pandamonium Posted May 11, 2017 Share Posted May 11, 2017 Any interest in this?Located in Essex Link to comment Share on other sites More sharing options...
Split_Pin Posted May 11, 2017 Share Posted May 11, 2017 I'm currently finding out if I can use the engine and loom with my 1.0 gearbox. I shall report back. Cavcraft 1 Link to comment Share on other sites More sharing options...
Split_Pin Posted May 11, 2017 Share Posted May 11, 2017 Nae response from the Corsa pages regarding a sensible technical question. Does anyone else know the answer here? Link to comment Share on other sites More sharing options...
bub2006 Posted May 11, 2017 Share Posted May 11, 2017 1.0 I'm pretty sure is a f13 box. Same as a 1.4 manual. Link to comment Share on other sites More sharing options...
320touring Posted May 11, 2017 Share Posted May 11, 2017 Iain, if as bub says, the gearbox is the same, the loom shouldn't be much problem. Likely its only the ecu/clocks and engine bay side loom that is different. They'll likely connect into the main car loom under the dash. Should be able to either unplug and swap, or splice it in as needed. Link to comment Share on other sites More sharing options...
Split_Pin Posted May 11, 2017 Share Posted May 11, 2017 Cheers chaps, doesn't sound beyond the ken of my tame mechanic(s) Link to comment Share on other sites More sharing options...
outlaw118 Posted May 11, 2017 Share Posted May 11, 2017 Will be epic colekshun fred.... Link to comment Share on other sites More sharing options...
Split_Pin Posted May 11, 2017 Share Posted May 11, 2017 Yes I was thinking that. We Scots have a habit of travelling to London for old Vauxhalls though! The Moog, Cavcraft and outlaw118 3 Link to comment Share on other sites More sharing options...
bub2006 Posted May 11, 2017 Share Posted May 11, 2017 From what I recall the 1.6 had either f13 or f15, bigger had f18 and anything with cr in code was a close ratio. Link to comment Share on other sites More sharing options...
pandamonium Posted May 12, 2017 Author Share Posted May 12, 2017 It's my uncle's car by the way, this needs to sell as he is buying the Nippa Link to comment Share on other sites More sharing options...
Split_Pin Posted May 12, 2017 Share Posted May 12, 2017 PM'd you mate. Cavcraft 1 Link to comment Share on other sites More sharing options...
sierraman Posted May 12, 2017 Share Posted May 12, 2017 Nae response from the Corsa pages regarding a sensible technical question. Does anyone else know the answer here?You often find there's quite a few differences between the engine fitted to Autos and Manual. The radiator often incorporates an ATF cooler, the flywheel might be different etc. On the other hand it will have had an easier life. Link to comment Share on other sites More sharing options...
Split_Pin Posted May 12, 2017 Share Posted May 12, 2017 That's ok I have everything else to make it a manual in my existing car. Link to comment Share on other sites More sharing options...
lisbon_road Posted May 12, 2017 Share Posted May 12, 2017 Probably crankshaft different for flywheel fitment too? Remember also that the auto Corsas got the single point injection engine, unlike auto Astras which were multipoint or twin cam. The SPi engine is adequate in a Corsa mind. Link to comment Share on other sites More sharing options...
pandamonium Posted May 15, 2017 Author Share Posted May 15, 2017 Anyone? Link to comment Share on other sites More sharing options...
pandamonium Posted May 18, 2017 Author Share Posted May 18, 2017 Price reduced before I throw it to the eBay wolves. It needs a thermostat and temp sensor, less than 30 quid all in. I'll entertain swaps or trades. .. Link to comment Share on other sites More sharing options...
gadgetgricey Posted June 2, 2017 Share Posted June 2, 2017 Got a Rover 75 diesel auto that needs work , if that would wet your whistle,MOT to the end of July. PM me if interested and I'll send you details (good and bad) Cheers Dave Link to comment Share on other sites More sharing options...
