toejam Posted September 26, 2016 Share Posted September 26, 2016 2 small jubilee clips can be joined make a bigger jubilee clip, but you know that already. jubilee clips are good for balancing propshafts too Uncle Jimmy, mercrocker and tooSavvy 3 Link to comment Share on other sites More sharing options...
toejam Posted September 26, 2016 Share Posted September 26, 2016 Lidls jubilee clips are crap. Buy the real deal.. Laseraligningfoofooflanges 1 Link to comment Share on other sites More sharing options...
Guest Hooli Posted September 26, 2016 Share Posted September 26, 2016 Ignore what the experts say, a four pot Sierra gearbox DOES fit a a V6 car. It just doesn't last very long as the input shaft doesn't reach the bearing in the flywheel. This was important knowledge when a type 9 was £50 a pop. Link to comment Share on other sites More sharing options...
tooSavvy Posted September 26, 2016 Share Posted September 26, 2016 You *need a 'concentric slave' in YourLife TS Link to comment Share on other sites More sharing options...
twosmoke300 Posted September 27, 2016 Share Posted September 27, 2016 No one needs a bloody concentric slave !One of the most useless inventions in automotive history . Take a 20 quid part that takes 1/2 hr to fit and easy to bleed and replace it with one that's 50 sheets plus , needs the gear box out to replace and is a twat to bleed ( single pipe versions ) And for what ? A better clutch feel ? My arse . Try the clutch on a 90s Honda . Light as a feather and lovely to use - through good engineering and quality components not useless disposable plastic crap . Grrr tooSavvy, overrun, sheffcortinacentre and 9 others 12 Link to comment Share on other sites More sharing options...
twosmoke300 Posted September 27, 2016 Share Posted September 27, 2016 Guess who has done a Renault trafic clutch this week ? Craig the Princess, scaryoldcortina and scdan4 3 Link to comment Share on other sites More sharing options...
rainagain Posted September 27, 2016 Share Posted September 27, 2016 When changing the front discs on a FWD car, once the disc is fitted start the engine with the gearbox in neutral, there should be enough drag in the components to cause the disc to rotate slowly. This makes checking for run out easy, just watch out though as the fact that one wheel is rotating but the others are stopped can bring on the ABS fault light. In some cars this might not auto reset the first time you drive it properly. Or just sellotape a pencil to the top of an axle stand, position the end of the pencil against the disc and manually turn the disc. Link to comment Share on other sites More sharing options...
twosmoke300 Posted September 27, 2016 Share Posted September 27, 2016 A disc would need to be pretty bad to see it like that . Max allowable run out on a Honda is 0.2mm iirc Link to comment Share on other sites More sharing options...
5speedracer Posted September 27, 2016 Share Posted September 27, 2016 If a job looks complicated and requires skill and knowledge beyond those you possess harp on about it to those you know have them.Hopefully their vanity or bravado means they'll do the job for you to illustrate how thick you really are Sent from my X17 using Tapatalk Slartibartfast, Banger Kenny, Rocket88 and 4 others 7 Link to comment Share on other sites More sharing options...
Richard Posted September 27, 2016 Share Posted September 27, 2016 If a brake disc isn't keen to come off the hub you can help it along by screwing bolts through the back of the caliper mounting holes. Not too hard or you can snap them off, but a little pressure will make the next clout with the hammer much more effective. Banger Kenny and rainagain 2 Link to comment Share on other sites More sharing options...
rainagain Posted September 27, 2016 Share Posted September 27, 2016 A disc would need to be pretty bad to see it like that . Max allowable run out on a Honda is 0.2mm iircThe pencil method works quite well, the 'high point' wears away the lead so you can see the gap quite easily as you rotate the disc. I find shining a torch down makes it even more obvious Tamworthbay 1 Link to comment Share on other sites More sharing options...
PhillipM Posted September 27, 2016 Share Posted September 27, 2016 A disc would need to be pretty bad to see it like that . Max allowable run out on a Honda is 0.2mm iircMax on mine is 0.05mm - good look seeing that! Link to comment Share on other sites More sharing options...
NorfolkNWeigh Posted September 27, 2016 Share Posted September 27, 2016 No one needs a bloody concentric slave !One of the most useless inventions in automotive history . Take a 20 quid part that takes 1/2 hr to fit and easy to bleed and replace it with one that's 50 sheets plus , needs the gear box out to replace and is a twat to bleed ( single pipe versions ) And for what ? A better clutch feel ? My arse . Try the clutch on a 90s Honda . Light as a feather and lovely to use - through good engineering and quality components not useless disposable plastic crap . Grrr+++1200Guess who has had 2 fail in a Gaylander 2 in the last 3 years ? Link to comment Share on other sites More sharing options...
Kiltox Posted September 27, 2016 Share Posted September 27, 2016 Carry a fucking jump pack and basic tool kit in your fucking car More a note to self than a tip worldofceri, mercrocker, robinmasters and 2 others 5 Link to comment Share on other sites More sharing options...
RustyNuts Posted September 27, 2016 Author Share Posted September 27, 2016 If a brake disc isn't keen to come off the hub you can help it along by screwing bolts through the back of the caliper mounting holes. Not too hard or you can snap them off, but a little pressure will make the next clout with the hammer much more effective. On that note if you have two small bolts going through the disk to hold it onto the hub, they'll almost certainly be seized and you won't undo them with a normal allen key or star bolt bit. Instead you need a impact screwdriver - you insert into the bolt, twist in the direction of undoing and then whack with a hammer repeatedly if needed. It has a special mechanism that will applythe hammer force in the unscrew direction to undo the bolt. Without this, you'll almost certainly round out the head of the bolt. tooSavvy 1 Link to comment Share on other sites More sharing options...
Station Posted September 27, 2016 Share Posted September 27, 2016 If a nut or bolt looks rusty and rounded off, just fucking cut it off with an angle grinder. just cut the fucking thing off ffs. sierraman, Banger Kenny, robinmasters and 2 others 5 Link to comment Share on other sites More sharing options...
sierraman Posted September 27, 2016 Share Posted September 27, 2016 Then discover it goes into a blind casting... tooSavvy, gadgetgricey, beko1987 and 1 other 4 Link to comment Share on other sites More sharing options...
mat_the_cat Posted September 27, 2016 Share Posted September 27, 2016 If you're struggling to do up a track-rod end or other balljoint without it spinning, put a little grit/ dirt in the taper and push it in to position while doing up the nylock.The dirt can be just enough to jam the taper so you can do the nut up Or use a normal nut to seat the taper, then replace with the nylock. Uncle Jimmy and themildbunch 2 Link to comment Share on other sites More sharing options...
wuvvum Posted September 27, 2016 Share Posted September 27, 2016 After all the fun I had last week, my top tip would be: Just pay a fucking garage to do it. Jazoli, Eddie Honda, Vince70 and 10 others 13 Link to comment Share on other sites More sharing options...
toejam Posted September 27, 2016 Share Posted September 27, 2016 For condensation (water )in a petrol tank , just add some meths . It mixes with both petrol and water . Fuck knows if it works , i only read it somewhere Link to comment Share on other sites More sharing options...
twosmoke300 Posted September 27, 2016 Share Posted September 27, 2016 The old school enduroboys used to put meths in the tank for wet races for the same reason Link to comment Share on other sites More sharing options...
For Fiats Sake Posted September 27, 2016 Share Posted September 27, 2016 Don't buy this car: Rusty_Rocket 1 Link to comment Share on other sites More sharing options...
matty879 Posted September 27, 2016 Share Posted September 27, 2016 if you need to angle tighten a head down without an angle gauge,use a tippex pen at 12 oclock on each bolt head,makes it easier to work out how far youve turned it fordperv 1 Link to comment Share on other sites More sharing options...
wuvvum Posted September 27, 2016 Share Posted September 27, 2016 Mrs Blunders vid - Renners 6 and 16 together at 0:34. Link to comment Share on other sites More sharing options...
twosmoke300 Posted September 28, 2016 Share Posted September 28, 2016 if you need to angle tighten a head down without an angle gauge,use a tippex pen at 12 oclock on each bolt head,makes it easier to work out how far youve turned itAnd each flat is 60deg dome 1 Link to comment Share on other sites More sharing options...
Tamworthbay Posted September 28, 2016 Share Posted September 28, 2016 For condensation (water )in a petrol tank , just add some meths . It mixes with both petrol and water . Fuck knows if it works , i only read it somewhere It does work, I have done it one motorbikes in the past but can make them run a bit lumpy. I don't know how it would affect a catalytic converter but maths burns pretty clean. Link to comment Share on other sites More sharing options...
PhillipM Posted September 28, 2016 Share Posted September 28, 2016 Poisons cats, if you want the same effect but without it running rough use Isopropol Alcohol instead (rubbing alcohol), you can get it from most cleaning suppliers or paint mixers. Link to comment Share on other sites More sharing options...
fordperv Posted September 28, 2016 Share Posted September 28, 2016 if you need to angle tighten a head down without an angle gauge,use a tippex pen at 12 oclock on each bolt head,makes it easier to work out how far youve turned iti always put a dot at 12 and a dot at 3 Link to comment Share on other sites More sharing options...
matty879 Posted September 28, 2016 Share Posted September 28, 2016 i always put a dot at 12 and a dot at 3i just put the other dot on the head where it needs to be ie at 180 270 90 etc and turn till they meet Link to comment Share on other sites More sharing options...
inconsistant Posted September 28, 2016 Share Posted September 28, 2016 If you're doing any sort of mechanical work on your car your hands are probably going to be dirtier than your winky so my tip is to wash your hands before having a pee rather than after. worldofceri and robinmasters 2 Link to comment Share on other sites More sharing options...
