Split_Pin Posted July 16, 2018 Share Posted July 16, 2018 This has settled down of late into something very pleasurable to drive. But I have a fair few cars sitting waiting on my bucket list so its time to move on. Spec: BMW Diesel 1951cc 115bhp. 163,000 milesConnoiseiur spec gets you electric memory leather seats and climate.SE gets you a rear sunblind and cruiseIt also has the 'Driver Intelligence Pack' which gives you rain sensing wipers, parking sensor and auto dim mirror.It also has 4 electric windows, mirrors and remote central locking. I'll start with the negatives:2 months MOTNeeds 2 bottom arms (just over £100 for the pair)The clutch release bearing whines when you depress the clutch whilst driving. It isnt loud, hasnt got any worse for me or the previous owner. Having the radio on a low volume or the windows open makes it inaudible. The clutch otherwise works perfectly and bites crisply about 1/3 of the way up. There is a slight leak from the steering rack. Its not serious and perhaps leaves about 3 small drips overnightAn inline thermostat was fitted but the top hose either hasnt been tightened up enough or the stat needs pushed down the pipe a bit more as there is a very slight coolant leak from there.The sump plug doesnt have a washer so there is the odd drip from thereThere is/has been an oil leak further up the block but I havent investigated that as it doesnt drip.If you fill it over 2/3 there is a fuel leak. I believe its the circular seal at the top of the tank for the pump. The tank is plastic.A/C isnt that coldSome scratches on the osf wing and rear bumper.Drivers window sticks going up, but I just budge it up on the button.Tyres are old worn and shit. They need to be replaced. Incorrect profile on the back.Small amount of water ingress in the boot from the rear window trim clips.Airbag light is on most of the time, connectors under the seat are the culprit, a clean up is the likely solution. The good:Engine and gearbox work great. No smoke at all even on start up nice and smooth for a dizzler, starts first time. Interior is in very good condition and is a lovely place to be. Apart from the A/C, all the toys work.Exterior generally smart and presentable.Underneath is solid including sills. I Vactan'd Hammerited and then stonechipped all areas which had surface corrosion.Brand new upper rear suspension arms fitted a month ago.New starter.New osf drop linkOil and filter changed in May, PCV filter changed in March by the PO (trusted shiter)New fuel tank strap2 new jacking pads as they were missingGreat on diesel, 45 mpg thereabouts.Osf caliper is now behaving itself after I stripped and cleaned it. I do love this car but I also love several others so I am chancing my arm here. I really cant see what else it would need for another ticket other than tyres, the airbag light and the lower arms. I am looking only to get back what I paid for it. Car is located near Cumbernauld in Scotland. jumpingjehovahs, oldcars, clayts450 and 4 others 7 Link to comment Share on other sites More sharing options...
Split_Pin Posted July 16, 2018 Author Share Posted July 16, 2018 I would happily give this another machine polish prior to sale! I have also cleaned and treated all the seats which now make satisfying farty noises when you enter/exit to let you know that you have DECADENCE. oldcars and Wingz123 2 Link to comment Share on other sites More sharing options...
davehedgehog31 Posted July 16, 2018 Share Posted July 16, 2018 Shame you're parting with it, hope it stays on here. That's a lot of car for £300. Split_Pin 1 Link to comment Share on other sites More sharing options...
Split_Pin Posted July 16, 2018 Author Share Posted July 16, 2018 2 tons of car as it happens! Aston Martin and oldcars 2 Link to comment Share on other sites More sharing options...
Split_Pin Posted July 16, 2018 Author Share Posted July 16, 2018 Looks like this is going on ebay. Wish me luck! Link to comment Share on other sites More sharing options...
aldo135 Posted July 16, 2018 Share Posted July 16, 2018 No 3 way swaps this time?!!! GLWTSM8 Split_Pin 1 Link to comment Share on other sites More sharing options...
dome Posted July 16, 2018 Share Posted July 16, 2018 That is a bargain. It'll shift no bother. Hopefully on here! Split_Pin 1 Link to comment Share on other sites More sharing options...
pauldoubleyou Posted July 16, 2018 Share Posted July 16, 2018 Big spend on these is the rear arms.. especially for Scottish versions. The captive bolts shear and make the removal of them a ducking nightmare. Major selling point that it’s been done. Tbh if it had longer test I’d have this, I’m not far away from you. I just don’t have the time to retest it. If you need it scanning I’m sure I have the software still somewhere. I’m up near the erskine bridge. Sent from my iPhone using Tapatalk CortinaDave, oldcars and Split_Pin 3 Link to comment Share on other sites More sharing options...
Split_Pin Posted July 17, 2018 Author Share Posted July 17, 2018 Provisionally sold Bucketeer, loserone, oldcars and 6 others 9 Link to comment Share on other sites More sharing options...
fatharris Posted July 17, 2018 Share Posted July 17, 2018 Not surprised, they're fantastic machines, I'll have another one day! Split_Pin 1 Link to comment Share on other sites More sharing options...
Lord Sterling Posted July 17, 2018 Share Posted July 17, 2018 Oooh bloody hell. Oh dear. If only I had £300 spare. I need something a bit cheaper on fuel to drive to work in as my BMW is costing over £45 a week. Bah! Split_Pin 1 Link to comment Share on other sites More sharing options...
Split_Pin Posted July 17, 2018 Author Share Posted July 17, 2018 It does about 40 to 45 mpg, apart from the 973cc Corsa, this is the most economical car I have owned. aldo135 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted July 18, 2018 Share Posted July 18, 2018 Thank fuck for that. Temptation removed. Tam and barefoot 2 Link to comment Share on other sites More sharing options...
