Welcome to Autoshite
Guest Message by DevFuse
Roffle
MGFfle! £10 tickets
Roffle
  • Please log in to reply
60 replies to this topic
#1 ONLINE   djoptix
djoptix
    Rank: Austin Maxi
  • Full Members
  • 469 posts
  • 9 thanks
  • LocationFederal Republic of Dirtystainia
  • Country : Country Flag
Posted 05 April 2019 - 11:24 AM
Well, here it is, lots of fun has been had in this brilliant car but time and HMRC are on my case, so it has to go. Get ready for summer/ideal project/etc etc etc!!!
Headlines:
  • 1.8 VVC with 52mm throttle body for extra zooms*
  • MOT until 24/03/2020 - registration is P69 FKN if you want to check up on it
  • Red leather seats
  • Decent hood and rear window
  • Surprisingly dirt cheap to insure - about £160 a year for me limited to 3k miles and that's with no NCB and my 9 points declared...
  • Loads of fun.
Stuff that came up on the last MOT, and the action taken, was:
  • Horn sound not in accordance with requirements (7.7 ©)
    This was because of my hilarious* klaxon horn. I've got two horns fitted, you can plug in whichever you feel like (or both).
  • Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength outer sill (5.3.6 (a) (i))
    Now welded.
  • Electronic power steering warning lamp indicates a system malfunction (2.6 (a))
    The tester says that the light came on on the test drive but I didn't believe him. It's never happened before and hasn't happened since. I cleaned the PAS fuse under the bonnet anyway.
  • Offside Front Track rod end ball joint dust cover excessively damaged or deteriorated so that it no longer prevents the ingress of dirt (2.1.3 (g) (ii))
    Replaced the track rod end.
  • Nearside Front Lower Suspension arm ball joint excessively worn (5.3.4 (a) (i))
    Replaced top and bottom balljoints on nearside.
  • Exhaust carbon monoxide content after 2nd fast idle exceeds manufacturer's specified limits (8.2.1.2 (a))
  • Exhaust carbon monoxide content at idle exceeds manufacturer's specified limits (8.2.1.2 ( B))
    Although it did pass on the next test, they note "vehicle struggled with emissions". This is probably because before the test it had been laid up for several months. Since then I've driven 400 miles to Blyton and back, as well as hammering it round all day at up to the redline, so I'm confident the emissions will be in significantly better shape now.
I bought this from here about 18 months ago I think. Since then it's been a second car and has been loads of fun, and a brilliant first track car.
In daily use it's great to have the hood down, it starts first time every time, and is generally no trouble. On the current tyres it is bloody dangerous/loads of fun [delete as appropriate] on wet roundabouts. On track, in the dry on R888s, there are insane amounts of lateral grip and very little understeer/oversteer. The brakes are awesome, even though they are standard, though I did manage to get some fade within about 7-8 laps of really pushing at Blyton, which I guess is due to lack of heat dissipation; though on the day in question, the rear brakes really weren't working as well as they should, so it might just be that I was leaning on the fronts too hard.
Since I've had it it has had regular maintenance - a couple of oil and filter changes, plugs, etc. The winner can have their choice of wheels, either the VVC 5-spokes or the TF 6-spokes, plus a spare set of standard 6-spokes for track use if they want them (I'm keeping the tyres though). I'll also supply the original 48mm TB. I think I can detect a bit of movement in the offside balljoints so I will change those as well before it goes. It had a new bottom-half-of-downpipe-and-flexi-hose shortly after I got it as well.
Body wise, despite the welding required for the MOT, it looks pretty solid all round. There is some rust on the battery tray but otherwise it's pretty good; there's a spot on the bottom of the drivers' wing as well, shown in photos, but I have a spare wing to swap onto it so I'll try and do that before sale as well. All panels are straight with no significant dents or scrapes.
Mechanically it seems sound and everything works. The gearshift will never be as slick as an MX5 because it's cable operated, but it's pretty good. There are various aftermarket bits available to get the shift better, but I honestly haven't found it an issue; when the box is cold it's sometimes just slightly harder than it should be to find third, but once warm, this goes away. The heater is extremely efficient; you won't be cold, even with the top down.
Engine wise, I haven't had a K series before so I have nothing to compare it to, but I have no reason to think everything isn't OK, particularly since I've twice driven it to Blyton from Bristol (400 mile round trip) and done a track day and then driven home again. The coolant did get very hot on the track day last year, but it was an extremely hot day. The exhaust has a slightly "air cooled" note to it which might be a small blow at the manifold, but it's not a cause for concern, just pointing it out because it's there...
Bad points:
  • Not completely watertight. There is a drip in the driver's footwell and a couple around the hood, over the engine cover. I've never tried to trace or fix them.
  • No carpet - removed by urban_paranoia because they got wet and stank. I've replaced them with rubber mats which I like more anyway, and it gives it a more rough-and-ready feel when you sit in it... which I don't mind...
  • As mentioned above, it can be GR8 4 DRIFTIN in the wet if you're not careful...
  • Could probably do with the tracking doing since I changed the TRE.
Will add more details as I think of them. Any interest at £10 a ticket?
  • eddyramrod, barefoot, Aston Martin and 5 others like this
Shit you are brave taking one of these on, they really are hopeless.
#2 OFFLINE   Jazoli
Jazoli
    Omnipresent
  • Full Members
  • 2,131 posts
  • 33 thanks
  • LocationNear a big lake
Posted 05 April 2019 - 11:29 AM
No 52 please, I'd buy this outright if I hadn't just bought a motorbike.
  • djoptix likes this
sigs are shit, wgaf?
Thanked by 1 Member:
djoptix
#3 OFFLINE   Kringle
Kringle
    Rank: BL Wedge
  • Full Members
  • 794 posts
  • 10 thanks
  • LocationMid Wilts
Posted 05 April 2019 - 11:32 AM
Number 17 pweez
That Panda
djoptix
#4 OFFLINE   loserone
loserone
    Leaf blower
  • Full Members
  • 4,602 posts
  • 68 thanks
  • Locationbehind the tree
Posted 05 April 2019 - 11:33 AM
One please, I could do with a fleet of metro subframes
  • djoptix and Aston Martin like this
405 with two engines, Leaf, 206 GTI Legacy H6 Spec B. MGF VVC
djoptix
#5 OFFLINE   mitsisigma01
mitsisigma01
    Rank: Citroen Ami
  • Full Members
  • 1,189 posts
  • 15 thanks
Posted 05 April 2019 - 11:37 AM
Is it in Brissle
#6 OFFLINE   83C
83C
    Farting in France's general direction
  • Full Members
  • 1,153 posts
  • 12 thanks
  • LocationThe Insular Peninsula.
Posted 05 April 2019 - 11:41 AM
I have no use whatsoever for this, I’m looking for an estate with a towbar.
42 please.
  • 1984 Leyland Tiger - big, slow. Much like the owner.
  • 1990 Land Rover 90 - awaiting regeneration.
  • 2006 Ford Transit - load lugger.
  • 2011 BMW 525d - boring modern.
  • 2013 Kawasaki ZZR-1400 - small, fast.
djoptix
#7 ONLINE   gadgetgricey
gadgetgricey
    Rank: Citroen Ami
  • Full Members
  • 1,547 posts
  • 23 thanks
  • LocationWest Midlands
Posted 05 April 2019 - 11:48 AM
I have no use and don't think I'd even fit.
#28 please
Trying and failing to fix cars for 30 years
djoptix
#8 ONLINE   djoptix
djoptix
    Rank: Austin Maxi
  • Full Members
  • 469 posts
  • 9 thanks
Posted 05 April 2019 - 11:50 AM
Is it in Brissle
Good point. Yes!
#9 ONLINE   purplebargeken
purplebargeken
    Someone who is developing reduced levels of patience!
  • Full Members
  • 14,480 posts
  • 62 thanks
  • LocationSatan's Shitty Toilet
Posted 05 April 2019 - 11:52 AM
Nnnnnnnnng
  • djoptix and Ohdearme like this
Triumph Toledo - 2.0 for added sleeper shite
[b]Rover 45 Club - CVT easy gear change not shite
#10 OFFLINE   Fat_Pirate
Fat_Pirate
    Rank: BL Wedge
  • Full Members
  • 970 posts
  • 9 thanks
  • LocationHampshire
Posted 05 April 2019 - 12:11 PM
I'll have a random.  Got no use or space for it but it's PRETTY RED CAR.
  • djoptix, Ohdearme and Dan_ZTT like this
2003 Mini Cooper S
2003 Berlingo Multispace
2002 CLK230 convertible
1991 MX5 scrapyard dodger
djoptix
#11 ONLINE   Broadsword
Broadsword
    Rank: BL Wedge
  • Full Members
  • 924 posts
  • 15 thanks
Posted 05 April 2019 - 12:31 PM
11 please.
djoptix
#12 ONLINE   Dan_ZTT
Dan_ZTT
    Rank: BL Wedge
  • Full Members
  • 887 posts
  • 18 thanks
Posted 05 April 2019 - 12:34 PM
Yep. One random here please.
2002 MG ZT-T 190+ - mostly working
2018 Kia Rio 3 - hers
djoptix
#13 OFFLINE   GeordieInExile
GeordieInExile
    Rank: Austin Maxi
  • Full Members
  • 445 posts
  • 4 thanks
  • LocationNewcastle upon Tyne
Posted 05 April 2019 - 02:53 PM
One random please, always wanted one of these.
Gannin' along the Scotswood Rooooooad... in my 9-5 Aero.
djoptix
#14 OFFLINE   barefoot
barefoot
    Rank: Renault 16
  • Full Members
  • 3,849 posts
  • 11 thanks
  • Locationthe East Mid - Lands
Posted 05 April 2019 - 03:56 PM
Stitch me up with a ransom please.
djoptix
#15 ONLINE   Cavcraft
Cavcraft
    Rank: Glasses/bottles/bottles/filter tips/John Player Special no
  • Staff
  • 43,851 posts
  • 199 thanks
  • LocationMoving up on second base Behind Nicholas van whats-his-face.
Posted 05 April 2019 - 03:58 PM
Erm...no. 34, please.
"As for actually admitting to liking Corsas on a public forum: you're a bollock-brained, biscuit-eating, faux-northern, bastardy, bollocky, wank-brain"
djoptix
#16 ONLINE   JimH
JimH
    Rank: Austin Maxi
  • Full Members
  • 281 posts
  • 7 thanks
Posted 05 April 2019 - 04:16 PM
I have no need for this and no time to do anything with it.
A random please.
djoptix
#17 OFFLINE   Timewaster
Timewaster
    Yeah, yeah.. I'll do it in a minute....
  • Full Members
  • 6,187 posts
  • 22 thanks
  • LocationThe sticks
Posted 05 April 2019 - 04:43 PM
#46 please
Pete M wrote:
Jesus H. Tapdancing Christ, I can't believe I'm sad enough as to post on the interweb
Des wrote:
the fine art that is welding, like trying to shovel butter into a badgers arse with a soldering iron.
Don't suffer in silence. Samaritans 116 123
djoptix
#18 ONLINE   Lacquer Peel
Lacquer Peel
    Rank: Talbot Matra Rancho
  • Full Members
  • 11,039 posts
  • 51 thanks
Posted 05 April 2019 - 05:36 PM
One random please.
djoptix
#19 OFFLINE   HarmonicCheeseburger
    Rank: Citroen Ami
  • Full Members
  • 1,710 posts
  • 17 thanks
Posted 05 April 2019 - 05:50 PM
Can I have two randoms for Aston Martin?
1994 K11 1.0 CVT Micra - Spent way more then needed but loving it :)
Thanked by 2 Members:
djoptix , Aston Martin
#20 ONLINE   rainagain
rainagain
    Rank: Citroen Ami
  • Full Members
  • 1,760 posts
  • 17 thanks
  • LocationFife
Posted 05 April 2019 - 05:54 PM
#27 please
djoptix
#21 ONLINE   Iamgroot
Iamgroot
    Rank: Austin Maxi
  • Full Members
  • 115 posts
  • 6 thanks
  • LocationNewtown, Powys
Posted 05 April 2019 - 05:55 PM
No 38 for me please
djoptix
#22 OFFLINE   busmansholiday
busmansholiday
    Rank: Citroen Ami
  • Full Members
  • 1,571 posts
  • 13 thanks
  • LocationPeoples Republic of South Yorkshire
Posted 05 April 2019 - 06:34 PM
Mrs BMH went and bought an 04 TF in Feb in red. Therefore, it stops me being interested. Well, had not Eddyramrod bought her C3 leaving a space in the drive
Fuck it, no 59, if possible, the most unlikely bonus number, allegedly.
djoptix
#23 OFFLINE   clayts450
clayts450
    Urban on-roader
  • Full Members
  • 2,588 posts
  • 42 thanks
  • LocationNottingham
Posted 05 April 2019 - 06:53 PM
An MGF and a 420 both come up and me, serial MG-R licker, with an empty wallet, FFS.
I suppose the only consolation is it's staying in the fold so maybe I'll get a crack next time around
(also posted on the 420 roffle topic)
GLWTR
Current Fleet
1992 Rover 214 SLi (Oct 2018->) status: broken 1994 Rover 420 SLi (Apr 2019->) status: hooligan
1996 Rover 620 Si auto (Jan 2019->) status: wafty barge 2004 Rover Streetwise S (May 2017->) status: willing puppy/daily
Historical choddage (stopped driving 1999-2016)
1969 VW Beetle 1300 1977 Morris Marina 1.3 Super1983 Skoda Estelle 120L19can't remember: Rover Metro; Vauxhall CorsaVauxhall Cavalier ;
2001 Rover 45 V6 Connie (May to Oct 2018); 2003 Chrysler PT Cruiser CRD Limited (Jan 18 to Jan 19 - roffled off here, now with fellow Shiter's missus here)
#24 OFFLINE   snagglepuss
snagglepuss
    A town called Alice
  • Full Members
  • 11,029 posts
  • 182 thanks
  • LocationAccrington .. who the heck are they ...
Posted 05 April 2019 - 07:33 PM
5 & 29 please
1990 - Rover 800 820si - On the farm
1990 - Peugeot 205 1.8D
1991 - Mx5 Track beast
2003 - Getz
2006 - Lancer Estate
djoptix
#25 OFFLINE   Sealtainn
Sealtainn
    Rank: BL Wedge
  • Full Members
  • 817 posts
  • 6 thanks
  • LocationMossbank, Shetland Islands
Posted 05 April 2019 - 07:52 PM
Don’t need it, haven’t got any room for it, can’t afford tickets with Buick bill looming so therefore I’ll have a random please
Sent from my iPad using Tapatalk
  • snagglepuss, djoptix and Ohdearme like this
1990 Ford Granada 2.0i Ghia
2012 Ford Transit Minibus (Mrs Seals conveyance)
1991 Buick Park Avenue
djoptix
#26 OFFLINE   gm
gm
    aka geordie mark
  • Full Members
  • 1,990 posts
  • 18 thanks
  • Locationchesterlestreet
Posted 05 April 2019 - 07:55 PM
I've not won anything for ages, stick me down for a lucky random somewhere in the middle please :)
  • snagglepuss and djoptix like this
djoptix
#27 OFFLINE   omegod
omegod
    Rank: Renault 16
  • Full Members
  • 2,226 posts
  • 30 thanks
  • LocationLiverpool
Posted 05 April 2019 - 08:39 PM
Where is it ?
#28 ONLINE   Dan_ZTT
Dan_ZTT
    Rank: BL Wedge
  • Full Members
  • 887 posts
  • 18 thanks
Posted 05 April 2019 - 08:44 PM
Where is it ?
Bristol I think
#29 OFFLINE   Maurice Marina
Maurice Marina
    Rank: Austin Maxi
  • Full Members
  • 155 posts
  • 2 thanks
Posted 05 April 2019 - 08:45 PM
Random please.
The Nissan Micra 1.0L Vibe is a bitch. And I spanked it.
djoptix
#30 ONLINE   djoptix
djoptix
    Rank: Austin Maxi
  • Full Members
  • 469 posts
  • 9 thanks
Posted 05 April 2019 - 10:03 PM
Where is it ?
Dan is correct - Bristol.
Also tagged with one or more of these keywords: Roffle
