1987 Renault GTA :: For Sale
PhilA
 Share
This kind of puts me off ever touching a Renault here if I ever see one!, so far the Jeep has been just the usual few electrical problems (as I'm an Electronics Engineer not a problem) and a power steering pump - I will keep this in mind when looking at earlier Renix Jeeps tough!
Link to comment
....then sit there and look at it, panic about what I have done, go to the newsasians to get some fags, smoke the fags, panic a bit more and then give it up as a bad idea and go to the pub instead.
Then oddly I'd probably find my phone ringing, with a request to borrow some random tool, as a ruse to get me over to sort it out....
Link to comment
That's what friends are for :lol:
I learned the hard way- I'm guessing the dash was designed for installation at the factory before the doors were put on and/or windscreen was put in because getting it to fit through the gap proved it to be maybe 1/2 too wide for the car.
Some sort of strange black magic, that is.
Regardless, I put the dash back in- what I omitted from the story was it had to come out again because the loom goes over one of the pegs, not under, which then prevents the dash from going on all the way because it snags on the loom.
Then the trim that surrounds the A pillars broke.
Then the overhead interior lights fell apart. Literally. i have them in my toolbox, they're in about 6 million little plastic pieces.
Thankfully the lights were used all the way through to the phase 2 Clio, so I can scavenge those. The plastic trim in the car feels like porcelain. the heat from the sunshine has made the plasticizers in the plastic leech out, and the result is very, very brittle plastic that snaps if you so much as look at it funny.
I don't know what I'm going to do with the headlining yet. I guess I should start by finding out what color it was originally and go from there. I think the windscreen or rear window has to come out to get it out- the thing is one of those molded jobbies and not a "traditional" headlining like you'd find in, say, a Cortina.
the interior I'm still undecided about. Previous owner, or one before, had a dog, which has torn up the rear door cards. Those I may be able to salvage, but having a rear seat may not suit the 'look' of the car once it's painted- I'm thinking probably faux roll cage made from plastic tubing (gr8 for crashin) in the back, with stock seats and belts up front.
--Phil
Link to comment
Oh yeah, and a photoshop of the paint scheme.
Renault rally colours by renault9gta, on Flickr
Seeing as the paint is on its second coat already (original color was still silver, but a much finer, lighter shade of silver metallic, called "Sterling") and all the sun-facing panels the paint has dissolved, it all has to come off and be redone. So it might as well look the part.
Can always undo paint :)
--Phil
Link to comment
Spent a little time tarting up the bodywork, to eyeball what the car needed to look like.
The car's butt was very bland- original factory color scheme.
Festive Renault GTA back by renault9gta, on Flickr
Tarted it up with some Christmas lights to get things a bit more festive.
Took the spoiler off, sanded it down and gave it a coat of black.
Rear spoiler, rubbed down and keyed by renault9gta, on Flickr
You can see there the difference in surface finish of the paint. Underneath the spoiler, where the sun hasn't gotten to it, it's actually still quite nice.
Renault GTA black spoiler far view by renault9gta, on Flickr
Looks better for that, but the rear bumper still makes it look like a Dodgem car. Typical Federalization of any vehicle to include MAHOOSIVE foam bumpers.
Gave the back end a coat of black between the lights and redid the black on the lenses as well as cleaning the years of chod that had accumulated in the (silly design) open edges at the sides which made the lights look grimy.
(Newer photo because I can't find one from around the time)
All the lights on at the back. The eagle-eyed amongst you will notice the rear lights are Federal-spec too. The swage line doesn't line up with the light divider, like on European models, as the indicators and reverse lights are bigger. There's also no fog-lights because law here doesn't require them.
In the top picture with the car draped in lights you can see a dent behind the door, where something- looks like a shopping cart- has gone into the body and pushed it back.
Took out the wet-n-dry and the hosepipe and began to sand the paint back after taking the insides of the car apart and bashing it back to shape.
Plenty of layers of paint- you can see bare metal, the black under-primer, the paint primer, the paint, several layers of clear-- this is where the factory paint stopped. they advertised a multi-layer protection which involved galvanisation, corrosion protection, paint and a wax polish coat. Maaco or similar have employed Stevie Wonder to mix the paint and David Blunkett to paint the car in the past by looks of it but that did admittedly save the bodywork from the worst ravages of the climate down here.
Masked it all up and gave it a quick prime and then a blow-over with some white.
Looks acceptable. Certainly passes the five-yard test.
Did the same for the front.
Bought some new headlights.
One had water in and the other had no reflector left.
Light output was Land Rover at best.
...how about no. This'll do better, thankyouverymuch.
Gave it an oil change after redoing the bearings... and the rest is in the next instalment :)
--Phil
Link to comment
Those rectangular Sealed beam headlights are really prone to leaking after a few years, one of mine on the toyo had a dissolved reflector and water in it...at least you can get brand new ones at Walmart for $7.99.
Still don't understand the lack of rear fog-lights here, I expect it would be too complicated to explain in the Drivers Manual.
And don't get me started about the rear red indicators some cars have here!!!
Link to comment
Ha, yes. My old truck had red turn signals to the rear.
I'm used to it. Both the vehicles we have now as daily drivers have brake/turn to the back to flash the brake lights as the indicator.
Red rear fog lights here is legal though. I'm surprised Louisiana allows it, but the driver's manual states that you may fit them if you wish to aid visibility in poor weather.
(Plus, my driving test to move here involved driving around the block, stopping at 4 stop signs, not running a child on a tricycle over and parking up again. the written test took longer.)
--Phil
Link to comment
Ah, I remember the brittle dash plastics on my '83 Alliance well. Barely touch them and they'd crumble to bits!
I almost tore the lot out and binned it. Instead I spent several hours with glue and repaired it. Still, however, infuriating.
Link to comment
--Phil
Here in Mississippi I just had to do the "written" test on a computer, while I was doing it my 3 year old son I was looking after wandered off and I had to go get him and come back so had to complete the test in half the allowed time, passed fine!!.
Link to comment
Somewhere aroundabout this point in time I got fed up of the Really Noisy Pulley that was fitted to the side of the engine.
With the engine running, it was by far the noisiest thing in the engine bay.
Lifted the battery out.
That was inadequate for clearance.
Ended up having to pull the battery tray out.
The offending article. Thankfully work has a hydraulic press and it's a fairly common bearing.
It made a SQUIZZZZzzzz noise when spun on my finger. I suspect the insides were drier than .. a dry thing.
Fitted a new one and the noisiest thing in the engine bay is the fuel injector. This is a relief, as it means the tappets are shimmed correctly...
--Phil
Link to comment
Does the Renix system use OBDII for external interface?
Renix II does not. It's a proprietary electrical and logical interface. Open-collector output from the ecu which requires inversion, then it runs at a funny speed (62500 bps) with a proprietary protocol (XR25).
OBD-II would have been so much easier.
-Phil
Link to comment
The opportunity to purchase brake parts fell through until next week.
Today fell apart too.
Tomorrow I hope to be able to liberate some good data off the car's ECU for someone and also hopefully test the new electronics.
I also need to put some penetrating oil on the brake unions and bleed nipples.
--Phil
Link to comment
--Phil
Link to comment
Update from yesterday. It was just too hot out.
110F / 43C in the shade, with no breeze.
Because the car's at the mother in law's, I get to contend with this each time I go down to the car:
Tidied up some, now a little better. At least I have access to the vehicle...
Had $20 available to spend that I'd earned doing someone a favor.
Bought some bits and bobs that I need. Two jubilee clips for the heater hoses, some PB Blaster penetrating oil and some primer and a bit of Chrysler Bright White.
Set the fan up and got the computer running to try out the electronics.
The Serial port adapter will talk to it but the Arduino won't. Back to the drawing board with that.
I'm by now running out of time as I had to be somewhere.. plus it's too hot and I'm sweating buckets- which isn't good for electronics.
Did the main thing of the trip- took a look at the brake unions. They mostly look like this:
Squirted those, the ones at the back and the handbrake cables with PB Blaster to let it sit:
checked my lights on the offchance, as I'm keeping an eye on things to see what's randomly stopped working. Oddly today the front foglight has started to work again.
Packed up and headed out. Have more electronics to work on but I think I know what I'm going to do there.
--Phil
Link to comment
--Phil
Link to comment
I've just read this thread from beginning to end, and frankly I'm half amazed, and half just plain jealous.
You, yesterday:
It goes into much greater detail over on RR. It's usually in the top 3 pages if you want to go read.
I think I'm pretty much there with the fuel injection though. Just a couple little bits to fix. Climbed in, twisted the key and it started before the oil pressure light had went out. (Fourth compression stroke).
Ain't too bad. Saw that the brake on the back was weeping too. Going to replace it.
--Phil
Link to comment
You, yesterday:
--Phil
Link to comment
Spent some time tonight after gathering enthusiasm, to rebuild things on the breadboard.
That small mess on the board makes it run (9 discrete components in all: 1 transistor, 1 optoisolator chip, 5 resistors, 1 diode and an LED), the other few bits are to make the RS232 port on the desk "pretend" to be the car.
Welp, that's the code running on the Arduino, reading in data recorded about 8 years ago from a Jeep. I'd say it works on the bench alright..
..which means it SHOULD work in the car.
--Phil
Link to comment
--Phil
Link to comment
Again, I fail at electronics and wasn't thinking what I was doing. Going to grab a few more bits and bobs and rethink the circuit.
On the plus side, I came home yesterday afternoon to this:
Which, when unpacked, contained this:
Now I just have to convince the wife to let me buy the spares I need to complete the brakes, and I'll be set. Right now she's doing the books and checking see if I can get the bits this week or not. So far I've been told no three weeks running. Way it goes, I guess.
Really need to address the driver's side window too. I've a feeling the mechanism is either going to be completely FUBAR or I'll have to do some major hacking about to make it work again.
Note to manufacturers: PLASTIC IS NOT A GOOD MATERIAL TO MAKE GEARS FROM
--Phil
Link to comment
  • PhilA changed the title to 1987 Renault GTA :: For Sale
 Share
  • Similar Content
    • By eddyramrod
      Copied over from Shite In Miniature...
      Note for future reference...  I've decided most of my Matchbox (-sized) cars can go.  It's a vast collection,   Most have been repainted at least once - by me, obviously.  My eyes and hand aren't good enough to do them again.  I've got way too many to list so ask if there's something you want and if I've got it, we can do a deal.  Most will be 50p each plus postage, so it'll make sense to build up a parcel.
      I thought it best to do this, then I'm not clogging up the main thread.  This could well go on for months.
    • By ruffgeezer
      Ok I'm going to see if we've enough interest in the Autoshite Dealership stickers to run off another batch.
      I will need to pre-sell a minimum of 120 before I will place another order, and I have contacted the company that made them to recheck the run price.
      I am also considering a new design with the url in it, but done so it doesn't stick out like a sore thumb (and I corrected the boobies for this run!):
      Please state your interest by copying the following and adding your name below:
      Eg:
      Ruffgeezer: 1
    • By PhilA
      I now own this.
      Yes, I put a big scrape down the door loading it. It'll hammer out though.
      All being well it should be at the house tomorrow.
      I've got the car loaded up with parts, heading back home tonight, the seller offered to haul it down with his truck for the price of fuel so I jumped at that.
      So, a bit of backstory. Guy bought the car back in 2010, running (ish), smoked about in it for a while then realized the original engine was toast. So, be bought a complete beater of a Fury which he broke for parts.
      He rebuilt the engine a bit bigger, it's a 327 (5356cc) now, not a 318 (5211cc), tubular dual exhausts, few other ninaks. Gearbox was gone through he says.
      Then the sad part. He's originally from California, posted in the navy police. He was serving back there for a while and while he was away he found a guy who was all about restoring old cars and sent the car to him to be rebuilt.
      So, the guy chopped out a fair bit of rust, replaced it with metal, did a bit of bondo work then painted it. The car was originally white, and was chosen to be repainted by the seller in mauve.
      He said "Whatever parts you need, let me know if I'll send it you", so was ordering parts.
      He arrived back in Mississippi, stopped in at the place... The guy has skipped town, done an epically poor job of painting the car (though he did hang the doors and trunk well, I'll give him that), and applied a random sheet of steel with some pigeon-poop in the trunk where the trunk floor had rusted out.
      I'm not sure what I'm going to do, but I think I may actually get the car back down to metal, straighten it out and paint it. I've done better paint with aerosol cans.
      So, he gets left with the car as you see it. Sad, but he got gypped out of a five-figure sum for essentially what comes down to a $200 paint job and a bit of crummy welding.
      There's a spare block (might do something fun with that) and some trim, dash, odds and ends in boxes, some new lights, but there's a bunch of stuff I'm going to have to source. Looks like the car might have been in a hail storm at some point too, so that needs straightening up.
      So, yes. Work, but should be fun.
      Phil
    • By Tepper
      I've just bought this. Came up on FB marketplace just down the road from my unit, couldn't say no! Do I need it? No. Will it cause me grief? Almost certainly yes. Is it a big majestic bastard? Absolutely. It needs a few bits and pieces doing, including spheres all round and some warning lights supposedly caused by an ABS sensor. My Lexia won't talk to it, so that's the first order of business. Wish me luck!
    • By omegod
      My efforts of the last few months have come to fruition and I'm pretty pleased with the outcome
      I'm a serial Omega botherer and some years ago I got a sniff of this 1996 Vauxhall Omega 2.5 V6 24v CDX manual that was no longer being used as it's only owner was no longer able to drive, sad circumstances meant it was stored unused for 5-6 years .  She was a non runner and in a neglected state by the time I was able to rescue it and  @worldofceriwas employed to bring her to me, excellent service and highly recommended!
       When she arrived she was covered in the usual moss and grime and was still on the original 1996 tyres which were perished and barely held air.  Non running cause was found to be a completely ruined fuel system as the petrol in the tank had turned to a bright green mess that had dissolved all of the internal rubber pipes into a black sticky goo, I don't think I've ever smelt anything so toxic,  a thorough tank clean, new piping, sender unit refurbed , filter and new pump  and she burst back into life.
      Further recommissioning work required was 4 x new Michelin tyres, Cambelt and waterpump kit , complete replacement exhaust system, service , wipers, alternator was refurbished with new internals, new battery and literally scores of hours of cleaning and gentle refurbishment .
      The main dealer service history is incredible with 8 miles between services some years.  She walked her MOT and  now drives like a she has just rolled out of the showroom, unsurprisingly given she's only covered 17 k from new, the interior leather looks like it's just had the plastic removed at the dealers and the rear seats have allegedly never been sat in
