Lacquer Peel Posted February 20, 2017 Author Share Posted February 20, 2017 There is a primer bulb and I have been using it but there are a few variables like the fuel screw not being at the standard setting and I don't know if the pump timing is right, but I believe it'll start as long as the timing isn't wildly out. Link to comment Share on other sites More sharing options...
Rusty_Rocket Posted February 20, 2017 Share Posted February 20, 2017 Best way imo is to put a clear, clean piece of pipe on the pump outlet.Suck on the pipe until diesel comes through. That way you know the pump, filter and lines are as full and air free as possible. Lacquer Peel and Arthur Foxhake 2 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 1, 2017 Author Share Posted March 1, 2017 Richard is up this way with work and we got it going again despite my best* efforts (slamming the bonnet down with the bonnet cable improperly routed) The cam and injection pump pulleys were off by one tooth each (my wrestling the belt on) and the stop solenoid plunger was stuck.It would not idle but adjusting the fuel screw as Arfur suggested got it to idle.It revs quite high at idle so I guess the pump is too far advanced.The timing belt sits slightly adrift of the injection pump pulley which is a bit worrying. Arthur Foxhake 1 Link to comment Share on other sites More sharing options...
Dave_Q Posted March 1, 2017 Share Posted March 1, 2017 ISTR on my last XUD the belt sat on the outer edge of the pulleys, never fell off though. Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 1, 2017 Author Share Posted March 1, 2017 It's off the outer edge of the IP pulley. anonymous user 1 Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 1, 2017 Share Posted March 1, 2017 I was just going to post in here to see how it was going. Have you tried the idle adjustment screw on the back? Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 1, 2017 Author Share Posted March 1, 2017 Not yet, which one's that? I adjusted the fuel screw until it'd idle okay, wind it out and it won't idle at all. it's very much a "fast idle" as if the timing is too far advanced. Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 1, 2017 Share Posted March 1, 2017 On the back left of the pump as you stand in front of it, there's a threaded rod resting against a lever. I forget if it's left or right but the idle should slow down one way or the other. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 1, 2017 Author Share Posted March 1, 2017 Phoned the local motor factor looking for a new stop solenoid - "never heard of one, bye". Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 1, 2017 Share Posted March 1, 2017 I have one here in a scrap pump.I'll go and extract it for you. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Richard Posted March 1, 2017 Share Posted March 1, 2017 The existing one might be ok. I think it was just stuck from lack of use and I felt that removing the plunger would eliminate that from the potential reasons for not starting. Tonight's job is to try and make both the stop solenoid and glow plugs work from the ignition. It does worry me that the belt runs off the edge of the pump pulley, is there a reason why that should happen. I can't see that anything is in the wrong place. Arthur Foxhake 1 Link to comment Share on other sites More sharing options...
bub2006 Posted March 1, 2017 Share Posted March 1, 2017 If I remember right, on the xantia belt around fuel pump ran close to the edge too. Richard 1 Link to comment Share on other sites More sharing options...
dave21478 Posted March 1, 2017 Share Posted March 1, 2017 Potentially dumb question, but do you have the bottom pulley for the aux belt on? This pushes the timing belt over and stops it working its way off. Richard and alf892 2 Link to comment Share on other sites More sharing options...
Guest Hooli Posted March 1, 2017 Share Posted March 1, 2017 Are all the pulleys alligned? No spacer missing for the new pump or owt? Tensioner bearing ok? I've seen tensioners run out of true on other cars & cause the belts to work off to the side. Richard 1 Link to comment Share on other sites More sharing options...
Richard Posted March 1, 2017 Share Posted March 1, 2017 I replaced the water pump and tensioner when the engine was out, the original Lucas pump was in place then. The belt runs exactly where it should on the cam pulley, it's just the pump pulley it's running a bit too far over on. The pulley and pump were bought separately, I'm wondering if the taper varies on them. I can't see how the pump could be fitted any differently. The crankshaft pulley is in place, the top cover is the only part that isn't in place at the moment. I'm struggling with the glow plug wiring. It's the van's original glow plug relay, which did work before the engine swap, connected to the van's own loom. There are five wires going to it but one of them must not be getting the signal it needs because the relay isn't energising. Does anybody know which wire is which and what's needed to make it work? Link to comment Share on other sites More sharing options...
Guest Hooli Posted March 1, 2017 Share Posted March 1, 2017 I was just thinking aloud, I don't know these engines in particular. Richard 1 Link to comment Share on other sites More sharing options...
320touring Posted March 1, 2017 Share Posted March 1, 2017 I was saying you should just wire the gloeplugs on a separate circuit that goes from battery to plugs via a relay - fit a 2nd hrw switch to the dash and wire it through that? Richard 1 Link to comment Share on other sites More sharing options...
Richard Posted March 1, 2017 Share Posted March 1, 2017 That's the back up plan, but it would be easier if it could be made to work the way it's meant to. Link to comment Share on other sites More sharing options...
Dave_Q Posted March 1, 2017 Share Posted March 1, 2017 Is the pump sprocket aligned with the cam sprocket as far as you can tell? I had one once where I put the pump spocket on in the wrong orientation, this forced the key into the taper and expanded it a bit. When I put it back on the right way it sat too far in - couldn't tell with the bolt in. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 2, 2017 Author Share Posted March 2, 2017 I don't understand how it's possible to put the pulley on the wrong way. Link to comment Share on other sites More sharing options...
Dave_Q Posted March 2, 2017 Share Posted March 2, 2017 I managed to put it on in the wrong rotational orientation while trying to change the pump with the sprocket pinned to the bracket. The sprocket is fairly soft metal, I put it in with the key not in the groove but it went in far enough to get the bolt in, then tightening the bolt pulled it on even though the key wasn't in the slot. Not saying that's what's happened to you but it is possible. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
jonathan_dyane Posted March 2, 2017 Share Posted March 2, 2017 +1 I've also managed to wrongly fit the pulley failing to properly engage the woodruff key which foxed me for some time. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 2, 2017 Author Share Posted March 2, 2017 That's probably what I've done, given my excess ineptitude. Link to comment Share on other sites More sharing options...
Dave_Q Posted March 2, 2017 Share Posted March 2, 2017 It's possibly worth a check. If it's off it would also mess up the pump timing, you did say you were having some problems getting it to idle? It should be possible to check without disturbing the cambelt, when I did mine the pulley was cracked slightly around the hub bit in the middle. If you take the bolt off but leave the pulley in place it might also be possible to see if the key is in the right place using mirrors or bendy eyes. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted March 2, 2017 Author Share Posted March 2, 2017 The pump timing is off because it's sitting as far advanced as it'll go but the pulley being wrongly assembled makes sense as well. Link to comment Share on other sites More sharing options...
conkerman Posted March 2, 2017 Share Posted March 2, 2017 Glow plugs. Does the DW8 use an ecu feed to the plugs. The 5th wire may be doing this. Bung a fuse inline and give it 12v. Sent from my Vodafone Smart ultra 6 using Tapatalk Richard 1 Link to comment Share on other sites More sharing options...
Richard Posted March 2, 2017 Share Posted March 2, 2017 I'm sure I've tried adding 12V to every pin, I'll try again tonight though. Link to comment Share on other sites More sharing options...
Arthur Foxhake Posted March 2, 2017 Share Posted March 2, 2017 I've just removed the stop solenoid. Shout if you want it. Found a new in the package p bush you can have as well. Updated aluminium design. Spare woodruff here also if needed. Richard and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
Richard Posted March 2, 2017 Share Posted March 2, 2017 Progress was made tonight. I noticed that the bolt at the back of the pump was at the opposite end of its slot from the studs at the sprocket end, meaning the pump couldn't be rotated for timing. We noticed that the DW8 had two sets of holes for the pump mounting studs, and it turned out that the XUD does too. With the studs moved to the other set of holes and the pump in Arthur F's suggested position it started and ran much better. It's made the belt run properly on the sprocket too, so it was a fruitful evening of tinkering. KruJoe, andy18s, Arthur Foxhake and 5 others 8 Link to comment Share on other sites More sharing options...
Guest Hooli Posted March 2, 2017 Share Posted March 2, 2017 Are all the pulleys alligned? No spacer missing for the new pump or owt? I was right in thinking the pump might be mismounted & putting the pulleys out of line then. Damn I'm good at this 'spot the daft mistake over the internet' game. Lacquer Peel and Richard 2 Link to comment Share on other sites More sharing options...
