SiC Posted July 30, 2017 Share Posted July 30, 2017 When buying my MGB GT, the condition I had with my wife is that I sold my Smart Roadster. I bought this around February this year as a project car to fix and have fun for a bit. The previous owner bought it in 2009 and used it right upto around 2014. He then had kids and so it sat on his drive. In 2016 he then re-MOT'd it and got it back on the road. In early 2017, it started having gear fault issues. He took it into his local Mercedes garage who "diagnosed" it as a SAM issue (body computer). This costing a lot and not being very practical for his needs, he stuck it on eBay. I won it and picked it up. The gear fault issue turned out to be a chaffed wire going to a gearbox control motor. I re-soldered this damaged wire and rerouted the cables away from where they were getting chaffed. I inspected the SAM (body computer) as these are prone to getting wet and fritzing out. It was perfectly fine with absolutely no water damage at all. I sealed up the tub above it that can leak to prevent it getting damaged. I've had a fair amount of use out of it, but only really used it when the weather was nice and worth taking out. So I've done about 1.5k in the 6 months or so I've owned it. Features:Absolutely great fun to drive. A clique but it is literally like a go-kart. You sit close to the ground, whole heap of turbo boost and a flappy paddle gearbox. Corners like shit on a stick.Only 80BHP, but only 800kg. So shifts pretty respectably. Not stupidly fast, but when in gear and boosting, it can build speed up pretty darn well.Rear engined, rear wheel drive.So much drama. You get chirps from the turbo when changing gear and a nice raspy sound from that 3 cylinder engine.Traction control for when you're pushing things a bit too hard.Has the flappy paddles on the steering wheel. These came included as an option with those 3 spoke alloys (which I really love too).Boost and temperature gauge pods. Again this was a cost option from the factory.A whole heap of previous service history. A lot of it Mercedes/Smart and a lot of Smart specialist.Body work in excellent condition.Working retracting electric roof. You can open and close this at any speed. You can remove the side beams in seconds and put them in the front bonnet storage to go completely pillar-less.Since owning it, I've:Had 4 new tyres put on - Goodyear F1. I felt no point scrimping on this as crap handling tyres would spoil the car.Had replaced the 3 engine mounts - including the awkward front mount.Had the ABS reluctor rings replaced - these rust up over time and cause the ABS to kick in at low speeds.Replaced the Thermostat. Previously it was a bit "lazy" and sit between 80C-90C. It now sits bang 90C when warmed up. Crawling in traffic it creeps to 100C, fans kick in, thermostat opens full and temp drops down to 90C, as designed.Sealed the wiper scuttle tub above the SAM unit (body computer) with generous quantities of Tigerseal. This is where most of the bad reputation for dodgy electrics come from. The tub has a drain at the bottom which can get clogged with leaves + dirt. This causes the tub to overfill and leak out of the crappy foam seal at the top. As the body computer is underneath, it gets a soaking and goes a bit crazy. This computer controls the lights/wipers/windows/locking/etc and is around £750 odd to replace.Replaced all 6 spark plugs (2 per cylinder), including the tricky to get to bottom ones and the spark plug leads too.Greased up the window rails, so both windows open perfectly.Greased up the hood rails, so the hood retracts fine.Recalibrated the clutch actuator. This usually gets done by a specialist or main dealer when serviced. As these get out of the dealer network and serviced by the average garage, they're not fully aware this needs doing. Unfortantly as the clutch wears, the ECU doesn't auto re-calibrate itself. So unless you re-calibrate it occasionally, you get kangarooing stop/start in traffic and jerky gear changes. With a Delphi DS150e diagnostics tool, it takes about a minute for it to do it and it'll be good for a good while. It now changes smoothly and quickly - I reckon quicker than I can if I was driving a manual gearbox.Aircon regas. This doesn't have the usual split pipes that they all seem to have. The system still had 200g of gas in (takes 650g) and so was keeping pressure just fine. Unfortantly, just recently it seems to be surging between 1k and 1.5k rpm, so I suspect the compressor on it maybe on its way out. Probably didn't appreciate not being run for a few years. As there is a roof that comes open, I never really ended up using it anyway. It might also be the belt that is worn too.Replaced the worn out door speakers and reset the radio code. No radio code was supplied, so I read out the code from the EEPROM, entered it and then disabled it completely. So when you disconnect the battery, it'll not ask for a code and just work when the battery is reconnected.Programmed an additional key. So 2 working keys. This is important as apparently they can occasionally forget a key. Especially if you keep pressing the buttons when out of range. The new key doesn't work that well in the ignition lock one way (fine if you flip it the other way), as the shop that cut it for me I don't think did a great job. However its a great spare key.Replaced the connector for the interior fan. A common fault, caused by the connector getting dirty, overheating and then failing. It now works just fine on all the fan speeds.Things that aren't perfect:When driving in a straight line, the wheel isn't dead straight - around the 1 o'clock position. Originally it was around the 10 o'clock position, so I had the tracking done at a local garage but the oafe of a mechanic ("I hate this car, too small for me to get in and out") I don't think got the wheel dead straight. The first time he did it was around the 2 o'clock position, so I went straight back and he redid it. Closer now but it still annoys the hell out of me. A better garage I'm sure can easily sort this. Doesn't pull to one side, just not centred correctly.Aux belt squeals at startup when cold. Pretty sure it either needs just retensioning (no auto tensioner on this belt) or just replacing. It only happens for the first 60 seconds or so and then is fine for the rest of the day. Something I keep meaning to do, but only remember when I startup from cold.Rust on one of the removable pillars/beams. You can get replacement ones for around £90 off eBay, or possibly have these resprayed. Doesn't affect the strength or structure of the car at all.As mentioned above, the aircon seems to be not playing ball. But extremely rare to have working aircon on these anyway. Plus you have that roof you can open. Could be the compressor, could be the aux belt.The aux belt for this is different to the other one.The front struts look a bit rusty and tired. If I was keeping it longer, I'd probably replace them. Still handles great, so much be in reasonable shape though. Springs and shocks are about £60 for each side from Euro Car Parts - so not terribly expensive.Missing the arm rest above the handbrake. I have yet to see a Roadster where this hasn't been broken off. Unfortantly the previous owner had lost the actual arm rest. The part is no-longer available either. You can get non-arm rest handbrakes from eBay for not a lot (~£30) and are not hard to fit. However my elbow handily fits in the gap in the middle anyway, so I left it as is.Apart from the above, its fine. Drives great, in good nick and runs just fine. The above is mostly stuff that I'm fussy/OCD about and I wouldn't like to not let people know. Probably wouldn't bother most other normal people. The thread of it is: http://autoshite.com/topic/26414-smart-roadster-the-poo-brown-go-kartExcellent site full of great article: http://www.evilution.co.uk - requires a £10 yearly subscription to unlock them all, but worth it. The guy has replied to a couple of my emails for advice too before I've started jobs. Far better than most Haynes manuals Price wise, I was trying to figure out what to put it up as. Looking at Autotrader, Gumtree and eBay, it seemed that its realistically worth around £1.5-1.7k on these. This is what I'll put it up for on those sites in a couple of days. I've promised the wife that I'll sell it, but its still got insurance and tax until October, I have just about got drive space and so I'm not in a massive rush to sell (for a change!). So with a bit of usual AS discount (because here is so much less hassle to sell), I've put it up as asking for £1550 ono - but AS discount available. I think that is reasonably priced for what it is? Not bargain basement, but then its not fucked or have a whole heap of major issues like a lot are around this price point. If you think its a bit high, feel free to make a counter offer. I'm fairly flexible. I'm in North Bristol (about 5 minutes from M4 J19) and can happily pick up from either Bristol Temple Meads, Bristol Parkway train stations or Bristol bus station. Some pictures: Boot:Under the carpet and metal cover is the engine - all 700cc and 80bhp of it:Front storage is actually surprisingly large and useful: Interior:Those boost gauges: Paddle steering wheel:No warning lights!Electric adjustable mirrors - bit of a pointless option as its so small, you can easily lean across to the passenger side anyway: (Chavy keyring was given as a present, so compelled to use it...) Pillar less: That rust on the removable pillar I was talking about earlier: Heaps of paperwork provided by the previous owner. Also included 3 different articles and reviews of it around the time it came out. Plus the original sales brochure too: Ghosty, RichardK, mrbenn and 14 others 17 Link to comment Share on other sites More sharing options...
djimbob Posted July 30, 2017 Share Posted July 30, 2017 looks cracking, always fancied one of these, shame I'm skint etc and other excuses, think you're selling the wrong sports car, but hey, a new challenge and you'll learn some lessons along the way with the MG to go along with the top work on the Smart You is winning in life and shite for sure SiC 1 Link to comment Share on other sites More sharing options...
stripped fred Posted July 30, 2017 Share Posted July 30, 2017 Excellent write up, excellent photos. Very nice looking car. If I didn't already own an mr2 I would be very interested in that. GLWTS. SiC 1 Link to comment Share on other sites More sharing options...
Inspector Morose Posted July 30, 2017 Share Posted July 30, 2017 Damn. chaseracer and pilninggas 2 Link to comment Share on other sites More sharing options...
Insideimsmiling Posted July 31, 2017 Share Posted July 31, 2017 My Herat says yes but my wallet says no! Link to comment Share on other sites More sharing options...
Insideimsmiling Posted July 31, 2017 Share Posted July 31, 2017 My Heart says yes, but my wallet says no! My brains says damn you fingers work. chaseracer 1 Link to comment Share on other sites More sharing options...
Fabergé Greggs Posted July 31, 2017 Share Posted July 31, 2017 Apologies if you've mentioned this, but could you confirm the CO2 figure for tax? Link to comment Share on other sites More sharing options...
SiC Posted July 31, 2017 Author Share Posted July 31, 2017 Just hits the £115 band at 121g/km. Always wondered why Smart/Daimler didn't spend a bit more R&D effort for the UK and get it down 1g/km, so it was in the cheaper band. Link to comment Share on other sites More sharing options...
cort16 Posted July 31, 2017 Share Posted July 31, 2017 This is a great price I'd really love one of these one day. <unhelpfullcommer>I've just spuffed by shite slush fund and your friggin miles away. </unhelpfulcomment> Link to comment Share on other sites More sharing options...
Tamworthbay Posted July 31, 2017 Share Posted July 31, 2017 Lovely car, just out of my price range at the moment Link to comment Share on other sites More sharing options...
Guest Hooli Posted July 31, 2017 Share Posted July 31, 2017 It's like a car but smaller! Can't you keep it in the boot of the BGT as a 'lifeboat'? Slartibartfast 1 Link to comment Share on other sites More sharing options...
holbeck Posted July 31, 2017 Share Posted July 31, 2017 Just out of interest, how tall a person could this car accommodate? Link to comment Share on other sites More sharing options...
Dirk Diggler Posted July 31, 2017 Share Posted July 31, 2017 That is cheap; they're making 3k here with no effort; GLWS SiC 1 Link to comment Share on other sites More sharing options...
SiC Posted July 31, 2017 Author Share Posted July 31, 2017 Just out of interest, how tall a person could this car accommodate?Smart at the time reckoned around 1.9m (6ft 3in) and 100kg. But as all people are different shapes it can vary a lot. Some on forums report that they're 6ft5 and fit, etc. I'm 5ft 10in and fit perfectly with loads of room. holbeck 1 Link to comment Share on other sites More sharing options...
anonymous user Posted July 31, 2017 Share Posted July 31, 2017 Just out of interest, how tall a person could this car accommodate?I'm about 6'2" not that small and with a dodgy right knee. It was a bit of a bugger to get in, I always likened it to trying to get in the bottom drawer of a filing cabinet. Once in it was great fun to drive until it was time to get out, where unless I could open the door fully there was no point trying. holbeck and SiC 2 Link to comment Share on other sites More sharing options...
SiC Posted July 31, 2017 Author Share Posted July 31, 2017 Yeah, getting in and out isn't straight forward compared to your average car. But then you're really low to the ground and stretched out. Handily they put enormous doors in, so you can kinda swivel around. It does to me make it feel like you're wearing the car though, rather than sitting on it. I reckon the rust spot on the removable pillar is possibly caused by hands grabbing there to extract themselves out. Link to comment Share on other sites More sharing options...
Vince70 Posted July 31, 2017 Share Posted July 31, 2017 I really wish I had the space for another car that really is a nice sorted roadster at an absolute bargain price.It won't hang about for long that's for sure. Link to comment Share on other sites More sharing options...
chaseracer Posted July 31, 2017 Share Posted July 31, 2017 Damn. Link to comment Share on other sites More sharing options...
Guest Lord Sward Posted July 31, 2017 Share Posted July 31, 2017 I love those SMARTs. Link to comment Share on other sites More sharing options...
carlo Posted August 1, 2017 Share Posted August 1, 2017 What a lovely ad and description of your car. You are obviously in the 0.5% of the population who cares about these things, and your responsibility to the eventual buyer. Bravo. SiC and egg 2 Link to comment Share on other sites More sharing options...
SiC Posted August 1, 2017 Author Share Posted August 1, 2017 think you're selling the wrong sports carI had a day off today and my best mate came down. We went out in it today for a blast around A-roads and both I thought and he said I'll miss it. It's also pretty effective for scaring your passengers shitless on the twisty bits! It grips and handles far better than I'm prepared to push it. Not even anywhere near to getting the traction control light flashing. I can see why some call it the poor man's Lotus Elise. Except, unlike an Elise, it has driver aids so you can push hard and know you have the computers in case you run out of ability. Definitely going to miss it. I wish I could have both on my driveway. Link to comment Share on other sites More sharing options...
RichardK Posted August 2, 2017 Share Posted August 2, 2017 In a sane world, I'd have this instead of one of my SLKs. They are awesome fun. Link to comment Share on other sites More sharing options...
djoptix Posted August 5, 2017 Share Posted August 5, 2017 Ohmigosh that would be so much fun. And by the looks of things you live very very near me... If only I had three less children. Link to comment Share on other sites More sharing options...
SiC Posted August 9, 2017 Author Share Posted August 9, 2017 A week bump. Now on eBay too and had some interest. We'll see which ones actually are not time wasting... Link to comment Share on other sites More sharing options...
Mally Posted August 9, 2017 Share Posted August 9, 2017 If you accept an offer do not remove the ad until cash is in your hand. It causes no end of problems when the 'buyer' fails to show. anonymous user 1 Link to comment Share on other sites More sharing options...
RichardK Posted August 10, 2017 Share Posted August 10, 2017 And now I've got the possibility of a 90-mile-a-day commute, one of these would be perfect, but not until I know it's happening. *sigh* Link to comment Share on other sites More sharing options...
SiC Posted August 10, 2017 Author Share Posted August 10, 2017 Since listing it on Saturday, so far I've had 17 messages, and a number of offers. Up for £1550, as that's roughly its real value. Best so far is £1500, but thats wanted to be delivered to Crawley (nah ain't happening). The other two are at £1350, one in Sussex and other person in Cornwall. The guy in Cornwall looks like he strips bikes for parts as a business - which would make me sad if it happened to this, but then cash is king. As they haven't viewed it, I've let both them know that the aircon isn't very effective and the belt squeals at start-up. Something I'd usually say before someone coming to see it. Oh and I've got 2 people wanting to view it this weekend - but both appear to be travelling quite far. Far more interest than I actually expected and its been hard-work trying to reply to all the questions and queries. However I'd rather have someone just come and view it, then buy the old-fashioned way! Might list it on Autotrader, as hopefully I'll get a bit more traditional type of response. Had mixed success with them though... I would say that I'd rather wish someone would buy it off here, as it is so much less hassle! egg 1 Link to comment Share on other sites More sharing options...
SiC Posted August 13, 2017 Author Share Posted August 13, 2017 Sold! To a very nice couple who used a Lotus Elise as a daily driver. Kiltox, holbeck, chaseracer and 6 others 9 Link to comment Share on other sites More sharing options...
