Welcome to Autoshite
Guest Message by DevFuse
Split_Pin's Rover 75 CDT Connoisseur: 20/7/18 So long :(
  • Please log in to reply
379 replies to this topic
#241 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
  • Country : Country Flag
Posted 16 May 2018 - 11:44 AM
I've spent most of this year scrabbling about under cars and haven't got much more left in me for this. I just want a hassle free option.
  • oldcars likes this
2003 Rover 75 CDT | 2002 Renault Sport Clio 172 | 2000 Corsa B | 2017 Dacia Duster
Car Reviews 1/1 and smaller: https://www.youtube....KdUmtnq5VNMSnJg
#242 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 16 May 2018 - 11:45 AM
I had this and it was ball joint shield rubbing.
What's weird is that it does it at idle, although less loud.
#243 OFFLINE   Tickman
Tickman
    Rank: Citroen Ami
  • Full Members
  • 1,981 posts
  • 24 thanks
  • LocationDundee
Posted 16 May 2018 - 02:33 PM
 Cartakeback Govan have offered me £112 for it.
You cannot take this option.
1968 Morris Minor 1000
1972 Triumph Toledo
1985 Reliant Scimitar SS1
1986 Talbot Express Camper
1988 Peugeot 205 (Chuck's)
2001 Renault Clio (Meg's)
2003 Skoda Octavia
#244 OFFLINE   beko1987
beko1987
    Reliable Renault
  • Full Members
  • 14,527 posts
  • 49 thanks
  • LocationThame, Oxon
Posted 16 May 2018 - 02:38 PM
How far are you from sf18, and is anyone going that knows your address?
2001 Gooner2 Ph1 1.9Dci Expression (His)
2008 orl Vauxhalls r Shit Zafira 1.8 SRI 140 (Hers)
#245 OFFLINE   mk2_craig
mk2_craig
    Rank: Rapport Ritz
  • Full Members
  • 2,589 posts
  • 11 thanks
  • LocationIT'S CLEAN THE PLATES HAVE BEEN CHANGED THAT'LL BE $7438.
Posted 16 May 2018 - 02:49 PM
Get it FIXT!! You'll need it for when the Corsa is getting its 2.0 engine fitted. :)
1984 Ford Fiesta XR2 - Devaluing the neighbourhood since 2008
Nottinghamshite
Channel Island Cack
Everywhere Else
#246 OFFLINE   Mally
Mally
    Rank: Renault 16
  • Full Members
  • 2,399 posts
  • 34 thanks
Posted 16 May 2018 - 03:00 PM
In all probability, a 2.5 KV6 might be a better buy, most of the diesels are nails either cabbed or just worn out. KV6 more likely to have been cosseted all its life by its octogenarian owner.
Would disagree with this.
The diesels are capable of many more miles with much less hassle..........sometimes.
Petrol has head gasket, belts, thermostat housing, fuel consumption, problems. I've probably forgotten a few more.
#247 OFFLINE   sierraman
sierraman
    Rank: Isuzu Florian
  • Full Members
  • 9,387 posts
  • 84 thanks
Posted 16 May 2018 - 03:15 PM
I realise it sounds wasteful but quite frankly I'd chuck the money into a better one and bale this one. If you were completing the work DIY it would be debatable whether it was worth doing, paying someone its literally money down the drain, buy one off someone who has been daft enough to chuck money at it.
I don't know what the racket from the engine is but the clutch is £4-500 easy, then the rear arms again another couple of hundred at the garage, before you know it you've chucked a thousand quid at it.
Could always stick it on Gumtree, mention the noise, hope they don't notice the fucked clutch and hope for £300 or so. A lot of agg potentially but you might drop on someone that will have it.
#248 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 16 May 2018 - 03:23 PM
Ok after some encouragement I have decided that the least I can do is investigate the noise, even if its just to get closure.
A shit sleep and a massive turd of a working day have likely aggravated things, not the best mental environment to be making decisions in.
Off out running tonight, usually puts things in perspective.
  • Jim Bell, dome, Tickman and 3 others like this
#249 OFFLINE   oldcars
oldcars
    Rank: Motorway Services
  • Full Members
  • 6,105 posts
  • 35 thanks
Posted 16 May 2018 - 03:40 PM
You know me then  :shock:  :mrgreen:
  • Split_Pin likes this
#250 ONLINE   Datsuncog
Datsuncog
    Rank: Renault 16
  • Full Members
  • 2,740 posts
  • 66 thanks
  • LocationNorn Iron
Posted 16 May 2018 - 03:47 PM
Sounds sensible, man.
I knew that if I didn't at least have a go with the Gooner Twins, I'd always have had that quiet little voice muttering away, "what if it were just something really simple?"
It was a bollocky few weeks, but at least when the pair of them did go off to their uncertain fates, I was sure in my own head that I'd done all I could - and their maladies exceeded my skills and wallet.
The just-fucking-bale-it crew were right all along, but I'm still really glad I was able to confirm it for myself.
Here's hoping it does turn out to be something really straightforward on the Rover; you're surely due a lucky break.
#251 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 16 May 2018 - 04:28 PM
Cheers Tim :)
  • Datsuncog likes this
#252 OFFLINE   dome
dome
    Rank: Renault 16
  • Full Members
  • 2,685 posts
  • 18 thanks
  • LocationPeoples Republic of Fife
Posted 16 May 2018 - 10:10 PM
Give me a shout if you want me to give it a prod, you're not far away.
  • Split_Pin and The Moog like this
#253 OFFLINE   rml2345
rml2345
    Rank: Renault 16
  • Full Members
  • 3,603 posts
  • 3 thanks
  • LocationLANDMINES!
Posted 17 May 2018 - 12:17 AM
Sorry to hear you're having more bother with this thing man, it's been an ungrateful POS so far. I'd have suggested top mount were it not for the fact it's doing it at idle as the previous owner to me did the nearside mount and spring before I got it. Might be worth checking the bottom engine mount as well incase its burst another. Investigating it is the right thing to do even if only for closure so you know you're not sacking it off for something daft but I can understand why you're at the end of your patience with it.
  • Split_Pin, Datsuncog and oldcars like this
Current Wheels;
1994 Volvo 850 GLT Saloon (Twice)
Previous Wheels;
2003 Peugeot 406 HDi Saloon
2003 Rover 75 CDT Connoisseur Saloon
2003 Toyota "Leyland" Yaris T Spirit (Three times)
2002 Mitsubishi Carisma DI-D (Blob)
2001 Rover 75 CDT Tourer (Clover)
2000 Rover 75 CDT Saloon
2000 Honda Accord SE Executive
1996 Citroën Xantia Dimension (Les Hamper des Bisquites)
1996 Volvo 940 SE Turbo Estate (Beeb)
1993 Citroën AX Neon (Les Tin des Bisquites)
1994 Volvo 850 SE Saloon
1989 Volvo 740 GLE Saloon
1988 Volvo 740 GL Saloon (Telly)
#254 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 17 May 2018 - 12:02 PM
You have got me thinking. The upper aux belt pulley has rubbed away an as yet unidentified component that sits between it and the inner wing. Its a small dome-shaped thing that appears to be capping off some sort of pipe. Perhaps the upper mount has partially collapsed, dropping the engine onto this. Turning left might be shifting the engine further onto this and increasing the noise.
I'll have a look next week as I am investigating the Corsa's waterpump tonight as it is weeping a bit.
#255 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 17 May 2018 - 07:36 PM
I checked the droplinks and as expected theres a bit play in the o/s one.
I may also have *just* found what the racket was.
  • Jon, The Moog, Shep Shepherd and 9 others like this
#256 OFFLINE   beko1987
beko1987
    Reliable Renault
  • Full Members
  • 14,527 posts
  • 49 thanks
Posted 17 May 2018 - 08:13 PM
Blimey!
#257 OFFLINE   Jon
Jon
    Rank: Citroen Ami
  • Full Members
  • 1,777 posts
  • 3 thanks
  • LocationNZ
So has the noise gone? I hope so! Has there been much collateral damage?
#258 OFFLINE   beko1987
beko1987
    Reliable Renault
  • Full Members
  • 14,527 posts
  • 49 thanks
So you were going to scrap it for a screwdriver!
  • Split_Pin and Datsuncog like this
#259 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 17 May 2018 - 08:32 PM
I havent started it yet because it only really made the noise after a short drive. Everything points to it, the noise right behind the dash, turning left so the metal part rattled off the inner wing and doing it at idle.
I reckon it got worse only recently as the handle of the screwdriver wore away and it loosened. The pulley and belt look fine thankfully.
I shall use it for the station on Monday to see for sure.
  • The Moog, Lacquer Peel, dome and 1 other like this
#260 ONLINE   The Moog
The Moog
    Licking Lichen
  • Staff
  • 9,297 posts
  • 128 thanks
  • LocationAccrington .. who the heck are they ...
Posted 17 May 2018 - 08:34 PM
That's a result. Hence don't trust internet diagnosis
  • Split_Pin, Lacquer Peel and oldcars like this
1999 - 406 2.0 hdi 90
1991 - Eunos Track beast
2003 - Getz
#261 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 17 May 2018 - 08:35 PM
Even if the noise is still there is has taught me a lesson to investigate things once the 'fuck this shit' has subsided.
  • Jim Bell and Datsuncog like this
#262 OFFLINE   dome
dome
    Rank: Renault 16
  • Full Members
  • 2,685 posts
  • 18 thanks
Posted 17 May 2018 - 09:05 PM
Top diagnosing! There's no way I could wait til Monday though, get it out for a spin!
  • Split_Pin and oldcars like this
#263 ONLINE   davehedgehog31
davehedgehog31
    Rank: BL Wedge
  • Full Members
  • 845 posts
  • 12 thanks
  • LocationThe Town for Tomorrow
Posted 17 May 2018 - 09:07 PM
That would do it!
Agree with Dome, I admire your patience, I'd have all the tools still strewn over the driveway and be away a spin.
Chods;
1994 Peugeot 405 GTX 1.9 XUD Turbo
2003 Suzuki Alto 1.1 GL
2007 Citroen C1 1.0i Vibe
#264 OFFLINE   clayts450
clayts450
    Urban on-roader
  • Full Members
  • 1,886 posts
  • 24 thanks
  • LocationNottingham
Posted 17 May 2018 - 09:11 PM
Has to be the best ever repair* - let's hope it's completely fixed* now.
Truly gobsmacked.
P.S. Have I won the roffle ?
Current
2001 Rover 45 V6 Connie; 2003 Chrysler PT Cruiser Limited CRD2004 Rover Streetwise S
Historical choddage 1986-1998 (stopped driving 1999-2016)
1969 VW Beetle 1300;  1977 Morris Marina 1.3 Super; 1983 Skoda Estelle 120L; Rover Metro; Vauxhall CorsaVauxhall Cavalier
#265 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 17 May 2018 - 09:52 PM
I guess not having to rely on it just now makes me more relaxed about whether it will or won't still make a racket and I reckon thats a good thing. I might take it to the station tomorrow.
The engine is still healthy though, so is the gearbox and the body and interior are looking rather smart now. Plus its sunny and mild for the forseeable future so that means I can shite away after the wee man is in bed without any barriers, as long as I'm in when the streetlights come on.
  • Shep Shepherd, Jim Bell, dome and 1 other like this
#266 ONLINE   Datsuncog
Datsuncog
    Rank: Renault 16
  • Full Members
  • 2,740 posts
  • 66 thanks
  • LocationNorn Iron
Posted 18 May 2018 - 12:15 AM
Yeesh, that's the stuff of Autoshite lore right there - here's hoping that the surgical* removal of the screwdriver provides the cure we all desperately wanted here!
If so, that would be a fine result.
Rollcall of shite:
1980 Ford Cortina 1.6 L (1997); 1976 Mini Clubman 1.0 (1997); 1973 Vauxhall Viva HC 1.3 (1997-2005); 1984 Datsun Sunny B11 1.5 Coupé (1999-2000); 1983 Datsun Sunny B11 1.5 Coupé (2000); 1986 Ford Fiesta 1.1 Ghia (2001-2003); 1996 Ford Escort 1.6 LX (2003-2008); 1985 Toyota Corona 2.4 Avante (2005-2006); 1981 Ford Cortina 2.0 GL Estate (2008-2010); 1993 Volkswagen Polo 1.0 Genesis (2010); 1996 Citroen XM 2.5TD VSX Estate (2010-2011); 1988 Volvo 240 2.0 GL Estate (2011-2012); 2004 Alfa Romeo 156 1.9JTD Veloce (2012-2014); 1993 Volkswagen Polo 1.0 Fox (2013-2014); 1996 Renault Laguna 1.8 RN (2014 - 2018); 1997 Renault Laguna 2.0 RT Sport (2015-2017); 1998 Renault Laguna 1.8 RT Sport (2017 - 2018); 2003 Subaru Forester 2.0 XT (2018 - present)
#267 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 18 May 2018 - 06:02 AM
#Barry Scott
AND THE NOISE IS GONE
I thought I had found all of the buttons on this car but this morning I foound another. Its a symbol depicting a very old style desktop PC and its on the end of the indicator stalk. There is a button on the end of it. I'm saving that surprise for later.
  • mk2_craig, Shep Shepherd, beko1987 and 6 others like this
#268 OFFLINE   beko1987
beko1987
    Reliable Renault
  • Full Members
  • 14,527 posts
  • 49 thanks
Posted 18 May 2018 - 06:53 AM
I hope the windows XP startup sound plays when you press it
  • Split_Pin, dome, oldcars and 3 others like this
#269 OFFLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 18 May 2018 - 07:13 AM
Ha ha I never thought of that!
#270 OFFLINE   cpjitservices
cpjitservices
    Rank: Citroen Ami
  • Full Members
  • 1,867 posts
  • 27 thanks
Posted 18 May 2018 - 07:33 AM
Hmmmm this is food for thought.....
I'd love a 75!
Pref in 2.0 and a tourer.
I wonder.
Hmmmmmm
Audi A4 Avant  - 1.9 TDI SE - 1999 - undergoing restore, 240K miles
