Welcome to Autoshite
Guest Message by DevFuse
Split_Pin's Rover 75 CDT Connoisseur: 20/7/18 So long :(
  • Please log in to reply
379 replies to this topic
#361 OFFLINE   sierraman
sierraman
    Rank: Isuzu Florian
  • Full Members
  • 9,387 posts
  • 84 thanks
Posted 04 July 2018 - 11:37 AM
Red rubber grease.
#362 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
  • Country : Country Flag
Posted 04 July 2018 - 11:44 AM
Bit late now though! Ill get some for next time.
2003 Rover 75 CDT | 2002 Renault Sport Clio 172 | 2000 Corsa B | 2017 Dacia Duster
Car Reviews 1/1 and smaller: https://www.youtube....KdUmtnq5VNMSnJg
#363 OFFLINE   Mally
Mally
    Rank: Renault 16
  • Full Members
  • 2,399 posts
  • 34 thanks
Posted 04 July 2018 - 11:47 AM
Not sure they all have pad sensors?
Re bottom ball joint, you have to change the complete bottom arm, make sure the rubber block is changed as well.
There are 2 difficult bolts, strange spanner size but can't remember what. Also need ball joint splitter.
Quite awkward to remove them and I have a pit. Took me 2 or 3 hours and I didn't enjoy it.
#364 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 04 July 2018 - 11:53 AM
Thought that. Not a job I shall be doing myself. Thankfully bottom arms are cheap enough.
What brand would folks recommend? The most common is 'D2P' but I have never heard of them before.
#365 OFFLINE   oldcars
oldcars
    Rank: Motorway Services
  • Full Members
  • 6,105 posts
  • 35 thanks
Posted 04 July 2018 - 12:02 PM
I think the sensor is on the drivers side front. One on the rear as well but i can't remember which side.
#366 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 04 July 2018 - 12:12 PM
Just contacted the Rover specialist, he said £100 to fit everything so thats just over a couple of hundered including parts, not worth me sweating over such a job for a relatively small outlay to get someone else to do it.
MOT isnt until Sept so can leave it as is until just before then.
#367 OFFLINE   Mally
Mally
    Rank: Renault 16
  • Full Members
  • 2,399 posts
  • 34 thanks
Posted 04 July 2018 - 03:03 PM
MoT it first before you spend money on the bottom arm.
The possibilities for fail are endless.
Mine goes for MoT quite soon. I'm confident*.
  • oldcars likes this
#368 OFFLINE   oldcars
oldcars
  • Full Members
  • 6,105 posts
  • 35 thanks
Posted 04 July 2018 - 03:15 PM
Mine goes for MoT quite soon. I'm shitting myself.
FIFY
#369 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 04 July 2018 - 03:22 PM
Play is deffo in the 'excessive movement' banding I'd say. Imma get the guy to give it a pre mot inspection anyway although I cant see it needing much else tbh.
#370 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 08 July 2018 - 06:02 PM
I took this out for a test drive tonight and my previous efforts have made bugger all difference.
The wheel is still roasting hot after a few miles so its obviously still sticking on.
I am at the stage where I'm not pissed off with it anymore, I just can't be arsed with not being able to drive it half the time.
Think imma just get something else thats a bit more reliable!
#371 OFFLINE   Mally
Mally
    Rank: Renault 16
  • Full Members
  • 2,399 posts
  • 34 thanks
Posted 08 July 2018 - 07:05 PM
Are both front wheels hot?
Leave it a while, then jack up the offending wheel.
Will it spin freely?
If yes, press the brake hard with the engine running, release the pedal and try spinning the wheel.
Wheels do get hot. As long as the brakes don't bind or pull it may be normal.
Could well be the caliper sticking, can also be a restriction in the brake hose, but this seldom happens.
#372 OFFLINE   sierraman
sierraman
    Rank: Isuzu Florian
  • Full Members
  • 9,387 posts
  • 84 thanks
Posted 08 July 2018 - 07:10 PM
Like I said very rarely can you unstick a failing caliper with a strip down unless you are popping the piston out and overhauling it. You could try doing this but you might find getting the piston itself out difficult without an air line. An exchange caliper shouldn't be mega money.
  • Split_Pin and oldcars like this
#373 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 08 July 2018 - 07:11 PM
The other wheel is barely warm at all, as I would expect. Life is too short to be bitten on the arse by a car every other week, unless its something special like a DS!
#374 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 09 July 2018 - 06:42 AM
Drove to the station this morning and the osf wheel was barely warm. It was 16 degrees out and the caliper only appears to bind when the ambient temperature is above about 20 degrees.
#375 ONLINE   davehedgehog31
davehedgehog31
    Rank: BL Wedge
  • Full Members
  • 845 posts
  • 12 thanks
  • LocationThe Town for Tomorrow
Posted 09 July 2018 - 07:20 AM
I'd say it's not worth worrying about for the usual two days a year then!
  • Split_Pin likes this
Chods;
1994 Peugeot 405 GTX 1.9 XUD Turbo
2003 Suzuki Alto 1.1 GL
2007 Citroen C1 1.0i Vibe
#376 OFFLINE   oldcars
oldcars
  • Full Members
  • 6,105 posts
  • 35 thanks
Posted 09 July 2018 - 07:35 AM
Same happened with mine.
I'm the same, always spending money fixing it and not getting much use out of it.
#377 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 20 July 2018 - 05:56 AM
Nice to meet you Tam, hope you enjoy it and it serves you well over the next couple of months.
For all its faults, I bloody loved this car and I shall have another soon.
But for now, my automotive feet are itchy and there a few cars that I want to test drive :)
That's a wrap.
  • aldo135, stephen01, DVee8 and 2 others like this
#378 OFFLINE   Tam
Tam
    Rank: Austin Maxi
  • Full Members
  • 454 posts
  • 5 thanks
  • LocationKirrie Hills
Posted 20 July 2018 - 07:58 AM
Likewise on the meeting and even with it's little grumbles a 75 just relaxes you up the road.
Not really taking my time but economy was also good.
  • aldo135, stephen01, Tickman and 1 other like this
 64 P6 2000,   74 P6 3500s,   75 P6 3500,    92 R8 214 Si,    03 90 Def.,    03 75 CDT,
 04 25 TD Lagoon,    04 ZT 135+,     04 ZR 1O5+ Lagoon,    05 ZT 135+ Lagoon,    05 ZR 105   -   PICTURES
#379 OFFLINE   purplebargeken
purplebargeken
    Someone who is developing reduced levels of patience!
  • Full Members
  • 12,907 posts
  • 44 thanks
  • LocationSatan's Shitty Toilet
Posted 20 July 2018 - 08:01 AM
Christ, I can only dream of an mpg figure like that.
Hyundai i10 auto - white goods shite
Rover 75 1.8 auto - wafty kettle
Ford Galaxy - big red shite with added space
BMW 318i Touring with dealer optional indicators fitted! Gently sleeping!
Triumph Toledo - 2.0 for added sleeper shite
Triumph Dolomite 1850 auto - crusty shite
MG ZT Mean Green Machine
MGF 1.8 VVC BRG floppytop shite
#380 ONLINE   Split_Pin
Split_Pin
    Rank: Isuzu Florian
  • Full Members
  • 8,591 posts
  • 35 thanks
Posted 20 July 2018 - 08:05 AM
Looks right at home there!
