Richard Posted January 3, 2017 Share Posted January 3, 2017 is it possible to ungum them? Link to comment Share on other sites More sharing options...
Supernaut Posted January 3, 2017 Share Posted January 3, 2017 If you get an XUD with a Lucas pump, at least it's a running engine for now. You can then source a Bosch pump (and injectors) later and swap it. Lacquer Peel and The Moog 2 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 Don't DW8 engines get ring gumming on veg? Did I dream that? They shouldn't, the combustion chamber is similar to an X/TUD. I've just spoken to the seller on the phone, he seems alright but I can't collect it til next weekend. Longblackcoat 1 Link to comment Share on other sites More sharing options...
Supernaut Posted January 3, 2017 Share Posted January 3, 2017 Where is it? Be good to meet you, and lend a hand. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 It's in Perth. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 Xsara stalking DeeJay, DVee8, Richard and 4 others 7 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 Where is it? Be good to meet you, and lend a hand. You're welcome to point and laugh while me and Richard attempt an engine swap but it's not local for him or you. Link to comment Share on other sites More sharing options...
Supernaut Posted January 3, 2017 Share Posted January 3, 2017 Perth? Aye, not exactly local to me. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 Neither is Evanton if you want to point and laugh. Link to comment Share on other sites More sharing options...
forddeliveryboy Posted January 3, 2017 Share Posted January 3, 2017 Put that gorgeous* Xsara on the road and modify the broken Blingo into its trailer. Obvious, innit? That way you only carry a load of spare air around when you need to, like for the ten pallet trip. Xsara = many Autoshite points, nearly as many as homemade Blingo trailer. The Moog and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 http://www.ebay.co.uk/itm/TIMING-TOOTHED-COGGED-COG-SYNCHRONOUS-CAM-CHAIM-BELT-KIT-SET-WATER-PUMP-/381306361202 £45 cam belt and water pump kit, WCPGW? Also, I've seen a Bosch pump setup with everything but the injectors on eBay - will it work with the DW8 Bosch injectors or XUD9TE Lucas injectors? Link to comment Share on other sites More sharing options...
Supernaut Posted January 3, 2017 Share Posted January 3, 2017 It'll work with the Lucas XUD injectors. I did that for a bit before swapping to Bosch injectors. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
KruJoe Posted January 3, 2017 Share Posted January 3, 2017 Our Will might have some injectors. Bosch him a pm. (swidt?) Dave_Q, Cavcraft, Lacquer Peel and 1 other 4 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 I wonder if it's possible to put TD injector nozzles in the DW8 injector bodies. This cheap and easy engine swap is getting quite convoluted and expensive. Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted January 3, 2017 Share Posted January 3, 2017 I have a bosch pump, lines and injectors in my shed. Slightly juiced up as well. P.M me. loserone, The Moog and Lacquer Peel 3 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 SPEED MACHINE. Link to comment Share on other sites More sharing options...
Supernaut Posted January 3, 2017 Share Posted January 3, 2017 I wonder if it's possible to put TD injector nozzles in the DW8 injector bodies. This cheap and easy engine swap is getting quite convoluted and expensive. Why? I thought you were putting the entire XUD engine in? Why are you pissing about with any DW8 parts? Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 Why? I thought you were putting the entire XUD engine in? Why are you pissing about with any DW8 parts? To get the right injectors and nozzles for a Bosch pump. Link to comment Share on other sites More sharing options...
Cavcraft Posted January 3, 2017 Share Posted January 3, 2017 There was an MOT-less one owner Bosch FLAVA 306TD on Gumtree round here the other week. It looked alright but was hopelessly over-priced, had fancied it for the same reason as you LP, but it was just too expensive to bother. Could you shoehorn a 2.1TD in for shits and giggles? Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Richard Posted January 3, 2017 Share Posted January 3, 2017 No reason why not, but I think there's a bit more fannying about with driveshafts. It's hard to find a fully mechanical pump 2.1 as well, most of them are Lucas EPIC. Cavcraft and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted January 3, 2017 Share Posted January 3, 2017 They will run a bosch mechanical pump no problem. And lots of boost. Pretty sure you can put a 306 gearbag on as well. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
320touring Posted January 3, 2017 Share Posted January 3, 2017 They will run a bosch mechanical pump no problem. And lots of boost. Pretty sure you can put a 306 gearbag on as well.Now we're getting somewhere. 2.1td Bosch pumped lingo with ALLTEHBOOST FASTEST PALLETHAULER IN DA NORF Cavcraft 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 3, 2017 Author Share Posted January 3, 2017 I think even a standard 1.9TD will be nippy in a Berlingo. With a Bosch pump and tweaks, even more so. 320touring and Cavcraft 2 Link to comment Share on other sites More sharing options...
320touring Posted January 3, 2017 Share Posted January 3, 2017 I think even a standard 1.9TD will be nippy in a Berlingo. With a Bosch pump and tweaks, even more so.True true! Link to comment Share on other sites More sharing options...
Guest Hooli Posted January 3, 2017 Share Posted January 3, 2017 SPEED MACHINE. Fuck that for a lark, those things feel nearly as dangerous as C15 with a N/A dizzer Link to comment Share on other sites More sharing options...
Richard Posted January 3, 2017 Share Posted January 3, 2017 I believe Shetland hire Berlingos can get within 30k of the speed in that video. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Guest Hooli Posted January 3, 2017 Share Posted January 3, 2017 I believe Shetland hire Berlingos can get within 30k of the speed in that video. The NHS had one lingo with a turbo in Derby a few years ago, that could also get within 30k of that video's speed. Felt totally unsafe doing it mind. Link to comment Share on other sites More sharing options...
Dave_Q Posted January 3, 2017 Share Posted January 3, 2017 I can confirm that a HDi Berlingo can achieve 180km/h on a slightly downhill section of the A1(M) autobahn near Das Leeds. Allegedly. 320touring and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
bub2006 Posted January 3, 2017 Share Posted January 3, 2017 Fuck that for a lark, those things feel nearly as dangerous as C15 with a N/A dizzerC15 n/a feels totally* safe at all speeds and corners Link to comment Share on other sites More sharing options...
Lacquer Peel Posted January 4, 2017 Author Share Posted January 4, 2017 Fuck that for a lark, those things feel nearly as dangerous as C15 with a N/A dizzer I ragged mine (contribution to its downfall maybe) and it just felt like a slightly top heavy 306 to drive. Safe and secure. Link to comment Share on other sites More sharing options...
