Welcome to Autoshite
Volkswagen Golf 1.6CL - offers - clutch fried, would it roffle for £1.25?
#31
OFFLINE
Posted 23 October 2017 - 12:57 PM
2007 Mini Cooper
1987 Vauxhall Astra Estate
#32
OFFLINE
Posted 23 October 2017 - 03:13 PM
I replaced the thermostat housing and thermostat when I got the car. have a check forleaks around the area (to the right of the valve cover and down a bit.
They are only plastic. May need a tighten or a new U clip thingy. I have the U clip if need be.
The coolant was there 'cos useful.
- DeeJay likes this
Hyundai i10 auto - white goods shite
Rover 75 1.8 auto - wafty kettle
Ford Galaxy - big red shite with added space
Triumph Toledo - 2.0 for added sleeper shite
Triumph Dolomite 1850 auto - crusty shite
#33
OFFLINE
Posted 23 October 2017 - 08:53 PM
Update, the coolant light started flashing on the way to work this morning, which apparently is a common occurrence on mk3 golfs. That might explain the bottles of coolant supplied with the car...
Yes they are very fussy and the moment the level drop 1mm too low it puts the warning light on. They aren't the easiest of cars to get air out of the cooling system either.
- purplebargeken likes this
What's the retail on one of those plumbed in fire extinguisher systems?
#34
OFFLINE
Posted 24 October 2017 - 05:54 PM
I'm sorry to report that I've found a 'mainstream' car that I like! What next? I'll be joining old skool Ford and criticising Xantias soon...
- mk2_craig and purplebargeken like this
2007 Mini Cooper
#35
OFFLINE
#36
OFFLINE
Posted 30 October 2017 - 06:30 PM
For some reason my abiding memory of the H-plate Granada Scorpio pool car my Dad often used to drive was that it had a torch key. No idea why.
Anyway, top work with the Golf. People have a downer on the Mk3 but I always thought they were alright.
#37
OFFLINE
Posted 30 October 2017 - 06:47 PM
Torch keys are COOL.
Aye I remember my old mans H plate Orion had a torch key, think most Fords at the time did, and he had an R plate mk3 Astra with one as well, think they died out with the introduction of remote central locking because you no longer needed a light to see the keyhole in the door in the dark.
Previous Car History:
97 R Vauxhall Astra 1.6 LS
02 51 Peugeot 206 1.4 LX
04 04 Renault Clio 1.2 Dynamique
98 S Hyundai Accent 1.3 Si Coupe
05 55 Vauxhall Corsa 1.4 SXi
02 52 Vauxhall Astra 1.6 Comfort
97 P Volkswagen Golf 1.4 SE
05 05 Vauxhall Astra 1.8 Design
09 59 Renault Clio 1.2 Dynamique
15 15 Vauxhall Corsa 1.4 SRi
09 09 Volkswagen Jetta 2.0 CR TDi Sport 140bhp (Current)
#38
OFFLINE
Posted 30 October 2017 - 08:42 PM
Key torches were the biz back in the day. Nice fixeration Sir!!
- Craig the Princess likes this
#39
OFFLINE
#40
OFFLINE
Posted 04 November 2017 - 03:08 PM
Cool!!!!!
#41
OFFLINE
Posted 25 November 2017 - 10:48 PM
140716 miles and it'd starting to die. Knocking is getting worse and it is now hunting at idle and won't drive at a steady speed without stumbling. It looks like this will be another short ownership for me...
2007 Mini Cooper
#42
OFFLINE
Posted 25 November 2017 - 10:54 PM
Hunting at idle will be a gummed up throttle body - give it a seeing to with carb cleaner and a toothbrush. The crankcase breather system in these engines was a bit crap tbh and grots the TB butterfly up really fast, especially in winter when it blows loads of mayo gunk through due to how its routed. If its a keeper (and its sounds like it isn't) then this is the one and only engine I've ever had which has responded well to STP Fuel System Cleaner - the £15 one. It made a hell of a difference to mine and became a once-a-year service item.
can't help with the knock though. turn the radio up?
#44
OFFLINE
Posted 25 November 2017 - 11:05 PM
Knocking?? Oh no
#45
OFFLINE
Posted 26 November 2017 - 12:30 PM
My 1.4 mk3 (same design) ran for about 50k with skeleton-wanking-biscuit tappets. It rotted away before I got bothered enough to replace.
1989 'G' VW Scirocco 1.6GTD - back on the road, fettling commences
2004 '53' Skoda Octavia 1.8T - daily
Current hankering: Subaru Forester
#46
OFFLINE
Posted 26 November 2017 - 02:14 PM
I've cleaned the throttle body and it drives much better now, but the weird idle/drive is worse.
On pulling up it revs between 1500 and 2000 rpm up and down until it settles at about 1100 rpm
While driving it wanders up and down randomly.
Is this a TPS fault?
2007 Mini Cooper
#47
OFFLINE
Posted 26 November 2017 - 02:16 PM
1974 MGB GT - A stereotypical classic car.
2007 Honda Civic EX CTDi - The reliable runner that is like the family pet.
2010 Aldi A4 - Owned to placate the wife on my crap buying
My history: 2003 Clio II 1.2 16v (First car), 2003 Honda Civic 3dr 1.7 CTDi (Isuzu lump), 1992 Mazda MX5 1.6, 2005 Mazda RX8 192bhp, 2005 Saab 9-3 1.9TiD 150bhp, 2007 Honda Civic 2.2 CTDi, 2004 Renault Scenic 1.6 Auto (Now Kiltox FiL), 2004 Saab 9-5 2.3t (Now Hooli), 2004 Smart Roadster 80bhp
Wife history (that she used/owned but I had frequent use of): 2002 Renault Clio II 1.2 16v (Billabong!), 2006 Mazda MX5 1.8, 2004 VW Golf 1.6 FSI, 2005 Renault Scenic II 2.0 (went bad from the drive back when buying it!), 2002 Vauxhall Astra 1.6 16v (now phil_lihp ex-colleague), 2005 Renault Laguna II v6 (Now angle)
#49
OFFLINE
Posted 26 November 2017 - 06:29 PM
Spoke too soon.
It's back to playing up again
2007 Mini Cooper
#50
OFFLINE
Posted 26 November 2017 - 06:45 PM
Chuck a post on the fb Mk 3 forum, they seem to know their stuff.
Has to be a sensor of some kind, especially as the clean up cured it for a while.
#51
OFFLINE
Posted 26 November 2017 - 06:49 PM
- purplebargeken and oldcars like this
1997 - 406 2.1 TD estate
1991 - Eunos Track beast
2003 - Getz
#52
OFFLINE
Posted 26 November 2017 - 06:54 PM
Hold on.Asking a knowledgeable mk 3 person.
Check for air leaks on all the vacuum pipes around the carb. There is a pipe from manifold to the servo and it has 2 caps on it that do nothing. They fall off and it will tick over like a bag of shit
#53
OFFLINE
Posted 26 November 2017 - 07:34 PM
Anyway, the clutch has just failed spectacularly leaving me stranded. Awaiting recovery now.
I love old cars....
2007 Mini Cooper
#54
OFFLINE
Posted 26 November 2017 - 07:35 PM
- oldcars likes this
2007 Mini Cooper
#55
OFFLINE
Posted 26 November 2017 - 07:36 PM
Carb? Not very knowledgeable.Hold on.Asking a knowledgeable mk 3 person.
- purplebargeken and Sigmund Fraud like this
#56
OFFLINE
Posted 26 November 2017 - 07:40 PM
I love old cars....
You really don't have any luck with cars recently.
#57
OFFLINE
Posted 27 November 2017 - 12:29 AM
TBF I open most bonnets and expect to see carbs. It's always disappointing when there aren't any.
I suspect that if we substitute the words injection gubbins for the word carb it will all be okay. Maybe.
- Lacquer Peel likes this
#58
OFFLINE
Posted 27 November 2017 - 01:37 PM
Any news? Bites finger nails. Misses. Gnaws thumb off instead.
Pleasedon'tscrapitPleasedon'tscrapitPleasedon'tscrapitPleasedon'tscrapitPleasedon'tscrapitPleasedon'tscrapitPleasedon'tscrapit
Further internetting declares the following:
Idle Control Valve
Throttle Body clean and replacing the gasket
There is also mention of using such witchcraft as vagcom......
The above doesn't really address the glaring clutch issue obv.
Chodspeed on getting her fixed!!
#59
OFFLINE
Posted 27 November 2017 - 02:20 PM
Given the worsening knocking noise followed by apparent sudden clutch failure I wonder if the two might be related. Maybe driveshaft/cv joint failure rather than clutch itself?
Doesn't explain the poor running though!
#60
OFFLINE
Posted 27 November 2017 - 06:40 PM
And nobody dare suggest negotiating with my ex, she's not that kind of person, and we've only just had the court crap sorted.
2007 Mini Cooper
Also tagged with one or more of these keywords: For Sale
For Sale
Autoshite →
AutoShite →
Possibly for sale. Citroen xantia 2 litre petrol auto sinkerStarted by dean36014 , Today, 02:19 AM ![]() |
For Sale
Autoshite →
AutoShite →
Daewoo Lanos SX 1.6 - W-reg - £200, offers welcomeStarted by dollywobbler , Yesterday, 06:18 PM ![]() |
For Sale
Autoshite →
AutoShite →
1957 Morris Minor For SaleStarted by Tickman , 23 Apr 2018 ![]() |
For Sale
Autoshite →
AutoShite →
2005 Audi A4 Avant £650 ovnoStarted by ruffgeezer , 23 Apr 2018 ![]() |
For Sale
Autoshite →
AutoShite →
Buy a brand new* car for £500 - Perodua Myvi for saleStarted by wuvvum , 23 Apr 2018 ![]() |
