flat4alfa Posted August 11, 2018 Share Posted August 11, 2018 Octane booster for what? Not petrol that's for sure - You would probably get a bigger octane boost dumping a couple of litres of cellulose thinners in the petrol tank Sorry should have elaborated with 'typically mixed with Toluene' Again, look at the bulk of many of those top oil-change-time 'engine cleaners' and find what the main ingredient is. Kerosene is common Link to comment Share on other sites More sharing options...
Timewaster Posted August 12, 2018 Share Posted August 12, 2018 I was gifted a tin of 'Tunap' injector cleaner by the lads at my local VW parts desk when the Lupo SDI started to hesitate and run rough due to Mrs Eunos poodling round at sub 2krpm on a perpetual basis. They reconned it was the proper stuff and the chaps in the workshop swore by it etc. In short is did sweet FA. In the end a 30 minute motorway drive to Barnard Castle in third gear (Eeek) was the answer and solved the issues, the car has run well ever since. Italian tune ups FTW IME.Quote my youngest: The car doesn't go this fast when mummy drives it. Shirley Knott, sierraman, chaseracer and 2 others 5 Link to comment Share on other sites More sharing options...
puddlethumper Posted August 12, 2018 Share Posted August 12, 2018 My mechanic said to put 2 stroke in veg to keep things clean.So I do. red5 1 Link to comment Share on other sites More sharing options...
Scruffy Bodger Posted August 12, 2018 Share Posted August 12, 2018 Some of the fuel additives for dervs contain cetane boosters so it gives you a false sense of improvement. Ime just drive a derv with a heavy right foot, not necessarily revving the nuts off it just don't granny it about everywhere. I've never had a diesel fail on emissions yet and I've had many. As for adding acetone, I'd be careful with how much you use. I had access to loads of it years ago and had thoughts of using it as a fuel improver. I dropped some fuel line into some as a bit of a test. The fuel line simply fell to bits after 24 hours. What it would do to other vital bits in a fuel system, fuck knows but I didn't want to find out! Link to comment Share on other sites More sharing options...
406V6 Posted August 12, 2018 Share Posted August 12, 2018 Back around 89/90 I had a couple of petrol injected cars (including Astra GTE 8V) that had problems with hot starting. Using Redex injector cleaner - a cap full with every tank of fuel - sorted the problem. These days I always use super unleaded and never have problems. Link to comment Share on other sites More sharing options...
djimbob Posted August 12, 2018 Share Posted August 12, 2018 If you have an engine which is clagged up then these snake oils may well help clean the internals to a greater or lesser degree, but they won't fix actual mechanical issues like injectors with fucked springs or whatever sourcery lives in them! You can't really beat taking things apart and cleaning them manually, but if you don't want to go down that road, then by all means try the potions - personally having seen the innards in a pug 207 1.6 hdi and the clag therein from 2 years of granny driving equivalent, no amount of redex and italian tuning was going to resurrect that orl modern diseasels are shit Link to comment Share on other sites More sharing options...
sierraman Posted August 12, 2018 Share Posted August 12, 2018 Having took a few EGR valves off, the amount of carb cleaner and scrubbing with old toothbrushes and wire brushes it takes to get a satisfactory result makes the probability of the so called EGR cleaners in a 300ml tin working practically nil. Link to comment Share on other sites More sharing options...
iainrcz Posted August 12, 2018 Share Posted August 12, 2018 I drove all my pug diesels like I'd stolen them. Two were FAP HDi How many issues did they have?Zero. Probably did 20mpg less than they should but hey if I was skint I'd walk.I'm not a heroin addict and we don't have 13 kids so my cars get have a decent running budget. Sent from my VFD 710 using Tapatalk Scruffy Bodger and steveo3002 2 Link to comment Share on other sites More sharing options...
sierraman Posted August 12, 2018 Share Posted August 12, 2018 Can’t stand seeing a diesel getting lugged everywhere at 30 mph in top. Times have moved on it’s not a 1978 Ascona 2.3 diesel. Link to comment Share on other sites More sharing options...
red5 Posted August 12, 2018 Share Posted August 12, 2018 My mechanic said to put 2 stroke in veg to keep things clean.So I do. 0.5% (by vol) Mineral 2t ftw. Ps, not really. puddlethumper 1 Link to comment Share on other sites More sharing options...
DodgeRover Posted August 12, 2018 Share Posted August 12, 2018 I don't think 2t in veg will make any difference, it does with proper older diesel engines running pump fuel though since they removed most of the sulphur and lubricants from it. Link to comment Share on other sites More sharing options...
red5 Posted August 12, 2018 Share Posted August 12, 2018 They removed sulphur yes, but modern stuff is full of lubrication centered additives. Best advice is use a decent premium heavy oil - they have the 'good' (expensive) additives. Link to comment Share on other sites More sharing options...
forddeliveryboy Posted August 12, 2018 Share Posted August 12, 2018 As for adding acetone, I'd be careful with how much you use. I had access to loads of it years ago and had thoughts of using it as a fuel improver. I dropped some fuel line into some as a bit of a test. The fuel line simply fell to bits after 24 hours. What it would do to other vital bits in a fuel system, fuck knows but I didn't want to find out! 0.35% has no bad effects on anything containing or within a fuel system in my experience. 35% probably would. Link to comment Share on other sites More sharing options...
Junkman Posted August 13, 2018 Share Posted August 13, 2018 The bloody best injector (and carby, while I'm at it) cleaner, is half a litre of Diesel in a tank of petrol.If you have given up in life and actually drive a Diesel, on Diesel, or any other such piss take that's trying to qualify itself off for beinga propellant for motor vehicles that in fact aren't, ALWAYS add a cap full of two stroke oil to a tank, without failing, to each and every tank fill. And dump that expensive snake oil into the sea. The fucking cod will love it.Because if you read the fucking ingredients of that shit, you will find out it's exactly what I mentioned above, but for snake oil prices. Link to comment Share on other sites More sharing options...
castros_bro Posted August 13, 2018 Author Share Posted August 13, 2018 The bloody best injector (and carby, while I'm at it) cleaner, is half a litre of Diesel in a tank of petrol.If you have given up in life and actually drive a Diesel, on Diesel, or any other such piss take that's trying to qualify itself off for beinga propellant for motor vehicles that in fact aren't, ALWAYS add a cap full of two stroke oil to a tank, without failing, to each and every tank fill. And dump that expensive snake oil into the sea. The fucking cod will love it.Because if you read the fucking ingredients of that shit, you will find out it's exactly what I mentioned above, but for snake oil prices. I ALWAYS add two stroke oil to a tank, without failing, to each and every tank fill Shirley Knott, forddeliveryboy and Lacquer Peel 3 Link to comment Share on other sites More sharing options...
forddeliveryboy Posted August 13, 2018 Share Posted August 13, 2018 Old style ATF is meant to be so effective at cleaning things out that a remote place on a windy day is recommended. The traditional approach was to drain the filter of diesel, replace with the aforementioned then drive Italian for a minute or so. djimbob 1 Link to comment Share on other sites More sharing options...
