Wingz123 Posted April 17, 2018 Share Posted April 17, 2018 Is this a diesel? Sounds like stuck/sticky injector or injector seal blowing. Take the cover off....is there any black death? (Evidence of oil sooty carbon build up around any of the injectors) I reckon this is the very early beginnings of injector seal going. Get it done asar than wait as the black death will take over and it’ll be ny on impossible to get the injectors out to replace the little o rings (seals) Just done mine on my sprinter... Link to comment Share on other sites More sharing options...
Liggle Posted April 17, 2018 Author Share Posted April 17, 2018 Is this a diesel? Sounds like stuck/sticky injector or injector seal blowing.No, its a petrol. Lots of vids on YouTube of the same thing, most are cured by engine flush and oil change or oil treatment. That'll be my first stop, just invested in a Pela pump (wanted an excuse to buy one for ages) so will get that done at the weekend. Link to comment Share on other sites More sharing options...
mercrocker Posted April 17, 2018 Share Posted April 17, 2018 http://forums.mercedesclub.org.uk/index.php?threads/m116-engine-tapping-noise-blocked-oil-channel.41937/ Link to comment Share on other sites More sharing options...
Liggle Posted April 18, 2018 Author Share Posted April 18, 2018 Replaced the caliper: This would explain the sticking, torn seal and loads of rust and crap around the piston: Nicely glazed and cracked pads: I read online about holding the engine at 4K rpm in a gear for a minute or so to see if the tapping cleared and it only bloody worked! Must be oil flow related, engine flush and oil change planned for the weekend. It’s behaving for now! Dirk Diggler, theshadow, DeeJay and 1 other 4 Link to comment Share on other sites More sharing options...
Wingz123 Posted April 18, 2018 Share Posted April 18, 2018 Waaaahhhhhhh ^^^^^ can you explain exactly what you did? Were you stationary or on the move?.....intrigued by this! Link to comment Share on other sites More sharing options...
Liggle Posted April 19, 2018 Author Share Posted April 19, 2018 Waaaahhhhhhh ^^^^^ can you explain exactly what you did? Were you stationary or on the move?.....intrigued by this!Just held it in second once moving and up to 4.5k rpm, drove like that until the road speed limit changed and it had cleared! It cleared but came back slightly around 1.5k rpm but cleared once you revved above this under load. Cold start the next day it was rattling again but cleared once driven round the block and warmed up, hoping to play with my new Pela pump toy and flush/change the oil this evening. Link to comment Share on other sites More sharing options...
Wingz123 Posted April 19, 2018 Share Posted April 19, 2018 What you reckon is causing this then? Has the oil just lost its lubricating properties thus making it sound rattily? Link to comment Share on other sites More sharing options...
Liggle Posted April 20, 2018 Author Share Posted April 20, 2018 Flushed and changed the oil, the pela pump pulled out 8.5L so did a great job: No rattles since, even on a cold start this morning. Fingers crossed that’s it! Only thing I noticed really was deformed oil filter but I think that’s pretty normal on a filter that needs replacing? Lacquer Peel and Uncle Jimmy 2 Link to comment Share on other sites More sharing options...
Liggle Posted September 25, 2018 Author Share Posted September 25, 2018 Well several months and 2k+ miles later the engine has been sweet as a nut, has literally never rattled again. I used it for commuting for a bit and it tipped 30mpg regularly. This will be taking part in a charity rally from Sunday onwards, we will be covering over 2500 miles in 5 days as part of the 'Gib or Bust' 2018 rally. That also means in approx. 2 weeks time it'll be up for sale/roffle, I'll post up when I am back with the details. Link to comment Share on other sites More sharing options...
Liggle Posted October 10, 2018 Author Share Posted October 10, 2018 This is being scrapped the end of next week unless anyone on here wants it?Just completed a charity banger rally in it, did over 3000 miles in a week.Good points:- MOT until 9th Nov- Drives well- I put 4 brand new Falken tyres on it 4k ago- Recent front caliper & pads, battery & exhaust (battery alone was over £100)- Pulls well and we achieved 30mpg on fast motorway runs without failBad points:- Had to put some K seal type stuff in but its not used a drop of water since, and its never over-heated, I put it in as a pre-caution due to coolant dropping every few hundred miles- Random hesitation when hot in traffic, brand new Bosch crank sensor included- Surface rust, but solid underneathNeeds to be collected between 18th and 20th October otherwise it'll be scrapped locally for £199 hence the price. All the remaining stickers are removable, just not got the time/inclination. DVee8, oldcars, loserone and 2 others 5 Link to comment Share on other sites More sharing options...
gadgetgricey Posted October 10, 2018 Share Posted October 10, 2018 Where abouts are you? Laseraligningfoofooflanges 1 Link to comment Share on other sites More sharing options...
The_Equalizer Posted October 10, 2018 Share Posted October 10, 2018 £199 - nuts! If you can do some spannering I think CLKs are one of the best bargains out there at the moment. If anyone is tempted by this, then also buy yourself a copy of the "Mercedes WIS" on the bay of delights. This will give you access to all part numbers whichis invaluable in running one of these. CLK320s were about £35K plus in real terms.Hopefully this won't be turned into bean cans. I did chuckle that the original owner chose the fully electronic seat adjustment option, but went with cloth. Laseraligningfoofooflanges 1 Link to comment Share on other sites More sharing options...
skattrd Posted October 10, 2018 Share Posted October 10, 2018 Where abouts are you? He's in Leicester … I am slightly tempted myself, but must resist. Link to comment Share on other sites More sharing options...
Liggle Posted October 10, 2018 Author Share Posted October 10, 2018 Sorry, I forgot to add mileage is 143k and I'm in Leicester Link to comment Share on other sites More sharing options...
Cavcraft Posted October 10, 2018 Share Posted October 10, 2018 Bargain that and these drive an absolute treat. Where in Chester did you buy it from? Link to comment Share on other sites More sharing options...
JayB Posted October 10, 2018 Share Posted October 10, 2018 I'll happily take it off your hands! PM sent. richardthestag and Cavcraft 2 Link to comment Share on other sites More sharing options...
Exiled_Tat_Gatherer Posted October 10, 2018 Share Posted October 10, 2018 This makes me (almost) want to be back in Blighty!!!!!! Sorry I can't help as I'm in to collect a T5 and a certain van in the very near future - so I'm screwed....... Link to comment Share on other sites More sharing options...
DodgeRover Posted October 10, 2018 Share Posted October 10, 2018 This makes me (almost) want to be back in Blighty!!!!!! Sorry I can't help as I'm in to collect a T5 and a certain van in the very near future - so I'm screwed.......Aren't you picking up a cf recovery as well? Link to comment Share on other sites More sharing options...
Laseraligningfoofooflanges Posted October 10, 2018 Share Posted October 10, 2018 OMG mega bargz I find that cloth interior oddly alluring Link to comment Share on other sites More sharing options...
Kiltox Posted October 10, 2018 Share Posted October 10, 2018 Bargain that and these drive an absolute treat. Where in Chester did you buy it from?“STAY OUT OF MY TERRITORY” Heisencraft Cavcraft, Brodders and wuvvum 3 Link to comment Share on other sites More sharing options...
320touring Posted October 10, 2018 Share Posted October 10, 2018 “STAY OUT OF MY TERRITORY” Heisencraft"I'M the one whose engine KNOCKS" wuvvum, Kiltox and blakey79 3 Link to comment Share on other sites More sharing options...
Shandylegs Posted October 11, 2018 Share Posted October 11, 2018 Guess who should have been quicker on the uptake! If by any miracle this hasn't been sold I'll take it please. Thanks...... Link to comment Share on other sites More sharing options...
richardthestag Posted October 11, 2018 Share Posted October 11, 2018 Flushed and changed the oil, the pela pump pulled out 8.5L so did a great job: do NOT tell the Austrian German Francophile who hates my ancestral county and lives in the UK Link to comment Share on other sites More sharing options...
Liggle Posted October 14, 2018 Author Share Posted October 14, 2018 Sorry for delayed replies, I am in Spain at the moment. Had a lot of interest in this, provisionally sold to JayB Link to comment Share on other sites More sharing options...
Liggle Posted October 18, 2018 Author Share Posted October 18, 2018 SOLD skattrd, Datsuncog, Floatylight and 1 other 4 Link to comment Share on other sites More sharing options...
Datsuncog Posted October 18, 2018 Share Posted October 18, 2018 Good news! Let's hope this one lives to fight another day. It really doesn't look half bad. Liggle 1 Link to comment Share on other sites More sharing options...
