wuvvum Posted August 27, 2018 Share Posted August 27, 2018 I've been in two minds whether to sell this one or not as I've grown rather fond of it since I finally got it through the test, but I have my sensible head on at the moment so I'm putting up a for sale thread while the going is good. I took this in part exchange from bramz7. It came with an MOT failure sheet which I naïvely thought didn't look too daunting, but I had failed to take into account the car's Frenchness and my own uselessness, and it took me rather longer to get sorted than anticipated - by which time other things needed attention as well. So it's had a new front wishbone on the nearside, a new track rod end on the offside, a new CV boot, and a new wheel cylinder and brake shoes on the offside rear. It's also had welding on the offside sill, done by the garage that MOTd it. I've also done various other more minor bits to it like fit new wiper blades and fix the reversing light. The horn didn't work when I got the car - this turned out to be a mystery issue with that particular circuit in the fuse box, as the lighter and the HRW (which are on the same fuse) didn't work either. I wired up a separate push button for the horn (passed the MOT but could really do with the switch fitting in a better place), and I also wired in a twin lighter socket as the lack of charging points for sat nav and phone were getting to be an issue on longer journeys. The HRW is still inoperative though. Mechanically it is spot on - mileage is relatively low for a 24-year-old diesel Peugeot at 115K. It starts straight up every time and has never given me any trouble - the only thing I can fault it on is that the idle is a little on the high side. It does need the tracking doing - the usual counting-the-threads trick didn't work when I replaced the TRE as the lock nut on the new one was a completely different size. I got it reasonably close but it really needs doing properly - the steering can "kick" a bit over sharp bumps and scrubs slightly on full lock, especially in the wet. There was an advisory on the MOT for slight play in the other TRE, so probably best to get that replaced at the same time. I'm buggered if I'm doing it though given the fun* I had with the one I did replace. It's still perfectly drivable as it is though - I've done over 2,000 miles in it since it passed its test and to the best of my knowledge no nuns or kittens have died. There's also an occasional knock from the front over bumps - not sure what's causing this as there weren't any advisories for suspension components on the test. It could even be the TRE causing it. The bodywork is a mixed bag - most of it is very clean and shines up well, but there is a dent in the offside rear quarter / door and the front wings are bubbling at the bottom where they usually go, just above the bumper. The MOT tester also said that he reckoned the nearside sill would need some sparkly stick attention by the time the next test comes around. The interior is pretty clean for the age, and the seats are comfortable enough for me with my dodgy back to do a 250-mile stint without any problem. The electrics, such as they are, all work apart from the aforementioned HRW. I've fitted upgraded speakers in the front so the stereo is now audible at motorway speeds. Windows are keep fit all round but it does have central locking (although this doesn't always work on the tailgate). It also has the funky vacuum-sealed sliding sunroof - bramz mentioned that this had a slight leak in heavy rain but I've never had any problems with it. Oh, the driver's pin switch for the interior light is temperamental and the boot light doesn't work, apart from that one time when it did. And the coolant temp light sometimes comes on randomly, which is mildly irritating, but the radiator fan kicks in and out as it should (the only time it's kicked in was when sat in traffic on the M25 in 30 degree heat) so all's well on that front and I think it's just being French. The best thing about the car is the performance. It's not brilliant around town as it has quite a lot of turbo lag (TADT,S) but on the dual carriageway / motorway it is much faster than it has any right to be - the way it goes from 60 to 80 in 4th is quite something, and it'll cruise happily at quite illegal speeds. If driven sensibly it's bloody good on diesel. MOT is to June next year and I think that just about covers it. Embarrassingly I have very little in the way of photos of the car, but here's one from when bramz owned it - I'll take more tomorrow, if I get time before work. aldo135, michael t, drum and 14 others 17 Link to comment Share on other sites More sharing options...
bramz7 Posted August 27, 2018 Share Posted August 27, 2018 Probably one of very few cars I would buy back, had I not got stuff needing sorting! Brilliant little thing, and probably the quickest 8v XUD I have ever driven, it really was powerful. Link to comment Share on other sites More sharing options...
wuvvum Posted August 27, 2018 Author Share Posted August 27, 2018 I did actually half think about offering it back to you as a p/x for the R11. Thankfully you've decided to keep the Renault so that particular temptation has gone away. Link to comment Share on other sites More sharing options...
reb Posted August 27, 2018 Share Posted August 27, 2018 Better than mine in every conceivable way, except it has too many doors and is too red.The switch for the light on my drivers door is dodgy too, works if you poke it, I think they possibly all do that. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
Bucketeer Posted August 28, 2018 Share Posted August 28, 2018 Another absolute barg from Wuvv's Boutique.If I wasn't catastrophically skint this would already be sat outside my house, being given a right good licking. JohnK and Cavcraft 2 Link to comment Share on other sites More sharing options...
Uncle Jimmy Posted August 28, 2018 Share Posted August 28, 2018 Sceptre...phwoar! Link to comment Share on other sites More sharing options...
SierraMikeHotel Posted August 28, 2018 Share Posted August 28, 2018 The switch for the light on my drivers door is dodgy too, works if you poke it, I think they possibly all do that. I 'gree, our old 309 was the same from nearly-new. Lovely thing but I need an estate at the moment I thought I'd missed out on 205s so it's good to see they're still available at shite prices, maybe one day! Link to comment Share on other sites More sharing options...
wuvvum Posted August 30, 2018 Author Share Posted August 30, 2018 Grabbed a couple more pics this morning before work - I'll take some better ones at the weekend if the weather allows. Dent: Inside: Engine: Lacquer Peel, BorniteIdentity and theshadow 3 Link to comment Share on other sites More sharing options...
wuvvum Posted September 1, 2018 Author Share Posted September 1, 2018 More pictures. Wing grot: Carlosfandango, michael t and ProgRocker 3 Link to comment Share on other sites More sharing options...
wuvvum Posted September 4, 2018 Author Share Posted September 4, 2018 Bump. Link to comment Share on other sites More sharing options...
Bucketeer Posted September 4, 2018 Share Posted September 4, 2018 How this has not sold yet is beyond me.If anyone is put off by the location/distance/whatever, then Bucketeer Delivery Service is most likely available. Also, this is proper bravery. I haven't dared open a sunroof since about 1998. The Moog 1 Link to comment Share on other sites More sharing options...
reb Posted September 4, 2018 Share Posted September 4, 2018 How this has not sold yet is beyond me.If anyone is put off by the location/distance/whatever, then Bucketeer Delivery Service is most likely available. Also, this is proper bravery. I haven't dared open a sunroof since about 1998.post-190-0-03342700-1535838725.jpgMy can-opener spec dealer fit one lets less water in when it's open! Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
wuvvum Posted September 8, 2018 Author Share Posted September 8, 2018 Bump again. ProgRocker 1 Link to comment Share on other sites More sharing options...
wuvvum Posted September 25, 2018 Author Share Posted September 25, 2018 Back to the top again. I really don't fancy my chances of finding a sensible buyer for this on Gumtree... Link to comment Share on other sites More sharing options...
ProgRocker Posted September 26, 2018 Share Posted September 26, 2018 Good luck with the sale wuvvum. I think it looks spiffing in red with white wheel trims. Sent from my SM-J320FN using Tapatalk Link to comment Share on other sites More sharing options...
wuvvum Posted September 26, 2018 Author Share Posted September 26, 2018 Would there be any interest at all in a roffle for this? Link to comment Share on other sites More sharing options...
skattrd Posted September 26, 2018 Share Posted September 26, 2018 I seriously would like this, but am in fleet reduction mode ... fancy a swap for a crusty but legal Aerodeck? Link to comment Share on other sites More sharing options...
They_all_do_that_sir Posted September 26, 2018 Share Posted September 26, 2018 Would there be any interest at all in a roffle for this?Yesh Sent from my F3211 using Tapatalk Link to comment Share on other sites More sharing options...
Broadsword Posted September 26, 2018 Share Posted September 26, 2018 Yes! Link to comment Share on other sites More sharing options...
Coprolalia Posted September 26, 2018 Share Posted September 26, 2018 Yes! Link to comment Share on other sites More sharing options...
wuvvum Posted September 27, 2018 Author Share Posted September 27, 2018 I seriously would like this, but am in fleet reduction mode ... fancy a swap for a crusty but legal Aerodeck?I do like poppy-uppy-headlight Aerodecks, but I'm also in fleet reduction mode unfortunately (recent purchase of a massive van notwithstanding ). Might give a roffle a whirl then, if I can find someone to look after the Paypal side of things. Link to comment Share on other sites More sharing options...
Ghosty Posted September 27, 2018 Share Posted September 27, 2018 AERODECK?! Link to comment Share on other sites More sharing options...
Daviemck2006 Posted September 27, 2018 Share Posted September 27, 2018 Would there be any interest at all in a roffle for this?Aye Sent from my SM-T585 using Tapatalk Link to comment Share on other sites More sharing options...
New POD Posted September 27, 2018 Share Posted September 27, 2018 Would there be any interest at all in a roffle for this?Nah. Link to comment Share on other sites More sharing options...
skattrd Posted September 27, 2018 Share Posted September 27, 2018 No worries Wuv, if I can sort things out my side I might be able to do a purchase, but don't hold it for me. AERODECK?! Yes, I'll do an advert for it in a day or so. It's the red one as seen at a SF Wales and Lincs, just a little rustier now as I was using it a bit. Link to comment Share on other sites More sharing options...
RobT Posted September 27, 2018 Share Posted September 27, 2018 Might give a roffle a whirl then, if I can find someone to look after the Paypal side of things. Happy to help on that front Wuv. I'll have a couple of randoms too. Link to comment Share on other sites More sharing options...
bramz7 Posted September 27, 2018 Share Posted September 27, 2018 I'll have two Link to comment Share on other sites More sharing options...
wuvvum Posted September 28, 2018 Author Share Posted September 28, 2018 Cheers Rob. Let's give this a go then. £7.50 a ticket. 1.2.3.4. RobT5.6.7.8. Broadsword9.10. bramz711.12.13.14.15.16.17.18.19. RobT20.21.22.23.24.25.26.27. Daviemck200628.29.30.31.32.33.34. bramz735.36.37.38. Mike D39.40.41.42.43.44.45. TADTS46.47.48.49.50.51. Daviemck200652.53.54.55.56.57.58.59. Link to comment Share on other sites More sharing options...
Daviemck2006 Posted September 28, 2018 Share Posted September 28, 2018 Two randoms for me please Sent from my SM-T585 using Tapatalk Link to comment Share on other sites More sharing options...
They_all_do_that_sir Posted September 28, 2018 Share Posted September 28, 2018 Random over here please Sent from my F3211 using Tapatalk Link to comment Share on other sites More sharing options...
