catsinthewelder Posted January 2, 2019 Share Posted January 2, 2019 Some vaguely ill informed Invacar discussion cropped up elsewhere, thought some of you would like a look. LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 2, 2019 Share Posted January 2, 2019 very interesting read thanks for sharing I wonder how long the rail distribution thing continued for? I wonder if anyone has a picture of a long line of invacars on rail? bonus points if there Model 70s (I see a model 67 in one of the pictures but nothing later) catsinthewelder 1 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 12, 2019 Author Share Posted January 12, 2019 Got TWC fired up (dying battery) and went for a drive. Sluggish as hell. Awful. Got back, rear wheels were warm... Turns out the handbrake mechanism has been sticking, possibly for quite a while. Oops. I went through it front to back and found various sticky points, including the main pivot. Freed everything off and she was rolling sweetly. Went for a test drive and wow! While she still doesn't like hills, she's a flying machine on the flat. 60mph is really quite easy. In fact, I hit 65mph before discovering that the brakes were shite! Turns out I'd adjusted them up with the handbrake binding in seems, so with that freed off, the rears were way out of adjustment. Single-wheel braking really not good... All sorted now. An Invacar transformed. Have some new pulleys on their way from a friendly source. No guarantee they'll fit or indeed work in this application, but my contact reckons it's worth a go. Won't have them until February, but I will report back. privatewire, timolloyd, GrumpiusMaximus and 11 others 14 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 12, 2019 Share Posted January 12, 2019 Got TWC fired up (dying battery) and went for a drive. Sluggish as hell. Awful. Got back, rear wheels were warm... Turns out the handbrake mechanism has been sticking, possibly for quite a while. Oops. I went through it front to back and found various sticky points, including the main pivot. Freed everything off and she was rolling sweetly. Went for a test drive and wow! While she still doesn't like hills, she's a flying machine on the flat. 60mph is really quite easy. In fact, I hit 65mph before discovering that the brakes were shite! Turns out I'd adjusted them up with the handbrake binding in seems, so with that freed off, the rears were way out of adjustment. Single-wheel braking really not good... All sorted now. An Invacar transformed. Have some new pulleys on their way from a friendly source. No guarantee they'll fit or indeed work in this application, but my contact reckons it's worth a go. Won't have them until February, but I will report back. ohh thats excellent news! (well not the sticking part but the transformed part) I do wonder how long the handbrakes been sticking for, hopefully its not worn out any of the components are we going to be treated to a new 0-60 run? or a top speed run? I wanna know if a Model 70 can actually hit 82Mph (might want to avoid 88Mph so you dont end up going back in time ) are the new pulleys supposed to be the same type as whats on TWC or are they of a different type? (if I read the Manual for the transmission properly theres 2 types ones "speed sensitive" and ones "torque sensitive", whatever that is supposed to mean...) Link to comment Share on other sites More sharing options...
dollywobbler Posted January 12, 2019 Author Share Posted January 12, 2019 The pulleys are from an entirely different application, but still for a Salsbury transmission I think. Top speed run limited here by geography! Not enough straight bits... LightBulbFun 1 Link to comment Share on other sites More sharing options...
Dick Longbridge Posted January 12, 2019 Share Posted January 12, 2019 The pulleys are from an entirely different application, but still for a Salsbury transmission I think. Top speed run limited here by geography! Not enough straight bits...You need to gaffer tape all the shut lines, spray some Teflon on the paintwork, and get it over to the salt flats. It’d be a first! Lacquer Peel, dollywobbler and Christine 3 Link to comment Share on other sites More sharing options...
PhilA Posted January 13, 2019 Share Posted January 13, 2019 That's good news on the brakes. That can seriously transform a vehicle, I know. The CVT may have spent a lot of its life at maximum and scored a ridge in the shaft, perhaps? Do the new pulleys have their own shafts or do they slide onto the existing equipment in the vehicle? Phil LightBulbFun 1 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 13, 2019 Author Share Posted January 13, 2019 Should slide onto the existing shafts. LightBulbFun 1 Link to comment Share on other sites More sharing options...
They_all_do_that_sir Posted January 13, 2019 Share Posted January 13, 2019 Is it worth asking a machine shop for a quote to turn up some new pulleys? Sent from my TA-1012 using Tapatalk LightBulbFun 1 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 13, 2019 Author Share Posted January 13, 2019 Have some pulley plans, just can't really say more until it happens. LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 14, 2019 Share Posted January 14, 2019 WARP DRIVE! this was a very fun video to watch you could of brought back beard cam and use your beard as a vibration dampening "device" how well does she cruse at 60Mph now? (thinking about the 60Mph thread here ) RayMK and mrbenn 2 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 14, 2019 Author Share Posted January 14, 2019 Hard to say as it's not exactly flat around here. Will try to take her for a longer run. She needs it. LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 14, 2019 Share Posted January 14, 2019 Hard to say as it's not exactly flat around here. Will try to take her for a longer run. She needs it. I was wondering if a higher speed run might help the engine run better I imagine when these engines where used in those "Fiat 500s" they where more often then not driven flat out like a 2CV is New POD 1 Link to comment Share on other sites More sharing options...
Broadsword Posted January 14, 2019 Share Posted January 14, 2019 My favourite part of the most recent video was the moment you reached warp speed. Due to the unique way your phone was rattling around in the car mount, it felt like the Autoshite equivalent of the Star Gate sequence in 2001: A Space Odyssey. Should have been accompanied by the caption: “My God, it’s full of chod!” LightBulbFun, Remspoor, GrumpiusMaximus and 2 others 5 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 15, 2019 Author Share Posted January 15, 2019 Had a run out to town today. I do love driving this thing when it works, and it really does feel totally at home around town. On the sweeping A roads with terrifying crosswinds, not so much! Still, she cruises much more happily at 50, and I'm actually off the throttle a lot more on downhill sections. Still not very happy going uphill - which gets scary when there's an Artic up your arse, but definitely better. Incredibly, having one window open about an inch means demisting is not an issue as long as you don't stop moving. LightBulbFun, mat_the_cat, jumpingjehovahs and 7 others 10 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 16, 2019 Share Posted January 16, 2019 im glad she feels at home driving around at home (as thats what my future model 70 will mainly be used for because I sadly live in London and all the stuff that encompasses ) BTW I was having another flick through the workshop manual and I noticed it explicitly states that the CVT transmission holds the engine at 3500 RPM which so happens to be the peak torque point for the Puch engine, which would lead me to believe Model 70s have the "torque sensitive" Pulley setup from Salsbury I dont know if this of any help at all but I feel like it was worth pointing out especially as it was previously thought that the transmission held the engine at 3000 RPM (which did not make much sense to me from a power/torque curve prospective) but hopefully it helps Link to comment Share on other sites More sharing options...
dollywobbler Posted January 17, 2019 Author Share Posted January 17, 2019 Thanks, but there's no high-tech approach to these pulleys. It relies on springing and free movement. I suspect my pulleys are lacking somewhat in the free movement regard, hence it isn't holding the engine at the right rev point. It'll be interesting to see if the new pulleys make a difference, and where the revs end up. LightBulbFun 1 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 19, 2019 Author Share Posted January 19, 2019 Just went for a bit of a hurtle, just because I can. Can confirm that hillclimbing performance is still utter shite. I was hoping it might improve. No. LightBulbFun, mrbenn, Skizzer and 3 others 6 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 19, 2019 Share Posted January 19, 2019 Just went for a bit of a hurtle, just because I can. Can confirm that hillclimbing performance is still utter shite. I was hoping it might improve. No. is that with the current pulley setup or the new stuff? nice photo tho Link to comment Share on other sites More sharing options...
dollywobbler Posted January 19, 2019 Author Share Posted January 19, 2019 Current. New stuff isn't going to be here before late February. LightBulbFun 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted January 20, 2019 Share Posted January 20, 2019 That's a lovely photo. Curious to see how the heater in mine performs in the real world - testing it in the garage it seems to kick out a decent amount of heat. Especially having attacked it with the vacuum cleaner and pulled half a bag of crud out of the ductwork. Hopefully it won't be too long now before I'll be able to make a trip over there with TP and we can get some photos of the pair of them together. Have to admit that I'm suffering a bit from countryside withdrawal at the moment so an excuse to disappear into rural Wales for a few days seems a great idea! LightBulbFun, RayMK and dollywobbler 3 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 20, 2019 Author Share Posted January 20, 2019 I should probably attack the heater with a vacuum for the same reason. A hell of a lot of crud came out when I first opened the under-seat port. On the way to the NEC... (I didn't see the mess until a colleague told me I could have cleaned the interior a bit!). LightBulbFun 1 Link to comment Share on other sites More sharing options...
dollywobbler Posted January 26, 2019 Author Share Posted January 26, 2019 I went for a drive. There's a weather warning for wind today. I should have heeded it. The drive was very exciting. It was made more exciting by the wiper refusing to turn off when instructed to do so, a trick learnt from the 2CV it seems. I shall have to separate them again. The only way to get the wiper to stop was to try and find the dead position on the switch that cuts power by accident, or turn the ignition off briefly when the wiper was in the normal park position. Trying to do that while battling crosswinds is an experience, I can tell you. In fact, I just have. egg, Skizzer, RayMK and 5 others 8 Link to comment Share on other sites More sharing options...
dozeydustman Posted January 26, 2019 Share Posted January 26, 2019 I had a similar wiper issue on my second scimitar, flexi rod that went up the tube to the spindles was full of dried up old grease which means it couldn't hit the motor's park switch when you switched them off, so they kept running. Took dad and I about half an hour to get the flexi rod out, cleaned, new lubrication and put back in, then had no issues with it until we took the car off the road. Could also be the park switch gummed up. Hopefully it's an external one and just needs a squirt of something. dollywobbler and LightBulbFun 2 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 28, 2019 Share Posted January 28, 2019 I think TWC took "intermittent windscreen wipers" a bit too literal also cool to see your planning to take TWC to the National microcar rally, I definitely will see if I can hustle my way down there (aka check and see if Zel is going and if i can hitch a lift although its a good 8 months away so who knows maybe ill be able to drive down by then ) Link to comment Share on other sites More sharing options...
dollywobbler Posted January 30, 2019 Author Share Posted January 30, 2019 Sometimes, you just need to do stupid things. You can just about encourage a drift, but with so much weight over the driven wheels and none over the steered one, she just tends to push on instead. Then she fills the engine bay with slush and starts misfiring, and you start wondering if this was such a good idea after all... GrumpiusMaximus, Joey spud, Saabnut and 15 others 18 Link to comment Share on other sites More sharing options...
oldcars Posted January 30, 2019 Share Posted January 30, 2019 Sometimes, you just need to do stupid things. You can just about encourage a drift, but with so much weight over the driven wheels and none over the steered one, she just tends to push on instead. Then she fills the engine bay with slush and starts misfiring, and you start wondering if this was such a good idea after all...Reliants are class in the snow, spending most of the time sideways. Shame these are not so fun in the snow. LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 30, 2019 Share Posted January 30, 2019 Sometimes, you just need to do stupid things. You can just about encourage a drift, but with so much weight over the driven wheels and none over the steered one, she just tends to push on instead. Then she fills the engine bay with slush and starts misfiring, and you start wondering if this was such a good idea after all... I imagine with all the weight over the rear wheels it does help with traction at least? (or did you still get manic wheel spin? ) Link to comment Share on other sites More sharing options...
dollywobbler Posted January 30, 2019 Author Share Posted January 30, 2019 Wheelspin was amazingly absent! LightBulbFun 1 Link to comment Share on other sites More sharing options...
LightBulbFun Posted January 31, 2019 Share Posted January 31, 2019 this was a very fun video to watch its a shame there was not an external camera setup when you did the drifting/doughnut in the car park, tho knowing me I would end up accidentally squishing the camera BTW what was that god awful crunch around 7:09? (sounded gearboxy, im guessing you cant take model 70 out of neutral while the engine is running?) mrbenn, Burnside and oldcars 3 Link to comment Share on other sites More sharing options...
