320touring Posted March 2, 2017 Share Posted March 2, 2017 YAAAS! Good to hear progress on the boost chariot of choice:) Lacquer Peel and Richard 2 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 3, 2017 Author Share Posted March 3, 2017 Aye I fucked up. I've read about Bosch to Lucas swaps many times before and must have missed the bit about swapping the studs. Y u no fit Bosch to all XUDs? It's starting and running sweetly now and I'm pleased the cooling fans kicked in to stop it overheating at idle last night. There's still plenty to do but at least the engine is sorted now. One annoying thing is the light on the dash for the key and incessant beeping, I hope removing the bulb in the dash might kill it.Thanks to Richard for saving the day, I don't think I'd have worked it out on my own. KruJoe, loserone, Cavcraft and 3 others 6 Link to comment Share on other sites More sharing options...
320touring Posted March 3, 2017 Share Posted March 3, 2017 So it starts and runs now? MOT time, then mair booooost! Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 3, 2017 Author Share Posted March 3, 2017 Indeed it does. Replacing the wishbone bushes has made the front wheels a bit knock kneed, it's very unpleasant to drive even at low speeds around the yard. I guess the tracking was set with worn bushes, the track rod ends are fairly recent. It also needs tyres, the exhaust connected and various gubbins reconnected in the engine bay. Dishwasher tablet coolant flush as well - the contents dribbling out of the heater matrix when it was disconnected were disgusting. Cavcraft 1 Link to comment Share on other sites More sharing options...
Dave_Q Posted March 3, 2017 Share Posted March 3, 2017 RE the immobiliser light, will it not go off if you extract the chip from your old key and sellotape it somewhere near the ignition? Link to comment Share on other sites More sharing options...
320touring Posted March 3, 2017 Share Posted March 3, 2017 Fuck the light, get the BOOOST on! But seriously yes, hiding the chip near the ignition should fix it Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 3, 2017 Author Share Posted March 3, 2017 The chip is near the ignition, it's in the key. I guess it's whinging because the immobiliser isn't present.I wouldn't be so bothered if it was only a light but it's beeping constantly as well. chancer 1 Link to comment Share on other sites More sharing options...
Richard Posted March 3, 2017 Share Posted March 3, 2017 Is it possible to reconnect the immobilizer to give it something to find? Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 3, 2017 Share Posted March 3, 2017 Find beeps and add hammers? They_all_do_that_sir, Lacquer Peel and Richard 3 Link to comment Share on other sites More sharing options...
Richard Posted March 4, 2017 Share Posted March 4, 2017 Aye I fucked up. I've read about Bosch to Lucas swaps many times before and must have missed the bit about swapping the studs. I've a feeling the mentions of the studs, of which there are many, tend to occur in the "I've changed the pump and now it runs like shit" threads rather than the "how do I change the pump" threads that you would have been looking at. Dave_Q and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
Dave_Q Posted March 4, 2017 Share Posted March 4, 2017 Find beeps and add hammers?The beep is built into the clocks though (I think). You could whip them out and see if the beeper can be disabled/removed, may cause wobblers elsewhere though cos multiplex/bsi. Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 4, 2017 Share Posted March 4, 2017 Do the early vans have multiplex?I thought it was only the second generation? Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 4, 2017 Author Share Posted March 4, 2017 Aye I don't think this one is modern enough. It doesn't even have an ECU like later DW8s. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 5, 2017 Author Share Posted March 5, 2017 Now a brake pipe is burst, I can't see where it's coming from because it's all wet from driving through puddles. FFS! Seems to drive okay at least, seems nippy even without the intercooler and air intake plumbed in.The DW8 speedo connector plugs into the XUD sender but it doesn't seem to work. Double FFS. Link to comment Share on other sites More sharing options...
Guest Hooli Posted March 5, 2017 Share Posted March 5, 2017 all frogchod is shite etc Lacquer Peel 1 Link to comment Share on other sites More sharing options...
320touring Posted March 5, 2017 Share Posted March 5, 2017 Brakes only slow you down, and no speedo is a recognised* defence against speeding charges;) Lacquer Peel 1 Link to comment Share on other sites More sharing options...
SiC Posted March 5, 2017 Share Posted March 5, 2017 Reverse the polarity? Or swap the new sender with the old, if they're similar sizes? Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 5, 2017 Author Share Posted March 5, 2017 Swapping the sender might be the way forward but it's a pig to get at. Link to comment Share on other sites More sharing options...
Richard Posted March 5, 2017 Share Posted March 5, 2017 Did you ever drive the Xsara fast enough to see if the speedo worked on it? Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 5, 2017 Author Share Posted March 5, 2017 I did but I don't remember if the speedo worked or not. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted June 7, 2017 Author Share Posted June 7, 2017 Y0 gang. This is still a work in progress. It runs and drives but needs some finishing. I have lost the intercooler somewhere, and could use any rear brake parts that someone has kicking about (charity plea) also a cone air filter because the original airbox won't fit.Does anyone know how to disable the immobiliser beeper? I think it's somewhere around the fusebox. I set fire to a jump lead hot wiring the glow plugs to start it. Link to comment Share on other sites More sharing options...
320touring Posted June 7, 2017 Share Posted June 7, 2017 Tremendous:) #moarboost! Link to comment Share on other sites More sharing options...
Lacquer Peel Posted June 7, 2017 Author Share Posted June 7, 2017 Somewhere between perky and connecting rod/head gasket preserving boost would be good. 320touring 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted September 21, 2017 Author Share Posted September 21, 2017 Brakes fixed. The hose looked okay at first glance, but Hutchinson is PSA's OE supplier so it's likely 17 years old. Ughhhh. I took it for a spin on a private* back road, the bad tracking (due to my mis-fitting one of the wishbone 'P' bushes I think) makes it terrifying to steer but other than that it goes and stops very well, the 1.9 TD boosting and picking up nicely. That quick drive has spurred me on to get it on the road soon. It just needs a couple of small patches on the inner wings, the exhaust and air intake/filter hooked up properly, glow plug and stop solenoid wiring, and that bloody wishbone. Does anyone have some 'short head' PSA steel wheel bolts kicking about? It's running a mix of Xsara and Berlingo wheel bolts and it looks silly. I also want to KILL the ignition beeper, it's crying because the immobiliser no longer exists. Does anyone know how to kill it without tearing the dashboard apart? dollywobbler, Sigmund Fraud, Stanky and 3 others 6 Link to comment Share on other sites More sharing options...
Anthony Posted September 21, 2017 Share Posted September 21, 2017 Does anyone have some 'short head' PSA steel wheel bolts kicking about? It's running a mix of Xsara and Berlingo wheel bolts and it looks silly. Which type do you need - the earlier ones with the 19mm heads or the later ones with 17mm heads? And how many? I have a few kicking around I think, mostly earlier ones I think. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Talbot Posted September 21, 2017 Share Posted September 21, 2017 As far as the immobiliser is concerned, do you still have the immobiliser unit from the original DW8 engine installation? Best thing would be to plug it back in, but it be sat there doing nothing. There is a small ECU box for it somewhere, but I have no idea where on the pre-facelift Blingo. I think this may also be related to why you have no glowplugs on the key too. If the immobiliser is having a hissy fit, it will refuse to allow the plugs to run, or (if it were installed) allow fuel to flow. IIRC you could still crank the engine with the immobiliser activated, it just would not start. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Anthony Posted September 21, 2017 Share Posted September 21, 2017 IIRC you could still crank the engine with the immobiliser activated, it just would not start. Whilst I've no experience of the DW8 one, that's certainly the case with other 90's and early 00's PSA immobilisers. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted September 21, 2017 Author Share Posted September 21, 2017 The immobiliser unit is still present and plugged in but it's having none of it. The glow plug light on the dash glows dimly sometimes, I'm just going to fit a relay and switch for manual plugs. New window clip fitted, a fiddly job but made easier when you release tension by popping the wires off the pulleys. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted September 21, 2017 Author Share Posted September 21, 2017 Which type do you need - the earlier ones with the 19mm heads or the later ones with 17mm heads? And how many? I have a few kicking around I think, mostly earlier ones I think.The ones off the Xsara have a deeper head to retain hub caps, I'm only familiar with 90s era ones, a few off a 306 or similar would be fine. Link to comment Share on other sites More sharing options...
320touring Posted September 21, 2017 Share Posted September 21, 2017 YAAAS! good to see this back on the go:) Lacquer Peel 1 Link to comment Share on other sites More sharing options...
