually to change the lights for the heater controls or fit a cigar lighter or whatever. Need to do it again at some point to change the heater element. With all this talk of wheel trims, why not stretch out and get some original/tailored floor mats fitted. Can't find any used ones on eBay but herevare some tailored ones @ £17.50: http://www.ebay.co.uk/itm/Ford-Mondeo-MK-1-1993-to-1996-Black-Car-Mats-Various-Colours-/270693462658 egg 1 Link to comment Share on other sites More sharing options...
egg Posted March 8, 2016 Author Share Posted March 8, 2016 I'd love some OEM mats - they are £28 though... http://www.ebay.co.uk/itm/170796874989?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Lord Sterling 1 Link to comment Share on other sites More sharing options...
oldcars Posted March 8, 2016 Share Posted March 8, 2016 I would stick with original trims. If they are broken pick up the number you need and then repaint them all so they match. Best paint match i found for my trims was Ford Moondust silver. egg 1 Link to comment Share on other sites More sharing options...
egg Posted March 10, 2016 Author Share Posted March 10, 2016 Got the other headlight reflector today - so now have nice clear headlights! Another old stock bargain. Hopefully some more updates to follow over the weekend. Vantman, Magnificent Rustbucket, BorniteIdentity and 7 others 10 Link to comment Share on other sites More sharing options...
fordperv Posted March 10, 2016 Share Posted March 10, 2016 Such handsome cars Magnificent Rustbucket 1 Link to comment Share on other sites More sharing options...
Rusty_Rocket Posted March 10, 2016 Share Posted March 10, 2016 That's looking fresher than they did at their first MoT nice work. Link to comment Share on other sites More sharing options...
purplebargeken Posted March 11, 2016 Share Posted March 11, 2016 Lovely looking thing. Well done for sorting. Link to comment Share on other sites More sharing options...
Mr_Bo11ox Posted March 11, 2016 Share Posted March 11, 2016 Splendid work going on here, needless to say, I'm loving it oldcars 1 Link to comment Share on other sites More sharing options...
phil_lihp Posted March 11, 2016 Share Posted March 11, 2016 Sorting the lights and dressing the bumpers has made a big difference, love these cars. oldcars 1 Link to comment Share on other sites More sharing options...
Richard Posted March 11, 2016 Share Posted March 11, 2016 Did you manage to get hold of the right bulbs? It would be a shame if the lenses turned yellow again. Link to comment Share on other sites More sharing options...
trigger Posted March 11, 2016 Share Posted March 11, 2016 Very arousing. Link to comment Share on other sites More sharing options...
