Shirley Knott Posted May 1, 2018 Author Share Posted May 1, 2018 Yup, onto that one... That technique lead to the discovery of the 'troubles' in the back (I initially thought the passenger front footwell was the only area effected.) danthecapriman 1 Link to comment Share on other sites More sharing options...
Mrs6C Posted May 1, 2018 Share Posted May 1, 2018 If you can't remove the carpets entirely, a stack of old newspapers laid under the carpet to soak up the water, to be removed when wet and replaced then repeat until dry, works well. Disposable nappies - as large as you can get them - opened out with the inside pressed to the wet area and weighted down with something will also do a fine job of absorbing any stray liquid and, as they say in the adverts, they do not leak! Shirley Knott, Shep Shepherd and danthecapriman 3 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 2, 2018 Author Share Posted May 2, 2018 Right, another hour spent on the car this morning, in a new and exciting twist it seems having lifted the carpets on the drivers side, front and back are soaked there too... That's the full car The only positive in this whole saga is that the floors all appear to be rust free... Only one thing for it, full carpet removal and then test This morning I've taken out the drivers seat, pulled back the carpets where they were being held down by it and then put the seat back in... Two questions I have are... The plastic ECU cover/trim piece (Pictured on the right hand bleow) side doesn't seem to be held in by the usual torx screws It's the only thing that's holding me back from complete removal of the front/drivers carpet, does anyone know how it comes off...? SAM_6415 by Also to remove the rear carpets I'm assuming that the back seats and centre console have to come out? How is the centre console removed? Mrs6C and Jim Bell 2 Link to comment Share on other sites More sharing options...
Shep Shepherd Posted May 2, 2018 Share Posted May 2, 2018 That piece of trim is held in by interference only, so all you need to do is pull it gently towards you to remove it. The centre console is held in by screws in the recess between the handbrake and gear lever and fixings (can't recall if they are screws or bolts) found under a prise-out cover in the cubby hole Pawnote: getting stuck in like that with a car that's new to you is a great way of bonding with it. Or not, depending on your level of enthusiasm/insanity. Assuming that your car doesn't have A/C, have you checked the big grommet at the top of the passenger side bulkhead? It's unlikely, but water may have got past it during the engine clean. Shirley Knott, danthecapriman and Mrs6C 3 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 2, 2018 Author Share Posted May 2, 2018 That piece of trim is held in by interference only, so all you need to do is pull it gently towards you to remove it. The centre console is held in by screws in the recess between the handbrake and gear lever and fixings (can't recall if they are screws or bolts) found under a prise-out cover in the cubby hole. You legend EDIT: Pull back towards as in back towards the B pillar/rear of the car, or inwards towards the center column/gearstick etc? Shep Shepherd 1 Link to comment Share on other sites More sharing options...
Shep Shepherd Posted May 2, 2018 Share Posted May 2, 2018 A combination of both. Be patient and you'll get it out. Watch out for the vertical bit which goes up the A pillar, though. It's a lot easier to do than explain! Shirley Knott and Mrs6C 2 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 3, 2018 Author Share Posted May 3, 2018 Right, another hour or so's fettling this morning. I've noticed that the bearing on the alt sounds rough That will have to be put on the laterbase as other problems (Leaking) are more pressing.... Quick test, at least it's charging well.... Onwards and upwards. Shep Shepherd's advice RE ECU cover and centre column removal was spot on (Thanks mate!) As an added bonus I even found an OBD port under the armrest too... Progress. All carpets (Other than boot) and all but the drivers seat are now completely removed... Again, big thanks to all of you who've chimed in with advice/support thus far. Lots of the bits I've done would have caused a lot more grief and taken a lot longer without you lot, I appreciate it Next steps are to re-seal the kick/knee vent jobbies, remove cowl and check the drains there, re-seal the windscreen if possible and also apply creep and seal around the sunroof (Much as I loath to bodge it, it's already siliconed in place so going over that again and making sure the existing bodged seal is weatertight seems to be the best option at present.) Shep Shepherd, danthecapriman, Mrs6C and 1 other 4 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 3, 2018 Author Share Posted May 3, 2018 Assuming that your car doesn't have A/C, have you checked the big grommet at the top of the passenger side bulkhead? It's unlikely, but water may have got past it during the engine clean. Totally missed this part of your last post (Too busy rushing straight outside to tug the ECU panel off) No AC... I shall have a look on the firewall tomorrow morning. Shep Shepherd 1 Link to comment Share on other sites More sharing options...
Mrs6C Posted May 3, 2018 Share Posted May 3, 2018 Just feast your eyes on that lovely, rust-free, clean and wholesome floor! May I suggest that you could use these few days of good, dry weather that we are due, to remove the bodge of sealant from around the sunroof and open it up (if it will) to investigate that area properly? See if it is indeed a source of leaks and if so, why, for example if the drain holes are blocked, or pipes are missing etc. Then you will know for sure what is amiss. You can always close it up again and run a new bead of sealant around it but do a proper job of that, if you decide that to be the best course of action. IIR the 'seal' around the factory sunroof wasn't designed to be absolutely watertight, but allowed a small amount of water to seep in slowly, This was then removed by the four drain pipes... danthecapriman, Shep Shepherd and Shirley Knott 3 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 4, 2018 Author Share Posted May 4, 2018 Just feast your eyes on that lovely, rust-free, clean and wholesome floor! May I suggest that you could use these few days of good, dry weather that we are due, to remove the bodge of sealant from around the sunroof and open it up (if it will) to investigate that area properly? See if it is indeed a source of leaks and if so, why, for example if the drain holes are blocked, or pipes are missing etc. Then you will know for sure what is amiss. You can always close it up again and run a new bead of sealant around it but do a proper job of that, if you decide that to be the best course of action. IIR the 'seal' around the factory sunroof wasn't designed to be absolutely watertight, but allowed a small amount of water to seep in slowly, This was then removed by the four drain pipes... Yes, very pleased I've caught it in time to avoid rust! Tempting, but TBH I'm almost certain trying to scrape the sealant off enough to re-open the sunroof will result in damage to the surrounding paint... Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 4, 2018 Author Share Posted May 4, 2018 FML... Spent half an hour utterly soaking the Ovlov with a high pressure hose this morning, extra hosing for all of the suspect parts, ie door seals/windscreen/cowl/sunroof etc. It produced... Nothing...no leaks, nothing, nada, there're no bloody carpets or seats in there so if it had leaked I'd see it. Checked again 8 hours later, still all dry. The mystery is mysterious. Mind completely blown at this point. Need to get back to my VAG shite and put this one to bed now (Lupo needs front pads and discs, the Golf has a small blow on the exhaust) Tempted at this stage so smear a layer of sealant over all the suspect parts, put it all back together and call it job jobbed, keeping a close eye for moistness and periodically lifting carpets to check moving forwards At the risk of turning this topic into a kind of support group for people who've bought an aging Volvo and realised it's a bit of a pup, I've got two questions for the 700/900 series massive on board.... 1. I've removed both side/knee vent kick trims at this stage and I can clearly see the small black rectangular box that sits behind it on the passenger side (I'm assuming this is the part that commonly leaks?) It already looks like it's had a bead of silicone round it to me, I'm going to give it another for good measure, however I can't see one on the drivers side... I'm assuming if it's there it sits behind the ECU and said ECU must be removed to access it? 2. I'd like to remove the metal cowl that sits behind the bonnet and check the drains under there... I'm assuming there are drains there? This area is the No1 cause of wet carpets in Passat's I've owned so I'd like to check all is well in that area for my own sanity Clearly the wiper arms need to come off to get the panel lifted, any other tips or things I need to know about removal would be gratefully received! TIA. Jim Bell and Shep Shepherd 2 Link to comment Share on other sites More sharing options...
danthecapriman Posted May 4, 2018 Share Posted May 4, 2018 I can only go from the 700 models as I’ve never had a 900 despite them being essentially the same... The footwell vents are like a black hatch/box type thing. Normally the water runs down through the scuttle vent and down the sides of the A posts which is in the same area as these vents. Hence the leaks.On your 900 the ecu stuff is located on the drivers side where these vents are. On the old 700 like mine (no ecu!) there’s a vent on both sides and the two footwell trim panels are the same but mirror image per side. The 900 has a vent on one side and a solid slightly different shape cover on the other, I think. I’m not entirely sure if they did just leave the vent hatch under the ecu though? I can’t imag they did as it would seem pretty silly to install sensitive electronics next to such a thing, but... worth maybe trying to have a look behind it just incase?Imho it’d make good sense to re-seal these vents regardless. You’ve got it all stripped so you might aswell now. The front cowl cover (scuttle with vents below windscreen) does just unbolt. I removed it on my previous 740 to clean it out. Yes, water does drain out that way.When I did the last one it was easy to get out, cleaned out all the leaves and gunk then sprayed it with cavity wax (just incase!) and also reglued the mesh vent stuff that sits under the slots. Getting it back on was a bit of a pig though. It was tight and took a fair bit of messing to get it back in. God knows why!?I need to do this on my current 740 too as the mesh has come off on this one too. Edit; i think there’s a rubber seal to take off and some other clips under the bonnet too before you can lift the outer panel off. Worth checking before you just rip it off though! Shep Shepherd and Shirley Knott 2 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 4, 2018 Author Share Posted May 4, 2018 ^ Thanks. Everything I needed to know Shep Shepherd 1 Link to comment Share on other sites More sharing options...
danthecapriman Posted May 4, 2018 Share Posted May 4, 2018 ^ Thanks. Everything I needed to know Best of luck with the scuttle job.To get mine back on I had to put a towel on it, then step on it with one foot to push it down into place while someone else tightened the bolts. I don’t know if mine flexed as I took it off or something but when I put it back on the first time the bonnet would hit it when closing it down. It needs really pushing down home then tightening up.It’s possible it might just have been that particular one of course! Shirley Knott 1 Link to comment Share on other sites More sharing options...
Shep Shepherd Posted May 4, 2018 Share Posted May 4, 2018 I took The Volvo's scuttle panel off to lubricate the wiper mechanism and to clean and rustproof the bulkhead last autumn. Not that it actually needed much more than a vacuum out of the accumulated debris and the odd dab of Waxoyl: I found it such an easy job compared to a lot of things I've done on the car that I can't really remember much about it danthecapriman, Shirley Knott and Mrs6C 3 Link to comment Share on other sites More sharing options...
danthecapriman Posted May 4, 2018 Share Posted May 4, 2018 I took The Volvo's scuttle panel off to clean and rustproof the bulkhead last autumn, not that it actually needed much more than a vacuum out of the accumulated debris and the odd dab of Waxoyl. I found it such an easy job compared to a lot of things I've done on the car that I can't really remember much about it I’m glad you said that as it makes me feel better about doing it on my current one! I’ve been putting off doing it.The mesh grill things come loose and needs bonding back on. Looks like it’s just thick mastic type stuff securing it to the back of the panel? Tiger seal might work to reattach it? Shirley Knott and Shep Shepherd 2 Link to comment Share on other sites More sharing options...
Shep Shepherd Posted May 4, 2018 Share Posted May 4, 2018 Tiger Seal or similar would do the job perfectly. I used a bit of super glue to reattach the mesh on mine, as it was only coming loose in a couple of places. Take care, though, as the edges of it are quite sharp. danthecapriman and Shirley Knott 2 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 4, 2018 Author Share Posted May 4, 2018 Shep Shepherd to the rescue with pictures again Thanks chaps, mojo regained. Handful of brave pills tomorrow morning and I'll get cracking Mrs6C and Shep Shepherd 2 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 5, 2018 Author Share Posted May 5, 2018 Cowl/scuttle thing removed today. Not much to see, certainly nothing that could cause water ingress. My conscience has got the better of me, rather than immediately re-bodging, tomorrow I shall cut though/dig out the silicone and see if the sunroof works Clearly the sunroof seal/gasket is likely to be damaged doing this. I've done much searching but can't seem to find replacement seals for sale anywhere.... GrumpiusMaximus, Shep Shepherd and danthecapriman 3 Link to comment Share on other sites More sharing options...
Isaac Hunt Posted May 6, 2018 Share Posted May 6, 2018 Give the entire floor area a dusting of Talc. When the water trickles in it leaves a more visible trace. Worked a treat on a Rover 400 to confirm leaky rear light cluster seals and then prove 'cured' after some silicone treatment. Shirley Knott and danthecapriman 2 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 13, 2018 Author Share Posted May 13, 2018 Another nice weekend so some Volvo based tinkering has taken place Sunroof was cut open to investigate, it will lift to the open position but won't slide back. Shameful as it is, I've closed it and re-sealed it, only this this time properly with Sikaflex and Captain Tolley's Creeping Crack Cure (Yes really) After an hour and a half aggressively assaulting the car with a hose I couldn't produce any evidence of leaking, not a drop. Checked again the next morning and still bone dry.... Baffled. Today I bit the bullet and put the carpets/seats etc back in. An hour or so's wafting around this afternoon produced big grins. Coolant levels remain steady/carpets still bone dry. I've been unable to get to the bottom of what had gone on to get things so wet but will regularly check for water ingress (And possibly forever remain paranoid) during the rest of my tenure with the car. Onwards and upwards. Oils and filters ordered from ECP during another one of their perpetual '35%OFF!!!' style sales for just over 25 groats, I shall use the car for work this week and plan a minor service for next week at some stage. danthecapriman, Shep Shepherd, GrumpiusMaximus and 1 other 4 Link to comment Share on other sites More sharing options...
danthecapriman Posted May 13, 2018 Share Posted May 13, 2018 Excellent!Is it not just possible someone left a window slightly open in the rain/washing car which let the water in? I can’t imagine your floors being as sound as they are if it was a long term leak or one that’s gone unnoticed for a while. Use it and see I suppose. Having fixed mine some time back I still have a quick feel under the mats every few months for damp! None found so far but I’m paranoid! Shirley Knott 1 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 13, 2018 Author Share Posted May 13, 2018 Excellent!Is it not just possible someone left a window slightly open in the rain/washing car which let the water in? ^Gawd, I hope so. One thing's for sure, I certainly can't re-produce the leak myself despite much effort. I will proceed with regular checks and see how I get on... danthecapriman 1 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 19, 2018 Author Share Posted May 19, 2018 Time for another update. I've now owned the Volvo for a total of three weeks and that's provided me with enough time to fall completely and utterly, no questions asked head over heels in love with it... It's such a fantastic car to drive. Quiet, incredibly comfortable and there's something about sitting in it that somehow feels like I'm receiving a giant reassuring hug, albeit in automotive format. Ok, ok, I'll stop gushing, in short I like it a lot. On this basis of the information above I've now begun to lavish care/attention/cash... I always end up doing this with cars I buy TBH, but never has there been a more deserving candidate and in this instance it feels truly justified. First things first, one of the things that has been letting the car down was the peeling doorcards (A common niggle with the 940 marque I've later learned.) See images... I knew I needed to sort these and phoned all of the Volvo breakers/specialists I could find, only to be told that nobody had any in the correct colour and if they got any the would be £100-£150 and would be reluctant to post... Then, to my absolute joy and by some strange twist of fate I spotted a '90 reg 940 in saloon flavour in a scrap yard about 15 miles from home... Called them and asked, the car had perfect doorcards in the right colour.... The best bit is the price. They wanted £20 I don't think I've driven anywhere faster in my life. As promised the doorcards were perfect and other than the carpeted sections above the door pulls a complete match colour wise. The only anomaly is the front's didn't have speakers... The vinyl literally went straight across the cards? Very strange... Never mind. Holes were carefully cut for the speakers and the old ones (Pop riveted in) were drilled out and transferred across and fastened in place with small bolts and nylock nuts. Carpeted sections were also transferred across from the old cards without issues too. As is usually the case, the first doorcard had taken me the best part of an hour to remove at the breakers, by the time I was installing the last one at home I had them down to about 10 minutes per door. Next on the list was the sunroof switch. Having investigated and found that my sunroof was not only probably leaking but also borked, I'd sealed it shut again (But properly) until I could investigate further. Until that time it makes sense to remove the switch. Along with the doorcards mentioned earlier I'd grabbed a host of other spares from the breaker car as they were cheap, including blanks for my sunroof switch to avoid the temptation to knock it accidentally etc. Panel out... And blank installed to replace the switch until something can be done with the actual sunroof mechanism... Meanwhile my badly worn seat had been at the trimmers all week.... In effect it had come apart at the seams in several places and where-as usually I'd have been tempted to stich it back up myself, I decided that in this instance the car deserved better than that. The price quoted to remove the cover and make good again was surprisingly small. Seat returned and looking as good as new... And breathe... Interior now looking much nicer with non-damaged seats and minty fresh doorcards, lots of work but for circa £50 all in well worth doing IMO... gm, GrumpiusMaximus, puddlethumper and 10 others 13 Link to comment Share on other sites More sharing options...
danthecapriman Posted May 19, 2018 Share Posted May 19, 2018 Looks excellent. Well worth doing too, stuff like that really lifts a tired car imho, makes it look and feel like a nice car rather than an old banger. Shep Shepherd, Scruffy Bodger and Shirley Knott 3 Link to comment Share on other sites More sharing options...
GrumpiusMaximus Posted May 19, 2018 Share Posted May 19, 2018 I think I'm falling in love with the Volvo, too. Shirley Knott 1 Link to comment Share on other sites More sharing options...
Shep Shepherd Posted May 19, 2018 Share Posted May 19, 2018 Fantastic update! I need to take The Volvo's front seat to a trimmer, as it has a split seam on the outside edge of the driver's seat. sewed it back together myself years ago, but it's not the prettiest job. It might be easier to replace it, if I can find a seat. If anyone knows of a good driver's seat for a 740 SE or early 940 SE in grey trico plush going cheap, let me know. Shirley Knott 1 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 19, 2018 Author Share Posted May 19, 2018 ^ I'm 99% certain that's the exact colour of the seats in the breaker I've been rummaging in, it's a 1990 740 GL saloon... Unfortunately whilst the car is good and seems to have been scrapped despite it's last MOT in 2012 only showing 79k miles, the drivers seat looks to be completely covered in grime, maybe even oil? Frustratingly all other seats seem A-ok If you'd like I can buy the seat (Probably very cheaply indeed) and have a go at cleaning it up with washing powder/stiff brush/jet-wash? If I can get the muck out then good, if not I can dispose of it? Jim Bell 1 Link to comment Share on other sites More sharing options...
Shirley Knott Posted May 20, 2018 Author Share Posted May 20, 2018 This thread has become a bit Swede centric of late and I've been feeling slightly guilty about it, so up with the larks this morning washing and waxing my VAG shizzle... I'm always pleasantly surprised with how well they scrub up for such old cars Admittedly the Golf had newer wings fitted that I'd pilfered from a lower mileage petrol based breaker and both had a thorough going over with compound and polish when I bought them, none the less they seem to hold up very well considering they both still see daily grind type useage through salt, snow, short journeys and everything else our household can throw at them. Also, it's absolutely inconceivable to me that the Lupo is now getting on for 20 years old, I have to remind myself of that now and then... It seems like yesterday that these came out and I fondly remember them being in VW showrooms danthecapriman and Jim Bell 2 Link to comment Share on other sites More sharing options...
Amishtat Posted May 20, 2018 Share Posted May 20, 2018 I don't suppose the scrap 740 has a decent pair of rear lights by any chance? Link to comment Share on other sites More sharing options...
