Welcome to Autoshite
Guest Message by DevFuse
Project
Range Rover resto - 1972 project updates p17
Project
  • Please log in to reply
489 replies to this topic
#481 OFFLINE   richardthestag
richardthestag
    Rank: Renault 16
  • Full Members
  • 3,226 posts
  • 28 thanks
  • LocationBuckinghamshite and Devonshite
  • Country : Country Flag
Posted 13 January 2019 - 04:30 PM
Interestingly (or not!) the high volume pump I installed on my original early cover had slightly taller gears than the OE later setup. Only by a mm or so, so unlikely to make much of a difference but enough to stop me fitting them to the later cover when I changed that!
Bt of a tangent but as AS's resident Rover V8 expert, do you know of a UK source of (cheap!) alternative rocker covers apart from the usual Rover types? Not so much to 'dress up' the engine, more to dress it down. I was thinking of fitting a pair of Buick steel covers, mainly just to fox anyone looking under the bonnet!
https://www.ebay.com...rs/192724265476
P76 would do the trick as well but reckon I'd be lucky to find anything over here.
I found exactly the same, high"er" volume pump gears are nearly 2mm taller than the big gears.
just means that if you need to replace the gears you need to buy a whole new kit at £90 + vat rather than the big gears for a standard post 76 cover which are nearer £30.
Car now has a post 76 cover on it which matches the engine number to save that confusion. I notice that Famous Four are supplying the smoll oil pump gears, might just try a set of those and do away with the adapter plate on the early engine cover.
Sorry but I have no idea on alternate rocker covers. I am looking for a set of covers for an early 70s engine so at least it looks the part, round corners and filler 2" or so back from the corner. everything on ebay has been powder coated which I do not want.
Also on the search for any engines number starting 355.
Shitroen C4 GP 2007 1.6HDi - Wife's daily written off, farewell trusty but slightly unpredictable steed
Hyundai i10 2010 newbee - Wife's daily
Pug 307 - son's daily runner Sold to Arthur Foxhake
Range Rover Vogue 1993 - my daily runner
Daewoo Matiz 2002 - Sold
Jaguar x308 Sovereign 4 litre - sold to Hooli
Triumph Staaag 1973 - cheaper than a mistress.. just
Range Rover 1972 - ongoing extensive restoration
Range Rover 1972 - complete shed but in line for restoration
Land Rover 1969 SIIa SWB - belongs to Fathathestag but maintained and welded by me
BMW E46 318i touring - sold to hhhugues
VW Polo 2002 1.2l 3 pot bargain for #2 son
Renna Clio Expression+ 16v Barg for #3 son
#482 OFFLINE   mat_the_cat
mat_the_cat
    Rank: Renault 16
  • Full Members
  • 3,940 posts
  • 13 thanks
  • LocationRiding the trough of the fashion wave
Posted 14 January 2019 - 08:30 PM
No worries, if I ever find some alternatives I will have a set of the early ones surplus to requirements. They seem to confuse some people looking at it anyway "Doesn't look quite like a Rover V8 to me" I have heard!
#483 OFFLINE   richardthestag
richardthestag
    Rank: Renault 16
  • Full Members
  • 3,226 posts
  • 28 thanks
Posted Yesterday, 01:20 PM
First up I put together another sweary summary of work done so far for them that is interested
In other news; I finally bit the bullet and got on with the doors.
Passenger door that I picked up in the spares deal is a real beauty
It is an early door, glass was etched with an L plate reg from a car deceased in the early noughties.
Hinge edge is very good
lock edge is even better
spent a happy hour removing everything from the door ready for prep and paint
both hinges had play in them, new are affordable new and the machine screws are always* a complete bastard to remove. So I got busy with the cutting disc.
half an hour later both hinges and captive plates are free. hinges are scrap, plates and shims will be salvaged
this kind of stress crack in the outer skin on the bottom hinge is quite common from my experience, no idea why except maybe pressure from the door seal on the outer skin.
weld and flat (not yet finished) and this door is done for now
  • John F, Hooli, LightBulbFun and 1 other like this
#484 OFFLINE   richardthestag
richardthestag
    Rank: Renault 16
  • Full Members
  • 3,226 posts
  • 28 thanks
Posted Yesterday, 02:25 PM
drivers door next, for some reason drivers doors in good shape are unobtainium.
The original from the project car was properly fucked and also suffered accident damage that had affected skin and shell.
Although I have another 5 drivers doors on the project cars I am reluctant to remove any of those but do have a spare which came in the recently acquired spares stash.
The glass frame was already out of it, so easy to manoeuvre around.
Hinge edge is not pretty but the best I have seen for a while. this area is double skinned. A thin outer skin which is part of the whole single pressing door shell. and a heavy duty angled piece that fits inside the door to give it more strength.
door bottom responded positively to my smoll tapping hammer
lock edge however is in a similar state to the hinge edge. None of the rusty mess seems to go right through both layers of steel
the door skin is ruined by a couple of nasty dents and an extra hole drilled through next to the lock hole. The return edge all around the inside of the door was also very crusty. These door skins are made from birmabrite (alloy) and are a nightmare to work. generally melt rather than do anything useful.
so no heart was lost in peeling back the edges of the outer skin to reveal the innards.
No surprise to see the extent of surface rust inside. where I could find paint it appeared to be primer. it will be bead blasted back to bare clean steel before the skin goes back on again.
On the hinge edge I drilled the plethora of spot welds to remove the rusted outer skin
to reveal an unpainted inner section. moisture can easily get in here and the results of that can be seen here
5 mins with a cup knot wheel and mr grinder had it looking quite solid. rust was treated with FE123 rust converter from Rust.co.uk. had good results with this product. then coated it with a weld through zinc primer. I will coat the inside of the door with vactan when finished
looking at the bit I removed from the above door and fishing around the spares reminded me of the rusty and accident damaged door shell that came from the project car. this bit don't look too bad!
So I cut it off, cleaned up the inside, rust treated and primed it with the same zinc
then butt welded it into place. Happy days. skim of filler and this will be as good as new.
Hinge edge will be done next week when I get back down to Devon, will use a similar approach to revove the outer skin section. Repair that on the bench and then butt weld it back into the door shell.
  • Hooli and LightBulbFun like this
#485 OFFLINE   richardthestag
richardthestag
    Rank: Renault 16
  • Full Members
  • 3,226 posts
  • 28 thanks
Posted Yesterday, 02:55 PM
the door glass frame is up next.
5 or so fixings hold the whole frame into the door shell. Glass comes out at the same time, this frame had rotted badly around the bottom corner of the quarterlight
these quarter light rubbers are unique to the first 2 years of production and are currently unavailable. I need to repair this one and fill that hole. any tips will be gratefully received
the channel at the bottom of the quarterlight hole often rots out, as does the channel which holds the rubber on the left vertical trailing edge in this piccy. this one will respond well and may well end up being powder coated
drivers side bits sorted for stage 2
passenger side bits also found. this one is from a later car (anoraks will note the different quarter light rubber)
I also found that a single profile of steel channel is used throughout the construction of these frames. it is also exactly the same in shape and curvature as a 4 door glass frame which could be used to cut and shut good sections in where there is rust.
The only bit that might be a challenge is the channel that welds onto the quarter light side of the upright nearest the hinge edge of the frame. looks like it might be a right bastard to shape. I have a section of it which is going to the metal benders to see if they can replicate it.
Other bits done while I was in Devon.
A stroll up the field to admire centre of operations and Exmoor
sorted a selection of panels to go to the body shop this week for prep and paint. I have a pair of rear wings, one passenger door and front wing. looks like I will need to dig deep for a new lower tailgate and drivers front wing... ouch
this rear wing came apart easily and on the whole I think is salvageable.
Back at home work carried on
These 4 are the captive plates for the door hinges. they are all the same regardless of location. I have not been able to find a source for them new, though I have yet to be brave enough to ask LR dealer parts counter
cut the excess bolt from both sides of the plate. then drilled centre of each bolt
this stuff is great for maintaining lubrication of the drill bit, aiding the cut and also extending the life of the drill bits. #recommended
The trick is to drill larger and larger holes until the remains simply wind out under the pressure of the drill bit. Because I am going right through the piece I can use standard HSS bits and forward clockwise drill motion.
All but three out of twelve bolts shifted like that ^^. the others I took out as close as I dare and then worked at the remains with a centre punch and hammer until I could run a tap through. Easyout stuff was utterly useless because of the level of corrosion between thread and bolt.
I generally use Bosch or DeWalt hss drills, these on the other hand were utter shit. dulled after one drilling, even with the bestobel compound. #Shit
after a working over in the blast cabinet all are now ready for paint and reuse
  • mat_the_cat, timolloyd, Hooli and 3 others like this
#486 ONLINE   Hooli
Hooli
    Rank Outsider
  • Full Members
  • 15,231 posts
  • 188 thanks
  • LocationThe next petrol station
Posted Yesterday, 05:40 PM
Impressive work there.
As for the holy rubber, ask a cobbler. I've had the soft rubbery bits on bike boots fixed with a mix of glue and the rubber dust* from grinding replacement soles to shape.
Opinions expressed are those of this cunt, not any other cunt. They do not represent the views of those responsible for this forum.
Like any true Englishman I'm never unintentionally rude. If you're offended by this post, good as that is what was my intention.
Champion cunt in the cunt count 2018.
#487 ONLINE   artdjones
artdjones
    Rank: Citroen Ami
  • Full Members
  • 1,081 posts
  • 17 thanks
  • LocationCork
Posted Yesterday, 07:39 PM
Google Devcon for rubber repair compounds.I think Flexane is the trade name.
#488 OFFLINE   SiC
SiC
    Rank: Talbot Matra Rancho
  • Full Members
  • 10,016 posts
  • 98 thanks
  • LocationBristol
Posted Yesterday, 07:50 PM
I'm just catching up on this thread (currently at the start of November). However I noticed this:
Same bottle I was using. I've now upgraded to that BOC deal for £60 p/a rent and £40 refill. The bottle works out 5x more gas than those hobbywelds. I'm still on the same refill despite doing a lot of welding recently.
I guess it depends how much welding you are doing on if it's worth it due to the yearly rent. However you can return it earlier and get it prorated back.
Oldies: 1972 Austin 1100 2dr - Project Rust bucket, 1974 MGB GT - A stereotypical classic car.
Moderns: 2008 Audi TT - Utterly boring but very compentent, 2010 Aldi A4 - Owned to placate the wife on my crap buying.
#489 OFFLINE   Tayne
Tayne
    Rank: Talbot Tagora
  • Full Members
  • 13,138 posts
  • 164 thanks
  • LocationThe Granite City of Aberdeen
Posted Yesterday, 08:42 PM
Gummifledge is a brilliant rubber conditioner which extends the life of door seals and helps prevent them freezing up.
It always amuses me that e46s vie with the PT Cruiser as the car that's too shit for Autoshite,
#490 OFFLINE   somewhatfoolish
somewhatfoolish
    Deputy Vice-Pomfrite of the Titicacan Legation
  • Full Members
  • 2,283 posts
  • 30 thanks
  • LocationArgyll&Buteshire
Posted Yesterday, 10:10 PM
Maybe try Sugru? Failing that perhaps blobbing sikaflex(other polyurethane adhesive/sealants are available) into the voids and smoothing off artistically with a finger.
Given the number of these you're doing it might be worth thinking about making a jig, then you can just wang it under a pillar drill and get the remains of the screws out quick smart.
Also tagged with one or more of these keywords: Project
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
